View Full Version : Honda CRX / EF Civic (1988 - 1991)
- My Coilover Experiences
- What Repair Manual?
- anybody else ever do this
- My really slow CRX DX build.
- car starts rough with PM7
- D16A6
- car cranks, sparks, fuel flows, but will not start
- Diamond Racing Wheels...Need help!!
- '91 civic dx main relay...help?
- No spark after changing the ignition. Please help!
- wat cluster othere than a dc2 teg can u swap in to 88 crx
- A different kind of beast
- Which bushing?
- 91 ef civic
- 90 DX' Auto Rebirth List
- 4g prelude resistor box same as d16a6?
- Installing hood pins on ALL 4 corners.
- 1988 civic has no spark
- for a B16 swap into a 89 CRX, do i REALLY have to hammer into the shock tower?
- Which clutch to use
- Is my ZC basically a D16A6?
- Wtf!? Axle help needed!!! Please Help!
- 91 SI d16a6 problems
- will d15 ac comp. fit ls?
- Code 4 and no spark...help!
- Driver window rolls up crooked on '90 DX hatch.
- FMIC.... need to cut bumper support... what tool?
- Need help for torque specs for mounting block to tranny
- No start after MPFI swap, code 15/20, good spark and fuel, cranks
- will the ecu from an 88 prelude si work?
- Skunk2 front Strut Bar 522-05-0840
- dead '91 civic dx hatchback- please help
- 88-91 hood raise look
- Recharged my A/C with Freeze-12
- Need some parts for my build 91 crx
- What axles to use on 88 EF 4door SOHC ZC?
- EF2 specs
- Project Auto-X 91 hatch
- 91 crx si, in dire need of tuning info
- D15b2 TPS replacement
- Sunroof help
- ef
- AMR Coilovers wont go lower?
- Paint matching for beater?
- Seized D15B7 motor or auto trans..??
- Check Engine Light But No Code
- about to perform JDM front end conversion...
- Tune help!!
- CRX studders while accelerating & cruising
- 91 civic siR axle replacement, which ones?
- problems with gsr cluster in 91 lx
- A/C Compressor Noise....
- CRX B16A CODE 21
- Strange power issue.
- fuel injector wiring
- Crank pulley bolt tricks
- Engine Question
- d16y7 into 88 wagon. dpfi to mpfi help
- quick question
- D15B2 valves/pistons drilled 2 big?
- Need advice on checking a motor before purchase
- Where can I get an engine?
- 90 crx si brakes stuck
- normal to smell like gas around car after driving it ?
- questions about plastic covering inside of door panel ?
- What ECU do I need for 90 CRX with B16A2
- y8 head on a b7 block help
- CRX B series issue
- Jun pm6 ebay chip?
- 91 civic timing
- have a frankinstien swap 89 ef need wire harness help.
- sputtering.
- injector problems
- Need help finding header and cat converter...
- dizzy plugs
- Removing crank pulley bolt on d16a6.
- Wierd engine stall
- too much +toe after rear disc swap :(
- 90 civic Si de-rice build thread/ daily driver
- ITR rear seats in an 88 crx?
- can you identify these lower control arms? because i cant.
- Quick Ratio Steering Rack?
- What's the average build time for a CRX, B-Series harness from Chaseabays?
- Urgent - No start code 16
- brake setup for 90 CRX
- Converting hydraulic tranny to cable tranny
- anyone have info n this ef2 sedan?????
- Advice for camber kits
- Which brake lines to buy
- Need help MPFI car starts but low idle
- WHINING sound
- worth fixing up?
- compression check D16a6
- CIVIC SiR BUMPER FOGLIGHTS SIZE...
- both axle replacement
- 68mm Throttle Body TPS HELP!!! B18a/blox intake
- GW trans? help!
- Rusty Gas Tank
- Please identify this part - rear washer - picture included
- Low Offset Wheels on an EF
- Transmission noise
- Right headlight leaking.
- Side and rear hatch window trim removal
- Auto Aircon fuse?
- mpfi swap problem code 04 poping up.
- 1991 Honda Wagon AWD engine
- b16a to b18c1?
- Suspension bushing kit for hatch?
- stupid idol problems suck =[
- D16A6 In DPFI CRX With D15B Intake manifold?
- Anyone have pictures of SIR EF8/9 rear tail lights compared to USDM version?
- whats with rusting your hoods?
- ballast stay on drawing power
- need a hood
- Daytime running light relay bypass?
- is my compressor locked up?
- Is Honda MTF fluid is okay to use on worn out tranny
- are new vlaves required for blox type b cams in b16
- Code problems
- Tmfw's 1989 Si touge build
- my rpms are stuck at 2k rpm HELP ASAP!!!!!
- How to remove breather chamber or pcv box
- b16 air leak question.
- Just picked up this new to me 91 crx si
- No reverse lights. Bulbs good, switch good, what next?
