View Full Version : Honda CRX / EF Civic (1988 - 1991)
- 92 GSR Brake Upgrade
- Clean EF9! Lots of ugrades! My loss your gain!
- Clean! Honda EF9 for sale!
- EG Front & Rear Seats in EF Hatch
- engine help!!!!!!!!!!!!!1
- Door noise is killing me
- 97 gsr vtec solenoid 0n a b16a obd0?
- 90 DX hatch.. H23orH22 swap.
- New member intro
- 91 civic stalling and throwing # 15 code
- Weird Stalling Issue, already tested IACV
- DC2 Center Console
- Need a writeup or help on replacing steering rack bushings
- My EF9 wont crank. Any other ideas?
- CRX Tail lights
- firewall shave??
- sohc boosted ef with ac
- 91 Civic SI ecu code
- ef w/gsr swap, wiring b5/alt/vtec ps
- engine bay smells like coolant and i see the smoke b20
- Milling dseries head
- Blox camber kit (checked this 1st thread wit this)
- 4-Wire oxygen sensor
- Blown motor, limited budget, sohc turbo, or dohc vtec n/a
- CRX with B18B... Turbo manifold suggestions!
- D15b idle/run issue
- more power for now
- My ef isn't starting
- 90 Civic Clutch on 88 CRX w/ accord disc?
- OBD-0 B16A Distributor
- need to know how to install door sash/ black plastic trim piece ??
- ecu throwing codes
- Oregon CRX Build Thread
- DPFI full throttle bog issue
- B16a obd1 conversion with obd1 engine harness and female plugs
- No fuel filter...
- Thoughts on Bosch oil filter?
- OBD1 GSR in EF : code 7, 20 and Secondaries
- White Honda Civic ED7 EF3 with mugen CF48
- Recommended master cylinder for my race setup.
- ecu wire pin-outs
- weird engine problem???
- B18A1 swap in ef civic NEED HELP!!!
- 89 Ef Sedan OEM Lip Pics?
- obd1 conversion
- civic wagon transfer case question
- question about turn signals on a ef hatch
- axle problems.
- My ever changing caster
- ANOTHER "Will not start" DOHC ZC
- '88 CRX Si with rear discs
- DOUBLE [R]'S ED7 BUILD THREAD
- DPFI Feeling Slow
- Can't Get the VTEC Head Off. Please Help
- YAY! NO START! :D :D :D
- CRX HD promo video
- can I use a DA engine harness in my EF si
- obd2 d15b vtech into std 4door
- knock sensor and vtec wiring
- D16 Tranny in D15 Motor?
- d16y8 swap in 89si
- Upholstery/ Seat repair
- CEL on, fuel pump not, MR not the prob. HELP!
- a/c
- Where is the TPS (throttle position sensor) on my 91 Civic?
- Sd machine shop
- 91 civic no run
- cel and no start??
- Whats up Honda-Tech
- Texas 1st Gen JDM B16a CRX moved to California
- Temp Gauge Problem??
- What front knuckles are compatible with EFs?
- Swapping F22b in to '90 DX hatch.
- tall guy need lower seats ef
- CRX parts is what i got...
- under dash grounds
- in desperate need. another no spark thread but plz help
- b18a1-b18b1 head swap question
- Mini me still having problems
- CRX si rear stabilizer arm on a dx?
- How do I Install my Walbro 255 fuel pump?
- 1989 Si Crx Circle track
- chipped exh. valves?
- 91 CRX si not starting
- Suggestions for my 1991 Honda CRX HF
- 1989 CRX with B18A1 to B16 swap
- zc problems help! and questions?
- Bought a new CRX Climate control
- ef sedan project
- need help??? LEaking Gas
- how much is complete EF power steering worth
- Rain causing my car to run rough??
- OEM HONDA HOOD BRA???
- B18a1 swap
- hf cluster shift light
- b series shift linkage
- corner light/bumper turn signal light wiring help
- k24a4 ef swap build thread from WY.PICS!
- B18 wagovan troubles
- 89 crx si rear drum to disk conversion
- So just picked up a decent CRX...
- seats for a EF9
- honda gods please help no vtec!!
- ok tried to solder all my cut wires and no start now...help
- 88/89 crx handles better than 90/91 crx???
- Timing ground - PR4
- Volts gauge install help?
- will any ef pedal assembly work in my 89 si ?
- Doing A Swap?
- new to hondas need help
- Will these tires fit?
- Rywire MPFI harness wiring question
- 1990 dx hatch y5 swap CEL jumper location?
- Long time listener, first time caller, just bought a 91 CRX DX
- after-market compensator arm bushings? (picture provided)
- JDM EF9 Headlights
- Seat belt buzzer
- EDM CRX Si ODOMETER F/S
- intake manifold question
- No power
- d15b6
- Oil Leak/ Timing Belt??
