View Full Version : Honda CRX / EF Civic (1988 - 1991)
- how does the hole lineup in front lower mount
- LSV EF Code 7
- 90 si question problem.
- Fuel Pump Issue
- 91 Civic dying while running(oil in plugs). HELP please!
- No start after driving
- ordered uca from rock auto
- Need help starting my 91 Ef hatch
- Idling problems. Please help!!
- obd0 mpfi to obd1 vtec
- 1.6 head on d15b2
- Hf front sway bar bushing
- 91 civic ef sedan won't start need help
- My Girls 1989 honda civic si w/DOHC B16 with A/C.
- obd0 to obd1
- NEED HELP!! HAVE A SHORT N NEED SCHEMATIC FOR 91 CIVIC
- 89 Civic Si Build
- I can't drive 55
- What Size Rims/Offset?
- ef civic problem code 7
- uca from rock auto?
- Harmonic Balancer (Crank Pulley) - 22mm
- zc transmission
- confused with d15b7 swap into hatch
- Tail Lights and Gauge Cluster Won't Light Up
- 91 sedan rear disk question
- Front brake rotors
- 89 CRX Si replacement engine options
- 91 STD civic jumping idle
- Where is the ground for the rear license plate light
- 1991 hatch build
- c210 connector
- Sanden VS Matsushita A/C compressor
- CEL Code 3 (MAP Sensor) & Brake Leak
- 1991 hatch build
- running without a map sensor?
- PWDJDM civic hatch jdm rear bumper support work on usdm crx?
- upperball joint really stuck!
- B18 swap, innovative axles, what half shaft??
- CRX Build advice
- Need smog help please
- EG to EF coilover mod
- Wa-Honda-ED6's 1990 Civic slow, budget build
- No heat, temp gauge shows cold if cool outside
- What are some key suspension components for better handling while low?
- Manual folding mirror swap EF sedan
- Need input on d15b
- Need help please!! Honda Crx no start
- What size bolts do I need for the t bracket on a 94 integra transmission?
- 1990 civic cx ricer project
- Civic PGM-carb fuel mix lean
- 90 crx with a 95 gsr swap??
- D15B2 engine idle problem
- fiberglass CRX doors
- I NEED HELP SO BAD !!!
- Adding a trailer hitch on 1990 honda crx think i need a rear bumper reinforcement
- Cable transmission/clutch issue
- Battery relocation
- 91 STD "Panda Hatch" daily build
- 89 crx turbo lsvtec overheating issue
- 89 hf s2k cluster problems help
- Mk2 bushings
- EF Civic Frame Damage Question PLEASE HELP
- 91 SI Ebay parts Guinea pig
- tail light harness pics please!
- Whited's Second Build
- Si vs DX underhood fusebox?
- what size garrett turbo is best for....
- Suspension Solution
- Need Advice for a 400HP B16 Turbo CRX
- Part name
- b16a2 engine issue in 91 crx
- 1989 honda crx wont start
- Engine swap for 1991 Si. Deal or no deal?
- D16y8 swap in 90 DX?
- 90 EF Si with b18b1 help
- my 89 sedan.
- need help on dx automatic transmission
- 205/65/15 on CRX lowered?
- Stop tech steel braided brake lines any good?
- 1988 CRX
- having rev problems. Need help!!!!!
- Honda CRX Video
- Newbie Q's I need a new engine for my RT wagon
- Need input - cylinder head full of coolant but head gasket appears fine (pics)
- 91 EF ECU pin guide??
- 91 CRX w/ B16A2 Swap, stalling out after sitting for ~5 years.
- What Transmission bracket to use?
- 1989 CRX Battery light on. no start.
- b18a1 smoking issue
- organize wiring help
- Amplifier help needed!
- Ef brake booster
- drag racing crx
- OBD0/OBD1 check engine light: code 16 fuel inection circuit
- 89 HF Daily Driver Project **Image Alert**
- question for ignition setup -
- D16A6 Rebuild
- 91 Si wheel paint color code
- USDM mirrors on JDM Power Folding Mirrors for CRX
- how to change coolant temperature gauge
- Civic ef general help please :)
- 1989 crx si LSV swap help!!!
- Motor mounts
- CRX Swap
- 2nd gen CRX with F series or B series?
- what do yall use to clean up floorboards
- another timing belt thread
- Belly plate damage
- Rack end bushing?
- D16a6 into 91 civic lx
- Painting problems again...
- D14 and D15 dualcarb ECU the same?
- OBD-0 to OBD-1 conversion
- EFI Conversion suggestions and opinions.
- Crank, no start (only sometimes)
- Battery issues Plz Help
- help with low rpm at idle when warm
- lost on how to remove inner tie rod
- D15 swap :( help me please :)
- 1990 Honda Civic revving hard and burning smell
- 1,100 rpm idle....
- AutoPower 4pt with Interior??
