View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Compression Ratio
- seats for trade adn cash
- b16a dissy
- Tranny question
- springs........
- how to flush radiator?
- what is the best nos kit as well as cam gears
- crx chip
- obd?
- which camber kit are you using?
- help on a swap thanks
- Dohc zc vtec?
- input needed
- Viynl Seat Covers. Whose Interested
- Which Vss for use in a crx with integra type-r cluster???
- Wagon Short Shifter/bushing Question
- Emergency Lights!!!! HELP!
- 88 CRX Springs
- exedy clutchs?
- Good place to get copper gasket
- new head?
- Come and watch my DC4-1 header own me
- im noob to ef and i want answers!
- Wagon Questions:)
- Distributor
- Any of you need one of these??
- wiring???
- new brakes
- Just Obtained the perfect specimen....
- OBD0 -> Obd1 harness???
- Rear filler piece
- How do i go about figuring out if my mpfi is hf or si?
- what head gasket and timing belt will i need for a gsr block and a b16 head
- I Need A gauge cluster Wiring Diagram!!!
- VAFC not on..WTF?
- Help with b16 problem......
- B16a distributor problem
- crx 1/4 mile times
- Replace it, or not.
- anyone have an hf trans they wanna sell cheap or give away?
- need a crx piece !!!
- OEM sideskirts
- trying to figure out the codenames of this shit here
- WTB b16...
- Fuel Pump On B16A1
- crx dash cluster cover. HELP!
- New New New ___ Must Read!!
- Easy transmission question
- O2 Sensor Location on B16A1
- compression and octane
- b16 CRX,,, VTEC not working,, Vehichle speed sensor is where?
- 1990 civic LX
- wagovan, yay!
- Passenger side door?
- mpfi not working :(
- What year JDM Tails.....
- engine codes for zc
- shopping list for b16
- Question about the interior of a EE9 (European EF9).
- JDm Sir front
- crx engine swap? plaese reply
- any diff between 92 crank pulley and 91 ??
- b16 clutch
- How much did you pay for your CRX? ~POLL
- zc?
- zc???
- climate control knob...lights out?
- taking alternator out - HELP!!!!!
- hybrids + snow = ??
- Needed: Vehicle Speed Sensor (VSS)
- slipping clutch ownz me
- Exhaust rockers shot??? Head work ?
- new exhaust! pics!!! custom!!
- absolutely sick of my EACV and associated idle problem (DOHC ZC)
- Changing a break master cylinder on a '91 CRX Si...needs tips!
- 87 DX no choke
- car fuct itself yet again
- HELP!!! speedo just stopped working?
- upper control arm..
- Finally found the right one
- brake upgrade....
- tire prob?
- Valve Cover Disaster?
- just finished swap need some help
- how to get maximum fuel efficency
- ZC Ecu question
- ZC Valve Adjustment, Searched No One Has A Picture, is this right?
- b16a crx's post your 1/4 mile times!!!
- car timing (weird)
- dash board shack when car park while engine is on
- tuning b16a
- P30 Throttle Body Gasket on 1st gen b16..
- dx POWER.....
- break lights? need help asap
- did anyone swap a d16a1 into a 4th gen civic or crx?
- 89 crx si knuckles for sale-- chicagoland suburbs.
- 1988 Honda CRX Si Guage Cluster FOR SALE!!!
- CRX Tranny or clutch prob.
- Zc problems
- Race Cam questions?
- fluidyne or C&R???
- Hatch struts?
- Dohc ZC??
- tien ?
- ZC... What Next?
- More woes on SiR cluster
- Eibach ERS questions
- Drool, must see this pic, JDM madness!
- Will 99-00 civic si gauge cluster plug n play in 93 civic cx?
- Attn: Long Island, NY and surrounding guys/gals
- JDM sidemarker position? Pics? Diagrams?
- How to put an engine on a stand....
- GsR cams on my b16?
- need important question answered
- Power Down: CLutch
- Can it be done?
- need help on how to...ef jdm folding mirrors?
- obd0 --> obd1 harness, what extra wires are there to run from the obd1 ecu?
- ef jdm folding mirrors
- Oil on my spark plugs?
- how you became attached to your car
- question on crx 1/4 times
- ok sohc ZC almost done! last part.
- zc engine
- code 16
- Need help FAST....taking off axle hubs
- I've tried searching but I still have questions
- EF exhaust pics?
