View Full Version : Honda CRX / EF Civic (1988 - 1991)
- I need a sunroof
- ZC 1.6L SOHC non-VTEC
- Missfire/Backfire on Decel
- Crvtec Oh yes another crv/ls vtec Q thread
- no fuel injection....???
- b18a1 crx cel code 43 !!!!help!!!
- 89HF Map sensor question?? B16 Swap
- code 13
- seats
- high rpm
- 91 CRX SI Not Starting
- whats a good tire size for 14" wheel?
- overheating problem 91 civic Si
- Code 4 - Worth Fixing? Affect Performance?
- 91 civic dx......b18b1 swap
- 91 si seats in my 90 DX
- dpfi to mpfi question
- block help
- CRX Shifter console into STD?
- missing piece?
- Where can i find this?
- reverse lights don't work
- 98 ITR in 88 CRX
- 90-93 hubs and knuckles
- SOHC OBDO ecu question
- info on installing a b18c into a 90-91 crx
- I need some help:(
- stock stereo
- Advice on mounting seats to the floor.
- SADDEST THING I EVER SEEN!!!!!
- Broken bolt, its pissing me off
- Fed up with non DIY.
- Which year header
- 90 dx sedan - running 91si ecu obd0 - no vtec .. got 2 questions
- Preventing rust before it can happen
- paint codes.
- when i turn hard, like sharp turn at 20 mph i hear some metal scraping
- new to forum, a few questions
- motor mount inserts
- pic request tahitian green crx with amber corner and bumper lights
- Car wont start SOMETIMES, and died on me today
- mpfi conversion question - easy
- Distributor question!!!
- Back in the Game : Turbo edit advice needed
- aftermarket crank pulley worth it?
- how do u remove tar off floors help
- 2006 civic engine question
- What VSS for a b16a in a CRX?!?!?!?!?
- Leaking CRX hatch, what to do?
- news cams
- SOHC ZC...whp??
- ethanol..............damaging?
- computer chip
- d16z6 problem any input?
- AC not working
- A/C Removal
- Randy Gagan CRX - Love Ya. Won't Forget Ya.
- ? on unpluged sensor...what is it?91 Si
- question?
- need help on desiding color on my civic hb
- CRX front on a 91 CIVIC hatch
- Carbon fiber hood?
- question about white smoke
- head gasket question on d16a6
- head is on, now for timing.
- intake question for smog
- xenoncron chipping?
- turbo line on b16
- Whats up with my brakes!?
- swap help
- searched , started to have idle prob's , help asap !
- main relay but now no sparks????
- all my lights flicker constantlY! car shuts off randomly!
- I am new here.. CRX Si Turbo
- swap in 90 civic hb
- Help! B16 swap throwing code
- DC2 GSR Brake swap onto ef.
- zc tranny question????
- im not the best with wiring.. can i get some help
- afc2 trouble
- SOHC V-TECH TURBO SWAP
- wiring issues....
- zc headlights
- Strange water leak, what is causing this
- Running rough
- buying a new project car
- ZC to B16 wiring? what else is needed?
- ECU question, rough idle and flooding
- weird idle
- sohc convert to dohc?
- crx exhaust
- Putting lower springs on KYBs...
- SOHC ZC Spark Plug Gap?
- DAMN!!!!!!!!!!
- does any one know
- turbo vacuum diagram/pictures
- Which Alternator belt?
- test pipe install help!!!
- 1989 Honda Civic DX Series of Problem
- Something is wrong!!!!
- weird noise on tire
- b16a timing
- Turbo d16
- What exhaust....
- got a seat problem
- my gas gauge aint werkin?
- Clocking upper control arm bushings? Have you done it?
- Timing Gremlins (SOHC VTEC)
- y8 head swap
- tps
- proportion valve compatability between series
- Can I easily get 250HP out of a greddy Kit. DOHC ZC.
- Question for the auto body gurus
- engine problem need a answer
- spool valve oil leak
- Bosal Headers
- ITR Calipers - ITR Rotors??
- honda ballade
- LS b18a1 stock fuel pressure question
- A/C system
- ok so heres the deal
- Quickswap question
- *sometimes* start car , and a "wobble" noise after ?
- Map Sensor Wiring - Which Is 5V/Reference/Ground?? quick n easy
- About to buy these!! Part 2...
- Legend Brakes
- Dumb Question????
