View Full Version : Honda CRX / EF Civic (1988 - 1991)
- 1990 EF2 Sedan????????? (Side marker Question)?????
- ZC DOHC arp head studs?
- TRANNY PROBLEM??????
- OBD0 to OBD1: advantages?
- HELP---Hasport mount question.....
- pic request on crx with b series
- built h22 turbo rex
- need more injector info
- my 16 swap issuse
- 91 ef civic tach question
- brake master cylinder help
- Brakes (or E-Brake) Seized - Solution?
- just found out got 2 vin #
- how much does it weight?
- Strange brakes problem
- rexcar
- Need assistance on mounting battery
- i need help
- short shifter, which one?
- h22 alternator
- Tuning exhaust?
- I think I need help on this one
- ef diy
- prelude throttle or blox?
- front wiper alignment problems, please help
- 91 CRX rebuild
- 5 pin blue gauge cluster plug
- Carbon Fiber AWD Civic Hood
- CRX to hatch cat back question
- NEED HELP with my EF9 !!!!!!
- help my tranny wont fit
- DIY body work?
- 1990 Honda Civic DX
- what to do???
- cleaning fuel system?
- CRX Si exhaust
- EF Si injector info
- idle problem
- paint help
- stripped lca bolt to chassis
- Coolant Temp switch on DOHC ZC 1st gen
- h22 shifter/cables swap question
- Wheel wobble help!
- carbon question.
- Idle Air Control Valve compatibility
- Need Help with crx
- code 15 no spark.
- DIZZY GETS NO SPARK!!! NEED HELP
- d15z1 QUESTION
- "Before the baby comes", EF project.
- 91 civic 4dr Qtr panels ???
- CRX Starting Problems
- Crx won't start
- no power to injectors
- HELP Brake Lights Stuck On ??
- mini-me wont run
- ek zc cam in d15b2?
- Dual Exhaust Questions
- eg climate control to ef
- 1990 CRX EF8 sir
- gsr swap wont rev past 3500 rpm
- what do i need to make my stock sway bar work with blox lcas
- obd0 dpfi to obd1 mpfi
- unsuccessful dpfi to mpfi conversion =(
- ef9 cool build!!!!
- Sirry question.. 89 DX hatch.
- D16A Cooling & Lubrication question
- Password JDM Battery Relocator Question. . .
- B16a swap into a 1990 Civic DX...Kinda (Help out a new guy!)
- ef Sedan Seats in Ef hatch
- jdm ef9 doors onto 90/91 hatches
- b16a swap questions**help**
- Will a 215/50/15 tire fit in the fenders of a EF hatch on 15x8 +20's???
- ecu woes
- DA cloths into EF(ed) chasis
- Adjusting Cam Gears
- obd0 to obd1, with donor harness (searched)
- obd0 to obd1
- still usable?
- need sugestion on setup for launching
- manual Rack end bushing
- Fuel coming out of exhaust, BAD MPG!
- Project Rex Rawr
- Car won't start
- ef9 ac brackett?
- Question....do you have to have a traction bar to put a h swap in a ef?
- G-man's '89 4dr ef
- 91 ef with b18b LS helP!!
- tranny question
- torque specs
- TPS code
- will a crx cat-back exhaust fit a 88 civic?
- Is my crank toast?
- heater control knob stuck.
- help with vacuum advance!!!!!!!!!!
- 88-89 Teg ECU + D16A6 = Bad idea?
- JDM D15b question !?!?!
- Strutbar Fitment
- ef climate control
- 88/89 -> 90/91 cluster conversation question
- obd1 b16 does not start
- LSVTEC overheat? Or cluster malfunction?
- which starter to use
- CRX chassis measurements
- Corner Lights(Blinker/Park Lights)
- Power Steering - Pump = Manual Steering?
- Motor
- ef bumper swap?
- blinkers sometimes don't work, bad wiring?
- fuel pump problem
- need help please
- mirrors
- d16z6 swap coolant line help
- DOHC ZC
- how to take rear fenders off of a 90 dx hatch?
- loose clutch pedal
- b16a block with GSR head?
- '90 crx si with OBDO DOHC ZC (no start)
- Need some help with mini-me headbolts
- i need help with my 88 crx
- motor "dies" at 2000rpm
- need the pin out for dpfi obdo
- b16a clutch dilemna
- GSR CRX vtec stutter,power loss, Odd noise.
- need to find 91 crx si seats
- d15z1 problems (please help)
- Wagon Question
- Who makes the H22 header for the CRX
- Tach in a 91 Civic
- car seat in jdm crx rear seats.
