View Full Version : Honda CRX / EF Civic (1988 - 1991)
- EF SEDAN DRUMS TO INTEGRA ROTORS
- over heating ( searched, this is CRAZY!) poor man's type R in crx HELP!
- What to do what to do?
- Cable Tranny selection?
- b16 wiring placement....
- Mini me dizzy questions (D16y8 on D15B)
- I thought you guys may wanna check this out....
- boring cylinders
- Can i use d16y8 arp head studs on my d16z6 minime swap???
- is it illegal to drive like this? bye bye hood! (not what you think) pics inside.
- how do you wire vtec
- I decided it's time to part with my Rex ,
- obd0 alternator on b18b.
- CRX Hesitation/ Code 14 IAC
- fuel pump going out on crx.... inline or intake replacement?
- Best kinda lowering kit??
- wat kind of suspension for a crx 89 si ?
- I found this hose tucked under the rear crossmember
- ECU swap.
- How many turns lock to lock in an 86 crx?
- 90-93 integra pedal assembly on crx
- brake caliper piston size
- Break Lights Not Working
- Running too rich, MAP sensor the culprit but no CEL?
- ECU Question?
- Quick Questions about stock injectors B16,b18,what about dseries
- 86 CRX HF Gas tank
- head gasket seaping
- Help me make my car legal, tail light question
- ARP head studs
- Check Engine Light on After Header Installation
- Building a DX "Plus" have ECU questions
- coilovers??????????????????
- quick question
- piston-valve interference???
- 90 civic with 2000 ls spindles
- clutch issues: Should I be able to do this?
- 4x114.3 conversion-front hub assembly
- Gen1 CRX goodies on their way!!
- dizzy issues, rotor...
- H22 into my 90 civic dx need a link for good instructions and details on swap
- I bout a 99 b16 for my ef would a b17 gsr tranny work
- Main Relay.. Is there a way to hardwire?
- installed tractionbar/cross member car pulls to the left now?
- Front brake caliper problem
- MPFI swap using SOHC ZC head and intake...differences?
- CRX giveaway
- anything major to change at 150k miles??
- boring throttle body
- OBD0 w/ OBD2 Distributor and Alternator
- Misfiring B16 Problems
- 1987 carburated crx - smokes like a champ - swappable?
- Wheels
- Is there a way to tell the difference between 88 tranny and 89-91??
- can you ise a d series shifter with hasport shift linkage?
- Subwoofer in spare tire compartment
- Would like some opinions on these rims...
- battery question
- For thoes with a SiR frount end.
- y8 intake on a DOHC ZC
- eagle rods
- Are all D series DC headers interchangeable?
- s2000 gauges in a 91 hatch
- what is oversteer and understeer
- which is JDM
- d16a1 pistons
- undecided about selling rex?
- what sway bar
- wings west front bumper
- Tranny/Clutch alignment
- anyone have a black CRX with black GT3's and a polished lip?
- how much should i sell my crx for????????????
- HKS Sport Civic vs CRX Cat-Back
- passanger window glass
- Please help with a part # for a distributor?? TD-45U what application??
- Need help. Fog lights, factory wiring harness. Pics inside.
- 91 crx si with b16 distributor help
- OEM Corner Panels for a 88 CRX
- Adjusting ignition timing, no need to jumper anything right?
- EF HATCH WONT START
- Is the B18B 94-95 (LS) obd0 or obd1
- Help me save my REX =(
- D series Turbo Intercooler, too big?
- CRX Engine swap questions
- b16a, fuel problem I am running lean, is there anyway of fixing this, threw code 23 knock..
- b16a, fuel problem what is the stock fpr post to be at?
- this is my new toy. yay
- quick Q about lights
- what block
- Question with interior on a rex and ef hatch
- GEAR SPEED TRANNY how much did you pay for yours?
- CRX Wiring Problem
- wat size rims
- Headlight questions
- D15A3 stock head , what do you have on yours?
- EA CRX fenders on EA hatch...help please
- mini me swap?
- What booster/mbc with legend dual piston calipers
- switched rear control arms 88si -> 91dx (need help)
- a6/y8 hybrid OR d16z6
- D16Z6 Piston pics
- d15 cylinder head very hard to turn, timing always off
- Do they make an obd0 gsr?
- fuel mileage of DPFI engines
- wat kinda axels should i use
- 5g coupe front bumper on 5g sedan
- Pulling tranny
- d-series frankenstein swap
- How do i tell if my block is obd0?
- What internals should i use in my b18a1 block?
- carbon fiber sheets
- tranny grinding in b16a swapd si
- What axles can i use for my ls b18a1 swap into my 90 civic dx?
- Anyone know if it matters what splash guards to get??