- B16 Single wire o2 sensor
- How to keep that darn window straight?
- has anyone tried b2d adapter?
- EF Civic Seats?
- Caster Issue
- failed hotwire xpost from tech
- Honda spirit headlight covers - anyone heard of them?
- Loud whine, No start.
- 91 Sedan Heater problems
- A/C belt got shredded and torn after only having it on a few months ?
- cant remove roll pin
- Ocasional CEL, no codes, runs like a dream
- Air Conditioning
- crx seats
- radio speaker, weird noise
- whats this hose do?
- Side Skirts on EF Sedan?
- idk whats wrong
- CRX rubber seals.
- RM Cams on D16A9
- Dpfi to Mpfi harness question
- Track/Street ED6 Build
- b20 swap on a 1991 dx
- 89 Civic Swap sat for 5 years boggs down wont rev past 2500k
- My ed6 daily trackbitch project
- D16A6 gutless - wont rev past 4k rpm under load
- 89 si fuel pump mystery
- 91 civic rt4wd
- Sort of overheating
- 88 CRX cluster problems....which route?
- CRX and driving in the snow?
- 91 si radio issue
- ef rhd steering rack
- when you pull hazard fuse, then check eng light & code is gone, is the problem gone?
- oil in 3rd spark plug only.
- Have to wait 15 min. to start after turning car off!?
- Thule bike rack fit kits
- injectors for turbo
- How to install ac? (91 ef sedan dx)
- My 91 si
- Dc console in sedan with electric seatbelts
- Huge hesistation below 30% throttle and need help checking codes
- 1991 HONDA CRX SI ZC SOHC BLOCK
- Grounds and wires?
- DOHC ZC; power steering pump and bracket
- Wtb honda civic 1989 si driver front seat belt or fix the retractor
- 91 ef which head to use
- WTB: 90-91 EF HATCH SI SO-CAL AREA
- Weird Electrical problem
- rear door wont open from outside
- map/purge wiring
- MPFI distributor on DPFI engine
- DOHC ZC Rebuild - Runs like crap
- ZC turbo build
- Crx 91 wnt start after under dash swap
- c v j boot replacement
- Rear wing issues
- trans swap help
- Window run channels
- my 91si
- Interesting Case of Steering Wheel vibration
- Brake indicator on dashboard stays on
- JDM Dohc ZC questions
- neeed some help
- 89 Civic Si fuel pump not working!
- Grounds
- Timing Advance D15B
- Car won't start after driving!
- Hatch problems after lowering
- 91 civic only runs when holding key on start
- 91 Civic Wagon - How do you take out the rear liner?
- 90 civic HB possible clutch safety issues?
- Some help, please.
- stereo wont keep power
- exhaust poors out of air intake manifold ?
- 250 hp na build
- Need a new header!
- Replacing Rear Marker Light and Turn Signal Assembly
- 91 CRX si - cranks but won't start
- Zc help
- EF Civic Si Rear Bumper vs Non-Si Rear Bumper? (Covers)
- Basic hp increases?
- Testing Distributor Components on Crx HF
- BEST and BEST VALUE options for painting my car the factory color
- yonaka/ hasport?
- Bought 2 Crx HF's Looking For Advice.
- 235/60-15 M&H tire fitment and review(pics)...
- Trim removal?
- D15b into an 89 crx si.
- FYI A/C BELT
- help!!! cant get d series tranny installed
- 89crx hf won't crank. Need help
- Helpppp, Car Wont Start!
- how high can you raise coilovers?
- The million dollar motorcar project!
- Lost power to all gears!
- Dash Lights all stay on, no start
- car wouldnt start after driving on hot day, but started later at night 1st try?
- Relay won't engage while trying to start?
- 91 CRX HF Crankshaft Pulley?
- Paint problems???
- front corner light... uh?
- Anyone seen this seat/fabric before???
- ECT Sensor on B16 Head Question
- Engine difference?
- B18AI in si hatch vaccum line pics needed
- Can I replace the crankshaft key without messing the with timing belt?
- 91 civic hatch dx swapped. HELP
- OEM Red Honda Emblems for EF Civic 3DR?
- WTF WAS THAT NOISE
- disc brake proportioning valves.. where to buy them??
- o2 sensor clip missing help!
- D16y7 into 91 civic si
- battery has juice car has no power not even a battery light
- How do I remove the cable from the back of the gas pedal?
- How to identify Jdm bronze glass? What came oem in japan?
- Civic wagon OEM roof rack installation?
- 89 crx HF cam swap question
- Does a HONDA CRX have a backseat?
- Power options for EF si hatch
- Tail lights issue
- CRX Hatch Moldings/Seals
- side marker lamp assemblies (corner lights)
- 88 Rex No Power
- Need help identifying parts
- New to the Honda world
- d15 head on a y7 block any performance gains??