- D16 crank bearing colors
- For Sale 1989 Honda Crx Si BOOSTED!!!!
- NEed electrical help
- Gas Saving Article - REALLY GOOD!!
- Gas gauge
- what cams??
- Struts...???
- HELP! with a rollcage
- need help installing jdm power folding mirrors (CRX)
- 99-00 front end EF, yeah EF!
- sedan gas tank
- Will these slicks fit on a 13" steelie?
- ZC or Z6?????
- 90 civic dx with blown motor will 94 lx fit???
- crx
- anyone with a b20/vtec crx? in here
- B series cable transmission gurus needed
- Hood latch question
- 96 civic axle fit 89 crx si
- cel code 23?
- Clutch qustion.
- axle
- Pic and location of B16 knock sensor?
- Thinking about changing my color on my REX what do you guy think?
- one-wire vtec/ac clutch fan relay
- Jdm EF8 1 Piece Civic Headlights fit EF8 Crx?
- HELP HELP HELP
- 88-91 civics related to integra?
- car overheating bad! HELP!!
- wtf. just found out that the 88 and the 89-91 has two different moldings.
- coolant leak?
- Dpfi to Mpfi dizzy wiring!!
- I heart my EF stickers?
- have you had door hinge problems on your ef/ed?
- 2.5 Bar Install - Car Wont Idle/Run *NEED HELP*
- 88-91 sedan back seat swap?
- 89 CRX with Newspeed race springs
- sputter at open throttle
- LS's perfect ecu match
- y1 lsd transmission not going into gear
- EG lower rear tie bar. what the EF?
- Fuel Supply Problem
- Suspension question (lowering springs one side sits higher)
- Honda CRX windshield
- cluster swap
- Buying a MOTOR?
- 90-91 tails
- Mini-me swap information
- B18 swap almost done - few final questions
- msd kit not working
- HELP!!!!
- Need Help Learning How to Build Motors...
- crx w/ b18a1 help!!
- ls transmission ??????????
- Mini Me swap with a sohc zc block?
- which engine b16 or d16
- O2 sensor ?
- Need a little help
- New CRX Owner/Issues
- If you had 10k for an EF dream build what would you do?
- Can someone link me to a thread of how to convert your dx to Si.
- vtec po6
- b16 runs really rich
- 88 crx door panels fit 88 civic hatch?
- not in the where to buy section. i need carpet.
- Need some help 1.5 DX problem
- Is 60a fuse beefy enough for starter? Blew 1 already, will this be a trend?
- will 205/50/16 tires fit on my hatch?
- BROKE MY VSS
- no titled shell
- differance in 88 and 91 fenders?
- Motor 90 DX is bogging..
- Axle won't go in all the way...
- Wandering CRX....what to do?
- Another no spark question. searched.
- number of vehicles produced each year?
- Several problems...
- tranny problem...
- Blowin Smoke NEED HELP please!
- piston ring and bearing issue ...........
- Picked up a 90 CRX Dx a few pics included
- Are all B-series Rod and Main bearings the same ???
- does anyone know where to get wiring harness??
- Popping Noise in Front Suspension?????
- torque specs
- opinions on radiators?
- 89 si seats?
- my rex drives like shit
- for the experts
- need Z6 help in my hatch
- 205 fit on a 6.5"?
- gauges out except speedo
- 88-91 d series throttle body options
- sorry. mpfi swap parts?
- 500HP Axles for my EF....$489.00.......would you buy?
- SORRY
- FS crx stuff and hybrid parts.
- ITB info
- pic request
- I need help wont rev over 5
- Battery Relocation Help
- boosting on a 4 spd?
- need help finding amber bumper lights
- 97-01 itr into 91 crx dx
- Mugen spoiler VS EF8 siR spoiler
- I finished up my CRX a few weeks ago...
- zex wet kitt 100shot dohc zc
- B18 on a CRX
- backseat
- Idling problem
- need weight opinion
- Stock seats with 5 point harnesses
- sohc v-tec cams
- 90-91 civic ex 15/16 ths master cylinder and brake booster
- Anyone run in to problems with removing there ecu for security?
- oil pump need to know
- Pic Request- Clutch (pedal assembly)
- 89 civic B16 swap question
- coil-overs
- Crankshaft
- very weird electrical problem.. battery exploded
- Main relay Location 89 civic lx??
- Is this where fuel pump is on ef crx!?
