View Full Version : Honda CRX / EF Civic (1988 - 1991)
- how hard to get b16 ef in 13's?
- OBD0 to OBDI Wiring harness, no wire for the cooling fan?
- Richmond, VA. meet...10/5
- Resetting ECU - Advice
- ANY CRX Owners in the Orlando,FL area please write back
- Looking for JDM Tail Lights for an 88 CRX
- Need Help tuning my V-AFC for a B16A swap
- O2 sensor code again.... HELP!!!!
- New Member - Looking for links!
- why is my car not getting in time.....
- Best shipping site for shipping ummm say a motor?
- changing timing belt - engine out of car
- need part # or source for ECU connector pins
- can some one tell me what these car run on the 1/4 mile
- Any guess at whp?
- Spoon style lip, Update #1
- Rally Tranny
- A/C in a ZC?
- Code 9.. No. 1 cylinder position?
- Just gutted my CRX and i realized........
- Fuel Pump options?
- my crx was stolen tonight 9/18 from nor cal
- selling my car, what should i ask for it?
- Before I tare appart my block for nothing....
- name of site...
- Custom ZC Intake Manifold... Who said No Performance for the ZC?
- WTB: CRX Sun/Moon Roof
- CA residents/DMV experts HELP!!
- J D M CRX rear seat install. finished.
- tilt steering in hf ?
- D16Z6 in my 91 CRX Si--->what tranny? What mods?
- complete OBD2 wire harness swap into 90 CRX...will it work
- Bilding Motor
- Carburetion!!!!!
- 96-civic seats in CRX?
- who has used aem brake pads?
- anyone looking for a stock crossmember to cut up for clearance?
- arms
- ST Rear Sway Bar Endlinks Install Pics - UPDATED!
- NON-JDM back seat CRX?
- Painting my car . Need tips or guidance.
- anyone know what color the gas and temperature wires are on an 89 DX gauge cluster??
- civic/crx headlights & mirrors
- D16Y8 intake manifold bolt on to a A6 head?
- Shock absorber troubles (installation)
- Does anyone have Bullfrog stage 2 Cam shafts
- is the alt belt for a del sol DOHC same as first gen b16
- My Trip to Europe
- Odd problem need help......
- Thought some of you guys might be very very interested in this.
- why do most you guys go with b16a over b20b?
- 91 hb starion intercooler perfect!
- WTF? $12-15,000 for a b16 swap? Thats not right!
- stripping white paint off rims????
- HELP!!! z6 problems
- emissions help
- Help: Converting your car from auto to manual
- How much could I get out of a 91 crx si cluster?
- 02 civic v afc settings and diagrams
- anybody in the Vancouver area have a PM7 ecu I can borrow?
- D16a6 Dis Cap Wiring order?
- anyone using obd2 alternator
- im sure this isnt normal...
- anyone have a clutch for a 88-91 hatch? (San Antonio)
- car is dead. help me find out why
- heya i need this part:
- zc reliability...?
- my oil pan bolt
- Pros and Cons of head gaskets
- My trip to Cali..
- Does anybody have...
- crx 86---89 doors
- Advice from all B16A owners with Apexi VAFC Needed
- what oil should i use
- where is my knock sensor and my oil pressure on my motor?
- so ashamed
- carbon fiber hood?
- SPOON style lip spoiler for EF's
- 88 civic hatch, What seats can i Use???
- D16z6 clutch and flywheel in d16a6?
- D16A6 with DPFI rumor...
- Will this whee/tire combo work?
- Need some Advice after ZC swap -- I got problems :(
- My oil pan bolt!
- Is there a chance for valves to survive a snapped timing belt?
- Do i need more fuel???
- Head-Gasket keeps on going!!!! READ!!!! HELP!!!!
- **Replacing brake fluid??**
- would this fit a b16 in a crx
- Crx for $100!!
- Problem at WOT
- pr3 ecu codes?????
- Engine Weights
- got shafted need help
- hf d16z6 problem
- SIR front bumper!
- B&M fuel pressure PSI for b16
- Anyone know how hard it is to get a car passed after getting it rebuilt?
- What brand plug wires for ZC?
- Clutch for zc tranny?
- Determining LSD
- i know your probally sick or hearing this but owell (o2 loving)
- MPFI SWAP: Round Two
- obd0 to obd1: can i keep my obd0 injectors?
- Need 88-91 Dashboard for my car including tach and speedo
- Anybody that has a Forced Induction CRX let's see them w/ mods!!!
- Urgent question
- ok. i put in a factory tach cluster and it goes to like 4.5K RPMS and starts goin crazy, why?
- MY NEW mini me
- Vtec Hookup need help
- disable "service required" light?
- i have NO oil pressure in my si please help
- What year is my ZC?
- those two wires on the back of my B16a1
- starting concerns
- EF bulb question
- Brake Squeak
- valve adjustment for crower cams
- Code 17, VSS problem, could anyone please help.??
- Looking..........
- need help FAST!!!
- Picture posting?
