View Full Version : Honda CRX / EF Civic (1988 - 1991)
- boosting a dohc ZC
- b16 p28 question
- New Suspension
- pics of my k20 crx from ITB's 2 Turbo (Updated)
- Frozen Battery
- header clearance
- OEM BRA? Changes headlight...canadian?
- EF Bumper Support Removal
- Clutch suggestions for someone who's never driven a std more than 5mph?
- Where are these seats from
- ls engine harness in civic si
- where are these seats from
- hose question
- 89 crx si NO spark need help
- car wont start
- Upgrading instrument lights
- clutch going out need help?
- will a crx si lip fit on a ef hatch?
- CRX butcher make baby Jesus cry.
- My 1991 turbod civic hatchback is smoking?...Please Help
- unknown wires
- help 1988 crx engine d16a8
- The CRX truck.. Pic inside. (You may need to sit down for this one)
- Need tips to hang exhasut higher
- Gsr seats in a crx?
- OBD 0 B16 Tranny ID help
- 6 puck clutch
- I'd like to see some EE8 (EDM 1.6 VT)
- Looking for Parts!!
- complete si interior
- Does this FPR look okay?
- HELP!!! JDM b16a tranny (STICKER VIN?)
- tri y replica header installment
- what resistor box can i run?
- d15b2 mini me
- Y8 fuel rail on A6 head?
- How old is your EF now???
- does this sound like a fuel pump problem?
- ? on b16b swap on a 89hf crx
- 91 civic lx , starting problems.
- integra G1 se sideskirts on a ef anybody??
- is this a real jdm crx spolier
- 88 CRX build thread (56k warning)
- Another...mpfi swap...question
- d15z mini me trouble
- rev limiter?
- CEL obd0 b16a in a 1990 crx si
- NEed help engine cranks but wont start
- 91 Civic Hatch Shell wanna swap in a B16A OBD0 w/ Hydro LS tranny
- New Shell
- Question bout bumpers
- no clutch prssure
- Sohc zc
- Cylinder #1 and #4 Misfire code 12 and 16
- New ride
- flasher / sunroof problem
- best suspension set up
- so iam boosting my stock si crx
- newer crv
- aem cam gear on sohc zc non vtec
- What cam
- Replaceing stock intake manifold with 96 Civic Manifold
- !Help With Starter!
- disc brakes all around
- 91 ef hatch lip...
- how do u find the year of fenders
- 90 crx si mpfi?
- Building race spec ZC, info needed
- thermal exhaust?
- Clutch cable stretching
- need help with suspension (front wheel wobbles)
- b16a1 engine gasket kit not only head gasket... lets try this again
- slow acceleration, slipping clutch? help!
- tranny clearance?
- question bout crx&civic
- d16a6 wanting to upgrad cam
- Wire harness
- Can I do it
- Si transmission release arm "slack" and notchy gears
- High Idle, IACV, and Coolant Sensor ?'s
- iacv question
- integra rear disc conversion alignment problem
- Momo Steering Wheel and Hub
- LS Crank in a B16
- IACV: D15 or D16
- Mystery JDM motor, D15B plus serial number, pm9-6 head?
- easily swappable parts for my '90 4door dx?
- b16a jdm block vs b16a2 usdm block
- 2 questions...
- crx si carbon fiber sunroof question
- what should i check????
- Ok before i pick up this ef sedan...
- ef sedan foglight fitment im havin issues!!
- 90 civic std..b20 wireharness question
- 91 si w/ b16a swap cluster mod
- b16a1 No spark No Fuel. Help Plz
- bog hard at 4k HELP!!!
- quick pricing question
- LS into a EF Hatch. Starting Probs now
- Where to buy an engine?
- 90 lx, main relay????
- battery light always on
- D15B2 different crank "sizes"?
- CAR WONT START ALL THE TIME? help please
- CB7 Lip?
- need help...
- Megan Racing - Resonated Test Pipe
- Car won't start
- Brakes help
- Car has no juice..please help
- Help With header
- rear disc with 13" wheels?
- How to wire fan correctly?
- obd1 to obd0???
- Dizzy HELP!!!!!!!!!!!
- CRX hatch glass-- buy JY hatch, or buy JY glass and replace?
- Temperature Gauge Problem
- HELP! it cranks but wont even hold idle at WOT
- my first car and its a honda!
- Crx Websites!!!! OEM and Aftermarket
- Ecu????
