View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Wiring\Electrical help for Alternator and VTEC
- valve adjustment ( and i get it on how to do it ) but 1 thing ?...
- TPS problems
- changing tranny bushings in dx tranny.....?
- I have spark, I have fuel, car runs on starter fluid. any ideas
- 4.98 Wot .07 Idle. TPS, Adjust or Replace? How do you access lower screw?
- Z6 Motor
- need some help
- NEED HELP ASAP PLEASE!!!
- best intake manifold
- I want to keep the A/C, Which motor should I get???
- getting a code 41 w/ GSR swap, are OBD 1 and 2 O2 sensors different?
- Question on swap from a DX to an SI
- It Runs!!! --- Deserves a new thread
- TRANNY QUESTION
- Can you use a non-obd distributor in place of a dohc vtec (b16) distributor?
- I Seriously Need Help...Bad
- EF Sedan Exhaust
- seatbelts
- MY CRX TAIL LIGHTS WONT TURN OFF!!!!!
- HELP ZC POWERSTEERING HELP WHAT DO I DO???
- crx
- new here, help with my rexer!
- think this will be quiet enough?
- Where can i find some canadian doors for my CRX?
- quick 1/4 question?
- engine swap fpr crx
- best place that sells suspension components for crx??
- Going Turbo But Need Help
- V-tec Wont Hit in GSR Hatchy !
- some question about swapping a D16z6
- 90-91 bumpers on 89 Hb
- LIMITED SLIPS-(901 GOLD) & (902 GOLD) FOR SALE ~ INDIVIDUAL SETS AND BULK~
- Beaten to death, but just double checking my understanding
- need motor mounts for 84-87 civic/crx, B16 swap in progress.....
- So I finally got to start it up! (B18c1 crx - It's about time. Long post...)
- obd0 engine with obd1 IM, what ecu?
- Gauge cluster wont work!!!!!!
- ATTENTION MODS
- Js Racing vs Fake Js Racing vs Ebay vs Pepboys
- my CRX
- 86 Civic Si Clutch Replacement
- kinda need this answer by tonight or tommorow.
- Smog Check... (GASP)
- dual exhaust for 87 crx
- i dont feel safe with loosening my torsion springs should put anything in between them
- Guages Tweaking Out on when driving!!!!
- DMV smog ref (HELP PLEASE!!!)
- 3rd gear crunch spoils fun with B16/Y1 CRX conversion...what cure?
- IDLE PROBLEM********Please help
- Leakage around head gasket and bottom of water pump!!
- SEATS SEATS and MORE SEATS
- zc ?'s
- Turbo ?
- my CRX picture..
- Code Change
- dsm 450's in 89 b16 hatch
- anyone with a d15z1
- first swap, need some advice.
- THrottle cable help'
- 16 or 12 valve...?
- stolen hks muffler
- OBD0 - OBD1 w/ VTECFrog Harness - IT'S WRONG!
- HOW TO : Remove Transmission
- LS valves in a ZC?
- Caliper Paint
- 89 CRX Si wiring problems need help.
- H22 CRX Video Thread.
- Want a FREE iPOD or FlatScreen ?
- GsR Tranny
- Next Step to Finish Line pt. 2
- Radiator question
- It works.... perfectly!!! Thanks to all who helped me.
- So, you question MAACO's paint quality?
- Anyone got a d-series vss they can part with?
- Help! Can't get my b16 crank pulley off
- Concept of rice?
- BiggDogg doesnt know sh** about cars!
- Help Leaking transmission but where?
- How often do you use nitrous, what size shot? Any problems?
- Help: Vtec wire
- Stolen civic in Illinois, please be on the look out
- b16 S1 tranny???
- ITR brake MC install?
- Official TPS Adjust Thread. Code 7 . Throttle Position Sensor *HELP*
- ZC ENGINE REBUILD
- ef 4 sale
- FS: 85 honda crx si! MUST SEE!
- Problem Starting The SI
- manual for 88-91 sedan HELP!
- would 88-91 hatchback oem exhaust fit 91 crx?
- What pressure plate is this?
- Whats the sleepest thing in your EF?
- Quick Release Steering Wheel Hub
- What Happens when you cross a 91 CRX Si with a 2001 Ford F250 SD?
- Changing power steering fluid
- d16a6 Timing Help! , running like crap!!! (searched)
- Vin run
- odd problem with si cluster
- D16Y8 going in tonight
- Stage 3 cluth finally in
- 1st Gen CRX Question
- d16 head/d15 block?
- harness conversion
- Question about suspension
- Help! After Timing Belt Install, Off 1/2 Tooth?
- does spoon actually have a website to buy parts from??
- Question about reusing DX speedo gear in my B swap/tranny
- has anyone done this?
- dead battery
- wiring conversions
- defi gauges
- D15b vtec?
- IM gasket for MPFI swap on 89 EF dx
- jw..
- wat dash will fit perfect on my 90 hb si wit out fabrication
- paint your prefernece?
