- crx b16 transmission leaking
- 90 si engine harness mess!!
- Crx Toe Out problum
- CRX- Toe Out Problem.
- suggestions for 89 CRX SI b17a1 turbo
- radiator installation on crx
- b16a in 89 crx dx dpfi
- Honda Quick Lockdown's*unstealable*
- Hybrid Injector Swap
- using air compressor on change oil
- Looking for a New Air Dam for my 89 Honda Crx SI
- D16A6 Rebuild
- pic request/diy ef fog lights
- B16A swap in 89 CRX dx dpfi
- Which transmission!?
- Alternator Fitment With B Series
- safc tuning help
- 1990 Clutch pedal fix???
- question about tail lights
- DC spindles on EF?
- b18a worth the money and time?
- will this tranny work with this motor?
- vapor canister
- ecu opinions needed
- d15b vtec
- Your opinion..
- battery light
- ZC Q's part 3
- Cooland leaking from top of radiator
- 90 crx starting issues.
- Anyone use the NRG thin quick release?
- Battery relocation and WTF is a ZC swap?
- Wot issue?!?! Cant smash the throttle!!! Why?
- vibration at 75-85 not tire related
- 89 CRX Dx Oil Light on....
- LS/VTEC information + swap info?
- new distributor, now runs rough and LEAN
- Need help on Skunk2 Ball Joint removed
- Does anyone have the Skunk 2 struts and lowing spring??? If so open.
- obd1 conversion
- 1989 Civic Sedan Piston question
- I need help with my Crx asap!!!!!!!!!!!!!!!!!!!!!!!!!
- Help with two things please
- jdm b16 odb0 swap question
- ZC Q's
- crx suspension bushings
- help with trans swap?
- Brake light always on??????
- had some questions about my ee2 wagon
- TPS bolt
- Check Engine
- 91 civic si with zc no start problem
- door problems
- d15b2 throtle
- want to put newer 1.6 motor in 89 civic need help
- Hard CLutch?? doesnt go in gear!!
- idle at startup question
- Electrical Geniuses WELCOME! parasitic drain found? now what?
- D16A1 worth the swap?
- HELP!!! ZC redlines @ 3k rpm's? HELP!!!
- J's racing rep. lip on usdm bumper?
- Problems with ZC re-build
- Who created this CRX?
- shaved pulley?
- Vacumm diagram B16
- Is theft really an issue on these cars?
- stock ef ride heights
- Problem = alternator?, starter?, battery?
- crx weight question
- Ignition Switch Question?
- B series ?
- Ef9 Problems
- What does this wire do? MYSTERIOUS!
- how to smog
- where to get replica for EF9 Clear Bumper Lenses
- j1 transmission
- throttle body question
- 1990 CRX w/ DOHC ZC hood washers and COLD engine temps
- Theives strike again
- Idle Screw - Can it be taken out and replaced?
- B16 into 90Si O2 wiring help-yes I searched!!!
- Failed smog need help to pass
- just got 88ef wiring harness ?
- OBD-0 to OBD-1 and DPFI to MPFI
- loud skreetching sound??
- 91 crx d16y8 IAC sensor question?!!!! help!!
- 91 dx lca's
- b16 cable trannY into a 89 lx ( what axles to use )
- Need help mpfi swap!!
- crx si/wings west/white slips
- Quick Question
- Pg7/Mpfi
- TPS help! it always reads 5V no matter what!!
- intake help
- in need of help with b16a2 in crx
- clutch?
- Civic HB side garnish same as CRX side garnish?
- strange no start issue. HELP!!
- Headlights caught on fire....
- b18a1 to b18b1?
- cai question
- boosted jdm d15..
- rounded bolt
- 91 hatch light problem
- my hatch thread build up time!!
- Which timing belt?
- no spark
- Honda CRX issue?
- JDM d15b vtec oil pressure
- Vtec!!!!!
- Fuel Controller in B16
- please help with push button/toggle start install
- H22/Type-R 1/4 mile time
- cel code numb.43 obd0?
- Project Car Magazine #7 July/August 2008 issue
- BIG hole in HEAD! HELP!
- DA rear lower control arms
- Brake Lights?
- B16A OBD0 dizzy problems
- Ef sir conversion
- Need help asap please
- jdm cluster on us crx
- headers
- No fuel
- Alex Jones Releases "The Obama Deception" Movie FREE on YouTube
- car ran one day, next day wont run at ALL!
