View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Repair manual
- Taking apart tail lights?
- What is the correct part number?
- NRG Seats In EF...
- How does coolant flow...
- Need help with soch vtec swap
- When i put on front Camber kit.....
- Teg seats in crx. This is for my buddy
- Glasstop CRX production numbers.
- wiring for UK/EDM headlights on USDM car
- is this the ac??
- z6 inake mani onto A6 head... extra coolant line?
- b20 swap on crx need help on wiring
- (no start issue) i am a honda owner again, and it feels good. ($60 ef content)
- crx hf with a vtec-e
- Fuel Pressure Reg.
- rear window reinstall
- what parts do ineed for 91 ls swap in my 89 crx dx
- FAQ 88 to 91 doors.
- Brake Light Won't Turn Off
- can i remove a few items
- clutch question
- jacking points. With aftermarket crossmember.
- driveshafts
- pics of a bad day
- Could I have broken something?
- All Lugs Came off when driving, Lugs were super tight
- wheel spacers
- anybody got EF SI seats that will go into a 90 dx hatch?
- DA seats in 91 EF
- Tail light problem?
- D15B Jdm spec question
- Which Harness?!
- battery question
- wtb si crx sunroof panel stripping seal
- Messed up idle
- swap parts?
- Mini me 18-20 mpg?????
- Will a Z6 head fit on a D15B block?
- does anyone know what would cause
- Heat Control center
- crx headlight assemblly, 88 89 same as 90 91
- just installed skunk2 intake manifold fitment issues
- vibrations
- can i use any other window?
- can i run a 90 dx motor on a 89 hf ecu?
- Steering problem?
- My road racing crx.
- turbo issues
- supra non-turbo injector ???
- heater fan switch broke. temporary fix?
- Coolant level issue..kinda know what you are going to say
- D16 Header Fitment
- Wtf is wrong with my tps...
- Which Ecu?
- idle problem
- Comptech air intake on the rex?
- New here & need some help EF build
- what crx/hatch parts will fit on an ef 4 door??
- 90 crx dx and civic si hatch compatibility
- Honda swap Guide
- Beeping Won't Stop??
- wings
- b18c!
- ecu?
- what could cause this???????????
- GSR Rear seats
- Help car stopped running & wont start
- Carbon Kevlar or CARBON FIBER!?
- How can I take of the molding on my CRX?
- Repairing an Axel
- Junk Yard Memories
- D16A6 into DX Four Door? quick question
- cable speed sensor h22
- Removal help
- Power is on when key is off!!!
- crx front lip
- ATS Cup Wheels
- car won`t keep running ( fuel problem)
- D15b Transmission
- engine swap question for 89 civic hb
- itr motor in 91 crx si which ecu
- Ef squad???????
- What octane should i run for stock D16z6
- d15b2 question
- Gas Leak
- Header for B series in EF
- Thermal Exhaust On CRX HF...?
- D15b1 block, and z6 head
- erratic idle
- *** Cigarette Lighter Assembly * 91 Hatch
- How do I remove a broken manifold stud?
- freakin heater problems!!!
- Car clicking but not starting.
- what part is this?
- seat belts
- Need motor swapped in NH
- Massive Gas leak!!!
- Crx Power
- stock fuel gauge question
- very confused d15 with z6 head
- What exactly are the duel point motor's??
- domelight help
- Climate control question
- Engine Light.
- 91 si cluster in 88 dx
- 2000 Si seat's in a "91 hatch how well do they fit??
- Ebay short shifter or b&n short shifter function over fashion what do you think??
- tuning
- Egr ??
- zc swap jerky at 2000rpm
- LS VTEC into crx HELP
- a/c and heater
- Over revving car while driving
- 88dx to 90si cluster
- can 89 civc dx bumpers fit on a 91?
- fuel problem in 91 hatch
- d15b specs
- cluster swap.. help!!!!
- Car won't start
- *JDM Amber corners, HELP*
- itb'z ???
- USDM to AUDM comparo
- dohc zc msd
- dohc zc help!!
- Does a b18c5 fit?
- SOHC vtec * hp help* please read
- Fitting B-series turbos in ef's?
