View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Mini-Me OBD question...
- question about iacv problem when swapping y8 manifold on a6
- vtec on valve cover...
- Holy Oil Burnage
- Axle problem for 1991 civic SiR (EDM civic with b16a in it from the factory)
- any solutions to rust?
- lower balljoint question
- hydraulic tranny in crx?
- one piece headlights on crx
- need your guys help/opinion....
- weird knocking sound while driving! pleast help!
- Quick question about crx and hatchback!!!!!!!!!!!!!!
- A good link or post on swapping crx mpfi manifold to d16y8 manifold?
- Did I receive the correct steering tie rod??
- ......INFO PLS---->EF9 CAGE IN A CRX
- old skool... what wheels r these?
- fuel level gauge ?
- What flywheel should i get for my crx with si tranny and d16y7 block?
- speed limiter on pr4?
- The OEM specifications for the D16z6 valve gap
- type r Lsd
- down size??? (b20 to b18c1)
- 89 crx-b16a2- idle problems.
- coil overs poly bushing question
- Bumper question
- jdm sir headlights
- SOHC Upgrade ideas.
- Messed up gauge cluster goin whack!!? help!
- 95 b18c1 into 91 standard hatch with zc
- couple swap questions b16a2 to b18c5
- crx intercooler fitment
- strange thunking noise, help asap
- my crx
- weird honda tech???
- tourque specs on intake manifold
- what are good tires to use for autocross?
- Show or Speed first 1990 hatch si
- 1992 honda civic hatchback dx
- b16 camshaft in a ZC Doch engine
- 91 civic dx ???
- wipers b messed up
- Need gauge cluster!!!!!!!!!!
- EX 4 door tranny gear ratio's and final drive????
- WIRING AN ls/Vtec
- tach, gas, temp gauge stopped workin..HELP PLEASE!
- What plug is this for?
- WTH, heater has 1 speed
- oil leaking from cam?
- 3 door civic to 4door civic engine swap Doable??? (read on)
- Wierd problems with a b16 into CRX. Any help here?
- JDM taillights for '91 Sedan? Pics requested...
- Relocating Charcoal canister?
- cable y1 dif. bearings? (LSD install)
- shift linkage--Ls hatch/integra diference
- engine wont turn over
- Common symptoms of high idle (d16Z6/D16a6) mini me? You tell me..
- parts i need for SOHC
- Anyone know here to find these zip ties...
- tps troubles (searched)
- HELP b16 swap
- deep dish rims?
- Cheap Ebay wheel hubs
- Can a D15B2 beat a F22A??
- air/fuel ratio and volts gages
- damaged mount on Si dash
- engine check light
- who makes the best manuals
- help with smog "test only" air box issues too
- Need multipoint swap diograms for wiring harness
- WHat kind of engine is in my CRX. PICS INSIDE.
- speedometer cable
- fog lamp
- picture of D16??
- which way to turn crank pulley bolt when removing crank pulley?
- valves tapping cause oil burn?
- 91 civic hatch passngr mirror fir 4 dr sedan?
- ls tranny?
- fuel pump volume question
- what to do with the CRX center light
- tail light/reverse/blinker electrical prob.
- DO YOU HAVE A FAST SOHC?
- CRX Convertible? Gross
- Si tranny tranny question??
- question about turning.
- 2nd gen civic that will amaze
- Exhaust length differences
- Where could I…….
- how do i tell if the intake i bought is a z6 intake?
- B18A1 into an 89 crx si (searched already)
- b16 annoying idling problem
- 88-91 crx or civic motor swap, swap from an 90 integra
- how can you tell if your car is overheating if the temp gauge is broken
- CRX for a...CRX!?
- Used B8 bl/Red as C1...
- 1.5 with d16 intake head &ecu?
- Finished b16 swap, wont start,.
- Few Quick Questions
- EDM (european) valve cover restoration ? (with pics)
- Original Mugen Pro2 kit instruction scans ?
- B18C4 help neede badly... come on guys....
- Mini-me Project
- better handling suggestions
- Just got the bottle for my car!!!!!!
- 84 CRX Swaps
- what the hell is this code.
- d15b with d16 intake, headers and tranny....
- Interior Lighting fuses...
- Making 90-91 CRX SiR leather seats fit a 91 Civic HB
- Throttle body questions (did a search, no results)
- buddyclub stage3 cams
- should I....
- charcoal canister removed??? vaccum lines
- DA frontend on my 90 EF9
- Break problem...
- How do you tweak your engine?
- OBX Differential install w/ no shim - problems in the long run?
- OBD-0 distributor in D16Z6
- ZC engines cams stage 2 and stage 4
- RC 370 injector in a ZC doch engine
- b16b1 type r pistons in to a ZC doch engine
- How do you remove dizzy wires on a 91 si?
- 96' tails
- jdm b16 88-91 help
- Mugen m7's - taking apart?
