View Full Version : Honda CRX / EF Civic (1988 - 1991)
- check engine light problem
- Which CRX to choose 88Si or 90Si????
- My fuses are going crazy.... ?
- bumper question
- figured out a ghetto drag setup for the rear suspension
- Dyno charts of the exospeed cam for d16a6 requested please
- d16a6 IM, fuel rail, MPFI on a d15 block?
- Best motor swap?
- You have a 89 EF and 1000 dollars....what do you do?
- ZC axles....
- are all ecu's created equal?
- Cruise control into my crx
- Steering Rack
- Difference with this two Y8 intake mani *pics*!?
- ZC aftermarket cam specs?
- ractive short shifter?
- 84-87 crx?
- f22b1 in 90 crx si?
- Ls V-tec
- Intake
- si hb speakers...
- hf tranny question: can these be modified......
- dose anyone else's d16a6 do this??
- camshaft gear question
- cleaning IACV
- Should I wait on the MPFI swap?
- WTF?! glowing catalytic!! car died on freeway.
- aftermarket crossmembers?
- Help on a 1994 civic dx
- how much can i get som estock 90-91 crx suspension for
- apex'i n1 coilovers in 91 crx??? please help
- o2 sensor
- Grrr...Is it possible my Ground Control springs are mislabled..?!! (little help please)
- Motor comes out tommorrow!
- zc tranny/axel ?
- Bullfrog chipped ECU
- stuff needed!!!
- B16 swap woes
- Cold weather, high rpms idle?
- Performance Options
- Question about the B16 from Osaka
- civic 88-91 scale inside!!!!!!!!
- throttle body
- anyone willing to do a swap for me ? (Jacksonville, FL area)
- looking for a radiator...
- Sold my crx...
- Ball Joint removal (Lower)
- Do I REALLY? (gas Tank)
- Trying to figure out if I have a brake problem. Who knows the OEM breaks really well?
- let me introduce myself
- Check Engine Light Retrieving Probs.
- New family member...what should I do with her now?
- Car starts, then immediately dies?
- 2nd gen b16a
- getting b16 header off engine !!!!
- b16 boggin problem
- could yaa help me out...
- wiring help
- Honda CD Manuals
- Hi Other CRX Fans!
- crx gauge cluster housing?
- Exedy clutches???
- need smog help bad
- SOHC upgrades.
- zc help
- This is how you change a 90-91 cluster for a88-89, Enjoy
- Cluster help??
- b16 cold idle at 750?
- Im finally moving on... got an EG!
- H22 in a CRX
- OBD 1 O2 sensor question.
- cable y1 lsd in hydro gsr tranny
- Info for a lsvtec engine setup
- DA's and EF's.....same steering wheel hub?
- Question about rebuilding tranny..
- b16a s1 vs. b18a s1
- brake upgrade question
- Hit a median and fucked up my bumper
- after swap problems
- help! brake light question
- crx buildup???
- Rota GroupN
- ROUGH idle TPS or o2 sensor?
- anyone ever had a 1st gen b16 distributor rebuilt?
- anyone using place racing frnt crossmember?
- please help me with my LS-vtec swap all you guru's
- stock motor for a 88-91 crx
- d16y7 head on a d15b2 block?
- Looking for ZC engine complete, anyone know where to get it?
- hf distributor?
- smoking out tails?
- Hf crank into dx motor??
- "Frosted" Headlights
- Where's my heater core?
- have liquid (possibly coolant) in 2 and 3 exhaust...
- wiring power windows?
- ECU Codes
- any pics of rex lowered on neuspeed race springs?
- Think I figured out my overheat problem...
- Does anyone know of any informative 3G Civic pages???
- dropping the fuel tank
- Rear Disc conversion
- si seats? how much they usally go for?
- HX wheels + Falken Azenis
- the biggest single group of crx's i have ever seen
- what you think of my crx
- I can get free si seats..but i need help
- Integra console
- Starter fitment from 1989 to 1994
- Hop ups for D15B1?
- Torque Specs for Crank pulley bolt?
- What Code would this be...weird
- why does hondata only support a 9000 rev limit?
- what would u pay for this engine.
- 89 Integra ECU Automatic question...
- fuel pressure regulator?
- what do 90-93 ls integs run with just like exhaust/intake/wires.. little mods
- b16a
- Swapping EG seats into EF Civic's...
- ECU Grounds
- need some advice
- 00 gsr cams on 1st gen b16?
- Help me out on whether this is a good deal on these Si's
- cluster gap
- Hard starting
- check engine light when i break with it in gear?????
