View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Chopped EF Hatch
- Z6 swap....need immediate help before I start
- ls crank question...
- JDM FEEL'S sway bar
- can i use a b20 (CRV) oil strainer on a B18a?
- Need a replacement fan. Need info
- Fuel pressure Reg
- Where is everyone installing their FPR Gauge? Pics Please
- Paint Help
- obd1 O2 question
- Identifing Head?
- distibuter help!!!
- Painting the Engine Bay?
- starting engine problem?
- vacum tube?
- PLEASE HELP ASAP>>>VERY IMPORTant
- pictures of my new car..
- needa find a place to get new or refurbished side moldings
- can't timing to move to the red mark but runs good at tdc
- CRX REAR SUSPENSION
- cOnvErsIOn fOr mY crx sI
- Anyone Got a 91 Honda Civic Si Engine Harness wiring diagram?
- ----->[B]Full 1988 CRX Workshop Manual[/B]<--------
- dash lights dont work any more.
- Car Just Isnt Running Right, No Cels though *descriptive*
- i know someone has a pic of this....
- dizzy rebuild
- High idle after valve adjustment
- b16 code 12
- need help with minime timing
- I Got a clutch install write up here !!!!
- engine started.....now new problem
- si and ex fenders same????
- water tank for the sqirters
- zc crx
- Bigger engine (b16, b18c), bigger brakes??????
- CD player flickers on and off, when off, climate control dosent work??
- vtec not kick and i think timing is off please help
- 17"*7 rims fit for 93 DX coupe?
- Which TRANNY do you like and why???
- civic windows in a crx
- is the yellow and black wire off the resistor box a ground?
- Factory colors for 88 crx hf
- dohc turbo info
- skunk2 coilovers from DA fit my EF hatch?
- main relay, no fuel pump?
- Which Transmission for ALL MOTOR b18c1 crx?
- civic glass in crx
- B16 Engine mounts ?
- 87 crx si
- Fuel Pump Fiasco
- trippin temp gauge Question
- 86 civic?
- is there a catalog for ef only
- New clutch will not mate with tranny
- progress pics and some questions...
- will ctr pistions fit in a b16a1? what rods should i use
- Axles binding !!!!
- DAMNIT!!!! Code2! Out of ideas.
- does the d16y8 manifold fit A6 head?
- CRX clutchkit (ProClutch) ?
- HELP! APEXi Power FC in a CRX w/ a 200 JDM B18C5...
- Do I have a bad ball joint?...symptom...
- 85 Civic problems
- Place Racing x-member
- 86 dx si
- CRX Project!!
- which ring position, koni yellows and GC?
- z6 runs after.......
- $$WTB$$ REAR MUD FLAPS
- crx and da exhaust?
- SLOTTED ROTORS FOR 89 SI
- P32?
- WHere to buy ZC
- Modifying Signal lights question
- fuel filter
- block swap complete.....now no start
- got my koni's in, now i have a question
- CRX swap
- pinch bolt / shock position Q's
- HELP. CEL after swap
- 1st gen crx engine swap plz help
- EK Civic Type-R Pedals in EF CRX/Civic? Need Help!
- What tranny?
- why won't my front turn signals blink?
- code 9 and code ?
- ZC motor mounts to swap an ED hatch?
- 91 civic with a crx Front conversion?
- '90 Civic si Question
- civic 4drs hood
- brackets/sliders
- NOS
- slicks
- Which motor is better?
- 91 CRX Engine Swap. Please help.
- B18C/93 YS1 tranny swap: can I use a 94+ VSS
- hesitation at high rpms
- si vs hf tranny
- 'newb question'
- amber bumper lights
- Need sites for B18A1
- 89 Teg Brakes, on a 89 Hatch Si?
- got a problem speedometer drive sqeaking?
- CRV bumper
- i need to pull my longblock....help
- Tranny fill hole help
- Srange sound in gear box or tranny..
- Tell me what kind of vehicle this came out of and i will respect you for all time.
- mirror fitment
- syncro problem/question
- manual to automatic
- suspension
- 4dr spoilers/seats options
- I NEED SUGGESTIONS ON HOW TO TIME CAR CORRECTLY
- PLUG WIRE placement for 1987 crx si?
- Have 88-91 Civic Hatch DX...Swap info needed...
- SI and DX Wiring Harness Diagrams
- TEIN SS-P for CR-X... (so very nice) - damper settings questions
- whats the Vtec change over point for the Jdm obd1 pr3 ecu?????
- ITR wheel fits nice in a CRX (and update on my project)
- fuel cut off in a 91 dx coverted to a d16z6
- can I remove an engine without removing it with transaxle?
- I need help ASAP!!
- one piece front ends
- 91 Main Relay Location
- 1991 civic engine swaps
- Tranny noise with or without clutch engaged.
