View Full Version : Honda CRX / EF Civic (1988 - 1991)
- fuel pump wires?
- HCP AC bracket with hasport mounts will it work???
- car dead on highway
- D16A6 into hf (searched)
- Asked my friends and not want your opinion..
- question: rear lower control arms for our cars
- muffler suggestions!!!!
- Wiring question for d16z6 swap into 91 s1
- idle controller location
- Vtec problem on '91 b20 CRX
- Performance options with an 85 CRX For $1k total?
- Who has a JG 301X Camshaft ?
- brand new after market B series heads
- TRANNY??CLUCTH?? FLYWHEEl high rpms
- what do you guy think?
- HELP PLEASE!!!!
- want zc but have questions
- sooo, a towing company ripped my bumper off...need advice.
- HELP Ghost in my 84 crx
- TRANSMISSION QUESTION!!!!!!!!!!!!!
- found a CLEAN!!!!! 89 si
- SCAM ALERT!!! SCAM ALERT!!! IN SACRAMENTO,CA AREA
- zc questions
- Need Help, Possibly Timing Related
- ground control/tokico blue install, problems
- does anyone know where to locate a civic, crxukdm front end conversion, and ukdm oem parts?
- More power???
- Sedan Owners....do you have excessive wind noise?
- '90 Civic DX fuel mileage
- Tach Probs at High RPM, b16a1
- New 1990 Civic LX owner!
- car is not starting..pissing me off!! >=(
- Pics of the B16 swap into the Crix
- 1992-95 civic Si engine? A few questions...
- What's the compression on a d15b2 block with d16y7 head?
- hey everyone (Best Rebuild)
- Possible starter problem? Is it my silenoid
- weird noise while turning
- jdm map
- broken hasport mount pics...
- jdm crx front end conversion: body kit?
- b16's with A/C, look here
- 3 Questions: DX and Si Intake manifold Senors, doing DPFI -> MPFI. Please Help.
- How can you tell YS1 trannies apart?
- front sway bar sizes Qs !!
- I need a hood and fender
- B18c-R pass cali ref with what obd? kenji p28 ecu, or p73
- SIR Cluster connectors
- Torque Spec QUICK!!! Please! :-)
- lug nut stud removal...anyone performed this before?
- Car is sitting a little higher than i'd like, but coilovers are on lowest setting...
- motor flooded??
- b16a into 89 civic - anyone not used a mount kit?
- Interchangeable Mirrors...
- adjustable camber kits
- Newbie... brake question
- Ebay TYC Spoon Knock-offs: pics and how do i install manual adjuster? anyone?
- question about an 85 crx engine swap
- car wont start, wont crank?
- rear brakes
- Piece on door weatherstrip. What is it?
- need crx stuff
- Zc swap for friend, overheating...
- CRX seat question
- D16A6 cam dyno's??
- distributer ?
- Emissions??? B16a FAILED again
- i need 13 inch wheels that fit a crx that are at least 6 inches or more wide help
- Question will a 215/50/15 tire fit on an 88 crx?
- How much is it worth?
- LS Vtec 1/4 times?
- SEIZED LCA BOLT
- when i brake my steering wheel turns left
- where is the best spot to get a b16first gen motor from
- Suspension question
- HELP ME FIND MY 92 CX HATCH IN RICHMOND
- does anyone know if a 93 delsol si steering wheel wil fit a 91 hatch?
- integra/crx tranny question
- 550cc Mazda fuel injectors
- lower radiator hose
- CRVtec
- what axles i use for my b16 swap into my 91 civic si
- Full d16z6 swap or just the head/tranny?
- for those who got d16z6
- Is it possible to add factory moonroof to 2001 Honda CR-V ?
- Install Wiring Harness
- Oil pressure/temp gauge questions...
- brake question
- Nobody Looks to the OTHER B engine.
- @#$%@# ARG! Swap woes
- quick question on injector order...
- Fuel pump problem!!!!
- b16 injectors
- How much would you pay for Crx foglights?
- b18b1 OBD1 CRX, turbo?
- Interchangable????
- 94 Integra GSR Rear Disc bolts onto CRX?
- Street Imports Mount Kit
- Brakes are dragging..
- EF Squad Stickers!!! Getting interest going!
- What 14 inch rim fits over Integra disc brakes?
- help control arm is bent
- atte: wiring guru's!! help. tach needle on sir cluster jumps to 1k w/ motor not running
- Dumb question prolly.
- Civic Springs??
- B16a problem
- OT: EF SQUAD Stickers
- Exhaust system - back to stock w/B16 - will it suck?
- 90 civic upper ctrl arm question
- Used Car Classic?
- Attn: B16ers. OBD0. Which O2 sensor is primary?
- ANY SUGGESTIONS
- Problem with TRANNY PLEASE HELP
- B16A into 89 CRX
- What's she worth?
- AEM Fuel Pressure Regulator
- Please advise - CRX dying out of nowhere
- putting a f22 engine into a crx (then boosting)
- zc swap into dx:what axles should i use??
- i need help with the wiring a disszy
- switched a 93 ls into my 90 crx dx but problem wiring
- I want more, possible C5 swap, help!!