- hatch vs. hatch vs. coupe
- looking for parts
- sohc zc which check valve is to be used for turbo application?
- what is the compression ratio of a sohc zc?
- Anyone running a S1/J1 trans or Y1 or GSR trans?
- D15B Engine (I've Searched)
- timing belt question
- Need help with my n.o.s bottle
- Making an OBD0 to OBD1 harness....
- cf lip for 91 civic hb?
- d16z6 experience
- How much longer are extended studs than stock studs?
- shocks for hatch
- relocating fuse box,map sensor,etc..searched but?
- what does your mini-me idle at?
- Pulled a 14.79 again!
- So I blew my head gasket...now what...
- please help car died
- With a wrecked 94+ Integra, what can I put in my Hatch?
- wanted / looking for seat belt for CRX SI
- short shifter question
- Need help on tranny ??
- B series EF's (Tranny removal ?)
- b16 seems to be misfiring
- NEW BRAKE SETUP!!!
- Crx Updates.
- those with password:jdm cf lips
- Play in wheel bearings...
- 88 CRX Drive Axle Problem!
- starting problem....pleeeease help
- Need some help on a d15b2...grinding noise coming from tranny
- CR-X SIR bumper
- a6 block, zc pistons, y8 head, is this combo worth it??
- What year motor and also tranny
- where to find a pillar pod?
- All boosted EF's. What guages are you using?
- Anybody have any good.....
- 91 std hb rear disc conversion
- 93 LS motor in DX CRX, engine harness
- B16 pistons in a ZC
- no spark can't figure out why, checked everything please help
- AIR COMPRESSOR
- Oil Sprayers In a Dart Block with LS Crank
- all motor question
- B18a $$$$$
- Enter if you brake rotors don't rust IE: zinc coated or anything else...
- wich is better B16a1 or a DOHC ZC motor?
- 1990 CRX si SPEEDOMETER CABLE
- I have oem interior and stock 13in BBS wheels and cash looking to get rid of
- ECU pinout locations
- what to do with my engine?
- idle issue with my rex
- b16a1 tranny rebuild
- EF Si bolt-on exhausts.
- what should i look at first?
- Si fuel injectors in my dx rex?
- ls/vtec questons
- a6 running rich
- Color coded ECU pinout
- Fuel Starvation Question....
- Engine revs
- 1st attempt at swap
- over heating problem.....
- accord brake calipers
- 2006 CRX!!!!!!!!!
- 90 crx Si w/b16 14.4@95mph
- Buying a rex (need advice)
- body kits/coilovers/carbonfiber hoods for sale -all imports
- how strong are the stock axles??
- CRX Gas Tank on a 90 Civic HB Will it Fit???
- ecu troubles... 99-00 si ecu in a 4th gen civic, any clue????
- new on board just got 90 si need some power any input??
- zc vs. d16z6
- shock ???
- *** what kinda numbers am i looking @ with my "85" rex?***
- Head Gasket??which one??
- special kind of exhaust
- injectors not spraying, HELP!!!!
- A little CRX clutch funny business?
- wiring problems
- PM5 ?
- Best way of painting rims, non ready in a pepboy can style.
- My luck strikes again.... Broken bolt, pics inside.
- need help on throttle body install
- Can I use an EG flywheel with 90-91 Civic Si cable tranny???
- The possibilities are endless....
- exhaust question..
- empty cat
- 1992-2000 greddy intercooler on 1991 civic?
- will a d series greddy bolt up to a sohc zc?
- Konig Next on ebay...
- going to get parts for my hatch sat and have qs
- which would pull harder
- center console for my 89 hatch
- Buying a 1991 civic si tommarow for 200 bucks...
- crx ventvisor
- noob has q's
- 1988 Crx Si + Hx Rims + 90-93 DA front/back brake conversion ?
- 1988 CRX Si.......
- crx with S2K cluster
- 1988 CRX Si Engine Swap: B20 with B16 VTEC Head vs B18 w/ B16 VTEC Head
- Getting spark, but doesnt start
- SEARCHED! D16 into car that had B16...
- ive searched what clutch cable will work in my b16 hatch
- best way??????
- Hydraulic Transmission in EF...
- different power range CRX
- need help jdm D15b run problems
- car paintedi'm getting my car painted!!!
- need part # for distributor
- Corrosion on valve cover
- CRX HF oil pump compatibility.....
- b16a won't start and I'm getting pretty frustrated, someone help??
- Any engine suppliers sell transmissions alone?
- Zc head on a 1.6 ????
- Don't know what the problem is...
- SMOG ISSUES
- Distributor Lead Identification
- LOOK AT THIS !!!!
- My Car screams/squeals and vibrates when the A/C is on
- what is the best A6 bottom-end build up??
- ALB Light on JDM EF8 cluster. *SEARCHED!*
- Qs about Codes
- crx si gauge cluster w/ odo for sale
- A little CRX Easter Egg
- EF hatch 89-91 Hood same as Crx hood 89-91???
