View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Best Race Engine Setup For CRX
- what intake should i use?
- I am painting my car in a month and i donno what to do leave it stock or throw a bodykit?
- What engine (B16/B18/H22) came with 2.25 header collector/donut gasket???
- new member-do me a favor...please
- The 7 Day Projekt car
- Water leak problems...
- EVERYONE LOOKING AT THE EBAY FLOOR MATS LOOK HERE
- zc distributor help!!!
- OEM steering wheel cover... what's it look like?
- jerking problem
- 1991 Honda CRX SI Dark deminishing Oil.
- Steering Assebly & Trunk Light ??
- ANY 90-91 HATCH WITH GOLD/BRONZE WHEELS & BUDDY CLUB KIT
- Great Junk Yard Find.. CRX
- sticky valve
- heat sheild
- Anyone have any comments on these guys....
- Whats involved with putting a hydro tranny in an EF?
- b16a problem
- mini-me/MPFI junkyard tools question...
- grounds on 91 crx...??
- CEL 17?
- If you're using JIMFAB Motor Mounts, post here.
- Oem fenders made in taiwan?
- 88 civic wont start when hot
- dipstick for my b16a1??
- 89 crx si with ls, wondering what its worth
- D15B VTEC Swap
- coilover ?
- i have a 88 crx hf and the hatchleaks water!!!!
- 98 civic ex complete engine with 5spd transmission and ecu for sale
- problems with my car
- carbon fiber CRX hood for sale 200$ BRAND NEW turbo scoop
- Black sooty stuff
- 1990 honda civic hatch water leak
- removing gas tank NEED HELP FAST
- What front lip looks better (Pics)
- HELP: MY VTEC IS BOGGING
- JDM Front Bumper Conv. For 88 CRX.
- b16 cry for help!!
- Very Slow Acceleration. Any Ideas?
- 16" on an ef... got pics
- New Distributor, T-Belt and Water Pump and Losing power?
- suspension question
- Wiring Help on a 94 GSR in a 88 CRX
- urgent Starter Problems
- 14' tires vs 13's
- OBD2 Single Cam Swap into an 89 lx. help?
- LSD Tranny
- help passing emissions?
- launchin
- pics of steelies, which ones look best?
- 10 lbs of Sh!t in a 5 lb bag **Hasport** K24 in EF
- PIC REQUEST: EF8 & EF9 MUFFLER
- Illegal in California to heat wrap exhaust??
- Commuter Civic - Friend to OPEC
- New motor in progress (Almost Done)!!!
- lexan windows for crx
- Please Help-Car WILL NOT RUN RIGHT
- I seriously need some help with my rex, i've tried everything and it wont start?
- TEIN S.TECH springs???good or bad???
- SAFC2 or VAFC2
- Yet ANOTHER ZC question
- B16a Change Over
- wheels
- turbo d16a6 how much boost till i blow it up
- what obd1 d-series distributer fits a sohc zc (obdo)
- modifications
- Distributor wiring Q's.
- Tein HA suspension for EF's...worth??
- Would you guys buy real jdm ef8 sir fog lights in great shape for 210??
- Rex croaked HELP!!
- which tranny ?
- need help
- water pump bolts
- does the ls dizzy fit the b16???
- im putting a vtec head on a ls block
- 89 CRX Ignition Switch / lock tumbler
- B16a PRICE
- just installed air/fuel gauge and now get check engine light
- im F'in pissed....
- passenger side frame rail mount, need help asap.....
- MINI ME MINI YOU
- a 96 civic rad
- clicking problem
- If You're Using a JIMFAB product, post here.
- h22f motor?
- Crankshaft question.........
- tranny question
- exhuast ????
- Help! Oil and smoke from my downpipe
- ANY ONE KNOWS tiggscrx.... AKA JONATHAN...
- anyone got pics of half rads in crx's ??
- Shop might have switched ECU!! How can i prove it?
- Jello CRX 1.6-I16
- 88-89 rear end
- loud clicking noise, anybody know what it could be?
- transmission seal question
- shifter falls out of car
- main relay problem common? same as EG's ?
- Great offer Look HERE!!!
- I hate that f*cking sound!!!
- help installing inline fuel pump
- Advantages : DPFI to MPFI?
- weird prob with civic
- Where to buy Engine damper for CRX 88-91???
- head on a DOHC zc block?
- b16a original harness
- [Searched] Shaking wheel when braking..new rotors..
- H22 swap
- ITR intake mani on b16?
- coil overs................
- purchase b16
- any rewiring necesary to put UKDM Vtec cluster in 91 CRX SI?
- COuple of ?'s d16z6/d16a6 swap
- 92-95 camber kit - will it fit 90-91 hatch?
- will this fit...?
- what is the biggest shot of nos(dry) i could go on a stock ls motor!!!!! hit me back
- Be all, End all to Integra Knuckle conversion. If you've got an alignment print out, please post!