- leaking antifreeze?
- 89 civic hatch jdm front end
- 91 crx si seats into a 89 civic
- Cranks over but won't start....
- new project car
- zc bogging problem
- HKS dual tip?????
- How To Check Ecu Codes on a OBD1 Converted Crx using a p28
- will first gen hf drums fit on second gen si
- Help please
- Front Tow Hook install?
- tranny questions
- New Fuel pump primes, but car won't start! help!
- Need help
- Still having an idle issue
- crx ecu question
- ac removal
- How do i make my lights in my cluster brighter ????
- Tranny fluid bolt =]
- door not lined up
- power differences between ex, lx an dx?
- Where can i get the orange neddle cluster??
- Temp gauge problems? Help
- Can u put a ep3 steering wheel in ef9??
- Sag in rear bumper
- howdy
- yes another wont start thread :(....HELP
- ls/vtec q's... need to swap out pistons?
- Remove Axle Nut On Snapped Axle?
- Need a freaking exhaust!
- how do i remove the front bumper n filler piece off my 90 civic hatch?
- MPFI swap coolant leak
- 90-91 lx 4 door EF seatbelt question.
- does teggy seatz fit in a ef front and back
- hesitation/bogging under partial throttle, double yew tee eff
- Need Help - 89 Hatchback - Fuel prob
- Cluster Light Problem
- Cluster Lights not working. Dimmer is good, fuse is good
- 0bd1 wiring harness
- Check engine light!!!!!!!!wtf
- Parts needed for b16a swap?
- need help
- I need help
- Car stalling has engine light !
- play/poping in stearing
- does ANYONE make 88-89 crx amber corner lights???
- Best way for a novice to learn how to engine swap?
- Cluster minor problem....need help
- starter/ battery help
- jdm d15b question
- question about new block???????
- 90 ef sedan turbo question
- N/A or Turbo???
- thiss should be sticked!!!!
- help please!
- Help with my first CEL code. Please.
- changing a head gasket???
- Doing some swaping! need some help!
- My rex died today
- Running wireharness....
- Injector resistor box ? for you
- skunk 2 coilovers bouncy???
- Tire size question?
- Tuning Shop in Orange County CA?
- d16a6 & d16y7
- Console 4 90 civic
- knocken noise
- Quick Exhaust Question
- Starting problem
- 89 dx clutch/ axles work with a cable Si tranny?
- cant get rid of code 9
- How easy to replace a fuel pump?
- my civic swap no fire
- Sunroof issue
- Project: Ressurection
- EG Seats in a EF
- post up ef's with bumper diffusers
- Door water leak!
- 88-91 honda civic hatch question
- what should i do?
- D series turbo question
- holes in back bumper?
- Will a bad iacv cause this...
- Intermittent starting problem
- 4-2-1 header d16a6, please read!
- Fault code 16
- D-series Cable to Hydro
- what shift rod for b series crx?
- Fuel pump??
- compression ratio?
- Little "bump" on my fender
- D15B1/2 VS D16A6 timing belts
- stock size tires on ex ef?
- Merry Christmas, EFers!
- What Paint For Moldings
- EF Suspension compnents
- hesitation/crappy take off
- Merry Christmas to all my CRX Lovers
- need help on which goes where hose on manifold!Help!
- ATTENTION.....Any stolen blue CRX lately?
- antenna block off plates!!
- Looking for jdm one piece headlights..
- fitv help!!!!
- Tilted windows.
- what motor is this?
- new to honda's have dx ef and want to do a obd 1 conversion
- 1991 crx h22 build jdm goodies
- distributor question
- top hat wheel well
- Aebs Intake Manifold....throttle body?
- pistons
- how come no b18?
- 1991 honda civic si help!!!
- DA integra conversion
- i NEED an 88 standard underdash harness
- My car won't stop
- Plzzz HELP! d16a6 no compression...=(
- New front seat ideas
- Need Help With Cold Weather Start Problem For My New CRX!!!!
- Need advise on motor build please
- Main shaft bearing?
- How much oil for our motors d series b series k series
- obdo jdm b16 code 4
- I need some info on using a vj11 turbo( off of a ford probe) on a 90 crx si
- DSM injector wiring HELP!!!!!!!
- Help OBD1 B16 CEL Problems
- All I want for Christmas is....
- I sound like a NOOB, sorry...
- Transmission 89 4 Speed to 92-95 SI 5 Speed