- crx, no brakes?
- Automatic B Series
- looking for quiet exhaust
- Cluster swap help please...
- passenger fender needed 91si
- black widows
- Stock Intake Tube, LS in 88 Civic
- Ordered a JDM Dual Carb D15 recieved a JDM SOHC ZC Dual Carb, What do I have?
- Part# 95-99 Neon Radiator NON a/c
- what do these wires go
- temp gauge
- weird wheel position
- is there a Diffrence between the 89 D16a6 and the 90-91 d16a6
- Noise+smoke= i need help
- specs for d15b vtec igniton timing?
- DOHC zc valvetrain upgrades
- Please help!
- brake light and horn issue
- headache!!!90crxsi wit 90 ls motor..need mad help
- Green Aftermarket lowering springs
- sensor questions, need help.
- OBD0 turbo is it possible?
- Supercharging a D16Z2 EF?
- CarbonFiber Hatch... It is easy to put on?
- cable-hydraulic conversion?
- where does the o2 sensor plug mount?
- Valve Cover Interchangeability
- B18c in to crx Hf questions.
- Shocks w/ Adjustable Dampening: Opinions Needed
- crx front end wreck repair
- suspension problems
- Which B18 series engine is the one to buy?
- MSD ignition on a honda?
- weird valve issue? please look
- paint a 89 civic valve cover?
- Just can't win; Trans question
- camber kit
- CRX Automatic windows
- 89 civic LX starting problem
- 1990 crx siR
- zc motor into 4 dr EF
- motor vibrate too much
- k24 swap questions.
- Wiring Help
- swaping with ac?
- EF build Q's???
- steering column problem
- Overheating
- accord injectors/tb?
- hey give me advice!
- Turbo Tantrum
- Squeaky alternator belt
- h22a swap in ef resistor box help
- crx corner light problem.. happen to anyone before??
- Vtec connection.need help.
- Code 10
- Aftermarket Radiator
- Are all rear disc brakes hubs for the same?
- NGK Spark Plugs - D16Z6
- hub/quick release/ wheel combo, your favorite?
- If I put a Z6 head on my OBD0.....
- 95 si front rotors/calipers on 90 si ef?
- 89 mini me swap???
- Will this work?
- Relay issues
- Swap help!!!!!!
- another b16 prob
- help with crx fog lights
- maybee someone can help me....b16 swap...
- need help
- im a noob
- can someone help me out with this!!
- need help with turbo ef
- Can u install an integra tranmission into my civic???
- Help me finish my wire tuck
- repairing crx moldings?
- how did the crx gain weight?
- crx weather stripping?
- mounts, hasport, innovative or oem
- No electrical power in 91 civic dx hatch
- Transmission trouble
- rear disk's..on a sedaN questiOns..
- HELP DId a Engine swap Makeing wierd noise when trying to start
- 89 civic hb swap question
- help car not runnin ryt
- Reoccuring code 1
- what seats will fit in a 1989 civic hb?
- Headlight differences...
- EF Rear Bumper
- hatch front on a crx
- OEM replacement piston rings
- 88 crx stock speedometer switch to si
- is it my clutch or somthing else? help!
- EF hatch with red carpet?
- Crank, No Start Solid CEL
- CEL. 90 STD with d15 block DPFI
- EF Si and Ef
- my project crx w/ ls swap
- Heater Core removal?
- what type of ecu is this PM6?
- for sale ef9. si b20 swap
- no spark!?
- stereo not working on dx hatch
- 10mm wider front tires worth it?
- my heater is about to make me pull my hair out
- revs to 3500 when cold
- dohc zc crx dx did not pass emission...in need of serious help
- serious vibrations!!
- Help! 90 crx hf, bad vibration
- for all you traction bar users
- Just picked up a 91 EF
- Suspension Issues...
- skunk2 intake manifold question
- 91 civic si idles low
- Buying a motor
- Winter
- ef9 power folding heated mirrors
- Suspension/Steering Problem HELP!!!!
- mpfi swap troubles?
- Crx wont start help!!
- stock si ecu + vtec
- my hood prop cable disengaged itself help!