- Need Help geting PR EF x-member ASAP...
- What center console is this? OEM? 90-91 Hatch ? help
- Who else has this problem???
- I'm going to try this out
- Ground Control spring rates
- Tie rods going bad? or just do an alignment?
- zc starter and alternator into a B?
- Door Switch
- installing clutch cable?
- Need cylinder head advice!
- will a 92-95 header work with a 91?
- CRX Project Car.. what engine to swap in...
- interesting article - electronically actuated valves
- engine check light with turbo
- will a 91 crx windshield fit on a 88-89 civic hatch?
- Newbie looking for answers
- VECI Label for 90-91 crx si
- del sol e brake cables?
- Code 9 after obd1 conversion...
- 90-93 LS Teg Motor into a DX CRX??
- EF2 aka civic sedan
- Socal: Dyno day 10/19 !!
- Si Distributor on ZC doing hack tomorrow help
- 92 v-tec in a 90CRXsi....
- hoods?
- need cat for 89 si
- Going to swap... which engine???
- springs fit??
- looking for POWER!
- Teg LS Tranny
- B16A1 VS. B16A2
- Woohoo 1234567
- 88crx si trailing arms?
- FF Squad
- Advantages to adding carbs to my Z6?
- transporting engine
- what does a performance cluch generally cost..
- 91 HB DX:Guage cluster light prob
- A6 buildup.
- ineed struts!!!!
- Is it worth it?
- Cheap exhaust & engine mount questions
- What brakes for the EF civic?
- HKS Sport + CRX = Yummy.... *pics*(56K maybe)
- JDM power window conversion??
- Amber corners?
- Rear mount question
- What ecu to use with type-R engine?
- which camber kit do I get??
- SiR cluster install
- Do any D series parts fit in a b16?
- Race fuel -> premium fuel engine...ok?
- Where to find Mugen CR-X parts...
- ok im really upset and frustrated someone please help!!!
- Whats your best 1/8th or 1/4 mile times???
- need some 90-91 crx si ebrake cables!
- Brake Pads
- Want a cheap Dizzy? How does 68grand sound?
- anyone have the link to the trans ratio page?
- Nicer Car?
- anybody here running a Fluidyne rad?
- EF's with B16's and Ground Control Coilovers...
- engine idle went nuts
- 1st gen CRX: buying, things to look for
- antena
- Good deal?
- ZC with re-ground cams; will a stock ecu handle it?
- Crower Valve Springs
- Toronto area..Looking to buy a 1988-1991 CRX Si.
- Hondas are like Computers sometimes.
- Is there any companys that make carbon fiber............
- Heater problems!!
- What seats bolt on to 88-91 Civic H/B Chasis?
- place racing cross member???
- About how much could I get out of a DX tranny
- CRX Gauge cluster bulbs
- What should I expect to pay for an 88+ Si?
- Acid Dip? and valve train?
- Help B16a died!
- Transmission or Clutch?
- Zc swap in..but
- J's Racing front lip. Possible Group Buy
- What do you think my car is worth?
- MSN Group
- GRRRRR...Code 10 +engine light.
- JDM transmission parts?
- 88 CRX HF front brake pads
- procedure for removing oil pan
- b16a died today
- Ok ive got a zc in my crx now and i got a question or 2
- lowering spring help!!
- Transmission question
- Help needed finding a trans!
- 0bd2-non obd questions about the B20
- Master cylinder ?'s
- Orlando's Hot Import Nights on Saturday!! Who's going?
- grinding sound on engine start
- Ok EF gurus, how much could I get out of my crx rear interior??
- hybrid rex help?
- $231 for on OXYGEN SENSOR!!!!!
- Turn signal problem...
- D16Z6 Install
- experiences with cheap coilovers?
- ZC Question?
- anyone have a ecu thats broken
- PM6 ecu, chipped for vtec?
- Problems....need advice
- JDM front end
- Any body have info on Hydrotranny conversion in 4thgen?
- car drifting to right while braking
- OBD-1 in CRX question
- How much $ to rebuild D16A6?
- Replacing my brakes and rotar
- Speedometer cable on CRX?
- H22 vs B20/B20VTEC
- My new JDM bling bling!! what do you think?
- How much to have a b16 sleeved
- help on BARE min....RE:junkyard tuuubo
- car wont start....unless i put lots of play on the clutch cable and....
- 90 CRX Si cylinder boring disaster
- need help in Jersey
