View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Rust starting what to do
- engine trouble with the stock 86 rex
- Reading a torque wrench
- B18A build up?
- hopoking up the the couil to the tach
- STD hb meets b16a....help!
- Bump Stop?
- Need advise on what to buy si civic or si crx!
- is 200k+ miles on a CRX too much?
- check out my new header what do you think?
- 0.6 bar on honda civic nedd any change on Ecu ??
- Integra axles - ABS vs No ABS
- Spoon lug nuts?
- EF9 Roll Cage
- ZC dizzy problems
- Zc guys
- I just bought a cap+rotar for b16...
- transmission
- Problem with the swap...before the ENGINE IS IN THE DAMN CAR!!!
- cigarette lighter stays on while car is off
- Went to dragstrip last night. What do you guys think??
- How to remove Headlights?
- heater core?
- Si and SiR outer CV joints the same?
- mugen type r header
- A few more questions in my never-ending suspension saga
- Spark plugs and wires?
- B16a1 swap into 90 Civic SI HB
- Throttle body gasket
- quick question about backfire on a d16z6?
- EF8/9 Cluster swap help...
- Question about B18 swap?
- What does this sound like
- Heater vent outlet selection buttons stopped working.
- how does everyone hide their wires and where do they put the tach?how to wire in the tach to the coi
- Question about coilovers, lowering...
- another honda is murdered
- Seat Rails
- Element engine/drivetrain upgrade?
- TPS adjustment???
- b16 running like garbage
- NEED HELP: Have Tokico HPs/Blues...what springs should i get?
- Insurance Company help...
- Which rims to get 2002 Civic LX
- Z10 Radius Arms
- Is fuel pressure supposed to drop after shut off?
- My mini-me setup (Im new)
- Should I buy this DOHC ZC for $150? *pics*
- Crush washer question
- dropzone coilovers... not bad IMO
- Hybrid reliability
- will a carbon fiber hood fit in my hb ?
- si transmission
- 88-91 si seats
- crx front bumper support....
- how can i make my alt belt tighter?
- Gonna do another swap this weekend . any new tips ?
- d-series hydro motors fit a 91 CRX Si trans?
- CRX headroom problems
- Need some input
- 5 mirror Rear View Mirror
- EF Weight
- carfax
- question about integra front end on my civic hatch?
- d16z6 swap question
- Look what i just bought
- Update on Project 400HP ZC...56K nightmare...
- need help on si conversion on my dx
- DIY Daytime Running Lights for the EF chassis
- help. my doors hardly close.
- F-ing Ridiculous code 4
- Need Help with Identifying 5 speed trans
- crx owner stickers
- Size of the 6 flwheel bolts?
- D series Intake on a HF motor????????
- crx si seats - can headrest be raised?
- need picture of bolt
- Where do I find a....
- other dseries
- anyone running an-r header for b series motor? (searched)
- HKS style tips?
- b16 into EF hatchie, need some directions
- 5 lug conversion on 89hatch.............
- CRX w/B18C1 vehicle speed sensor question?
- pm6 or pm7 ecu???
- throttle body, need help (d16a6)
- Starting my swap on saturday...any suggestions???
- Info on Injen CAI for CRX w/ B16
- swap guys, where did you buy your engines?
- NEW CRX Clothing -- Front AND Back designs, no logos
- 1990 Honda Civic Hatch Si
- need some help with D series swap
- something going bad
- 91 hatch w/b16 turbo fitting problems
- You think you know your shit? Answer this.
- Just got a killer deal....
- my 92 civic hatch is surging
- CRX Electrical Problems
- Parts for...
- questions for the d series gurus...
- new motor what u think
- car wont start, help please
- Took my hatch to the track on sunday
- cooling fan and check eng light??
- Help... can't decide which 5th gear to swap in
- problem with my throttle cable, using b16
- HF crank on a ZC
- That CRX in HCI
- s1/j1 5th gear swap question
- Usefullness of SAFC at partial throttle
- Hb Vs. crx?
- I don't understand why our b16's get bad mileage but del sol vtec's are fine
- what's the deal with b16 o2's???
- Ls Swap into a Crx what axles? And where could I locate an obd0 dist and ecu?
- CRX Hatch wont stay open
- Tire pressure ?
- If i cut the stock shifter, will it be the same as a short throw shifter?
- Prospective list for my car...need your opinions...
- AutoPower Roll bars?
- A9 and A6 valves the same?
- what is wrong with my zc??
- B16A CRX, What kind of exhaust should I get
- Visual inspection of tranny?
- POSTIVE camber and BAD caster.
- Aftermarket cam specs list for D16A6.
- Best place to purchase OEM Clutch (89' CRX DX)
- heat does not work in my CRX!!! help!
- back seat question.
- pwr radiator for cr-x
- UR Crank Pulley on DOHC ZC...
