View Full Version : Honda CRX / EF Civic (1988 - 1991)
- CTR crankshaft pulley on b16a2
- passwordjdm & there rhd conversion
- 91 crx with obd0 b16 breaking up at 4k ...help
- Does the stock 88' std shift linkage fit 92-95 civic?
- how do u remove crx rocker panels?
- where can I find this lip?
- CRX Si B16A Swap Problems
- OLD CAR... OLD SMELL :(
- obd0 b16 question..
- WTB: LOWER CONTROL ARM FOR 88-89 SEDAN
- engine Smoking problem....
- EF3 zc to b16a swap (problems) ef9 parts ?
- HELP on On LS vtec Swap
- starter issues wondering if maybe a bad connection? PLEASE HELP ASAP!!!!
- Anyone running a Dynomax WLK-17749?O
- HELP...oil on clutch!!!!!
- ECU Problem!!
- !!!!!!!!!!!!!!!!!!!!!HELP!!!!!!!!!!!!!!!!!
- automatic 93 integra to 90 crx si shell problems?
- skunk2 intake manifold or type r intake manifold
- Suspension Problem, help.
- Quick Ac Question
- zc help
- Cheap Ebay Cold Air
- gas gage is not workin
- !!swap wiring help!!
- Orlando--- Free to a good home!
- Intrax Sway Bars
- Will this work on a ITR INTAKE MANIFOLD?
- car wont start (searched)
- 91 HB looking for heavy duty suspension (not lowering or racing)
- 89 Civic DX stalling again
- Anti seize and Loctite
- Pulled the head and this is what I see *pics*
- For Those with JDM fronts... Front filler question.
- 1989 civic HB first honda
- NEED HELP WIRING UP A TURBO TIMER IN MY EF HATCHBACK!!!!
- Motor Swaps...
- f22 in a rex need helpfull info
- 90 EF Hatch- O2 Sensor Help
- serious problem, sputterring when cruising
- Economy inner tie rod end
- f22 in CRX
- TRANNY PROBLEMS B16A PLEASE HELP!!!!!
- 1991 crx si door sensor, need help!
- mid process on tune up, ran into problems of wrong parts help!!!! ASAP!!!!
- 1989 CRX:
- Parts swap
- DA master cylinder, pedal feels soft?
- JDM CRX Brake issue
- quick question, help!
- intake manifolds
- What can I use?
- Almost no brake pedal
- Car is slow!!!!!!
- ef8 cluster only half lit up??
- suggestions...b18c5 fuel pump
- Knock sensor unpluged...
- FUEL PUMP AND MOTOR SWAP
- 1991 crx fuel ratio problem
- Axle Question
- AN fitting required to complete Nomex Fuel Line setup??
- 89 civic si help
- 89 CRX GSR...need air conditioning!
- ef9 suspension
- Some (probably basic) early-90s civic questions
- b16 spun a bearing
- Need Help With Tranny Mount question
- SUNROOF PARTS HELP!
- Wich Intake mani???
- weird streaks in my hood
- can i use LS shafts on my J1 trans
- 1989 CRX!? SPEAKER SETUP!?!?!
- I wanna get her started
- need help car wont start
- ef9 tbar
- problems with hasport cable/hydro setup
- Car missing on cylinder 3
- Fuel problems w/ b16 obd0
- 89 signal bulbs into 90??
- 1991 Crx si
- How to check for check engine light codes!!!!
- im putting a head on a motor and need help
- All CRX climate controls the same?
- factory options for an 89 si
- Short Shifter Question...Please Help
- 88-91 clusters and dash's
- offset question???
- converting 88 hf cluster to 90-91
- sedan head lights
- Ecu code 16 after a headgasket install
- NO RR TURN SIGNALS ON A 91 SEDAN ALSO SEAT BELT BUZZER GOING OFF HELP
- jdm stanley corners on a usdm front end
- crx cluster malfunction
- OBD1 conv. help
- R.I.P STOLEN EF W/ H22 SOCAL (inland empire)
- My ef build thread
- Should I keep my EF, or do I build an EG...?
- How to distinguish Knuckle???
- Want a 90-91 crx front end on my 1991 hatchback?
- header and exhausr choice
- help with swap. tranny/axle problem
- will a eg radiator fit in a ef hatch
- ENGINE MOUNTS?
- ac in 91 d16z6 swap
- Tranny bolt torque specs?
- manifold absoulte presure sensor
- Solid CEL - Alternator Sp fuse keeps blowing
- D Series motor mounts!!!
- b16 Problems.
- Si rev limiter...
- brake problems
- EK side skirts
- D16y7 Need some help
- Help: License Plate Light Parts
- someone wants a $85,000 crx? lol...
- Need Help 1991 Civic LX
- CRX is unsuccesful money pit
- 1989 Colored Interior Parts?