- b20 crx swap
- Bumper Help
- Exhaust Q's?
- Integra wire harness
- STi, WS6 T/A, SRT-4, Nissan V-Spec
- Hatch Rattle how would I fix this?
- Seized rear caliper, not sure how to fix.
- question about chassis codes
- What shift linkage?
- Forced air intake anyone?
- DOHC ZC head and block plus more
- what bumper is this??
- Keep blowing fuse, looking for advice
- fuel to Injectors question
- crx 1991
- What valves
- Challege with 91 honda crx hf exhaust system
- fuel injector
- car running to warm
- car wont start
- engine removal
- how slow would a stock 85 hf be w/ 17in rims
- Installing GSR Questions for Heating Component ?
- Questions about FPR and FMU
- EF 4dr w/ b16, any times?
- T-25 Turbo and Coolant Lines
- T25 Turbo and ZC
- Correct me if im wrong
- civc loading up???
- IACV question!
- TRANNY CODE FOR 2000 Civic Si
- Battery light came on after I douched out the engine compartment
- Dilemma :(
- Help me with my little dilema: Rebuild the A6 or swap in a DOHC ZC.
- 88-89 teg ecu for dohc ZC'
- any one got the same problem?
- SRT-4 vs Honda
- exhuast
- Who has done an auto to manual swap?
- My 88 CRX Si for 88 civic Hatch
- USDM type r pistons w/ eagle b16 rods in stock b16 block????
- best front crossmember?
- Brakes
- Timing Question
- Wiring problem - Im pulling my hair out here!!!!!
- CRX shell i just baught
- Clutch Installation?
- KYB AGX's
- new to the board, some pics and info on my car
- es suspension kit. black. what else am i missing..
- weird engine code
- BUILT Sohc/Dohc Zc or D16a6 Who Done It? Pointers?
- es bushing kit.. red & black
- Tie rod problem?
- Help: Fuel pump not priming, car not staying on But it cranks
- what does your b16a hatch run
- "exhaust question"
- how to read?
- firing order on a 90 si
- EF Hatch & Sedan---> Same Front Bumper?
- my new mod. actually i hit an elk doing 50mph
- Easiest interior swap for 88-91 DX hatch
- Question on Koyo Radiator? Crx/Civic Ef Only,Please.
- Major camber problem at one wheel. Please help.
- Anyone know the in/ex valve sizes on a DOHC ZC...
- I NEED HELP FAST WITH ECU PART NUMBER
- HB Civic in need of Power.
- More Wings West.
- why are the 88's lighter than the 89's?
- anyone paint there interior?
- 4 speed civic hatchback EF
- So who is all coming to N10?
- Engine Help.. prices!!
- Cargo Divider 88 CRX DX?
- TPS problems!! how to check it!!
- JDM cluster+ stock cluster??
- picked up my new EF....check it out (your cool 56k)
- What times do you guys run with ur LS swaps?
- what this part for ?
- buzzing relay / obd1 injectors? Wiring problem possibly
- Daytime running lights on crx ?
- How can I keep paint from chipping?
- car rolled down the drive way
- Crank pulley ...Help!
- Civic DX has trouble starting (fuel delivery)
- 91 DX Hatchback Master Cylinder Upgrade
- two way valve on gas tank?
- My "new" EF
- no lights WTF?
- 2000 Si spindles on my 88 hatch
- d16a1 out of 88 integra, is it worth the trouble??
- loss of fuel pressure
- anybody running a jun or toda header with stock x member
- zex nitrous kit help
- pm9 ecu pinout
- Whats the weight of an air conditioner?
- H22 Ef w/ Hasports Mounts H23 Cable Tranny How Hard?
- NEED HELP! (Timing belt/Headgasket Project) Wont start?!?!
- b16 headers with two bung.
- how much does your (lightened) flywheel weigh ?
- ECU setup? mugen chip experience?
- wat steps to take on primering a crx?
- ?new fuel pump issues?
- pipe rattles
- goin crazy need help
- ignition switch color codes ASAP
- New W/ Questions
- No spark on distributor.
- the earlier vtec kicks the weaker it is right and the later it kicks...
- new EF squad prototype shirt y0
- i just bought a Ls B18a Waiting to build a Lsvtec but....
- drum brakes VS disk brakes (weight dif)
- I really need help with installing a/c in an 89 crx with an LS swap..
- funny idle...
- Need Help with my JDM Obd1 pr3 ecu PLEASE LOOK!!!!
- JDM ITR 4.785 Final Drive in JDM Cable Trannies?
- Key won't turn in the ignition
- rear trailing arm bushings
- secret switch in 87 civic!!!...
- 87 CRX
- how to attach fuel pressure gauge to fuel rail?
- A'pexi EF civic exhaust and the rear sway bar Bang Bang
- ZC SWAP HELL Sputtering HELP