- KeepIT or LEAVEit
- Leaky Sunroof
- my car was totaled last week, PICS :(
- Good Shop in NH/Mass
- Will a 92-95 DC 4to1 header fit on a CRX? This is for a D16a6
- 88 CRX Suspention to 89-91
- how to fit 90 crx si seats into a 90 civic dx hb???!!!
- Metal Divider On Top of Throttle Body?
- for all you 1/24 scale model jdm nuts
- Do the one piece jdm headlights have amber in them?
- It's always something isn't it......
- ZC Questions...
- Any b16ers out there??
- G2 integra seats "rear" in hatch?
- Strange Idle issues? Suggestions?
- Help me spend $$$ on my b16a.....
- Which ones are better Koni, Bilstein or Tokico?
- How do you keep CAI from touching battery terminal??
- greddy b16a turbo kit on EF?
- Installing CUSCO LSD into B16A1 Gearbox Need Help!!
- crank sensor?
- 88-91 Civic/CRX ZDyne Gold ECU Group Buy
- Buying Civic HB what Engine to go with??????
- jacking points on the CRX ???
- need a link to the crx weight page.
- 90-91 CRX Amber corners (vision look alike)
- Mount Kit for b16a into a 90 crx dx
- i blew my fuse!! HELP
- anyone ever seen an S1 w/ factory LSD?
- My ES Bushings are in!
- SpeedTrialUSA Track Day @ GingerMan April 19
- Roll Bars illegal?
- cheap ass turbo setup??
- b18a swap STILL WONT START! arghh...
- How much is my car worth?????
- CRX • 88 to 89-91 suspension
- intermediate shaft
- What holds the inner wheel well in?
- Headlights
- Its starts then it dosn't start.
- front cross member for my 4 door.
- Turbo questions
- putting b16a into my 89 civic four door.
- Quick1!!
- 84-87 civic/crx sites???
- does anyone have a diagram of a zc?
- 88 red crx si with b16 swap for sale
- 92-00 strut bars fit a 88-91?
- hayame cam gears?
- D16a6 gas feedline bolt to Y8 fuel rail?
- fuel injector clips
- Camber kit need???
- Stock front License Plate Holder?
- wiring harness question
- VIS CF Hood for a JDM frontend. Are the civic and crx the same
- Gas smell when past 3/4 tank
- What AMP Circuit Breaker should I use for my trunk conversion?
- 2005 CRX !!!!!
- bouncing revs over 2k rpm?
- Anybody know where i could find or buy this console. *pic*
- B series into Civic 4 questions
- best rear bumper and side skirts for a CRX?
- Valve tap..not consistant
- power steering ???
- Can't find a good diagram for a DX -Si conversion..Anyone???please
- Any negatives to installing 92-95 shocks into an 88-91
- shorter shocks for lower cars?
- B16 in a CRX, Trouble, Please help
- CRX strut bar
- car wont start... wont turn over
- sir hoods? crx and the hatch the same?
- Injectors & valves in a b16a1 engine?
- max speed in each gear
- y1 lsd in a j1
- trottle cable on b18??
- was this a good tranny deal
- SPOON CALIPERS....wheels for caliper clearance?
- j1 s1 and y1
- were do the crx, si, hf, and dx redline at
- Searched but can't find
- b16 swap completed, but CRAZY TRANNY PROBLEM!!
- Did 88-91 Civics come in Green???
- JDM back bumper w/ lip help!!!!
- 4th Generation Civic Auto Insurance
- 91 crx si for sale engine swap and more
- I Need
- 88 CRX, with B16a swap, New Distributer Assembly? Where can I order one?
- Tandem Control Valve help?
- What is up with my car's gas mileage?
- Parts for "87 Civic
- Comments On '87 Si
- Just got another EF, Need help...
- help me out with my 88 CRX
- how hard to swap in a 1st gen b16a? really?
- Honda Part #'s
- PM6 SI ECU to 89 Teg ECU PG7
- EF9 B20 Vtec track video
- CRX B16 guys, got a few questions for you.
- civic 1.6L, civic 1.5L, del sol
- rear wiper removal / replacement
- DPI->MPFI reprint in honda tuning
- RHD Rex Swap
- EF civic and glass sunroofs
- Anyone know anything about the TANDEM CONTROL VALVE?
- Tien SS or Ground controls and koni yellows?
- Fuel pressure valve / Fuel line / Coolant lines! Where are these things?
- You asked for it! The CRX T-shirts are for sale at Sloptiks!!
- how can i tell if i have a HF or DX CRX?
- stupid question about a crx, and question about d16a6 motor.
- Has anyone used these bars on their ef????
- any1 ever replace a brake booster?
- civic si
- shifter???
- turbo cause headto tap and exhaust to sound shitty....
- Wheel nuts torque specs?
- How much?
- heat problems, do you experience these too or is your heat pro like mine used to be?
- I need some specific pics of 88 crx si...
- ef wagon stock side skirts
- body kits?