- need help wiring temp gauge
- B16 mounts way to big WTF!!!
- NEED 87 CRX CF hood
- Temp Gauge stuck
- Can I use this oil in a SI tranny?
- JDM Cluster Help!!!
- CRX 88 harness problem
- 0bd0 HF manifold trying to WIRE Y8 manifold
- So i got this question about vtec thats been buggin me, check it.
- WHICH BUSHINGS TO BUY?
- CRX Si (D16A6) order for tightening bolts holding crank housing?
- Car overheats, returns to normal when heat is turned on
- 90 CRX Si Axel question?
- civic sunroof swap?
- Fuel pressure problems
- si tranny on zc
- obd0-obd1
- new to honda-tec
- code 20
- OBD0 Integra engine harness work for mpfi swap??
- tuning turbo edit
- next step
- Mini-Me Swap...
- Car starting problems.
- swap question
- DOHC Conversion
- VYNL 91 HATCH FRONT SEATS BLUE IN COLOR
- MY CAR ISN'T RUNNING RIGHT.
- To bondo or not to bondo
- Looking for JDM ef9 doors
- timing problems?
- Question bout engines...
- FRied my Brake lines
- wiring
- my little delima
- how high should i rev
- Window Visors for Sedan
- Need some TQ specs............
- usdm hood on jdm front end?!?
- Are 88-91 Crx stock springs the same?
- will a 88-89 front bumper fit a 91 hatch
- the order Busted Timing belt on B16...Please help
- another question......
- New old civic from Italy
- difficult to do a k20 swap
- b18a or b18b, need advice
- Rear engine mount bracket won't fit back on...
- You think rexs and rust are bad
- gsr vs. ls/vtech can anyone help me decide??
- vtec ?
- do crx linkages fit in 91 dx hatch?
- will a d16a1 head work on a d15 block?
- New Here, Could use some help
- How/Where did you mounts your hood pins?
- ZC swap intake question
- what wire is for the seatbelt indicator?
- wiring differences b16 to ls?
- Lets see some wheel gaps
- i need advice
- are civic/integra shift boots the same?
- Stock EF braking distances
- Will it hit, Rub?
- ef gurus please help me out!!!!!!
- Passenger Side Seat belt beeping how do i disable it?
- How to adjust hood release?
- ignition timing off?
- 4.7 or 4.9 Final Drive for 91 Si D-series transmission
- sunroof leaking what to do
- Who does not use the inner fender lining?
- obd1 harnes onto y8 manifold
- turbo edit
- Looking for a first crx, what do you guyys think about this one?
- Code 16 Fuel Injector problem
- Anyone ridin on +35 offset JDM RIMS?????
- intake options
- CRX gauges cluster help in need??
- b16a crank pully key??
- b18b VS. b18a
- B16 install?
- DA6 XSI Wheels
- crx centrifugal advance doesnt advance
- ac stuff
- ac stuff
- B16/mpfi swap runs rich and wont pass emissions
- Dash Electrical Problem - Need Help!
- catalytic converter question
- Itr eater- This is it. What do you think?
- Fuel Rail Question
- msd ?
- Crx obd0-obd2 Alternator plug conversion questions.
- D series bearings
- Tons of Coolant Drained out of Oil Pan!!! Is this really bad?
- Clutch still slipping!
- 225/50-16 too big for a crx?
- oil press gauge install help please
- injector resistance?
- +55 offset 07 Fit HFP rims fit my rex????
- exhuast issues
- repainting my car
- Spare tire well has water in it....
- help please
- Guys I Need Some Help. . . . . .
- conflicting answers on B-Series swap
- ef traction bar
- honda wiring harness connectors?
- ECU on the ef's
- engine harness-this plug use? do i use this one?? ahh
- my $1300 EF hatch
- oil pan issues
- uca
- How much could i get for my Ride
- My new toy...89 Civic Si
- help me figure out what i have?
- HELP! MPFI swap in or near Charleston/S'ville SC...
- Need help
- Vtec Sound.
- integra axles in ef??
- i need help!!
- CRX brakes the same as 92-95's?
- breaking loose crank shaft pulley
- d15b
- any other guage clusters that are cable speedo?
- Rear Disk Brake Conversion Question*****
- how much can i sell it for ?
- key stuck in the ignition system NEED HELP URGENT
- Ls head torque spec
- b16 exhaust
- what color for a civic
- what do you think
- brake lights
- has anyone got work done at revolt
- Looking for a place in the Northeast that can tune my vehicle?? Anyone know of one?
- Exhaust help
- need help locating fuel pump relay, on crx!!!!!!!!!!
- What do you think this smoke is from *VID*
- Stock suspension differences across civic/crx trims
