View Full Version : Honda CRX / EF Civic (1988 - 1991)
- wheel noises?
- Front Transmission Mount
- mini me swap
- cluster problems..
- LS dual crower valvesprings on a 1gen B16a?
- HDSS vs. XTSS....
- Rare Crx Lip
- greddy turbo on a b16 question
- Read this if you have a 1988-1991 car before buying the SPC balljoint camber kit!!!
- Who's EF is this on ebay? looks very nice and mild
- aight guys need some o2 help.
- how would i go about installing A/C on my CRX DX?
- Connecticut Emissions Testing, Is this something to worry about?
- timing the dizzy - question about procedure
- ::will EK shocks fit on an EF??::
- What is this? *pic*
- FAQ: Integra MC and Brake Booster facts all of you guys should know about...
- help...B16 crx
- too many switches-2
- CEL zc swap
- tps out of wack
- hahaa another ebay v8 killer!! Link inside
- b16 swap in a 90 dx, bogging at full throttle.
- DOES ANYONE KNOW "SLOWAZZHATCH"
- Dual aluminum wing question
- D15B7 OBD0 with Y8 head; what to do?!?
- taking apart steering rack
- lost time in dizzy...
- civic door panels in crx
- Wrong clutch for b16a...
- Next mod? b16 looking to go faster
- steering problems!!
- Spoon vtec controller. Anyone have one?
- sohc vtech turbo ??
- Best place online to order main relay??
- Did a search, still confused. Help a moron please
- CRX HELP!!!
- D16z6 wirring harness for 91dx swap?
- 1.5 mpfi question
- Replace Sunroof Motor
- wat alignment to use on swap
- SENT TO THE REF :X
- Good d16z6 header?
- broken sunroof
- Shit...I might have made a boo boo (Installing my flywheel / clutch)
- 91 HF bumper support
- can an alternator solenoid valve FUSE preventing start???
- force injection
- how come i cant post in the classifieds section?
- ecu led stays on after mini-me swap
- CRX Si Rims
- My Car is sucking gas
- 93 teggie cluster and modified harness
- Parting out my civic sedan
- 4 lug type r suspension on a crx what is all needed???
- fixed the beast!
- VTECH
- 93 si swap into a 91
- Is this a real Si?
- Anyone w/ Place Racing Mounts and Hasport Linkage?
- Coilovers interchangeable ?? 90 crx : 91 sedan
- ok..who's a JDM guru?
- Summit Racing NGK plugs/wires...need someone with NGK exp.
- i got a vtec head do i need a ecu cause dual to multi port fuel???..ect
- what are you guys think about single cam vtech turbo???!?!?!?!?
- 215/40/15 dunlop sp?
- Question About radiator Fan **PLEASE LOOK**
- Turbo Tranny Si or DX? WHich one is faster?
- ok i need everyones opinion here please every one read and let mek now what you think
- How do I hook up the switch for my foglights?
- Cel but no code?? no light period?
- engine lift spots
- Injectors not firing on my EF. Code 16
- auto to manual swap.. already searched
- what tranny??????
- need help from anyone who's put in obd0->obd1 harness into a jdm wiring harness
- Possibly fried ECU?
- Just swapped D16Y8 into 88 CRX Si for a friend. Where having problems.
- b18b swap questions - (idling-shifting-performance)
- 4door exhausts
- Weird electrical problem
- Stock 92 LS times...
- Exhaust(un normal) Problem on my HB
- Price of swap
- crower vtec camshafts keep breaking?
- Lubricating the release bearing
- crank and bearing question
- Anyone who has an EF9 JDM airbox on a B16.
- ISKY valvetrain for D16a6 and D16y8/z6
- Searched but to no avail
- HELP! My B16a1 is lagging
- Will a D16 tranny fit on a D15B2 engine?
- JDM EF9 Climate control
- JDM D15B in 88 crx
- Looking into a Civic HB or CRX
- Starting problems!!
- HF Head question?
- Distributor
- If you are RETARDED and don't have a manual.....
- Anyone else own a 90-91 Civic EX?
- Opinions, Please! Replacing my radiator. What do you think of this one?
- Any one run Vibrant cat back exhaust on crx?
- speedo won't work
- Any turbo crx guys have this problem??
- I plan upgrading intake manifold. Need info!
- Brake upgrade
- Wiring the Check engine light to my P28 ECU Anyone?
- Part #s (ran search)
- Problems after installing ZC trottle body on A6 .... Help !!
- turbo install problem w/ radiator clearance!!!
- b16 crx hf vacume line problem
- Y8 IM on A6 head. A couple questions
- Valve Cover Gasket Question for 1.5L DX
- odd hatch combo, What model is it?
- Probably asked a thousand times (Beware, much flamming may occur from this question)
- Boggin Problem
- What do the #s on the Prop Valve mean?
- colr codes
- Best Motor to swap into an 88 CRX Si
- experience with built d-series?
