View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Some Questions......?
- Need pics of custom N1 style muffler on 2nd gen CRX or 4th gen Civic hatch
- barely failed smog...cheap and easy way to reduce NO's?
- B16 swap questions
- Mounts needed for z6 swap?
- Need pics of silver 4G HB
- d16y8 iNTO 91 hatch-ecu help!!
- Vtec controller
- 89 crx coilover help!
- what do u think about this?
- Recommended timimg for NOS ZC and spark plugs??
- Bouncing Tech Needle
- crx swap question?
- SCRAPPING 2.0 hatch project..........
- need a brake upgrade?
- For all you Civic HB Owners
- Crx SI ECU on a LS motor
- can you confirm ZC hp specs?
- Please someone kill me!!! I hate my B16
- *finished newest home depot projects on the hb*
- mileage difference between l3 si and dx tranny?
- whats an 89 si drivetrain worth
- just a quick question for b16a swap
- Billstein vs. Koni
- got a code 0 and a code 23 today
- 91 ls ecu in a 91 si ???
- ***APEX'I S-AFC install help!!***
- question on why my motor wont start!!
- Beefing up bottom-end of ZC
- Rex stories? Good idea/bad idea? Making a daily driver?
- ZC lsd trannys, how hard is it to find them?
- i/e/h frp, vtec controller=wats ur setting for ur controller? comparing
- when do i need cam gears?
- What is the stock timing on a....
- Is it worth it?
- My D16a6 on a engine stand.....
- Free Online CRX SiR Service Manual
- Need a pic of something....
- Apex Vtec controller- 91 B16 CRX SI
- SiR crx
- Suspension thoughts...
- Oil pump for ZC
- possible investment????
- Brake Question.......
- any car shows/drags in the Indiana, Ohio, Illinois, Kentucky areas?
- gude throttlebody?
- VTEC switchover
- yoyo
- intrax springs
- Mini-Me Help
- will an EG rear lower tie bar fit an EF civic???
- anyone need stock suspension
- do people still do zc swaps?...?'s
- Pinging
- what CAI for mini-me?
- Location of PG7 ecu???
- How do I know when to increase the Fuel Delivery?
- Rewiring Gauge Cluster from 89 to 91
- serious problems..need help fast
- typer
- axles...
- Need HELP!!
- More mini-me troubleshooting
- Taking out A/C Compressor?
- found a rex is it worth buying
- No tar?
- ecu plugs
- My CRX is back on the street! (nightmare)
- Anyone have a pwr mirror diagram for the '89-'91 civic sedans?
- jdm integra console
- best clutch
- moving bumper-light turn signal to corners?
- Sunroof gets stuck.
- what kind of camber kits is everyone using?
- Does the radiator from an AT Ek Civic fit in the MT version of the same model?
- want fuel presure on talon injectors ??
- Lowering my car AGAIN couple quick ?'s
- where can i find a cheap b16
- Alternator re-wiring... obd2 alternator
- Rota slipstream 16x7 rims, will they fit?
- FS: 89 crx hf REBUILT MOTOR!!!(also in classifieds)
- would your ecu throw a code if timing belt was installed improperly?
- 2000 type R seats into a 90 crx
- Car wont start unless you push start it
- OK finally got the rex insured and these are the problems:...........
- JDM B16A2 distribuitor
- which adjustable cam gears for a DOHC ZC?
- CKP Code 4 WTF please help...
- tranny+clutch swap 88 Accord DX to 91CRX DX?
- Mini me problems!!
- B16a or B18c1?!?!?!
- rear flip out window
- B16A2 sohc/dohc ECU difference
- Valve Lash for Mini-Me
- 92 LS(obd-1)...should I go obd-0???
- B16 starting then dies (sometimes)
- dsm injectors
- del sol radiator on b16 ef
- positives/negatives
- Anyone know how to take out the headrest off the Si seats???
- How to check tranny fluid level in a b16a1??
- Skunk2 exhaust...
- Taking out A/C Condensor?
- How much for CV Boot Repair ?
- sos! engine won't start
- lowering springs
- One final question before the ZC swap next week. . .
- DOHC ZC block guard
- homemade CAI
- eBay Coilovers
- JDM climate control in USDM rex?
- bouncy!
- 99 Si Exhuast
- michigan, ohio, illinois, indiana kids!!
- where is the ecu located at on a 1990 crx si?
- Upper Ball Joint
- Exhaust sound question
- Need some diagnosis
- MSD RPM activated switch....
- troubles
- WTB:used 88-91 civic carbon fiber hood!!!!
- Where can I find a jdm b16a tranny?
- are these Koni Yellows???
- if it aint one thing, its a mf nother
- Does any one know??
