View Full Version : Honda CRX / EF Civic (1988 - 1991)
- jdm moulding help
- Code 1 after DPFI to MPFI conversion
- car won't start
- O2 sensor
- 4G4D
- Fixing to buy a 1990 crx si...what motor to put in?
- DC radiator into CRX
- limited slip differential help
- h22 into a '87 CRX possible??
- obd0 and obd1 dizzy
- will other valves work?
- What size spacer?
- exhaust cut out / bypass the cat?
- O2 sensor?
- obd0 on a d15.......??
- what tires for street use
- d16z6 with p06 chipped ecu...need pinouts
- pillar mounted seatbelt conversion
- S2000 SRS Steering Wheel in EF
- nitrous question
- seat bracket
- EF Sway bar noise.
- questioon!!!!
- fuel pump problem
- 90 crx si question?
- cam gears
- MPFI-swap ecu contact pins...EBAY?
- Need help with 2 annoying problems, N00b status here!
- IDK what to do...should i buy this CRX SI? please help
- EG rad and slim fan
- swap list.
- f20c rwd ef??
- head swap, mpfi and obd0-obd1
- DOHC ZC Cams question
- No vtec and No cel's help......
- obd-1 mini-me
- Clutch problem
- New Valve Cover for my CRX
- CRX TURBO PROBLEMS HELP!!!!&**(@#&$&(^
- Carbon hatch for a 91 civic hatch?
- ???intake manifold???
- Trouble shooting code #43
- In need of opinion on corners.
- codes
- crx axle problems... help... tranny????
- axle problem
- D15b1 help
- 88 civic zc swap
- '87 CRX Engine questions
- How much voltage do i need to Start
- need advice on valve float, over rev, and compression test
- MY NEW CRX!! ANY TIPS?
- B18A1 shortblock/longblock the difference?
- vacuum lines HF>SI ????
- project 88 civic hatch shell has started and on it way
- Problem with relay
- 0bd-0 to obd-1 harness ?
- ECU light STUCK on.
- Help/Advice on a Quick Release Hub.
- ef hatch climate control into a crx???
- what could fit off the 92-95 civic
- brakes changing idle
- gauge cluster question
- CRX HF --> SI Brake Upgarde. Grocery List Help.
- CRX Shell help
- front bumper question
- whats the differens between b16 heads
- d16y8 head gasket on d16a6
- intake manifold bore
- Tilting my spoiler?
- Break in!!
- 89 hatchback DX Pan swap?
- converting 91 hf crx to obd1
- obd0 to obd1 coversion Help?
- ZC question
- Need help with RE-Wire on an 89' hatch SI b16a
- victor x with direct port nitrous
- My 89 civic Dx build.
- 91 civic Si
- rellly fast question....
- front lip question???
- HOW TO: Construct a cheap, simple, and effective EF catch can.
- 91 crx si overheating
- Gauges not working
- k20crx and h22crx round two which is the better motor (oh hell no)
- Hanging on for dear life at startup?
- Just installed short throw shifter..
- Honda CRX Turbo 4x4
- My '88 STD
- SHOOT ME NOW.....OIL LEAK FROM BACK OF HEAD ON FRESH LS/VTEC SWAP
- Anyone still making climate control face plates?
- only one axle, is it safe?
- d15b2 into 90 Si - won't start!
- intake mani
- obd0 harness - obd1 dizzy HELP!! T.T
- need help with bolts
- D16Y8 IM on a D16A6?
- picking which clutch kit????
- is there a diy for front lower control arm bushing replacement?
- messed up motor??
- LS into a 91 Civic Hatch
- Edelbrock turbo kit?
- emission problem
- weird B16A
- crx isnt running right?????
- Noob ?....
- 88 crx si to zc wiring help.
- spoon calipers?
- fuel pump issue
- new swap no spark and no oil light????????? i checked everything!!!!!!!!!
- rev. limit on p28
- Well, it's almost been a year, time for a build thread from wiZCo...... (56k? get lost!)
- wagon passenger mirror
- Koyo Racing Radiator Woes...
- ZC Tranny with LSD
- modifying crx exhaust to fit a 4dr
- idle problem/overheating
- traction bar for EF
- code 14 iac
- compression `
- b18a swap into 90rex need to know length to mod linkage
- half cut radiator
- my car pulls to the right, real hard!!!
