View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Does your sunroof do this?
- need help fast!!!
- 89 CRX Throttle problem
- little bit of help or link
- Distributor Question.
- Questions on building a 600whp daily driver
- EF turn signal alternating mod - HELP
- Cut rear bumper for muffler
- Headers ?
- Fluctuation in idle on cold starts
- D16A6 block with a Y7 head my timing belt doesn't fit????
- DOHC ZC pg7 ecu help
- B16 Wiring help
- The best SOHC D series head
- need a quick recomendation
- OBD1 B20 Swap in EF Sedan, CPS, CYP, CKP, Code 9, Need some Help
- searched and searched help guys
- What aem cai intake??
- Teg Center console option for 90-91 Sedans
- 88 crx help plz
- cracks in dash
- installing speedo cable?
- Doing RHD on my crx....
- CRX front bumper and hood
- wtt eg/dc traction bar for ef traction bar
- are this ebay M-Gen Chip work?
- radiator question
- will this rear disk conversion fit my 88 crx si?
- tokico shocks.....
- Intake Manifold
- STOLEN: 91 Honda CRX Hf
- Flame if ya want-VTEC DPFI???
- Failed Smog (GROSS POLUTER)
- Quick pick. lemme know wut yuh think.
- New clutch.. Should the arm have this much Play?!?!
- New Here
- Cable to Hydro Actuator
- skunk2 short shifter question
- VTEC PROBLEMS ON LS/VTEC...HELP PLEASE.
- Help. Ls swap into ef sedan
- Inerior
- Injector problems?
- RT4WD Drive Train Swap
- Car won't start after oil & trans fluid change?
- parts wanted
- OBD 0 Vaccume hose Diagram.. In need oF
- seat swap
- 88 CRX SI INTEGRA B18 GSR HEAD LS BOTTOM SPUTTERING HAVE CHANGED:DISTRIBUTOR,ROTOR,PLUGS/WIRES,FUEL
- i need some help with my braking problem
- piston hit the spark plug???
- sticky ignition?
- Turn Signals
- Oil in spark plug
- NEED INFORMATION
- little frankenstein help...
- no power to starter
- 91 Civic DX Shift interlock help
- Crankshaft Seal??
- b16 ebay header
- Motor mount swap
- 89 civic si - turn signal issues
- EF sedan with B18B1 won't start! HELP!
- d15b7 dizzy on a d16a6
- my battery relocation method
- sorry to rywire you are the best
- CRX Won't Idle When Cold in Cold Weather...
- I need dew window washers.
- Interesting project...
- DOHC ZC idle help!
- New to the honda game.
- Dash swap. help plz
- flywheel cover installation
- 91 CRX. Seatbelt won't extend... what to do
- Overheating Problem, Turning Clicks, Grinding Clutch= $500 :[
- mini me setup
- Engine Dress Up
- will B18 valve cover fit a B16?
- Anyone Using Evolution or QSD H2B on CRX/EF?
- no power
- engine problems please help?
- dpfi to mpfi obd0 to obd1 help?
- name these plugs and where they go!!!!!!!!!!
- B16 a1 swap vaccume hoses placement??
- New swap
- inferiority complex, how big is your H emblem? pic
- new guy, need help
- Horrible clunking noises over bumps, axles?
- fuel dilivery problem
- NEED HELP! I ran into a concrete pilon thing. Need advice
- EG/EK duckbill on ef?:
- wtb tranny
- alternator belt question
- 90 civic si hb ecu code 1
- z6 dizzy on y8 head
- ride height different on one side
- DOHC ZC please help
- Just got a Sedan & need some help.
- crx cluster in a STD 91 civic
- Popping Fuses
- wheres the H23?
- 1991 civic dx 4 door build up
- NOOB WITH A 89 SEDAN
- Looking for complete tail light set for an 1988 CRX si
- Bad resistor box?
- Gen2 CRX with K20 bonnet help
- rads? and Rear hatch?
- ef civic and crx
- I Ran over a FOX!!!! What is this that I bent???? Radiator Support Or......????
- usdm front end lip?
- Are there any bolts I shouldn't put Locktite on?
- Rear defroster not working
- Bad Distributor- repair or replace?
- timing, Cam Locks
- home made tow hooks
- manual fan switch help??
- Hi evryone !
- intake question
- Hasport mounts, changing the rubber inserts
- crx fuse box. What is this wire?
- wire diagram for obd conversion harness ?(i have the harness)
- 2 Door swap
- front camber kit
- OBD0-OBD1 Wiring diagram
- Turn Signal not working
- my b16 tranny grinds in high rpm,s but in low the shifting is fine need advice!!!!