- PLEASE post your ONLINE SHOP here
- The Track
- san diego ht meet
- cat and exhaust
- What tires for 13 inch old skool enkei's?
- I'm pretty sure I already know the answer to this but.....
- 90-93 integra mc and booster swap
- Where to buy a tranny in So cal
- rain = no go
- free hood
- 5pt Racing Harness in CRX, Anyone done it?
- suspension
- Thermal Wraps, has anyone used them?
- 85 harness in a 89 crx?
- 88-89 crx rear lower control arms?
- Best spring shock for under 600 ???
- Hesitation
- someone in NJ with DX tranny
- Old School Rim
- D16Y8
- problems with b16 in my STD
- I may be building B series cam gears..read
- Painted grill behind Fenders
- Gut the Cat
- I need help with my 89 Si.. its running really bad... HELP
- CRX HF swaped D16Z6 (wire problem)
- Name that part...
- holy shit! alignment cost?!
- Oil pan question????
- EFwith ls..
- Which tire size for my 16x7 rims?
- Greetings
- What Manfold Intake is better?
- question on suspension adn alignment
- Does anyone have an email address.........
- Someone hit my fender.. lucky ??
- Where to find 4G injector plugs
- Newer injectors with non-OBD Ecu.... Will it work?
- brakes
- 6 months and STILL trying to figure out what crx I want, opinions please....
- Too much to spend??
- White stuff on windshield Look!
- does anyone have pics of a 90-91 crxsi teardrop wheels painted gun metal or black?
- EF Owner in Arizona SCREWED My Friend Over! Must read!
- b16 arrived....questions
- Hypertech
- Car almost stalling. Need help Tech's.
- need a transmission place in md or dc....
- i noticed something rare on a 4th gen the other day
- who has upgraded their brakes?
- Interesting.... everyone *READ*
- 91 crx si rims w/tires, first $100.
- Sparco seats in 2g CRX - reusing seatbelt clips??
- my crx si w/si rims
- Stoopid question
- Vtec + turbo
- Thank you everyone
- ZC question,,,,,,,,,,,need anwser ASAP
- Finally its alive!!!!
- DC Sports Header
- cold air pipe that goes down thru frame and filter sits right behind fog lamp hole???
- My Busted First Gen
- Ultimate d16a6?
- anyone have a spare stock crx si exhaust?
- 88 CRX Si clutch, LSD, flywheel question
- codes 4 and 8
- choice: tokico "blues" or kyb agx's
- D motor piston questions
- New Swap Unfamiliar
- EF CRX for sale in so.cal.
- Can I use any Integra axles for my b16a/CRX Si swap???
- guess what i did on the way to work today hehe
- Anybody have an extra D-series oil pan?
- questions help!
- starter gone bad aon b16a crx, help
- Anyone got an all WHITE REX? <please post>
- Anyone got NA D16A6 Dyno plot?
- Need dist. pic.
- sir axles with y1 tranny??
- B16 alternator went out.
- Question on grinding in 3rd gear?
- sohc vtec head on an 91 hf bottomend......able to be done?
- Picture of JDM DC 4-1 on ef ground clearance
- Re-using clutch
- Washers from drain bolts! Reuse or new ones?
- 88-89 Teg Stuff for zc motor!
- mugen
- help !!! need help and suggestions with headgasket install
- Es Muffler...who's using one?
- Engine Clearence, Weight question, Hood CRX??'s
- What crx's have sway bars?
- 91 crx si rims for sale
- ecu
- Where is the best place to swap in South Cali???
- i need mugen cat back exhaust for my ef9!!!!!!
- 92-95 civic intake manifold
- Cable to hydro half conversion....
- d16y7 frustrations
- PG7 is it an 88-89 teg ecu???
- 89 b16 in CRX, alternator clearance, shorter belt?
- HF ECU with ZC?
- Auto to manual
- Latest pic
- Gas smell !
- looking for si back seats
- any has b16a swap with predator style hood or monster style hood
- Where can i find a RPM/SPEED calculator for a CRX Si???????????
- Car is having trouble starting
- Looking for cam suggestions for the D16
- Not trying to go crazy but....
- pin changes with B16 swap?
- What is the best motor mount to use for b20 swap in crx hf?
- PW0 ecu?
- Which oil for a motor that has......
- b16a?????
- Vtec solenoid wire on a pr3 ecu
- rear disc swap: 91 brakes on 89 arms?
- My second gear grinds.....grrrr.
- Advice On replacing the rear drum and control arm with disk
- When you put a B18C5 into a CRX, do you have to....
- EF 4DR Exhaust system
- Chassis Mods for EF 4dr
- How to I adjust the fuel mixture on stock engine ???
- Distributor problem?
- EF ownZ j00!