- harness bar for an ef
- need help with quick release
- should i take this offer???
- o2 sensor question B16 OBD0
- 89 crx dx
- This Is My 91 Civic DX Build
- Bad CAT, can it cause a code 1?
- Hondamonster's Rex build.
- not looking for sympathy
- Rewiring headlights to Toggle Switch
- JDM EF '88-'91 Civic Hatchback Front Bumper (Inc. Parking Pole)
- mini me vtec problems
- Starter Question?
- b16a vavle adjustment
- timing a d16
- header question
- fuel pump
- What year crx......
- Brake swapping
- Roadtrip planned. any way to increase mpg short-term? other questions too
- Video inside HeadGasket,Valve seals,Or Intake manifold gasket?
- Quick Question about D16z6 head!
- Wiring problems with fuel pump
- civic problem Help
- making a hybrid 4th/5th gen engine harness, help
- i need opinions on this much needed rebuild
- Motor pulled, a few questions. *pics* 56k beware
- McDonalds Hamburger
- seat bracket, sliders?
- help with headers
- red stripe on ef moldings?????
- wire problems
- Head Gasket???
- Spoon twin blocks on EG6
- gsr cluster in 89' civic hatch
- symtoms of bad main relay...
- Aluminum half cut radiator on ef.
- rack and pinion
- CAN I USE 100W H3's IN MY CRX FOGLIGHTS?
- crx replacement window motor
- popped up hood question
- Why isnt my AC working?
- Why is my tach dead?
- Energy Suspension Bushing review
- one piece front end ?
- Newbi here, looking for starter
- 91 Civic lx won't start
- Front sway bar mount
- 91 crx mini-me question??????????
- homegrown hybrid
- sitinthehall's project thread 1990 dx hatch
- everyone has one. My rebuild
- 1990 Civic Si D16A6 PROBLEMS
- B16 CUTS OUT BAD AT 7000 RPM'S PLEASE HELP
- Help - Mini Me Timing Belt Question
- suspension question
- Took some pics tonight..lemme know what u think
- pics of home depot lip ?
- Social Experiement
- what should i do with her?!
- tail lights keep shorting out
- inner cooler piping
- block question
- Please help me guys.. *dumbass inside*
- OMG A SCORE AT pick and pull!!!!!
- does it matter
- car cranks but wont start
- Aftermarket LCA's???
- EF9 Autopower 6pt. Cage Padding Question
- DID I SCORE
- rear disc swap
- how do i run the......
- 91 Civic LX won't start
- pics of skunk 2 springs on 88-91 4 dr
- ECU type..
- OBDI conversion O2 sensor question.
- has anyone ever rebuilt a zc tranny????
- 1990 Civic Hatchback Stock
- your thoughts on wheels
- aebs manifold..help
- installing delsol seats into my crx
- is there a diy clutch and flywheel instructions for 1991 4wd honda civic
- 6 grand!!!!
- honda coolant part # (concentrated)
- 02 sensor wiring help
- power chamber question
- 88-91 civic hatch lip???!!!!!!!!!!!
- bleeding my coolant system in a dohc zc
- main relay
- tps question
- b16 w/lsd problem.
- engine problem
- 88 hf tranny in a 91 si
- wet or dry shot nitrous on stock h22
- Anyone have sohc zc (domani) engine in a rex?
- Removing rust on engine parts
- b16 transmission giving me problems
- Tech stuff help me guys
- JDM B16A into '91 DX
- Question about ITB
- TDC arrow
- del sol seats in a 91 crx
- Radiator cap pressure?
- 1989 civic dx with gsr swap
- question about my MINI ME
- What are all the gauges I need for turbo kit?
- fmic piping?
- weird problems
- alignment problem
- 91 civic dx engine swap help
- CUTTING DOORS ON A CRX
- EFBLINK Shifter?
- fan not working
- what year is my GSR?!?!?!
- Any suggestions on fixing my suspension?
- 88-89 & 90-91 ?? whats the different
- Quiet exhaust setup without cat?
- 89 CRX HF axles=95 civic EX axles?????????????????
- map sensor question
- What VSS To Get? OBD0 B16. Do D16 vss's work?
- Problems with wiring
- ESI Exhuast Pipe (Help)
- ________Twin EG & EF Build Up: Project Coffee N Cream________
- EF Hatch and CRX door compatability question...
- d16z6 in crx si?
- JDM headlight problem.
