View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Jdm zc engine swap question
- POLL: Best overall pager systems ADD/VOTE
- B16 Stage 3 Clutch Cable Tranny
- wiring up the zc cam angle sensor
- b16 on nitrous question...
- charcoal canister removal
- what bushings are the same on the ef as the eg or ?
- b16 issue with nuetral stalling
- sunroof problem (searched)
- tractions bars?
- B16 VSS Question/Issues
- Code 14 or 15
- Coolant System Diagram
- will a 92-95 civic fuel pump work in an ef?
- b16 ecu code 2
- broke down crx need help pls
- fault code 10. how do i fix?
- GSR CRX in mass? emission laws?
- How to fix your idleing woes! FITV IACV
- CRX d15b vtec clutch choice & lightened flywheel &si trans mpg questions
- Engine harness question.
- Big Question
- 88 crx si d16 cranks but no start
- gta 4 photo shoot of my fit and rex
- my dohc zc undercrank pulley fell off :o
- JDM B16a (OBD0) FITV! NEED HELP!
- my newused 89 CRXsi
- Oil leak after timing belt replacement
- Steering wheel is upside down
- HELLPPPP. b16a thermostat/gaskets
- Crx w/ B16 having emissions problem Portland, Or
- Interior grounds
- broken frame mount
- car broke down .... HELP!!!
- 1.5 dizzy on 1.6 motor?
- battery dies when car being off?
- Skunk2 coilover help, on lift right now!!
- O2 sensor / atmospheric pressure sensor problem
- Update/Backdate question for auto-x
- Latest upgrades on my civic/Custom s2k dash board and B16ITB
- ecu question
- Its Stuck!
- zc distributor
- sticky steering rack after tightening
- Bought a cheap hatch...is it a lost cause???
- Purple hatchbacks?
- Brake noise :pics:
- Brake clicking noise..
- parts for my 91 hatch
- What alternator to use?
- jdm b15b vtec, in a 89 DX no fuel coming through
- doors?
- b16a first gen head gasket
- Mini-me coolant circulation problem
- front top strut bar on crx
- 88 CRX hybrid rear disc brake question
- !!!!!_____*********TRADES**********____!!!!!!!!!!
- Ground by thermostat
- what would this be called? a blessing in disguise?
- Best write up for tranny change ?
- obd0 b16 crx wont start
- ETD traction bar
- Fuel Injectors
- Pic request: Ramhorn with full-race PWR radiator. or suggestions.
- struts
- d16a6 to d16z6 swap questions!!
- Alt. ?
- D16a1 Swap
- crxDX h22 wont start have no clue why?
- The BEST $16 DIY CRX front lip. (From Intgera)
- which pistons would work
- single cam zc tranny
- Camber Correction for 91 EF HF
- front brake upgrade on 90 crx HF
- Innovative crossmember caster adjustable?
- obd0 to d16y7/y8 mini me obd2 harness help
- quick question
- help me please im at a loss. first startup.
- power steering?
- CRX rear storage box clips......help with finding part number.
- 91 CRX sound proofing materials.....help please
- Is Making an automatic crx to stick shift hard??
- where can i buy oxygen sensors for my b16 on crx
- code 9
- 89 CRX GSR No Spark. Please help!
- can anyone help me with this dizzy issue
- Rear Compensator (Toe) Arm Nut Fix
- Strut tower bar wont fit over intake
- what header?
- EX Sunroof ?
- Starting problem
- obd0 to obd1 distributor
- vtec or nonvtec on crx si/ civic si
- Black Friday at PepBoys
- engine list....?
- $800 Carbon Fiber hood problems. [From Password]
- Check engine light problem solved!
- need help to find longer bolts for neuspeed lower tie bar install
- Installed NEW OEM Civic hatch Carpet (pics)
- b series tranny ?
- vtec controller
- mpfi help??
- DA vs EF Rear Trailing Arm
- jumper harness ?
- Progress Anti Sway Bar
- Mac's 91 Civic Ex Sedan build thread: Project "Beater" - Engine swap, paint and lots of pics!
- half shaft question
- No Spark from Dizzy ( Did Search)
- new 91 civic owner
- 89 Crx Si help
- Wow...it's been months... Some tips...
- Can anyone tell me what the suspension set up is in this ef engine bay shot ???
- how much would it be to import a crx sir from japan registered and everything?
- Sputtering CRX SI, burnt valve?
- CRX bumper support weights
- HELP!!!!!!!
- HELP ON FENDERS!!!!! PLEASE
- Ingalls adjustable ball joine problem
- ok i really need some help plz...