- FRONT STEERING KNUCKLE / HUB UPGRADE FOR CRX!!!!! BIGGER ROTORS
- ITR r/lca, coilovers on a 90 crx?
- LS throttle body on ZC manifold?
- Trouble at high RPM, 90 Sedan
- Who is running a vafc2?
- please help crx axles
- D series swaps?
- Window trim removal. 4dr.
- 96 Civic LX Sedan pricing?
- pics of my 90 si
- Will 2000 Civic SI shocks fit 1990 crx si
- gsr guage cluster in 88 civic hb dx?
- i guess ill post my piece of crap hatch
- so....
- stripped wheel stud??
- NEWB HERE. I KNOW I SUCK. PICS OF EF
- droppin a b-18 in a 89 si
- timing on a sohc zc
- new replacement quarter panels
- egr valve
- new clutch, won't go in any gear.
- b18a1 rods?
- how much hp will my b18a1 rods hold?
- repairing bent wings west rear bumper??
- Help:crx prolems
- hydro tranny axles?
- Click/crunch sounds from brakes
- Cam Seal Removal... Searched, didnt quite find what i was looking for.
- b16 axles with gsr hub problem.
- getting rid of clutch cable..?
- Unsolved interior question.
- Ef Si/Ex Build...What would you do?
- code 9
- quick question about h22 lma in b16 gen 1 head
- I think its my master cylinder but id like a second thouht
- calling all tall crx drivers!!!
- A.C. system??? 1990 Honda crx si
- sedan door handles and locks
- what size exhaust on crx with n/a sohc zc
- msd removal issues
- BUMPER HOLDER?
- sir seats
- Clutch Engagement Problem, HelP!!!!
- help b20 vtec
- 89 Civic Truck
- I need Clutch, dont know were to
- wats the difference?
- MOTOR t ype
- Stupid question. Gear faceplate?
- clutch got stuck to the floor
- 1990 d15 ecu tuning
- lexan creations.com
- wiring help
- rack and pinion?
- Critique My D16A1 Build Up
- Car wont Crank! I only hear click???
- irregular idle
- HELP!!!!!!! car work go
- Need complete 1/4 panels? New source
- Car is cranking, but won't turn over.
- a couple of nub qustions
- Shift linkage and radiator problems during my swap.
- Just looking for a little help
- 235-60-15 on CRX?? How?
- CRX rust repair
- NEED HELP PLEASE REPOST
- I need parts for a DPFI-MPFI swap.Please help.
- alignment question
- Rear control arm ball joint
- problem
- MAF sensor ?
- fuel rail related
- crx coolant leak?
- Front end noise
- seized spark plugs on a 91 sedan
- launch control
- coolant hose from d15 work on ls?
- WOULD A 94 Civic TRANSMISSION BOLT ONTO A 90 CRX DX?
- CRX Interior
- is it possible
- Quick help please - Stupidest clutch problem you'll ever see.
- 4 door hood on a hatch?
- new problems boosted gsr hatch krazyness
- eg lip on an ef? *(yes I searched already)
- help w/ funny brake vibration & noise
- crx/civic part fitment to wagon?
- dual point injection tuning
- sticking idle
- I want STIFF springs for my CRX.. Guide me to them..
- Power Windows
- Need Help/Advice. Low RPM Surge Idle and Water Leak through door/rocker panel?
- cv axles help
- need help with vtec in ef with b16a
- SOHC ZC into EF trouble
- DX/STD to OBD1 dizzy wiring
- Help need Will start/wont start
- obd question
- engine swap bottom or top?
- want to go mini me for the mean time..
- just got a k20!!
- brake lights, turn signals, cluster wont work ....
- B16A SWAP IN 90 CIVIC HELP
- help with cable b tranny
- DPFI to MPFI conversion. possible to use a obd1 distributor
- aftermarket headers
- mini me swap
- MPFI help.. car won't start
- check engine light and ecu light staying on??
- engine bog
- glass sunroof/moonroof
- smoking problem
- 91 crx swap problem
- i have a question ?????help me
- Where to buy 88-91 Civic Fiberglass products
- My B20-R build for my EF9 conversion
- EF9Robert's new parts installed :-)
- Oil leakage.
- PLease help!!!! ecu fuse keeps popping
- put an LS swap in my crx but it wont start
- cunningham rods
- please help: car is always overheating!
- ek side skirt
- Where can i Buy a 1 peice Front end for my ef!
- Is there any h2b kits for an ef?
- HOT!!!!!!! AC does not work....need help!!!
- Bad Wiring Connections
- TypeR intake on B16 CRX
- Has anyone installed a dc2r intake mani on an EF8 (jdm b16a1)
- SOHC ZC SPECS ! ANYONE KNOW