- fail CA smog- semi stock 1.5
- Pics of your exhaust
- RED LINE
- VTEC doesnt engage in first until 7000 RPM?
- EF Exhaust
- WTD:eg6, dc2, ITR Subframe
- b18a1 vs D16a6
- home depot lip on 89 bumper fits with jdm headlights
- Homer's 15mins of Fame - Large Pics!
- Best swap for power/money balance?
- rear drums finally need attention
- *ATL*-NOPI NATIONALS
- Duplicolor - Restore your old Honda
- ecu code question
- EF with H22a
- Just when I thought it couldn't get worse....
- Estimate for a custom axle back exhaust?
- ef hatch removable roof racks?
- header
- Swapped under dash harness and car doesn't run now. (Fuel pump doesn't prime, hazard switch blows f
- Cheap glasstop crx !!!!!!!!!
- e.t times?
- dynoed with 3 diff intake.
- EF Speaker pods (pic)
- WHERE CAN I FIND CARSOUND DIRECT FIT HIGH FLOW CATS?!
- does anyone have a 84-87 civic
- Had a couple ?
- 88 civic header on z6 head
- overheating question
- JDM D15B in a CRX
- Just ordered my mirrors today!
- Crx Connecting Rods
- rebuild ?
- Msd cap for external coil
- 87 CRX - bolt-in swaps?
- hasport mounts
- to those of you rebuilding cable ls trans
- my dohc zc is not working right
- lookin for a LS engine
- body kit help
- 1994 D15B7 DX engine into 89 CRX ...questions!
- compressor engauging and disenguaging
- All motor B16A1 questions
- Do you love your EF/ED? Kind of long/rant.
- Are the headers the same?
- Studders on Highway... Wont start on occassion.
- d16z6 in a geo metro
- Can brand new OEM parts go bad?
- 89 Civic header design
- side skirt install
- got the mpfi done!! now i need help
- B16A1 IN 89 CRX SI
- quick d/b series question
- DIY LIP (56k be warned) *Finished
- HELP with WINDOW
- Will a 92+ civic header fit on my 89 crx?
- B series trivia: difference between motor years?
- FUEL PROBLEM PLEASE HELP
- Good deal?
- My turbo B16 Crx
- RSR GT2 Exhaust
- what engines can i put in my rex
- Custom axles for B-series ---> CRX
- What is better Tokico Hp or KYB GR-2 's for 91 Civic Si?????
- ZC distriubter
- Replacing Rear crossmember: any tips?
- all about crx vtec.
- air condition with a ls/vtec
- HELP! motor trouble
- should i buy 90 crx si?
- rarest jDm Parts???
- B18C heater outlets, can I connect them together?
- i got a Swirlie question
- Gauge cluster
- pr3 head casting numbers
- dpfi to mpfi
- *****WTT black center piece for a red center piece*****
- DOHC ZC start problem
- Hrm, in a rush, need a hand...
- Stock SIR airbox
- does the jdm ef hb sir fornt bumper fit on usdm headlights and hood?
- how do i lower my first gen crx
- 89crx fron end to a 94 integra
- b16 rung great! BUT NO VTEC CAUSE OF CODE 22 AND 23
- 89 STD hatch swapped and now...
- throttle cable problem in a swap
- Help me out and tell me what i can get for my car
- 88 to 91 cluster conversion
- DOHC ZC compatibility
- Car almost pass but then Tehc thought i had a "Acura Motor"
- Im looking for a jdm d15b vtec. Where's the best/cheapest place to get one?
- black top zc or brown top zc?
- turbo question
- b16 question
- Design problem for H22 into EF - input any one?
- B16 in EF
- What clutch?
- b16 tubro question
- More Wilwood Brake Kit CRAP: Lesson's learned
- help...i have a wiring question
- Side Markers
- dohc zc vs. b16. how hard is it to run a 14 sec. on an all-motor dohc zc?
- A/C Problems
- new here, some swap questions...
- what are these codes?
- new engine on my ef (questions)
- egr valve?
- CRX Dashboard Console Swap
- B18C5 into a 90 civic hatch back, anyone?
- Question....
- how to take off door molding without tearing anything up?
- Which camber adj. kit?
- seat belt light/fuel injectors?
- I can't find what year my dohc zc motor is?
- Do all D series trannys fit on D sereies Engines?
- Clutch and Tranny HELP!!!
- Speedo went crazy??
- modified B16 CA smog questions, will it pass emissions?
- b16 mount question
- People running a fidanza flywheel please take a look
- balancing question
- D16Y8 Into CRX-SI
- My car broke down, help
- 5th spark plug wire????????
- Help! Engine code 8 won't go away!!!!!
- Help me identify weird problem: Car randomly dies while driving or on startups
- timing belt question
- what would i need for this swap?
- y1 or ls tranny for boost?
- OBD0/I/II
- Please help a brotha out!
- How do I know if my tranny is lsd or not?
- good place to find JDM EF 9 front bumper