- My Ef9 build thread
- NEED HELP FROM THE EF MASTERS!!!! Mini me engine help
- B16 Hatch shifting problems
- DA SEATS IN EF
- can i get some info on legit engine swaps to do in my 88 ef??
- how to change out the cv on a ef?
- obd1 conversion: left key on now wont start
- B20 Vtec or Boost???
- CRX Battery Light
- 90 Civic B16A2 Vtech problem
- wtf?! help!!! my z6 swapped sedan bogs at full throttle!!!!!!!!!!!!
- Seat Foam
- 88 civic DX vs base/STD
- How do i replace the front motor mount
- anyongot 16 in rota attacks?
- b16 swap this weekend....am I doing it right?
- Header
- options for REAR : wider fenders , overfenders , widebody ?
- 95 D15B7 W/zc head Possible.
- Broken Bolt
- name this part?
- loose axles
- Water in exhaust
- USDM motors where?????
- T-belt change questions........
- Overheating only at high RPM
- question
- obd0 to obd1
- Failed smog.
- Can this fit... Or work?
- H22a1 swap....?
- B18A1 vacuum diagram questions
- how do i Install OEM seat belts into 1991 civic?
- oil light stays on startup
- whats wrong with my rex
- need help gsr swap hatch no spark
- CEL #9 CYL POSITION SENSOR...
- head code PM3-10 ?!
- Crx Laggs/pause's around 3k to 4k when near Empty, Fuel pump? Injectors??
- General CRX swap
- buddy club spec 2
- brakes dragging after change
- 91 crx oil pressure gauge question (removal)
- how does one raise a stock spoiler?
- b18b1 into '89 Crx si(searched but need more help)
- CRX glass removal
- 88 crx hf ls swap
- car died on me? help
- Just acquired a ZC Cam...
- Legit swap for 1991 crx si D16a6 CA.
- geting a code 16
- 90 crx gsr idle-start-fuel woes. help!
- Help!! Just a quick door question
- how do u fix the squeaky clutch ??
- wipers, signal, headlights, wont work! help!
- 91 EF SI stolen from me in South Jersey
- How do u bleed the clutch ??
- OBD0 to OBD1 injection
- upper radiator hose
- No start after dizzy replacement
- my EF89 CRX SiR
- Vibration and thud noise.
- DA to 88 CRX HF
- CRX 16x8 grid offroad
- WHAT DO YOU ALL THINK
- ef sedan bumper and hood question
- 8 crx si wiring help please
- Ef gauge question
- b16a OBD conversion out of ideas need helpski
- WHAT COLOR DO I SPRAY IT
- Help with Cam seal
- Automatic ecu mpfi swap
- radiator problem?
- Elect speed sensor swap... not the same ol question
- Leaking rear window 91 Hatch
- ef hatch backseat???
- swapping fuel pumps, need some advice
- harness question
- High pitched whiny sound = wheel bearing?
- Need Help with 91 hatch DOHC zc
- crx interior questions
- useful faq, mis-matching jdm and usdm parts
- header melted a/c line! R12 escaped! please HELP!
- Clutch problems
- Battery light with new batt and alt
- blinker help!!!!
- Help with wire tuck!!! please? WITH PROGRESS PICS!
- 91 ef d15b vtec
- axle question
- EF Suspension question.
- 88 CRX Si B17A1 New Mods
- H2B Starter problems (HELP)
- Brake Lights wont turn off
- how do ya get the lower alt . bolt out?
- what kind of hubs and axles on a crx hf,lsd hydro tranny b18
- Alternator Bolt
- Help please.. trans issue
- ls vtec lsd tranny prolbem with axle and hub help!!!!
- HELP!! no brake lights
- manual steering rack damper
- Hi guys! Fuel pump won't cut on =[
- help with alt. in RHD rex?
- HELP
- low rpm studer ?? b16a ? help
- crx dpfi to mpfi
- d16a6 idle stuck at 2500 rpm
- jdm gsr help!
- Adjustable Coilovers
- Where in Yokosuka can I go......
- b16a 88 crx lots of problems
- 1990 CRX - 1990 EF2 Question?????????
- CRX help
- 1990 EF2 Civic sedan QUESTION??????????
- My H22A 91 CRX
- obd0 ls problem HELP!!
- NEED OPINIONS ON WHEELS 89 SI HATCH
- 91 crx c-pillar bar question!
- need some help
- Friend hooked up battery backward, now no start!
