View Full Version : Honda CRX / EF Civic (1988 - 1991)
- help out i will loose it with this damn electric vss thing.. gsr cluster question in 91 crx
- B18a obd0 civic Questions
- Power windows on an ef8
- crx wanted south carolina
- extended wheels studs for CRX 88-91, can these be DIY'ed?
- yes i know anothe mpfi swap question
- will 2000 SiR suspension w/front forks fit in my 90 civic dx?
- Swapping my busted D for another one. Q's
- 1988 crx emmisions with glasspack
- DOHC F22b in a crx
- First starting car up, alot of smoke comes out
- . anyone like convertibles?
- Oil Oil and more oil
- obd0 ecu pinout request.
- AWD wagon
- a couple about swapping from a d16a6 or zc?
- b16A obd0 cam specs???
- brown radiator coolant
- check engine light ( 1 ) help!
- laguna gold mettalic
- i need a picture diagram of the inside of the 2nd gen ys1 cable b16 tranny
- distributor
- what rims
- clutch problem HELP!!!!!!!
- can any one tell me what is wrong with this??
- 89 crx door panels?
- DOHC ZC problem
- uberdata vs hondata
- Fuse Box Diagram (searched found nothing useful)
- B20 Vtec or GSR?
- zc motor and a d series tranny
- civic race
- B16 SWAP
- heting help
- 90 LS swap - HELP!
- b18 in a 91 hatch need help
- Valve adjustment?
- DIY Oil Catch Can
- exhaust leak into coolant
- H22A in a Honda Civic?
- obd0 b16a extra o2 bung on header???
- sunroof help
- 88 crx HF EGR, Fast Idle Control Valve, and d16a6 swap questions
- need pics / battery in the trunk
- b series shifter length specs?
- major changes ?
- mini me swap HELP IM NEW TO THIS SITE....
- Crx vs 2006 c230 Challenge
- couple quick questions
- crx problem...little help please.
- 4wd drive in 2wd wagon?
- alternator help
- ignition swich
- What Tranny Is Shorter?
- oil smoke when i rev hard
- Drag Car From The Woods, Help! 56k Dont think So
- *H&R ultra lows*
- quick question cant find exact answer in search
- Adding Another Audio/Video Component - ED/EF Related
- 16x7 42mm offset rims for a crx??
- ltranny swap question
- freeze plug????
- bad piston? next step....
- Dynomax super turbo mufflers!
- CAR WONT START (please help)
- quick question
- ODB0 ECU - Searched
- head lights question from a 4dr
- ecu fuse blows when converting to obd1
- Opinion/Review on Tanabe Springs GF210
- Buying a car that has been staying outside for 1 year
- slight vibration when driving...
- chip for civic
- hello guys, newb here...
- Fuel Gage
- obd0 to obd1 question?
- Replaced D16y6 with ZC on 91 Civic Si, 5th gear now running at 3k-rpm at 60mph
- d15b2 engine surging while idling.
- Intake differences? HF1 / HF2
- Cleaning head internals?
- ECU ?s
- Exhaust ???
- weight reduction.
- fuel pump relay noise
- WAgon wont start
- ARP Extended wheel studs
- My ZC has died, please help
- obd0 to obd2 question?
- do i need the brake master cylinder for the ls rear disk
- o2 wiring info 4 cx ?
- B18 LS non vtech any good?
- obd-0 to obd-1 quick question
- HELP!!! How do i remove the pedal assembly off a 91 crx si?
- Where should i start the process of elimination to find my problem?
- b16 help
- How to make a 90/91 crx si lip fit 88-91 civic std
- Good Deal? B16A3
- Differences in Crankshafts and Mains - D16A6 and D16Z6
- d16z6 tranny?????
- what to do with 89 DX (create your own poll! FUN!)
- universal fog lights, 88-89 sir comparisons?
- fast question...and a lil story.
- crx running shitty
- the engine just died
- billet vs. steel mounts
- harness ????
- searched but not my exact situation.
- wiper control arm (inside car)
- Help! b16 into 89 CRX
- Dizzy question
- VTEC ?????
- intake question(b16 sedan)
- calling all iowans
- need motor swap help??
- b16 issues, help please
- Whats the difference in a Dx and a Hf
- Lifetime alternator
- lsvtec or turbo b16
- heeeeeeeeeeellllppppp when hit the brakes door jam light blinks no brake lights (trex352)
- different heads
- ef sedan(lower control arm bolt)
- jdm P30
- PM10 >>>>SEARCHED everywhere and need to know what car its for
- p03
- can any one tell me a good way to make a stock 91 standard hatch back with a d15 b1 fast?