- hi guys im new!
- what parts do i need to make a RWD civic???
- EF night pics
- NOOB Tryin to learn
- D16a6
- another ef from san jose!
- ef pics
- Running Lights not working at all
- crx rear disc conversion(trailing arm bushings)
- junk yard tranny how can i tell what i got by just the the internal
- Outer tie rod end
- Need help badly
- need help tried everything d16z6 starts runs like crap dies and code 14 *SEARCHED
- Day Time Running Lights
- Crx B16a valve cover ground????????????????????????????
- Did I mess up?! N/m
- steering problem
- Anyone put hid bulbs in jdm fog lights?
- crx lsvtec sputter
- 88 b18a hatch switch to b18c1?
- Gauge cluster lights not working
- Is it necessary...
- Intermitent Engine Shut off
- help crx wont start.only thing that works is hazard lights
- tdc and cps????
- ground wire ?
- Need help with a stalling CRX.......its driving me crazy
- CRX As First Car?
- whats the fastest way to get the gasket off the head
- Extremely high idle!
- crx idle problem dpfi need suggestion
- Harness Question..
- dunno wut my fuses are, any1 got a pic?
- Cutting out badd!!!
- excuse the noob question!
- Where to get CRX logo floor mats?
- do you lose the EGR valve on skunk2 intake b18a1 ?
- anyone here from san jose?
- jdm front ef9 f.s
- Ran out of adjustment on my clutch cable
- What rear suspension can a CRX have?
- Noob with a 89 Civic Hatch DX
- need some rt4wd wagon help
- Turn Signal Problem on 88 Hatch
- Crankshaft pulley
- D16z6 distributor work on ls vtec?
- Sun roof relay Crx Si
- EF hatch on ebay with DA front
- crx brake guru need some help
- Electrical nightmare help
- Clicking noise under steering colum in Automatic Crx
- vss ?
- gsr swap, burning oil but no smoke.
- thermosensor..what do they do
- My h22'd ef question.
- Purchased a CRX shell with wiring issues...... look inside
- Lifting a crx
- Code 116???
- Auto to manual swap
- ef and crx fuel pump cradle different?
- need help
- orange wire paired with black/yellow wire, fuse #14
- HELP! 91 civic hatchback si B SERIES SWAP QUESTION
- crx won't start
- 96-98 EK Fog lights on 88 CRX Bumper????????? Is this true??????
- engine sputter during accel
- Hey guys new to the forum kinda, just got my first EF!
- speedo cable broke, dragging on ground
- fast question
- right turn signal doesnt flash! :(
- I need help with my Swap !!
- do sedan or hatch seats fit crx
- Integra rear seats in ef hatch
- can a walbro 255 fuel pump be used as daily driver?
- distributer leak COVER
- Need a little help, please.
- Need some help!!!
- is it possible to????
- More Problems
- zc swapped crx won't start
- wagon
- whats the best way to fix this? F#!K rust!
- b16a swap wiring help
- How do I remove the tail lights?
- TPS QUESTION
- New Axles, Acceleration Vibration
- Vids and pics of the other day, burning off donuts...
- Steering rack help? rattleing and wheel play, scary...and more ideas on broken v-tec
- How leakage out the water pump weep holes is OK
- Possible project?? 4wd Ef HB
- coil over o rings??
- HOW many of you have had to replace your STEERING RACKS???
- 90-91 CRX door FAQ question
- Dumbass friend... new steering column?
- i need help on harness on my ef ppl help me out plz
- SOHC Cable Transmission Codes...
- DOHC ZC oil pan
- gsr turbo???
- HELP>>>JDM crx head lights? what kind of bulb is it. i want hids and no auto store carries
- BROKE my clutch pedal has this hapenned to anyone?
- 1991 civic dx starting problems
- Best thing to do with a d15b
- crx b16 won't even crank
- Tein HA 16-way adjustable coilovers for EK9 into CRX?
- 1988 Civic Tach Problem
- CYP - cylinder sensor
- car overheated, rad fluid leaking
- JDM climate control in my USDM crx?
- H4 Hi/Lo HIDs
- Manual Transmission Output Shaft Seals
- Type R gauge swap help
- My ee wagon...
- JDM S1 transmission 5K RPM at 80MPH
- taking off window trim piece
- stupid guess lol
- D16y7 mods
- no vtec???
- help took out ignition switch new one wont go in
- how do i post pics up
- Brake problems 1990 Civic Ex Automatic
- Sorry Newbie first post - Will 185/75R14's fit a 1990 civic hatch?
- starter question
- ok i need some oppinions
- Rims fit a 91 hatch?