- wierd papers
- Windshield Washer Jet tubes?
- hybrid seats in 91 si
- Duall over head cam heads on D motors and ZC motors?
- Best suspension setup
- AM Radio Reception
- Help H22 into a 90 CRX
- i am getting a perform shift light ...so
- Chargespeed lips for 88-89 Civic USDM!!!
- HF is killing the third battery in under 2 weeks
- Odd question about jdm ef9 front end
- 1983 Civic Information
- DX TRANNY
- second gen zc swap
- 88-91 civic 4dr door caps
- PR3 B18C vtec problem
- Friend's Car Stolen :(
- good deal? need your advice.
- what are these called?
- Block guards
- Transmission!
- integra seats into 90-91 hatch..?
- auto Si?
- zc mounts for an 87 crx si?
- D15b2 oil pan on SOHC ZC???
- 91 dx hatch wont start.why?
- Flywheel cover....
- Getting back into EF's - possibly with a CRX
- Rear rubbing and vibration
- 90 CRX with dohc ZC swap not starting
- Aftermarket guage sending unit ?'s
- CRX ESSENTIALS HELP
- Rear disc conversion
- hey
- h22 swap in 91 rex----already seacher and looked at 2point2s thread..answer not found.
- Questions and tips on B18 CRX swap
- CRX Shop???
- couple of weeksDPFI to MPFI ECU's
- B16 Question - Used Search - Could Not Find
- Problem with installing the turning lights
- Nitrous on stock motor, how much?
- Replaced Battery And Car Won't Crank..........Help!
- TPS help
- full-race traction bar roxors my soxors
- Another awnswer for "what is the best engine for my crx?"
- need p28
- Wheel Fitting size
- LIGHTS
- crx vtech relay help
- carbon fiber lip for a crx?
- need to pass smog
- intake backfire
- what cam do i put in my tdo4h boosted crx
- EF to EG ECU change over harness?
- Where can i find a cheap CRX HF Cat?
- I need a smaller radiator...
- computer problems
- USDM engine question
- what JDM motor put on my crx ???
- tranny/press plate/disc/flywheel question(s)
- need help
- compression
- People in the Toronto (416) area, might want to check this out.
- Gauge Cluster is alivE!
- Most you would spend on a CRX?
- B16 swap into 90 crx
- Filling a Y1 tranny with fluid...
- 90-91 Civic Guage Cluster Question
- 91 hatch with b18b1
- crx help needed
- have a 91 bumper on an 88...which head/corner lights?
- 1989 Honda CRX HF
- 3X SiR
- EF Hatch Appearence in GTA: San Andreas?
- Y8 MINI ME IS COMPLETE!!!
- Code 22 VTEC Oil Pressure Switch B18C P72
- Difference between canadian crx and usdm crx
- How To: Fix leaking CRX roof/hatch *pics*
- crx b16 trouble!!!
- need a chassie diagram. does anyone have one for the sir and si?
- ES bushing kit come with these??
- zc info need help!!!
- help with civic plz........:(
- help with d16z6 swap
- 88 crx ls swap
- Dumb gauge cluster question....
- Cams
- Full JDM B16Swap for sale.
- cluster questions HELP!!!!!
- i changed a hydro. clutch in my 92 hatch. i drove it for a day and it seem cool. the next day as i w
- ZC in a 85 CRX SI
- which new distributor to buy for pr3 ecu?
- tenzo-R harness
- swap problem need help asap
- Can I put a 90-91 LX gauge cluster into my 89 DX 4 DOOR? HOW?
- strange starting problem plz read
- argh... freakin gay tune shop... be warned...
- did a 5speed swap on std hatch. now car wont crank. what could be wrong?
- My CRX
- help a newb out with rebuilding engine
- front cross member
- V8 RWD CRX (believe it)
- ok d series swap question...
- How easy are they to work on? 87 CRX si
- Throttle Position Sensor- TPS. How do i set it?
- b18c swap?
- rear disk brakes
- 88 hf question
- 88 dx problem help!
- Real JDM or not?
- Crx Hybrid Set-ups
- Leaky taillights
- DIrty oil after oil change
- reverse lights not working on 1991 Civic
- Hwy driving pictures
- CRX Snow Tires/Wheels Question...
- need help w/ jdm d15b
- Need help...cant find body parts
- :::Floor Mats:::
- IACV Problems
- B16xxx or B18xxx for a 1991 Honda CRX Si?
- every ef fav. season is approaching winter....
- i need a 90-91 civic four door, 5 spd
- Jammed Hood Latch - Need Help Quick!
- All you 15'' wheel people enter!
- CRX 2010
- Transmission Problems
- Need info on LS Swaps in EF9's =)
- Taillights........
- b16 abused build it back or leave it alone ?