- mud gaurds 89 crx
- Wireing Help
- Rich E-Brake Light
- EF hatch Problems
- New Cam gear
- DIY HOW-TO: SIMPLE HEADLIGHT WARNING BEEPER
- changed the axle/tie rod yea i searched
- mpfi swap problems...
- TWO Questions for my 89 Sedan. Bogging from dead stop, and white plugs
- EF Steering Rack...which is tightest (already searched)
- Is this a DA master cyl?
- 1988 Civic, 1.5l - Check Engine Light @ 60-70 MPH - error code 4.
- hot or not? HELP.
- si cam in d15 dpfi?? any good??
- zc swap help wiring night mare!@!!!!
- swap trans or swap to hydro
- i wanted to get an idea of how much you guys would pay for this hatch
- pic request red crx with 15" rota c8 in royal gunmetal
- what is a dizzy?
- fresh SOHC ZC cam/rod/spring questions
- 88 CRX Si, LS vtec swap, and power steering.... help
- crx si seats.....
- USDM front end crx carbon fiber answers needed
- heater switch stuck
- D header??
- Link to Exhaust thread??
- 98 integra steering wheel on ef?
- Pedal assembly
- upper rad hose and valve cover gasket b16a?????
- DOHC ZC main bearing issues
- do any crx models/trims have beackseats.....?
- sedan question
- HELP
- thease cams any good
- Speaker install question, 1986 hatch
- wow. what a day.
- Question Bout B16 Swap
- b16a header/ o2's question.
- Choas when cold starting (searched)
- Stupid question???VSS that bolts on my auto??
- can i use my 93 axle's on my 1990 4door that has a d15b with a 89si tranny HELP!!!
- H22 into a crx
- smoke problems
- ecu question
- 1990 honda civic dx
- wheel width's
- jdm front end problem
- B-series mounts?
- Squeeks from Rear Hatch Area
- Part Number for Vehicle Speed Sensor
- LS/VTEC swap in my 91 crx HELP!!!!
- ?? about Ls/B16 Tranny...........
- Which axle seal for a b16 tranny.
- ZC ?
- Do i need it? Honda civic wagovan 1991... Pics inside
- what makes obd0... obdo
- B20 swap...need some help
- EF8 Mounts?? Where....
- sohc to dohc
- iab making dual runners work w/p28?
- DPFI Intake Manifold on a D16A6 Head
- 1988 HONDA civic sedan/17in GUNMETAL MESH RIMS/POLISH LIP wheels $1300 nyc
- d16z6
- HEY STUPIOD QUESTION NEED HELP
- new clutch but grinds in third need help
- CRX leaks under dash, on to floor when it rains.
- parts for mpfi and mini me
- si tranny
- wtb: zc head
- blown head gasket problem
- Where this must be connected ? Manifold ...
- Project CRX
- 1g Turbo CRX drag race video
- jdm crx wing with brake light?
- 1989 CRX New Project help.
- sohc vtec in a sedan
- distributor issues!!!!
- Code 8, Top Dead Center\Distributor Replacement Question
- Rebuilding my D15B2
- Header Gasket
- C's shifter
- coolant froze???
- engine 4 sale
- so i def got my jdm front end on!!!!
- i bought ebay headers
- teg seats into my hatch- How to do it ???
- Doing ES bushings, what's the diff. between black and red?
- b16
- NEVER buy from hondaperformancepartz/Jesse De Leon/t04epwr@aol.com
- I need some help with my CRX dieting program...
- 90 CRX Si
- EF8 SiR Hood Issues HELP!!
- DOHC ZC stock injector size?
- 88 WAgon Transs?
- Help? 91 CRX Si Mechanical Problem Inside
- miracle x crossbar 91 civic
- Best Spark Plugs
- car cutting out at 4k rpms
- Timing belt install question ?
- I think everbody should watch this ASAP
- Wisconsin Shops??
- right hand wheel drive crx shop
- Won't start after CV Axle replacement
- Anyone used one of these lexan sunroof replacements?
- time to un-pimp z auto - my project thread.
- Crx interior space?
- Possible LS Turbo, Looking for questions and tips
- Is it worth building a SOHC head?
- DOHC ZC exhaust header, clutch, Proformance info
- Broken trans? not sure
- shot peened rods
- rear control arms
- MPFI Hose hook ups
- any tranny experts around?
- d16z6 harness
- 91 hatch
- What seats should I buy?
- when hit the brakes door jam light blinks no brake lights
- crank jsut spins
- HID question
- b18 swap-car goes to left side....
- spring/shock install help
- dohc zc swap into 89 si
- b18a1 bearing spec question
- intake mani suport braket thing