- HF with Si Engine Price
- 91 Std Engine Swap
- Should i use PR3 pistons on a b18 block???
- Need HELP! D16z6 swap fuel in coolant
- Need help installing a VAFC.....
- side of fuel rail hose??
- jdm cornor lens
- distributor wiring
- Civic and CRX Clusters the Same?
- Urgent, Need help: did search, really confused on how to power injectors on MPFI swap
- Powder Coating forged Wheels?
- swap problem ecu ligth on
- Pic request. CRX guys.
- FS: toyota supra tailight conversion for crx
- OBD-1 injectors in OBD-0..help!
- NO dash lights in 91 hatch.
- Fair price on a d16a6 50k miles? d16z6 hydro tranny too?
- What Stock Injectors should I Get for a B16A
- Anyone tried a B20Z head on an B18b block?
- Swapped Engine Weights %
- D16Z6 Vs. ZC....
- doors
- Maybe IMPOSSIBLE to remove CRX (with AC) Heater Fan ?? No answers!
- Putting my CRX in hybernation
- how do you remove the tps?
- turbo dx??
- Battle Of the Imports Joliet, IL - Red CRX w/ Hole Cut in Hood Pics
- 89 si airbox fit in 88 dx?????????
- B18a vs B18b
- Removing A/C....how much weight reduced?
- 5g civic motor?
- Anyone try TEG LS SPINDLES on their DX hatch, I have them, but.......????
- Just finished my B16A2 swap into my DX hatch, few problems, please help!!??
- anyone have LS/vtec turbo on the crx??
- ok need some help...someone in NY
- ZC cooling problem, can anyone diagnose?
- Engine codes... Alphabet Soup.
- need confirmation of ZC valve adjustment spec's
- built D-series
- Can someone please point me out to a page with the complete info on what is needed to put a B18A int
- master cylinder & O2 sensor ??
- my car still wont start!!
- zc code 4 problem
- zc swap help, won't rev past 3500
- shifter bushings
- Problem with HF/Z6...
- HELP: starting problems / and any advice for an 88 civic dx
- oh yeah....
- wiring those four wires (b16 swap)
- FS: 90-91 taillights complete set - excellent condition $60
- Looking for some info...
- Apex Exhaust
- I need help.I´m new here!
- i need a tps!!
- VTEC engagement 4,400 or 5,800
- Anyone has DC b16 downpipe to share?
- nos...questions
- Sohc vtec in a Dx crx
- 84-87 Civic Sites or Forums?
- 88si carpet in 89si yay or nay?
- CRX window fix
- brakes feel unresponsive, what to do?
- brake upgrade
- Heater control Stuck, what to do?
- 89 to 91 guage cluster wiring changes?
- ecu code 7 blinks TPS?
- B17A1 CTR (12:1) smog
- zc stalls when a/c turns on!
- Exhaust pipe routing
- Help! My Rear LCAs are shot, what should I replace them with...
- d16y7 in 90 Std Hatch question
- pulling a z6 on sunday what do I need to get
- HELP PLEASE Heater Fan Removal?????? Cold Winter SOON!!
- A6 head on Z6 bottom end?
- D16Y8 Valve clearances... Anybody have a Haynes/Chiltons/Helms on a '96+?
- cooling fan relay
- Goodbye
- tranny difference
- looking for pics of.....
- Type R shifter?
- Advanced timing - Close to overheating
- Hey There (Newb Thread)
- Need some help, need some fuel system parts CHEAP!!
- ""help""Spark plug is lookin kinda strange!
- Planting B-Series into CRX
- H22 swapped EF?? Anyone? Anyone?
- installing a headlight assembly
- Has anyone tried Hondasaver's d16a6 cam???
- New; need some common definitions
- JIMFAB X-Member, WHO HAS ONE!? need yer feedback
- Can I use my SI plug-wires on my ZC engine
- Maxi-frig freon?
- suspension tech sway bar install...
- How to flush radiator
- Resources
- which gasket to use?
- Radiator leak?
- help wiring up vtec
- h/b sway bar
- 88 hatch speed senson question
- Jimfab & Z10 X-Member - WTB? Reviews? bushings? ASAP!
- Question for ppl with Fastbrakes kit
- Big newbie question
- D16a1 or D16y7 head?
- shopping list
- Mount Inserts
- air/fuel ratio guage going crazy WTF
- car idles up and down after warms up?
- Si front bumper replacement!
- no antifreeze in car
- Anyone have an extra a/c button?
- who had that crazy duct tubing intake?
- leaky rear main :(
- Hatch rattle
- pr3: rev limit and vtec ingagemenet:please
- What would you do HELP!
- my 91 crx si w/b16a (jdm) pics
- Bottoming out?
- Fuel Gauge inop. ???
- wiring hook up for b16 in a ef
- witch dc headers do i buy for my zc
- Need Help!
- tach will not work
- 89 civic si, stalls out and wont start for a while??????
- please help with suspension.
- check out this old skool hatch