- Dohc ZC turning problems
- limp mode
- What DID you do to your EF today???
- Si springs vs. Dx springs and other OEM spring questions
- timing a zc????????
- Got a new ride and a pretty rare one should be a good project
- walbro with low pressure
- Bogging Problem
- help with y7/y8 mini swap
- msd 6al
- quick ? about jdm rex!
- brakes: front pads size on 88 hf rex?
- my 91 si build thread
- deleted front bumper turn signals. need to fix relay
- Minimum wheel size with ITR brake upgrade on EF?
- Do urethane bushing kits make a noticeable difference in handling?
- Help with D15B
- ew1 with si head and tranny
- pdf file for the B16
- 89-91 DX OR SI Tranny which will yield better fuel mileage?
- What is the proper range for a temp gauge?
- rear lip
- Ef8 Sir rear bumber
- ZC versus Mini-Me ?
- Corner lens issues on 91 CRX
- ALTERNATOR NOISE ?????
- 1991 crx seats in my EF hatch (91)
- ok need to find out like asap bad
- Help Code 3 after b16 swap
- over heating.... try to figure this one outttttttt
- Civic RT4WD Decal emblems question wagon
- 205 on a 7" wheel?????? will it work? pixs?
- how to mod crx parking lights
- Tyson's thoughts on brakes. leave your comments.
- weird electrical problem? STD hatch
- XSI SWAP IN CRX??
- obd1 converted and problem
- Whats the difference of these coilovers?
- when buying new oem hood, what color is it?
- Oil pump pickup gasket
- Rear lights are acting up!?!?
- a6 head gasket repair parts list
- Difference EF8 vs. EF9 Power Folding Mirrors
- Canadian civic- seats?
- Full race traction bar with stock rad
- Overheating problem again, need input
- shift rod seal?
- No power
- 87 Honda Accord seats in 89 CRX SI
- Prelude Cluster?
- What can i rev at?
- Norm Reeves Honda Car Show
- obd0 ecu question
- mini me help
- Urgent question about steering???
- need a left rear brake caliper, where can i find one?
- FAILED emissions... (need help....)
- do hatchback tail lights fit four doors?
- engine rebuilding, how long till its broke in
- big problem
- d15b2 idle adjustment
- Efs with a swapped b-series motor, what did you guys do with the wiring???
- B16 AXLES
- front end conversion
- Single ZC TB
- b16 w/ls5 or w/ls 4th and 5th
- valves
- Painting questions??
- need some help??
- temperature guage spike
- could it be the fuel pump
- my post seem to have disappeared ...... how do I get a hold of a MOD?
- Rear main seal replacement
- keeps blowing fuses???
- turbo question
- ok so i just got a ef with a d16z6 . . . . . . .help!
- crank pulley at tdc... searched.
- b16 swap rear mount bracket help! searched all day...
- EF Sedan Exhaust system interchangability?
- honda dealers in the US that will ship to Canada for cheap?
- D15B4 Dual-carb workshop manual
- D16a6 si Tranny Grinds Info..
- b16 front engine mount in ef?
- Searched still need help! ARP d16y7
- IMMOBILIZER 00 gsr help asap please
- RcAutoworks radiator
- "The What Does Your EF Weigh Thread"
- dumb question but
- half shaft
- help me!!!!!!!
- 91 si
- Timing belt snapped, new engine or new head?
- got another hatch-and stripped it to the bone
- Crazy noise???
- B16 Cable Tranny
- help with eacv sensor
- engine harnesses crx and hatch
- weird nosie ???
- B18c swap into a 88 civic hatch?
- Help with Burnt valve
- civic transmission fluid capacity
- Tranny seal question
- Just bought a d16z6 ef now what?
- quick question (did a search)
- crx harness
- what throttle bodies will fit a y8 mani?
- Please help me identify this strut bar in my 91 REX
- brake upgrade....
- What works well for refinishing the black trim pieces?
- decals?
- 89 Civic Fuel Sending Unit
- checking cel codes...
- Heater blowing but not hot...
- zc with HF engine harness
- coil pack conversion
- Hi Im new to your site and need help
- Bought the worst peace ever
- alighning doors
- b16 exhaust question
- *Itr header on b17*
- noise problem!! very irratating. help!!!!!!!!!!!!!!!
- b18 swap questionz
- Rear Disk brake swap?
- cam gears
- carpet removal
- before/after jdm front end conversion
- instrument cluster with tach
- Car doesn't crank, but has all the right conditions. WTF?
- New EF owner
- h series b series swap hp gains
- mini-me questions
