View Full Version : Honda CRX / EF Civic (1988 - 1991)
- supercharging the EF?
- how are koni yellows?
- Fired up the B16 for the fist time today:) (long)
- 88-89 rear bumper vs. 90-91??
- Two questions.
- Nice CRX Interiors for j00!
- CODE 9 and 20
- how much for alternator and starter motor?
- using a switch for ecu pin connector
- Anyone got tein in there crx?
- Clutch Release Shaft only moves a little? Cable wont reach?
- replacing rear drums...
- 89 hatch dx
- new idea.... need time Estimate
- lsd
- anyone who has a strange or bright colored hatch show me a pic.. i wanna see what they look like in
- Quick Rollbar question..
- JDM EF Parts
- Koni Yellow/Sport perches?
- strange ZC starting problem
- HCP mouts...Good? Bad? Ugly?
- problems starting car - need help
- How do i.....
- Bolt-In Kit$
- what do you tink?
- MariofestIII, MD VA DC Meet
- CF ZC Hood
- o2 sensors
- RUST under jack point!!!
- FYI: Tim Hastings (Zum01) Upgrade Eng...
- struts w/ neuspeed springs
- skunk 2 exhaust???
- Obd 0 to obd 1 questions.
- pass side mirror ?
- Timing is everything.
- northern Florida & Southern GA members only
- CRX HF harness...can i do this?
- Another honda-tech meet. This time paintball madness... PA,NJ,NY,MD,DE everyone is welcome
- anyone have a pic of a iac valve?
- Civic no0b.. Bumper question Si vs. DX
- wut sidemarkers to use???
- my d16a6 makes a clink in the motor at 4500 rpm's?
- compression #'s
- WHO out there has done an auto to manual swap??? I need info- thanks
- need a b16a motor 1st ge????
- When nitrous attacks
- i dont know my what my engine is
- Got nailed by a Mustang today!!
- Detachable steering wheel????
- engine help please!
- D16z6 head
- Sidemarker
- I was wondering.. zc/crx ..
- 2000 civic si seats in 88 crx
- a little help here
- A6 and ZC fuel rails, the same or not?
- $2,000 to burn!! What should I get for suspension and brakes???
- axle back exhaust fitting with ww bumper?
- Crower Cams?
- Snap in 2nd gear
- my car hit 200,000 miles today
- 91 crx si Ebrake cables for disc swap. $$$ GOOD LORD $$$
- How to mate the trans to the engine out of car, impossible?
- Adjusting TOE settings
- Anyone here have true poly mounts?
- zc complete, where to get?
- headers for a sohc zc
- Koni Reds VS KYB
- B series vs. Hood
- D15B2 not starting
- headers
- holding my steering wheel 90 degrees
- Civic D16A6 compatible
- Rear disc brakes
- Just when you thought it couldn't get any worse!
- which a/c bracket to use with z6?
- turbo timer help???
- intake manifold from d16y8 fit a d16a6?
- what coilovers for EF?
- Car runs hot when low on gas? What s the prob?
- custom exhaust opinions?
- b16 exhaust mani question
- will an 88 crx si shift linkage work with a b16 if lengthened?
- Thinking of selling my wagon, what is it worth?
- Is it always bout how fast u can go?
- Battery question
- Plug Wires Order on a ZC, I searched.
- Lowering 1st crx, plus want to mod?
- ZC Distributor Wires, Cant find White Red, Need Help
- Compression Ratio ???
- Just a l'il ol' brake question.
- driverside axle
- Post pics of your championship white, silver, or blue CRX/Civic
- where did you mount YOUR crossovers?
- code 15- car still runs
- what radiators are you guys using with your b18 swaps.
- Should I buy this car?
- EF b series swap parts and others
- cv boot leaking grease..
- Pictures/Story/Roll over from Last weekend's Autocross
- CRX Short Shifter Pics?
- D series flywheel!!!!!!!
- Loooking for one of these...
- NX's Incognito kit
- New to the site
- Semi DFW Meet (this Saturday)
- crx si and crx
- what does si stand for
- DC/MD/VA People
- Blew up the EF last night.....
- 5 lug V.S. 4 lug
- safc
- Will a 2nd gen SI air pipe kit fit a 1st gen SI? CRX
- Gsr in 91 si hatch
- zc problems please help!
- DPFI to MPFI Question
- cv boots????
- Installing Rear Seats
- Will a EG or EK steering wheel fit on a CRX without a hub?
- what the hells wrong with my baby!!!!!!!!????????
- FS - 88 Civic DX HB
- how does one contain themselves
- 90 dx crx...auto-> manual
- I want to make sure I did my timing belt right
- to those with 90-91 CRX SI rear discs and stainless lines--where did you get them??
