View Full Version : Honda CRX / EF Civic (1988 - 1991)
- possible compressor bearing noise?
- b and d series tranny's
- New guy w/ a question
- im confused
- starting uncertainty. my dx won't start. i get hear a click when i turn the ignition...
- y doesnt my b16a1 pr3 crx have no power?
- hf crx: changed ecu from pm8 to pm6 and still reving to 5700
- how to adjust teh clutch? teh setup right now i cant even chirp 2nd
- Spark plug gap for 1st gen B16a (jdm yO)
- WTB: d series trannies?
- lexan windows
- Axle Problem
- IAT sensor for B16A motor?
- Clutch Replacement in b16a1...How Too???
- Another Turbo'd D-series
- brakes pulsing/vibrating??
- Need Help Installing Hasport mounts (B Series into Crx)
- axles
- what is this???????
- RSF2 with tires
- my first crx project
- air conditioning removal
- whats the engine code for a 1st gen crx si fuel injected?
- Vtec swicth leaking
- Zdyne wiring document help
- EF Wire Tuckers BEWARE!!
- Clutch pedal sticking then releasing a few seconds later please help !
- No power whatsoever but battery is fine..
- how do you CRX/B16 non lsd get traction??
- Security for a CRX
- y8 intake mani on d15b2?
- 88 CRX Transmission
- pics of sir wing on hatch
- Crx with all 4 gsr disc brakes, what suspension to use?
- relocating battery and optima red top ?'s
- installed autometer but doest work someone help!!
- 91 civic four door lx, door locks inop HELP!!!!
- 1990 Civic H/B Swap Advice!!
- would my dc2 coilovers fit a 1st gen crx?
- LED's in blinkers now solid and buzz from flasher.
- d16y8 knock sensor
- injector wires...two left
- Requesting ECU
- overheating VERY BADLY! :(
- b16 ls transexual..oops
- would this add any power?
- Header for my EF w/ B16A
- Bent frame bad alignment...options please help!!!
- D16Z6 and ZC SOHC Vtec?
- tsudo exhaust
- Just replaced my alternator, did i get a bad alternator?
- 88 JDM ZC tranny non lsd in a 90 hatch WHAT AXLES AND HALFSHAFT?
- cooling fan
- what fan??
- b18 into a 1990 DX h/b
- Do 89 crx si and dx have the same drivers side glass?
- 88 prelude ecu in 91 b16 crx???
- Timing Question!!!!
- Buying a 91 CRX Si
- what would u put in your car gsr or h22
- bearing questions
- BRAKE PROBLEM?????
- Best Exhaust
- tire size question
- WTB: 1988 TO 1991 CIVIC AWD WAGON PARTS
- d16a6 with a ported d15b2 head
- D2 racing full coilovers for EF/ED comparison (searched)
- jdm b16a into a 90 crx si harness??????
- 1/4 mile times....
- Intake manifold for B20 vtec's
- H22 swap question
- are replacing brake pads hard on a hatch
- PROJECT CRX JUST STARTED... NEED HELP!!!
- YS1 and Y1 TRanny need help
- CRX could do this?
- header problem need help
- d15b2 w/ d16a6 internals
- b16a1 o2 sensors ?'s
- b16 swap done but injector problem HELP!!!
- Cuttin springs?
- 95 civic dx swap into crx si??
- catalogs?
- Removing condensor
- EF9 gracing the cover of Honda Tuning!! PICTURE
- crx turn signal issues
- BARed H22EG intrest?
- want to build up a trnsmission
- b18 in 91 civic... has spark and fuel = no start
- 92-95 SOHC TRANS SWAP INTO 88-91CIVIC HATCH
- Need some help on keyless door handles?
- Stupid Harness wires
- torqe specs on doors
- cheap parts?
- uberdata
- mini-me advise needed
- Differences in auto transmissions
- H22 TB and fuel pump on a B16a powered 89 rex HF???? (informal intorduction)
- got a tach, need to know how to hook it up
- looking for info on si swap going into hf, haveing problems
- Owned by "The Pin"
- new front camber adjuster, what you think????
- D16a6 wire harness?
- CAN SOMEONE HELP ME ?
- My LS\Vtec build
- A/C Connectors? can i cut them?
- Single cam ZC w/ Y8 head 13:1 compression?
- Which OBD1 distributor are you guys running ??? ( TD44U, TD42U )
- crx si intake manifold
- 3 inch drop
- jdm zc hood question
- selling my hatch
- question abt the station wagon shocks
- bodykit or not?
- obd1 conversoin
- Who's running a carbed hatch?
- Engine Light, Please help!!
- cable to hydralic transmision
- The final chapter in my ED6 project
- might swap b16a2 for itr motor need some help guys
- Yikes! Not sure if this can be good?
