View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Who's Interested in a 2-1/2" Cat Back Exhaust System?
- b16 swap into 91 civic hatch, problem :(
- Anyone using "SRR Lower Control Arms" on there car?
- ?'s about a b16a
- whats the best cable tranny.. si, ls, or gsr?
- rear brake conversion???
- what is this thing (button switch conected to clutch pedal.89 crx hf
- body kit or turbo??
- 88 hf brake problems
- color
- service manual for tranny rebuild?
- best way to shave bumper trim on doors ??
- car is useing alot of gas
- Need help with this sensor.
- USDM/JDM Si Hatchback Differences?
- HF or Si, what's it look like?
- Crane SOHC VTEC Cam? Where to buy?
- very quick tranny question
- what dose DOCH mean?
- resetting ur ecu...does what?
- supra pistons and b-16 rods looking for info on them
- When did production start on 89 crx sir's?
- fan switch on y7,going into a crx
- B16 Swap Can I leave the Front Mount
- good shock/spring setup for EF??
- color codes for wires on stereo?
- need color codes for stereo wires before clip
- $1100 for a used d16 ex motor? haha
- Hi All
- How to wire a CRV in a crx?
- i know its been asked a million times but. . . . .
- best b series mounts???
- Look what i bought for my CRX :)
- HF is a gas guzzler
- what lip for EF8 front
- pr3 code
- head gasket?!?!
- Does anyone know
- 3rd gen question
- crx head swap question
- JDM Front End Installation help needed
- Sidemarker wiring diagram
- i just got in accident with my car..pics.. 56k beware
- Which year modle is this for. 88-89 or 90-91 please help
- DX and Si distributors interchangeable?
- Looking to buy an EF 4 door. Got some questions.
- setting valves with adj. cam gear
- 1991 Honda Civiv HB STD
- 89 D-series May Find Home in 87 Civic Sedan (...if he gets the right HELP)
- won't start, no spark, diagnosis help please?
- whats this??
- Knock, knock, knock under the hood...
- SOHC PRY Racing Camshaft, anyone know much about them?
- after market fuel rail??????????
- MOTORS IN CALIFORNIA
- 17's on a civic?
- does anyone have a swap guide book or cd ?
- sold 88 HF, bought 90 Wagon...
- HCP shift linkage help needed...really notchy.
- Fuel gauge stuck on full!?!?
- wiring diagrams
- Redneck Junkyard.... 1 Dead MINT Civic hatch.
- 94 dx hatch for 3000...good price?
- plastic bag melted on header, what to do......help!!!
- g2 integra front on ef hatch?
- crx cat back
- just picked up an '89 hatch for a beater... what trim model is this?
- glasspacks?
- d16y8?
- **Sus. Tech with aftermarket exhaust!! ahhh driving me crazy...HELP! **
- studder-step
- PL3/9000 what tranny is that???
- b16 ef oil leak
- Window problem (chewed up mounts)
- the Race Kar finally got on track for the first time the other weekend (pics)
- Oil on spark plug threads.
- Fuel Cut only at 6800 rpm!?!
- quick o2 sensor question
- Tranny probs and quest..
- 90 civic dx and si
- Water pump???
- Motor swap
- Needs Ring Job No Compression
- 91 CRX Si D16 to B17swap - Should I do it.....
- Cat Issues
- Will '90 Civic DX hB front calipers bolt right up to my '88 CRX HF lines?
- Buddyclub spec 2 Exhaust
- will 1994 EG reak disks fit '90-'91 EF???
- missing?
- Failed smog.. High on NOX
- replacing fuel filter on DOHC ZC (i already searched).. help needed!
- LS/Vtec ECU Question?
- any other ideas for fixing irratic idle???
- cable b16 clutch
- b16 failed emissions (TX)
- feul pump not turning on
- VAFC /PR3 question
- How to tell what year my ZC Tranny is?
- Question on swap
- ls swap in 89 Si what tranny?
- pr3 chips
- CEL
- new to honda tech
- ZC Tranny Hops back and forth HELP!!
- Dilemma over EF3
- hey
- Larger TB rotor?
- mini me no vtec.....what will it feel like
- Motormounts for a 1984 CRX (ZC)
- how much added horsepower
- dx to b16a wiring problem
- Pros and cons of Skunk2 SS
- Can i use an 90 Integra compressor on my b16a CRX???
- Short Shifters
- vtec head
- code 8 owns me
- transmission..HELP
- crx si rear sway onto std civic - worth it? will 89-91 endlinks work with 88 lca's?
- 88-89 civic dx rear bumper vs 88-89 civic si rear bumper differences or not....
- Update on crx modifier
- TPS Sensor
- obd0 to obd1 DIY questions
- price break in nitrous with 5 orders
- Si cam..do I need Si timing belt too?
- cleaning cv joint... anybody?
- 89' Mugen Crx body kit, what yr bumper lights?