- anyone in northeast ohio
- B17 block....
- DAMN Brake light wont go off!!!! WTF!!!
- water pump
- Cluster hood
- Norcal bbq meet
- Spoon PWO ecu in near stock CRX SiR?
- b18a in a 91 si rex
- im gettin a gauge cluster from an 91 integra GS .. anyone know the wire changes i must make ??
- what junkyard distributer cap works on the zc?
- OVERHEATING?????????????!!!!!!!!!!!
- rod length?
- Honda Sun/Moon Roof????
- How to get the head off my zc
- Help. DPFI to MPFI conversion
- valve adjustment on D series
- Any NY/NJ/CT people? Meet?
- What seats will fit in a 91 CRX HF?
- online helms manual.....
- Where to do clutch work in north atlanta?
- is there a different of civic cars
- Helms crx or 92 civic si
- Removing Transmission, Won't Come Off
- JDM rear bumper install
- overheating problem
- typr R clutch and flywheel in y1
- Good drop for CRX's? What springs? Camber kit? HELP!!!!!!!
- EACV failure with no codes?
- D16Y8, B18A/B or B20Z
- crank angle sensor
- really wierd problem someone please tell me what it is.
- because I value your opinion.....
- should i go synthetic or not?
- look what I got this early morning?
- What's so great about Spoon Engines?
- Wagon Links
- I guess Im retarded but help with Hasports wiring instructions
- Meet up at Maple Grove Oct 19th-20th at IDRC event
- CRVTEC into 87 CRX - Hood Clearance Problems (with HASport mounts)?
- B-series Pulley
- aiming headlights
- Made my own Recaro Bracket to fit JDM ITR seats
- ecu's
- REplaced CLutch still aint rite
- how much would you pay for a itr block (new or used)
- turbo sohc
- 88-91 crx, vin locations?
- Getting ready to paint car need help.
- Any one got any pics of some drag rims tires
- What does it look like when you replace the water pump?
- ef9 jdm front end question:
- need link for d-series forum
- wiring question
- 93 DX
- damn e brake
- integra hubs on 89 CRX-- fitting questions??
- i need a y8 vtec selonoid!!!!!!!!!!!!!!!!
- Torching bolts to get them loose?
- Ryan's B16 Comes Home!
- Jdm front si done
- got my jimfab xmember today
- anyone using centerforce or exedy clutch ? need input
- 91 Civic Si - front-end chatter
- 91' crx hf brake conversion
- What do you think about 220 dollar b series mounts to put in 88-91 civic
- Wanted: CRX owners with Fields VTEC controller (click here)
- how much can i get for my car?
- Got my zc today. Have a few questions
- A few shots from nopi...
- I need CRX help
- srs
- New valve springs on B16 with ITR camshaft?
- Cluster NOT working at all! Help ME!
- Motor mount question
- S1 Tranny <--------Which Clutch????
- Got a New Project 56k beware!!!
- Quick Q: Will 90 CRX corner lights fit the 88-89 CRX?
- Ractive Exhaust Quieting
- Need an igniter... where can i get one?
- Got a Prob with my CRX and need help!
- crank angle sensor problems: help!!
- New member Question....
- Break In Period?????
- Somewhat new here.........question about my d15b7
- EFs @ nopi
- anyone ordered from hondamotorsonline.com?
- Catalytic Convertor? 4 Wire O2's?
- I need suggestions!!
- Anyone Up for Honda meet in Georgia? (Augusta) *Read*
- rough idle on swapped z6
- WARNING! Energy Suspension/Summit Racing
- For all you old schoolers out there.
- b16a1 code 6 coolant temp...
- how to tell if timing belt is new?
- Si tranny question real quick
- Clutch Problems
- How to recognize type-R camshafts?
- vtec solenoid
- main relay gone?
- PG7 88-89 teg ECU on a d16a6?
- Cylinder Head
- d16z6 swap into 89crx???? any complications?
- hf vs si rotor?
- re do the gauge cluster
- B series tutorial
- wats a good fuel adjustment for field vtec controller?with mods
- What distributor?
- smells like poop...
- wat front strut bar will fit a ef hatch with b16 on billet hasport mounts?
- calling all b18 crx's?
- Columbus, Ohio meet Oct 19th!
- 92-95 Greddy Kit on a a6 90 HB Si
- ls in a 90 crx si
- Non vtec cams?
- Balancing
- Code 10... I dont think their's a such thing
- Question from an EF Noob
- gas gauge
- Reliability of a CRX?
- Problems after swap...... Need Advice......
- will the gauge cluster from an 91 integra GS plug directly into my 89 DX cluster harness>?
- to vtec turbo or not to vtec turbo
- Dynoed that A6
- fuel smell?!