- throttle problems
- help plz clutch isnt disengaging
- great day at the junkyard!
- Caps for Mugen MR5
- hand brake stuck, lever is down, rear wheel does not move ..
- power folding mirrors on a dx?
- Mayday Garage features a........
- Help identifying Parts
- Which head studs/bolts
- b16 high idle problem
- 4 Year Old Suspension Problem Challenge
- Problems problems problems....
- 88 EF starting problem
- L or straight shaped heater/water cable?
- Hatchback Door Interchangeability
- IN NEED OF HELP!!!!!!
- Losing my mind...1990 crx
- need help tokico front shocks?
- 89 CR-X Si
- short ram intake???
- 1989 crx si b18a1 quick question
- Headlight problems
- alternator not charging
- Racing seat sitting too high for roll bar
- Are Optima Yellow Tops worth it?
- Alternator cabin fuse keeps blowing since battery conversion
- o2 sensor readings???
- Sohc ZC Vtec
- In need of 2.5" catback
- are honda civic and crx fenders the same ?
- crx2000... it lives!
- gsr cluster into a 89 crx
- Camber is f¥©<3d. HELP!!!!!
- My Toy CRX
- Koni/Ground control help :)
- ? about a starter
- 91 civic wagon
- another A/C thread
- 91 civic heads
- Transmission Swap(Auto to Stick)
- Honda Civic trailer
- climate control fan speed 1 and 2 dont blow but 3 and 4 do
- First post! Brand new Crx owner!
- CRX HF Engine with HX CVT Transmission
- Need help with a code 15!
- 89 sedan wire tuck, 5speed swap. help
- Code 20 ELD help
- Air Temp Sensor
- MiniMe Swap question 91 ef hatch
- Grant GT wheel horn ( probably an easy question )
- Wondering if this has/can be done... H22A w/H2B awd?
- rebuild help!
- 90 CRX HF Fuel Tank leak
- Compression at 100psi
- Helms or Haynes?
- Losing Brake Pressure
- Battery Starting Issue
- I NEED AC!!!!! B20b Ef sedan
- Transmission Internal Interchangability
- 1989 Honda CRX HF Start Problem
- 1990 CRX HF - No Spark, Won't Start
- Vinyl Wrapped CRX
- Bogging
- 89 si civic window problem
- HELP! 91 crx Hf wiring issue..
- Taurus cup holder mod?
- b16a3 in 90 crx si, WTF
- need help!!! d16z6 in a 90
- d15b2 to sohc zc wireing
- A6 Harness
- p08 vs mp6 intake monifold
- Turbo help
- blown 91ef
- LMA mod problems obd0 b16a
- Help! need to find out what seats these are for
- help with jdm front end conversion
- help with climate control relocation
- my ef keeps overheating on short distance drives...
- ef seats
- Amber Corner lights 90-91 hatch
- cooling fan not working
- My 91 Civic Hatch DX Project
- help!! car in no start condition
- Anyone selling a skunk 2 front camber kit for 90 crx?
- nrg lock broken into
- Brake Light Pedal Stopper
- ED suspension question?????
- code 8 and 20
- Car dying
- OBD0 to OBD2 questions.
- JUNK YARD, LOOKING FOR PARTS
- gas gauge off by little bit
- Electrical issue in my 90 civic Dx hatch
- 88 civic hatch rear bumper
- high comp. b16a2 questions
- DC2 jdm integra type r seats in crx?
- 91EX Civic sedan build
- problems with idle stalling and hesitation. im lost
- innovative mounts throttle cable
- 1990 Civic Si Gas Gauge Stuck but limits amount of gas into tank??
- missing/hesitation
- shock fork pinch bolt wont thread on new coilovers
- Distributor Problems
- Half shaft problem on a b20b swap in a ef.
- 89 civic dash lights?
- Engine help
- 85 CRX hazard light issue
- bolts from header to downpipe
- Mugen 4-1 Header / B20 VTEC / ITR Head
- replacing steering rack boots on 90 CRX Si
- A/C button on climate control panel falls thru hole ?
- Brake Problem
- is it the rings?
- Is this a ZC Sohc Non Vtec Camshaft?
- 1990 Honda Civci Wagon Help
- 90 civic lx dpfi - PCV question
- f/s f/t 91 ef hatch with goodies
- sidemarkers wont work!!!?!?
- Help brakes wont work????
- 1991 civic DX hb cold start problems
- CRX D16Z6 swap need help
- A6 cam in D15B1
- Gauge Cluster Wiring Diagram
- Civic 90 Si needs work in the NYC Area..any suggestions?
- Recommended tire size for 89 honda civic
- Is this a good shell?
- Help!
- crx converting to hydro trany. help
