View Full Version : Honda CRX / EF Civic (1988 - 1991)
- 91 civic hatch 2003 accord motor
- crx hood
- ls crx
- d15b7 motor in dx
- Suspension Techniques struts any good?
- crx seat belt
- Greddy sp2 on HF Qest.?
- car wont start (d series)
- crx foglights
- Water lrak in trunk
- I'm a CRX whore!
- need help with d16a wiring
- P28'd D15B running LIMP
- crx motor mounts help
- brakebooster/mastercylinder question *SEARCHED*
- d16z6/y8 valve springs & ret. in a d16a6?
- crx h22 dilemma
- code 23 (b16a1)
- Sunroof woes!
- Steering Wheel Bolt? Help plz quick Q!
- Would a bad thermostat cause cold temps?
- B-series motor mounts
- Timing Belt Question (D-Series)
- !?HELP?! Alternator and batterey issues!!!!
- Water in headlights
- head torque settings???
- brake booster question
- RHD swap firewall conversion need someone that has experience
- one a kind tranny
- spark question
- Can I replace just one strut?
- $60 to whoever can get this car running with no codes (909)
- please help!!! fuel pump isnt kickin after i did dpfi to mpfi and no spark!!
- EF Color question
- halfshaft
- My 89 Si LSvtec
- d16z6 Swap Questions- Da Rad- Code 21
- wiring questions
- New to the site and have compatability questions
- really strange acceleration
- Air/Fuel Ratio Gauge
- OEM wire plastic tiedowns
- turbo crx wont start
- NEED HELP!!!!!
- Civic Hatch Exhaust...
- Finally!!!!!
- i cant find out where my rpm wire goes on my dizzy
- Battery relocation?
- considering new headlights
- vtec or not
- crx SI rod bearings???
- 2nd gen crx DX/HF roof?
- rear disc problem
- 1990 Wagon RT4wd ?'s
- ITR interior in EF DX hatch
- Vtec question
- anybody ever had the same problem buying ex rotors?
- ls vtec throttle problems
- 300 WHP D motor recipe, yes you can have one alot easier then you think.
- Whats a good website to buy a swap at (any jdm engine really)
- b16a thermoswitch
- DIY: 11.1" brakes on DX knuckles at long last!!!
- D16Z6 WONT REV HIGHER THAN 3200?
- where do i mount my gauges?!
- New possiblities
- Did tune up and still has loss of performance/sputtering.
- D16Z6 Si tranny in EF
- Engine problem with D16Z6
- What are these leaks coming from????
- HELPPP!!! 91 civic hatch ls...... linkage or tranny prbolem?
- 95 si hydro tranny into 89 ef
- stray wires
- Just bought a 91 Civic SI.... 1 problem, doesnt start, have to push start it :)
- NEED HELP ON MY 88EF
- looking for a turbo sohc camshaft for d16a6, site
- d15b2 and zc question
- Lets all sit down have a nice cup jo and read the RULES
- D16 Head gasket question?
- electrical problems need some help & answers
- weird acceleration/ coolant temp issues
- help mpfi fuel Consumption 14mpg :(
- new to efs(dash)
- problems starting please help!!!!!!
- b16 swap
- somewhat new to the EF scene.
- ZC Crank Gear question
- zc swap into 1989 hf crx?
- 91 crx
- please help new to hondas need opinions
- head gasket
- shorted something out HELP
- B16 Mani
- help car is leaning
- b16 swap
- Do 89civic si have Door bars?
- crx B series hydro swap information needed
- tranny swaps(civics and crx)
- crx l3 tranny what to use? Experts needed!!
- What axels for B16 swap?
- spun main bearings
- Installing new arp rod bolts and need info about new bearings...
- lx auto won't turn over?? please help...
- Tire pressure winter vs summer settings
- new crx project this weekend!
- car wont start. batt ok
- quaife says there is no atb lsd for the zc l3 trans with 27 spline
- del sol dash in 91 crx?
- integra dash into ef hatch
- Whats the widest wheel/tire size you can use on your EF?
- overheating problem???? new thermostat badd?????
- control arms
- How do you PM
- Electrical issues, No crank, No start, No power, battery fine, help
- i have to be the most retarded person
- crx project
- Major Over Charging problem...Scared my car will catch on fire!!!! 19.5volts!!!
- sls/vtec questions
- Wipers Not Working
- anti-theif set-up question
- What Bulb Socket ?
- Fan Turns But No Heat
- where can i get a j's racing lip ?
- Goodbye to the Honda world!
- SI RPM
- Chipping ODB0 For BRE/TurboEdit
- question d16y7/y8 mini me to obd1
- I hit a curb. Need to find out if the frame looks bent? Opinions?
- d16y8 exhaust manifold
- check engine light goes on randomly.
- help!!!!!!!
