View Full Version : Honda CRX / EF Civic (1988 - 1991)
- So I swapped a b16 into my hatch...Is this engine placement right?!!?
- What are plugs 212 and 313 for on the EF si models?
- ok, so i just revved my sohc zc to 8k+ revs?
- motor mount swap
- No Heat!! Itz Cold Out
- steering wheels
- THROTTLE sticking ..??.
- can you add a/c button to climate control panel
- B-series Input Shaft Bearing Question
- CRX noise problem.........
- arp studs? interchangable?
- ingalls front camber kit...
- head decking question
- For people's car that smoke(solution)
- fixing rear quarter panels
- Brake Caliper leak
- GSR Seats in a EF????
- starter question?
- So Cal Locals Wanna Make Some Cash?
- Quick question about b-series innovative mounts
- control arms
- confused
- bent rear trailing arm? (also posted in suspension forum)
- Teggy centre console
- right side of gauge cluster died
- skunk2 cam gears
- What do you think?
- EG rear LCA's on EF?
- B18 clutch-B16 flywheel
- help with speakers
- full coil over suspension
- 86 Civic Seats
- My Old CRX: the general!!!
- NEED TO FIND A LSD D SERIES TRANNY WHERE COULD I GET ONE?
- *****STOLEN 1990 Rio Red Civic Standard in ATLANTA*****
- opinions please, need help
- little blue plug guage cluster plugs
- AEBS intake manfold question (PCV)
- hasport axles
- bought an a6 block... problems?
- Race me bart
- Where can I get these?
- Si or Ls Dizzy Wire Diagram
- D15 92-95 5 spd tranny into D15 Civic 4 spd man
- MY SEDAN PULLS RIGHT? DONT KNOW WHATS WRONG.... PLEASE HELP
- Ignition output signal. Help?
- whos got a 94+ teg cluster in their ef?
- D15B7 in a 91 DX CRX
- b16/question
- LMA question
- was on ebay look what i found for an ef.
- ef square fog light knock offs
- JDM MOLDING RED STRIPE
- DA sway bars??
- which one
- engine quest
- -Newb- Coilover Options
- b16 to crx rhd wiring?
- 1989 crx si project ...... hope the pics come out!!!!
- Any cars have the same hood latch as the 89 crx?
- converted to obd1-throwing code 41 heated o2 sensor help....
- swapping a B Series into my 91 std
- auto to cable tranny swap.
- Quik Question: Where Do I Get Speedometer Cable?
- d16z6 swap in ef hatch
- rods in b16a
- crx bumper support
- Project Suggestions.
- Can some tell me if these are 88-89 or 90-91 SI seats?
- help code 14 an 15
- Wiring Harness For Swap
- help! hydro conversion on my hf
- What to replace when disassembling motor?
- amber bumper lenses for EF hatch
- need help from engine building gurus- how do you replace thrust washers
- Random solid CEL, engine studders and dies, WTF??
- weird problem?
- OBD-0 B16 swap
- what axle do i need for my EF?
- 88 civic struts converting to 89/91 ?
- ingalls camber kit
- what camber kit to get?
- coil problem???
- difference between 88-89 and 90-91 cluster cover
- front end popping please help
- motor dies on startup
- alarm problem...
- Pulling Motor
- B17A1 A.C.T. Setup problems
- EF2 hood on a CRX ??? does it fit ?
- crx idle and check engine light problem
- Mini-Me vs ZC
- Brakes Help
- Code 9
- 92-93 gsr(db2) brakes on 1989 civic lx sedan
- Steering on CRX
- EG seat on EF?
- EF9 aftermarket fog lights
- Which would you take of the 2?
- My CRX set up...
- tein hood damper
- instrument cluster swap question *searched*
- Dohc zc performance parts
- cel dont know how to check codes though
- HELP!!i need Complete Wiring Diagram..Hoses plus Harness
- Heating problem...
- lowering seat position
- CRX wont start and Check Engine light comes on
- Noob Question
- I want to know the magic words to get my slack belts fixed.(old topic I know, but still need help)
- Real quick help please
- Getting My Motor Barred
- Whats the diffrence
- HELP?!?! my rex is throwing a code 7...
- New OEM Hood...Does not fit
- HF CRX
- No CEL, but ECU shows code 16 (injectors)
- JDM front end questions.
- blown intake manifold gasket?
- fuel pump
- need help with some rims
- omg i found the most murdered crx ever
- Someone Hit My Freshly Painted Car
- CRX DX coilovers work on DA tegs? Help!!