- Pulling a Gas Tank
- high flow cat
- WILL CENTER TAIL LIGHT FIT?
- I NEED a swap d16a6 swap done in Long Beach/OC next week!!???
- JDM D15B into 1987 CRX Si?
- whats a code 4 ?
- How to make seat brackets for EF or any car?
- a/f wiring (3 quick questions)
- Any Companies that make a hydro d-series mount kit for ef's?
- Comparison: Eibach Sportline Vs. H&R Sport-Looking for Pictures-
- just picked up a 89' DX hb, good idea?
- I need some help 2 topics
- suspension that works for under 400 bucks
- Turbo boost control question
- rear fender lip liner removal - prevent rust?
- forum rules updated
- Wagovertamino
- posible fuel problem
- 89 CRX starting problem
- 4gen coupe
- places or person that sells conversion harness OBD0 to OBD1
- just want to know
- funny idle?
- tach doesnt work??
- Crx d15b + powersteering??
- STarter problems! HELP PLEASE!!!!!
- will 90-93 integra seats fit in my 88 hatch?
- Shiftlinkage advice.....
- Transmission shops in (909) area?
- If u had......
- Good sport springs to go with tokico luminos for an EF
- Whats my car worth? Dohc zc rex
- D-series Compression Calculator?
- exhaust problem: help needed...
- Installed new plugs/wires and now have white smoke!
- ZC guys need your help
- Any with hf motors put in a Si/Dx trans?
- Pros and cons: EF over EG?
- SOHC ZC in my R-x
- rims and tires ?
- Reading spark plugs
- what head lights for my 91 hatch
- how to get fiberglas bondo off panels?????????
- what does it take to stop being a trial member????
- Clutch masters Fly
- urgent help! (just like everybody else...)
- manual transmission fluid question
- When will I?????????????
- cel w/no code......engine falls on its face. please help!!!!!
- car wont start =( , help me please....
- please help, Alternator problems
- Where to find a JDM CRX front lip
- Spoon vtec controller for pr3 obd 0 ecu
- 500rpm Idle
- MPFI & 5-speed tran or D16 upgrade?
- Is this the right valve cover gasket for D16A6?
- prize check on b16A bottom end
- getting rid of streaks on window
- Finished my comptech ice box install on crx. pics included.
- B16A1 Sir-1
- 89 civic 4dr lx won't start
- can't go past 7........
- help zc crx broke down
- crank pully nut help please
- USDM Ecu
- out of ideas...getting pissed off
- PM6 rev number
- For those of you who did the Sedan handle swap...
- Symptoms of a bad PP?
- 92 DX swap into 91 HF CRX
- anyone have pic of car with hood locks?
- Tein HA's
- B16a, Pr3,Obdo pass emissions?
- HF slotted rotor's?
- rocker panel help
- need a running d15b2 in tx area (again)
- 1987 Si- How do I get the CEL code and pic request of CEL code chart...
- CRX corner lights
- UPDATE! CAR FOUND! (Lots of pics)
- 90-91 Teg throttle cable pt # 17910-sk7-a03 for my EF swap...
- Del Sol Dash
- Smog
- B18A motor swap DONE! shitload of pics (56K users grab a snack)...
- selling 88-91 CRX parts
- Nice clean front lip for the EF...
- Valve Stem Seals
- water pump help please
- Is there an aftermarket shift linkage boot? Also would my pin idea work...
- Need Help
- does anyone know the diameter of the stock intake tube???
- Chipped p30
- What to do??
- O2 sensor and a/c expansion valve question...s?
- whos done a y8 intake manifold swap?
- Mini-me
- Vtec oil pressure sensor has 2 wires on it, everything I read says one?
- b16 crx O2 sesors
- What is the MB products website? I need a hood.
- Neutral sensor
- Anyones car idle high after performance driving a.k.a. tearin' it up???
- Car bogging down from dead stops.....
- Interesting discovery/benefit when I installed a Y8 manifold on my A6
- turbo rebuild
- 88-91 w/ B18b
- Anyone got H22 CRX timeslips to post?
- Fiberglass sunroof plug for CRX Si by MB products has been purchased and installed!!
- b16 to crx hf problems w/ vacume lines!!! pics inside
- B16a1 CRX 1/4 time
- b16a- GSR CAMS GOOD FOR SOON TO BE TURBO?
- HEADER QUESTION
- Smoking steering column, not holding idle, won't start etc... what's wrong?
- I searched.... Code 20. I have no ELD.
- ECU PROBLEM???
- 87 gas in b16 crx
- EF9 JDM airbox
- Reusing Head Gasket and Head Bolts
- changing eacv?
- blown Motor
- spark plugs
- dizzy wiring for dohc zc from si
- best turbo manifold for crx?
- SOHC ZC TPS
- extending my engine harness to the firewall???
- Stupid question maybe , what is a steering knuckle ?