- *UK spec and JDM spec crx v-tec cars for sale*
- WTB car for 3G's
- B20 VTEC fuel pressure and ignition settings
- Overheating????
- crx si exhaust
- BATTERY LIGHT
- A good Header for a "B16A1"
- car trouble
- crx and hid question
- New to honda-tech
- L3 transmission question?
- which eacv/iacv fits y8 manifold
- B16 tranny or not?? how can i tell?
- vafcII into obd-0 pm6, pm7???
- need help running oil lines for turbo!!
- i need a crx flywheel
- b16 help please
- looking for bumper for my 91 hatch...
- Bogging...help plz
- CRX Won't Start
- OBD2 Injectors. Will it mess up anything?
- i want a jdm sir front bumper
- dizzy problem
- Where can i find a good peice of plexi glass for my crx hatch
- wings west kit install...
- Honda CRX SI for sale.
- Input on new pro series skunk2
- some nub q's, and a pic request...
- Seat Belts
- HF Swap to SI
- D15b2: What are the NA buildup possibilities ( Searched >750 post still confused)
- alternator/battery problem, kind of a a long read
- electrical problem
- Need Help Now.....
- question?? i took off my dis cap and the rotor screw is tight but the rotor slightly moves, is that
- EF9 CRX SiR center tail light "CRX VTEC"
- AC question
- i put my motor back in my ef..
- stock si muffler
- 0bd0-0bd1 02 sensor wiring help
- EF8 Suspension Question....What Upper "A-Arms" Can I Use??
- NEED HELP ON MY REX
- whats needed for a d16z6 into a 4th gen?
- where is my oil?
- Red CRX lookin for some help
- changing rods is it that hard?
- b16 in 91 hatch --> which radiator hoses? cluthc cable?
- anybody else have shifter rattle?
- white/smoke coming out of exaust, smell burnin oil
- new radiator, what kind of fans???
- hiding the muffler
- My new project (not an EF)
- crx spring question! pls help!
- mini me problems!
- pls help me show my pictures...
- After b-series swap, wont go into 5th and reverse
- stoopid injector question (obd2 mpfi)
- 94 ls cluster in 88 Crx si
- DOHC ZC Tranny with DA Integra Axles mod?
- Pics of my project 4door
- blowing fuses, i'm stumped
- m22
- hey i know this doesnt go here but its important and for el vapp133 and please dont lock
- SK2S1 OR SK2S2???
- EG upper control arms on EF?
- Autocross Project
- Adjusting TPS
- Wings West 6pc. Body kit???
- CRX Camshaft identification problem
- Are resistor box and distributor plugs needed for mpfi swap?
- Idle question
- can i get an opinion on this pay'd nothing for it, thanx nate
- List of CRX Part Retailers
- WTF?
- Crx Smog Coming up
- which wire is the map sensor wire on the ecu?
- Skunk2 coilOWNERS
- Valve Adjustment Power Loss
- Trying to get started on wire tuck.
- New steering issues
- fuel filter
- d15b2 throwing code 7.......
- Are all B Series Valve Covers Interchangeable?
- Anyone rockin the LS Mesh?
- Went to retard timing and.....
- Need help removing rear end interior
- '94 hb - CRAZY TRADE FOR CRX!!!
- Bad Injector?
- where can i get amber corners for my 89 hatchback
- where to find the wiring diagram for the radio
- Steering wheel
- thinking of stripping the rex...opinions
- losing power
- B16crx Misfiring BAD HELP?
- f22 in civic
- Burning smell from brakes
- stock idle?
- NOLOGY HOT WIRES 4 SALE
- cranks starts but dies
- MPFI Swap-4 Red/Black Wires From Injector Resistor???
- Main relay problem
- Towing Auto crx on all fours?
- Rear Brake conversion??
- Need help with stripped bolt
- bogging after cai install
- Intake/Header/ECU....
- some autocross pictures and new wheels
- 0bd0 injectors
- My suspension SetUP
- steering column messed up
- Integra DC2 Type R Momo
- 88 civic b16 ?
- No bumper support! how do i hold bumper on?
- what do you use for fluid in your D cable tranny?
- Finally PASSED emissions! $250 and countless hours later.
- how to adjust clutch on a d series motor?
- help !!!!!!! with b18a1 swap help!!!!!!!
- installing camber kit
- Stock Plugs for a Civic EX 4 door sedan???
- Door buzzer problem
- Oil Pressure Light coming on in the morning?
- Best low and midragne N/A d16a6 cam? Delta 262?
- what headers to buy for ls/vtec
- WTF, car won't start, I need help (who is the master trouble shooting guru)
- Bronze 89' Si Wheels
- 88 crx si bumper fit 91 civic si?
- im thinking about swapping my Si tranny for DX
- turbo manny
- steering column broken