- not going into gear
- want to buy 90-91 CRX SI emergency brake cables.
- b16 EACV Help.....
- Individual throttle bodies on a6
- got some cams. need some advice.
- New guy needing swap info, (warning; rambling and long)
- 4 door power windows in a 90 hatch?
- noise in hatch
- boost
- SPAL power window kits?
- Quick tranny ?
- I need to find this site...
- d15b2 with y7 head
- Upgraded exhaust - now has check engine light and stinky egg smell
- 91 Civic HB DX
- manifold clearance?
- ZC question?
- Trunk noise?
- Auto '90 Si --- shifter console light
- Will 5th gen rear seats fit my 89 civic????
- car died
- prices on motor swaps
- i want a front bumper!
- Pics quest: Mugen style kit w/ IC.
- Spark plugs are soaked with oil on 89 Civic LX
- Movies... with my ZC REX
- which Trottle Body gasket do I get for my skunk2 Intake manifold?
- Good shops around Dallas Ft. Worth.
- HELP!! Gas dripping out of muffler
- My '91 Si- It's gone :o( [pics]
- automatic ecu question.
- Throttle body for 88 HF
- Shifting seems hard? Whats up ? hmm.. give me some ideas.
- Seat Problems....I Need Some Help
- Nor Cal Peeps!! Anyone delt with Motorsports dynamics?
- rear trailing arm bushing broke.
- Header Install
- How much for timing belt and water pump change?
- 95 Z6 Intake
- Race flo cat questions.
- check code 23
- Just bought an 89 Civic LX? Have a few questions?
- anyone know how the dc TCS sounds?
- Powder Coating
- Where can I buy some 13/50/195 tires
- Shock/Spring setup Q's for CRX
- Got Eibach?
- Question about WIRING (B18a in a CRX + making it MPFI).
- which motor build up to do
- Question on 90-91 ex brake swap?
- anybody got pics of an installed rollcage/bar?
- my boot is torn, loud knocking
- My Front axles and wheels!
- looking for used AEM CAI, no luck in classifieds
- Civic/crx Si rear sway bar fit 95 civic?
- Rev Limit kicks in early
- pix of how you routed piping???
- what is a good rotor that doesn't rust?
- will a 88 crx hf harness fit rght up to a 89-91 si
- catch can install--running lines in between the catch can and the breather?
- what are those valve cover breathers for?
- d16z6 intake manifold on a6??
- Pulls to the Right? Why?
- How much i can get for this rex parts?? *pic*
- Mini Me the CEL code
- HELP! no heat!!
- Where can i find motor mounts that are cheaper then hasport for a jdm b16a swap?
- Sad Sad story
- Where is the best place to buy a used Si trans?
- cable to hydro
- what would ..
- pics of my jimfab crossmember
- zc sohc crx .. code 16??
- Sunroofs
- Crossmembers?
- Headliner - ugly to take off?
- OT: Where can I find one of these Hot Wheels???
- adjusting/changing a b series clutch
- thought i might introduce myself
- Best aftermarket Intake Manifold
- hasport shiftlinkage broke anyone else w/ this prob?
- civic crx console in 88hb?
- Racing Block
- integra cluster in an 89 EF?
- anyone willing to trade???
- performance mods for the ZC
- Why can't I post in Classifieds?
- gude race package and power steering questions
- just did mpfi swap on sohc zc code 15?!?!
- car almost cought on fire!!!
- kuckles and hubs?
- Eibach Sportline kit?
- timing belt question
- No power to my ECU
- Radiator hoses for b16 hatch si?
- 1/4 mile times zc vs. z6
- B20VTEC Swap
- zc gas mileage?
- Anyone want a Recaro SRD?
- I Blew My CV Boot HELP
- Best Place to find cf hood???
- auto Vs. Manual(wiring specific) need IDEAS
- Another tranny identification tread
- Looking for tranny
- WTB: 88-89 cluster
- Can i tighten my parking brake?
- Crank Pulley Flew Off
- ground point inside near main relay-what is it actually grounding?
- rear windows for Crx
- what is this thing?????
- where is a good place to get insurance?
- autometer shift light stays on?
- Brake Rotors
- turbo crx exhaust?
- hasport shiftlinkage???
- mpfi swap price
- Error code 17. VSS, where is it located?
- Free 91 Si full drivetrain
- Whos' CRX is sitting outside at Genentech in SSF?
- 91 Axles wont fit 90 civic dx!!!! Please help!
- Crx power door locks
- my clutch wont release?
- 88 hf can i use a hf wire harness on z6 with hf distributor hf ecu si tranny