- Clutch diagnostics? (pictures)
- FUEL PROBLEM FOR 1995 HONDA CIVIC DX SEDAN
- ZC engine installed and runs like complete and utter CRAP! HELP
- d16a1 in 1st gen crx
- Will this gauge cluster fit?
- Need your opinion
- Frame/body insulation ?
- Vague shifting after swap...?
- my car runs like shit...HELP!!!!
- anyone run obx cat or axel back??? opinions
- Would wheels that came off a 90 accord fit on a 88 crx?
- Problem closing hood...
- Another opinion question :-) turbo or swap? and also should i mold b4 or after?
- black mugen mr5?
- CRX Si For Sale
- best hi temp paint to use on engine???
- ls clutch
- Want to build a CRX drag car.
- Seperating balljoints?
- tranny rebuild time on 90 CRX. What to replace?
- RUST HELP
- Attention all mechanics..(HELP)
- oil filter to use on b16a1
- B16 reliability?
- b16 o2 question
- CRX HF Steering Rack?
- CRX PM7 ECU help....
- PIX - "Dude, where's my Car?", Australian style....!! (56K beware)
- No A/C and heater
- EF8 SiR Power steering cooler?
- Need help w/ install of VAFC onto PM6!
- hard wiring radar detector
- How to make legal
- Differential Pin for 88-91 D series.... offer!
- Place Racing Linkage
- poor gas milage.. very poor
- which rims
- latest improvement on Honda design
- Opinions On Hatch Color
- those with aftermarket exhaust
- Photoshop/pic request: Flat black/polished lip Si wheels
- I'm thinkin of getting a vtec controller....for mpg issues...
- I think i was chipped, ECU problem need help
- help!!!turn signal goes on wen i press brake
- <<<< PLEASE HELP!!! I Need A 90 DX Distributor PLEASE HELP!!! >>>
- zc sohc sensors question?
- CSP/STS: Using update/backdate rule to lighten a 90/91 civic to 88 civic specs? (cross-post)
- Low idle emissions failed test....Help please
- new b
- Cable clutch problem....help!
- 88 crx si...worth the money?
- rear disc swap on a 89 hatch
- has any1 seen a ef with a b18c orb18b turboed?
- Si head on Hf block ...
- 2nd gear grind on 91 crx dx tranny
- Ghetto Garage Racing: GSR cam installation
- 88-89 amber corners
- Car will not start?
- damn cap and rotor
- Stupid Question But Ya...Tranny/Clutch
- rechiping my ecu
- how much for this
- Del Sol seats in 2nd gen CRX!!!! (yes i searched)
- CRX - antenna
- distributor problems
- pr3 obd 0 ecu codes
- how much does a B16 head weigh?
- CRX - new buyer inspection
- Question on 91 si with a b18b
- Where are all the stock grounds?
- Tranny internal transferring
- Problem on ZC, no spark. and ICM wiring.
- my engine took a shit on me =(
- My radiator is leaking! Best radiator to replace it? OEM, Aftermarket or performance?
- crx hvac controls question
- LS-VTEC (almost finshed)
- car wont start, not fuel pump like suspected
- can someone bring truth the the supra zc pistion?
- new here got a question..
- act clutch reinstall....do i clean anything?
- Adjusting B&M FPR
- Speedo cable into trans
- 4 wire O2 sensor on D16Y8 wired to a P28?
- My lil ef.
- EF7 ZC hoods...
- code 6 & 16 after trans swap?!
- hx or vx rims question
- Please help with Setup Qs?
- Turbo D15? Mpfi swap?
- Quick(bad) pic of my new setup
- Car wont start, Check engine light is On. Pleaze help
- will gsr front rotors fit in a 89 crx with stock calipers
- brake pulsates like crazy...need help
- Adjuster on tranny/clutch?
- B16 knocking sounds like coming from head......Read.
- 4dr ex tranny?
- Pics Of my beater.... What do u think?
- periodic hesitation from b16-her's what ive changed. any ideas?
- SI Intake in an 90 CRX. Anyone got pics.
- 88 and 90 Si Dist differences...?
- AWD Civic
- where can i got to get a turbo rebuilt??
- car trouble's
- Want to swap B16 into 90 CRX HF...
- CRX CRANK ANGLE SENSOR! HELP!!!
- crx/integra question...
- how much bigger are the front brakes off an intergra(91) compared to civic(91)
- Converting KPH to MPH on JDM Cluster
- around what hp should i expect?
- WTB rear si disk brake assembly
- how to change a headlight?
- Tranny Oil
- Ignition QUESTION
- Am I Wrong Here?
- Surfboard in CRX? I know it fits in hatch's
- Who sells a test pipe for the ef
- I can never remember...
- Just got a 90 HF for $100. What do I do now?
- Need advice on possible bad brake Master Cylinder
- Need some help to ID a wire. ECU side.
- PM6 power chip...
- PIN STRIPE???
- What's this on Si intake manifold?
- need parts.
- A little help please
- CRX Front bumper on a CIVIC?
- when i pulled out my spark plugs, they where black (looked like they been on fire or something)
- Will Accord springs fit on my car?
- Help! Weird Problem!
- LCA question