- Y8 Intake mani on my A6 cylinder head?
- ZC Q's
- voltage measurement on TPS?
- Auto to manual swap question...
- wiring diagram
- disk conv problem.
- First Crx!
- F1 Racing Flywheel question
- Engine swap poll
- d15b2 mpfi swap
- Making a d16a6 obd1?
- Problem with CRX in Venezuela
- need help..using obd-0 dizzy on jdm zc sohc vtec motor
- what is a good price ???
- fitv question
- DA Rear Sway bar on EF
- Need Help! EF9 Rear Bumper Filler
- b16a bogging..jumpy idle when warm,hellp!
- D16A6 si oilpan on a D15B6 hf motor?
- fixing rear fender flair rust on wagovan
- fuel pressure gauge
- d15b2 block with z6 head
- What ECU is a PS9?
- Almond Cream Hatchs! Post your pic.
- Rear wiper problem.....
- Had my dream car...now its gone
- Oil overflow
- Help speed sensor is stuck
- The mysterious Thermal R&D 3" catback.
- obd 0 b16 questions
- Aftermarket dampners what fits?
- swap info?
- d16z6
- Side Marker Template
- DIY: Rear Speaker Brackets In a hatch on a Budget
- Alternator and Distributor Repin
- d2 coilover front fork problem
- How to connect OEM EF2 fog lights?
- Am I burning coolant?
- Dashpots ???
- please help!!! DA integra front brake problem!!!
- Problem with stock seats and sliders
- Smog help
- Where is the idle adjust screw?
- 88-89 axle question
- good clutch for b16a before going turbo
- Best camber kits money wise?
- CRX Headlight Circuit
- b18a1 into a ef shell need help
- wtf??? this isnt suppose to happen!
- 88 civic fenders on crx
- Are Ebay gasket sets any good?
- What are theses plugs too???
- '89 Si Rear Drum Removal
- Valvetrain Question???
- 87 crx whats compatable?
- HELP WITH Y8 Manifold with no IAT SENSOR?
- 88 crx si new member
- hey i got 1 Question for U!!
- Crx cluster help " update "
- 91 crx si seat rail/sliders-questions
- my car wont atrart HELP!!!!!!!!
- GSR oil/water pump on b18a1?
- cant fix my idle..
- CRX HF Ring & Pinion set
- 1990 restoration project
- will axles work
- B-series back motor mount
- antenna question
- Brake swap question?
- b16a in crx bogging down
- ef auto to manual conversion?
- a few questions on a crx
- 88-91 Innovative Mounts issue.?? help.
- Help!!! OBD0-OBD1 Conv. Clarifications
- Need a How to
- am i getting fuel if i have fuel psi?
- Starting Problem need help??
- -need help here-
- 91 civic sedan tranny?
- 92-95 civic caliper fitment ???
- obd0 b18a1 ls/vtec help
- hf cluster wiring
- fuse keeps blowing..( I'm lost )
- Leaking coolant!!!!
- Get more oil volume! easy mod! b18a. pics
- Neon RAD. Radiator Info.
- Halo Install - What am I missing?
- How to reset the CEL (Check Engine Light)?
- sand paper grit?
- crx lip on sedan
- oil amounts
- Need 91 CRX foglight wiring Diagram
- 88 CRX Turbo/Radiator
- Seats?
- Replacing Fuel pump?
- almost finished my mugen
- exhaust question
- English Newbie with Pics
- B18A or B16A1?
- Legend calipers, 262 mm discs, what master cylinder, help!?
- Cusco Tie bar installed pics/advice?
- need pick of b18a1 with 91 si harness
- Removing throttle body for cleaning
- 91 CRX Clutch sticks to the floor
- clutch question
- car just suddenly died???
- Shifter bushing question
- heres why you shouldnt buy ebay coilover sleeves...
- Tried Searching.. My car isnt in vtec when I shift into 2nd gear.
- rear wiper on the 91' shuttle
- can anybody help me that actually knows about honda???
- OBD2 b18c1 into CRX harness question?
- battery relocation problems
- question about which steel braided brake lines for 88 crx Dx
- dohc zc swap in ef
- Torco Break in oil..
- jerking?
- will 94 integ springs fit?
- Civic VX Motor into a CRX Si
- please help b16
- OBD1 code 41 heated oxygen sensor heater
- Honda CRX engine swap
- Need help with what way to go with an engine swap.