- K&N Filter Price - What's a normal price?
- Help plz/washer motor located?/dizzy
- which helms manual do i need to download if i have a 91 crx.
- registration problem!!!!!!!!!!!!!
- well this header fit ??
- $165 Edelbrock 2-piece headers, polished
- b18c swap has begun!!
- What tires should I get for my hatch? sorry if this is in wrong place
- Compatible Dash Harness
- Anyone know the passenger volume on a 4gen hatch?
- Engine shuts off when wipers turned on
- Eclipse turbo on crx
- HELP!!! HCP no longer makes b-series - ef- a/c bracket
- replacing exterior panels on crx
- 91 civic std engine problems
- Redshift Civic Si Setup, good read..
- no power to the fuel pump
- already searched, cat, straight pipe, high flow, and gutted. any REAL answers on Catalytic Converter
- crx steering wheel help please!!!!!!!!!!!
- Fuel Filter
- So say I do this... how much will it run me?
- Going Turbo
- i need help with my underdash harness.
- hf tranny
- Junkyard treasure!
- Main relay problems?
- jdmcarboy
- car runs rough in cold
- wiring question (wierd stuff going on)
- 2 1/1 in thick 1/2 size rattie not fiting rite???
- b18a with a injector leak!
- Ignition on intake stroke?
- ITB's on a D-series..
- need help w/ EF8 front end.
- 89 crx hf, b18a1 swap distributor question
- Caster adjustment?
- alternater color codes
- Alternator Question.
- Trans Case...
- um guys...is this right??
- d15 question
- motor question!!??
- help clean my engine bay!!!!!!!!!!!!11
- tach installment
- clutch?
- how do i take off the tail lights (CRX)
- Buyin a CRX
- 1987 crx
- whats a good short shifter?
- tsudo catback?
- hey guys i need help with this buy
- A NEW TURBO D PROJECT
- B16 cold idle
- b-series tb pic request.
- Mudguard question please help!
- what map sensor to use with b16a
- Is CR-X SiR Carpet The Same A USDM Carpets?
- B16 Turbo, worth my time...
- $1000 bucks to cover d15b2 swap?
- d15b wiring
- Does da EF4 have a govnernor switch
- DA integra knuckles "hubs" on 89 EF???? help!!!!
- Trailing Arm Bushing Replacement??????
- Bumper question
- Yet Another Problem Axles (B Series Swap)
- $129 Edelbrock B-Series HEADERS!
- dizzy's interchangable?
- CRX SWAP QUESTION
- invidia exhuast system
- sohc zc wont start
- d16z6 in a 91 ef sedan
- cluster help
- squeeking sound
- cam duration and left of the stock civic SI cam? d16a6
- how much do i need to mod to get the greddy kit into my civic
- 90-93 teg throttle cable question
- Help. How to wire GSR into HF chassis
- Suspension question
- need throttle cable for mpfi swap?
- 220 on a tank with a 90 crx dx swapped b16a odb0
- 89 flywheel 91 clutch and pressure plate?
- 91 CRX Si: Sell or Restore
- 88 CRX Si light weight flywheel????
- how to take off a rotor
- My CRX ... noob
- Cover TB with hand, car starts up
- Power steering in an ef sedan????
- f20b-is it worth it?
- engine
- Edelbrock headers from Summit
- b18a
- Starting Issues
- what to do with 93 GSR wheels?
- sohc zc tranny axles..
- that sucks
- b16 swap question
- the zc hood lump swap
- NEW $100 '88 CRX Si Project :)
- throttle cable si on b16a
- help please! Poor mans type R
- 90 hatch.. swapping stuff from 90 ls teg.
- B16A mpg
- valve clearance
- WHAT WOULD BE BEST?
- calling out all ksport coilover users
- flickering lights/volt gauge acting weird
- My new Whip ( new to me ) 88 Civic Dx DPFI FTW!!!!!!
- Does anyone have a pic of the plug jumped in a dizzy replacement?
- automatic to manual swap
- dohc zc dizzy making loud squeal
- DA Seats in an EF.....Searched and found nothing. Help
- heater hose
- Can't get the bolt out for the alternator?
- my rt4wd wagon
- getting a CRX...
- Part numbers are the same for a SI distributor and a DX? Is that right??
- Need A Throttle Cable For My B16 Motor
- How do i reseat my injector connector
- Code 16 *HELP!*
- another how much thread
- need help on coilover install...already searched.
- 91 crx swap
- Turn signal lights...
- a6 to y8 mini me conversion
- swap info..