- TL Front Lip....
- ECU auto-manual... not the usual question
- CANT LOCK MY DOORS
- How to remove stock seat covers 91 SI
- racing coilovers?
- New To Imports
- Upper control arm swap?
- B-series parts on ZC?
- Spare tires for weight reduction?
- Who here has a AEM fuel pressure regulator?
- Ontario members that can weld
- JDM civic conversion?
- repinning ECU for B16 ?'s
- rear trailing arm bushing?
- whats the differents w/ delsol headlights and jdm h4h lights?
- Fitting a hood inside the HB
- alternator wiring for crx
- 88-91 d16si with 92-95 d16ex head
- Help Me Deside On My BUILD UP!!
- CRX QUESTION!!!!
- just wondering about vavle springs
- fuel pump in 91 dx
- replacing water pump on b18c1
- anyone w/ an HF with a ZC swap?
- Got some Goodies!!!!
- 161822 whats your opinion of this shop?
- Took ECU out, and now car runs like shit!
- DIY: B Series; How to Replace your headgasket!
- which J's racing intake for a b-series EF?
- Anyone ever overwork their brakes w/ a B swap in thier Civic/CRX?
- Cam Specs
- Have searched and searched
- 90 civic with ZC motor,,,,,, LS ECU????
- (racing clutch ) name your clutch!. like it or hate it?
- one thing i hate about honda-tech
- b18a1 vs dohc zc
- B18 throttle body on d15?
- Brake swap for Civic
- did search, ....which OEM acura/honda wheels fit crx?
- Hey guys
- Tein....Sag Or No Sag....
- Anyone have their smog info on a 90-91 CRX SI in cali??
- turbo piping for EF
- d16a6 .. What pistons to use or other setup to help bring compression up
- brake locked up on me
- y8 mani/type-r t.b. swap onto sohc zc
- JDM moldings?
- WTB: Turn Signal Lever, Drivers Headlight, Climate Control
- 90 Civic base model smog
- no timing marks on my crank pulley.
- Getting new paint. Need moldings
- Swap problem not starting
- what is a reasonable price you guys and gals are willing to pay ?
- feed back on junky parts vs new aftermaket core support
- A/C Swap?
- I need a place to find CRX parts in Chicago area
- Using 99/00 Si valve, MC, and brake booster with disc upgrade?
- I have two sets of unidentified stock taillights, help figure out they go on what car!
- del sol steering wheel
- HELP!! Reverse lights not working!!
- put put put plusating b16
- here's a list of crx lips
- b16a crx, i need help with my vtec, or bogging at 7500rpms
- poly urethane bushings?
- WTB: Jimfab traction bars for my 91 si.....!
- Using the B16A1 engine harness, will it work?
- Is this possiable!
- civic si bumpers
- kicked out
- To people with Erratic Idle problems heres one solution!
- most i can tuck tires
- Possible Clutch Issue
- 88 crx Si with ZC 1.6l DOHC motor swap - wiring harness questions
- PLEASE HELP
- CRX wiring/electrical gurus...Please help!
- EVERYONE with swaps in an EG coupe
- Tanable Exhaust?
- Post pics of your rex!
- ok why do i have to change so much when i do a 93 ls engine in my 89 crx si???
- hydro tranny question
- Not sure what is the cause - erractic idle
- couple of sohc vtec questions.
- Front Lip?
- Amber Bumper Lights
- Anyone have pics of ef8 w/ ctr SRD recaro seats..
- Is it worth $1100 Bucks?
- Temp Gauge Going Crazy
- electrical bugs in my system.... help!
- Axle fun
- ok i blew my tranny today
- Online B16A Swap list???
- leaky gas tank?
- Spoon ECU?
- Once again ZC STARTING PROBLEMS
- si harness on zc swapped into an hf
- REMOVING PAINT OFF MY CRX AND RIMS...
- Help: Where is the best way to fill oil in my tranny
- mystery problem
- B18C1 in my 1988 crx?
- Hole in My trans!!!
- i never thought this would happen..... (HASPORT mounts)
- safc on 1st gen crx??
- its been 20 days and i still cant post
- more info on hf/dx head swap , please
- CEL CODE 15 AND NO SPARK......
- cylinder #1
- Aftermarket b series mounts with factory style rubber
- WTF.............motor won't rev out!!
- rear sway bar problem with mounting (tow hooks)
- d16a6 head on d15
- *Poll* Your take on this debate...
- crx motor swap- what should i do ?
- STEERING probloms, turn the wheel, and car goes straight?????HELP
- What kind of seat rails
- dizzy conversion obd0 to obd1??
- problem fitting aftermarket headers in crx
- Tire choice
- b16a crx, vtec works but only untill 7500rpms, sorry.
- Turbo problems
- www.TheZCR.com meet in Colorado...
- 93 LS B18 IN A 89 CRX SI.....
- Those who have upgraded to EX knuckles/brakes/rotors
- Problems starting my car
- What is my CRX worth? If I choos to sell it...
- please help-'96auto EK tranny in '91auto EF???
- is this gonna work??
- where can i get jdmfrontend for 89crx