- Need your advice about coilovers
- D15 Cam??
- 91 si hatch with a zc good buy>?
- removing rear side popout windows
- seatbelt alarm
- blown cv joints, diff, or wheel bearings?
- parts list?
- big brakes on dx knuckle question
- fuel pump doesnt kick on, and my ecu light doesnt turn on...HELP lol
- DTK-Garage EF Hatch Build little by little
- ANOTHER Carbon Fiber Sunroof Thread... :)
- 91 Civic Wagon AWD
- My neighbor killed my ride!
- New from High Point, NC!
- Lowered my CRX today.
- anyone with a 90-91 help
- cel jumper not registering!
- why wont my fuel gauge work!?
- mini me ecu and dizzy?
- *HELP* Cursed EF
- 1989 Honda Civic Si/Best motor?/Your opinion will be appreciated!
- HELP! Oil in intake
- is it normal for a window regulator to be like this ??
- Dizzy Questions
- Machine Shop??
- help - window popping off track, . . . i took door panel off to inspect the parts
- engine bay cleanup
- EF died wont start no spark CEL dont work
- BC Spec 2, bolt to stock D16A6 Header/Cat setup?
- 89 ef9 si project need help!!
- Quick question on cleaning your IACV
- Just replaced A/C Compressor: Worked fine for 2 days, now does not blow cold
- Spoon vtec controller work with d16z6?
- paint job suggestions for crx
- EF/CRX with non-vtec B series.....
- Tps sensor went bad
- 88 ef hatch wont start
- 1988 Civic sedan build
- bad distributor?
- Pic request! beaks lower tie bar
- need actual electronic vss wiring info
- turning a 90 std into a 90 si. is it possible?
- brake booster check valve
- best motor for 90dx hatch w-o modding
- transmission help
- GSR OBD1 into 90 DX Hatch swap help
- rear lower control arm question
- Gsr water pump On LS>help
- OBD2 Dizzy wiring into an OBD0 engine harness.
- Will this fit or is it compatible? (ENGINE QUESTIONS)
- axle q
- My First Car: 1990 Civic DX (PROJECT)
- thinking of putting my Ls/vtec into an ef
- 89 Civic failed emissions question
- need help with this mini swap into a 89 dx hatch
- huge wtf with my swap? video inside
- 1991 HONDA OF CANADA DX HATCHBACK
- fuel pump question
- d16z6 help
- b16a2 swap in ef (POST SWAP) questions
- help with wiring
- D16z6 Swaped Crx!
- 4th gen prelude center console/arm rest in crx
- Fork in the road towards a 89 z6 swap
- Hey thats 24 volts that's NOT ok!
- starts and dies witthin half second
- Obd1 conversion runs terrible
- Pictures of Cooling fan and hookups?
- Problems with d16zc
- h22a crx
- 88 crx si harness on 91 civic dx hatch
- Problems with front strut bar on 91 hatch
- EF hatch b16 newb build!!
- help please!
- My EF is due for a Rebuild.
- 89 civic crx b16a2 na
- Injectors leaking MPFI swap
- flipkc's 91' Civic Si Project
- Touch up suggestions for CR-X SI
- Is there any way to get a good rattle can paint job?
- help with my zc engine asap
- cluster light
- a20 in a 89 dx
- 90 civic too many problems
- Vibration In Front End
- Automatic Ignition switch Lock
- EF or EG Buddy Club Spec 2 Exhaust? Need help identifying
- D16A6 Timing Diagrams
- Trouble starting car after it sits for a day, fuel pressure issue?
- MT CRX Build and Swap
- just won 10000 this weekend at casino
- 89 civic wagon help
- Problem with EK knuckles on 91 CRX HF
- temp gauge?
- Alternate Trannies for '90 CRX Si?
- My take on "Cupholders"
- b16a no spark in ef
- My Y49 build, all motor SOHC autoX fun!
- A6/Z6 mini me swap problems
- need help
- distributor trouble
- rounded off allen head
- windshield wiper problem
- Need help choosing engine.
- timing, advance, power issue
- C rex keeps dying at idle.. NEED HELP!
- D16a6 issue
- best single cam engine in a 91 hatch
- MPFI HELP PLZ (resistor box)
- Shelbyz4u2nv's Build Thread: NH-536M 1991 CRX Si
- civic battery light stays on...
- Need to redo SI seats.
- no spark until turn key back to off, then one
- A6 y8 MINI ME Questions
- Found a bone stock 91' CRX Si
- Mr Civic's EF
- What would i need to do a b20b swap on an ef hatch?
- Gauge problems
- hello all
- d15b2/d16a6 head
- 90 civic b16 HELP!!!!!!!!!!!!!!!!
- dizzy pinout
- B16 si swap into old school hatch
- Engine degreaser issues......
- Water leak in 91 hatch