- DPFI to MPFI question
- ...:: What all Transmissions will fit a d16a6 ? ::...
- jdm parts
- B16a with obd1 or 2 vss
- Brakes Newbie (still) Having a Hard Time
- HF vs DX axles and HF vs DX knuckles (and Teg knuckles)
- Need a know working OBD-0 b16a ecu to borrow! I think mine is broken..
- phantom grip lsd conversion-upgrade
- My EF got snowed on today
- blinker is fast
- civic hatch SI v. STD springs
- 1988 Civic wagon
- Does any1 knoe if the Da Lip fits the EF???
- little 90 feels like dieing at idle :(
- anyone know who's car this is?
- Is EF8 Stock Air Intake System Compatible With USDM Cars(When Doing Front End Conversion)
- B16 Tranny Question?
- NEWbie....
- full race radiator 1/2 size and FAL fan fitment in crx
- Wtf? Tranny swap question
- bad cps?
- jdm ef civic si brakes
- mpfi swap z6 mani, map sensor?
- unplugged control unit unknown?
- Injectors wont open no Grounds....
- d16z6 obd0 dpmi to mpfi i can''t find info on this for this motor
- o2 sensor....
- Rear wiper wiring question.
- Help ! with ECM code issue
- Clutch problems, NEED HELP QUICK!
- Ls brake swap
- problems with the crx
- Shed some light on rex dash? 90-91 bezel on 88-89 dash?
- d16z6 into 91crx
- What are these holes on the back of the bumper for...my friend told me but i forgot!!LOOK!!
- D16A6 Acting Strange- No Codes
- 90-91 CRX sir front clip????
- DA radiator interchangeable with EF? AEM fuel filter compatible?
- no spark fuel pump isnt working ef hatch dx obd1 jumper obd2 gsr... !!!PLEASE HELP!!!
- Lowering Springs and Shocks
- stock rad and turbo
- auto or manual ecu how do I find out?
- DA center console pieces into EF?
- swap info
- tranny
- rear disc brake swap quest. for my '89
- Installing D16z6/y8 into CRX, need input
- obd0 code 15 problem
- New shocks and sleeves, DISTURBING NOISE!!!
- FUEL PUMP
- CRX exhaust question
- Speaker removal
- My project! 91 honda civic si
- Tranny Install issues
- pic request: DRL relay, how to keep DRLs on all the time
- Let All Read The Rules Together.......................................... .Hooray!!!!!!!!!!!!!
- service manual
- question to all of u jdm frontend conversion guys
- Wiper Question...
- need help
- Does anyone have pics of the Cusco Brake master cylinder brace?
- Quick ? about exhaust
- valve springs, and valves
- JDM EF b16a o2 question
- Plug Wires
- Thoughts on better Gas mileage on my Crx HF
- engine mount problem
- I can't figure it out
- whats the deal about the 3 stage vtec or the vti
- how do you feel about the d15b vtec in a crx plz send feedback
- code
- OUT OF ZC AND D-SERIES WHICH WOULD YOU GO WITH
- NEED HELP I HAVE A 88 CRX SI AND NEED SOME INFO ABOUT A MOTOR
- help with springs 88-91 Honda Civic KYB AGX Adjustable Shocks
- Outside done. Inside is under construction PICS***
- P8R Head (Ive done lots of searching)
- Is the HF steering column interchangable???
- wiring
- wtb body parts for 89 crx hf
- Can I use my old MAP sensor for my B20 VTEC swap?
- hey i had a question about how much gas in the std 88 civic can hold
- axle
- $1000 for buddy club body kit unibody motor and help with install. Good Deal??
- Help With 91 STD model wiring
- signal light plugs
- Type R throttle body question
- HOOD LATCH ADJUSTMENT
- Steering rack or something else?
- JDM sir air filter replacment????????
- Exhaust systems?
- Thermo Sensor
- 03' CIVIC CLUSTER SWAP
- super tech springs with stock z6 valves?
- quick question
- Screwed up my EACV, and IAT wiring, what colors go on what plug?
- heater
- Drum brakes
- What fog lights are these?
- 11" fastbrakes adapter - anybody got pics?
- Questions about doing a Zc dohc Swap
- Need help with broken ignition column
- wire gauge
- o2 wire
- D15Z1 swap into CRX HF
- sway bar end link
- wiring problem!!
- spoiler question
- anyone up late?? obd2 gsr in 89 dx hatch... all wired no spark!! what could it be??
- distriButOr question?
- Help Need Your Input Potential Starter Problem I think
- 1 month for full swap
- Stock exhaust pipe size
- 90ed6
- Wire for lights on cluster
- 88-91 civic wagon rear trunk pic ?
- Can someone ID this thing on the intake?
- does anybody no what quaife lsd will fit a 90 zc dohc l3
- apart from the ZC, what else is an easy swap
- So I got a ticket for my Apex'i N1 today....
