View Full Version : Honda CRX / EF Civic (1988 - 1991)
- mini me idling to high !!!!
- question about extra stuff!
- traction bars who makes them for our cars
- San Diego H-T'ers: Stolen EF hatch Alert.
- Small Strange Electrical Problem, maybe you know how to fix it??
- How change automatic transmission to manual?
- will a GSR intake mani fit a b16
- Parking pole wiring
- HELP ME
- rear seats
- b18c1 in 89 ef hatch
- b16a SiR in 89 CRX DX wont start...plx help
- Head swap
- Quick engine question for you brainers that know your stuff =P
- weightloss modding
- New Dizzy still throwing code 4! AGGGRRRRRRR!
- ukdm speedo in my 88 swap?????????????
- Before and After of bumper restoration on the '83 1500S
- crx rear disc brakes?
- speedo not working ...
- HOW to fix speedometer?
- lightening stock flywheels
- Pic Requested : 88-89 CRX w/ Fog Lights.
- obd 1 crx.
- 10 inch springs on a first gen crx? will they work?
- ct smog question???????????????????????????
- clutch problem
- Oil found in all 4 spark plug holes?
- 1st gen b16 smog
- tokico illumina, which are front and rear shocks???
- 88-91 oem spring rate?
- JUST GOT MY SHIT JACKED!
- Si tranny in STD
- where can i get a fender
- Spike TV and EF CRX police chase.. 650pm est and on commercial.
- Need opinions (another header thread)
- 91 DX Question
- 99 LS manifold on b20 sawp
- crx door compatability
- 88-91 CIVIC/CRX [EF] : Omni Power Full Coilovers
- part # for civic knuckles
- 91 Civic dx hatch Oil drain plug
- B16 cams question....
- timing question
- where are part numbers on cams! pr3, p72?? HELP!
- head swap help plz im dieing hear
- IDLE ISSUE
- Another exhaust question...somewhat more specific than others
- HEAD swap question??
- d16z6 vtec question
- 13" Steel wheels over Civic EX/Integra 10.2" brakes?
- GAUGE CLUSTER
- sunroof motor removal
- crx problem please help
- Si conversion.....
- does anybody know how i can make 94 del sol seats fit my 89 hatch
- do i have to change my fuel pump? for a gsr swap in a crx???
- Fuel managment for a Turbo EF.
- how do u adjust tps sensor
- HELP!!! usdm header on a b16 CRX?
- Quick I need some tire recommendations....
- DOHC ZC Head Studs
- engine swap std. hatch
- wheel width and offset?
- EF B16A power steering in a SEDAN...Is it possible? What's needed?
- JDM CR-X VTEC
- dashboard swap
- Your car's morning routine?
- replaced thermostat now idle is sparatic. obdo b16a
- What CRX rear strut bars fit without having to cut the plastic panels?
- car swerves when i brake hard..
- where could i get a b18c1 short block
- I hate local repair shop!!!
- check engine light
- si gauge cluster
- Balljoints??
- No markings on ECU! How to identify from looking at the inside?
- jdm power window kit?
- Will a d series single cam......
- ZC No spark
- Got some JDM goodies, with a bonus. ... :)
- Quaife Quick-Ratio Rack & Pinion Kits ?
- Pir request , crx with tenzo sinko-r black with polished lip
- where can i get rear quarter panels for my 88 crx si PLEASE HELP!!!!!!!!!!!!!!!!!!!!!!!!!!
- where can i find carbon fiber spoilers for 1991 civic hatchback?
- WTB: GSR block
- torque convertor fluid
- OBD1 GSR swap sputters from 1500-2000
- 91 hf to 91 dx redline?
- what kinda bulb is in the jdm headlights for crx???
- 90 Civic LS SWAP
- hydraulic transmission
- Roll pin for shift linkage in B16 CRX
- sohc turbo,anyone making over 450hp?
- ecu question
- Is it me or the corner lenses on 88-89s...dont light up?
- Will the stock si rear swaybars bolt onto my 88 HF LCA?
- question......
- tech
- compression
- day @ the track 1/4
- Car wont go into gear. Clutch gone?! Please help immediately
- Radiator overflow tank....how NECESSARY is it?
- Question about Oil in Cylinder Head
- IDLE
- HEATER
- installing a 2nd battery
- Car keeps over steering!!! Help
- B16a
- Oil Leak problem B16a
- d16z6 swap in 89 hatch
- just bot myself a crx
- Oil in Coolant
- looking for vids of crx races
- 96 front susp assembly on a 91 hatch?
- Why does my Battery DIE? 90dxb16
- B16 repair/maintence questions
- How to swap a K20a/k24a/k series motor in your EF , CRX
- Da Dash in a 91 civic 4dr???
- Keep blowing fuse - Altenator Solenoid Valve.
- is this engine better than???
- wtb: 89-91 honda civic/crx aftermarket struts/shocks.
- 88-91 honda civic shocks?
- All 88-91 ED Brake Boosters equal?
- Car's finally painted....
- 3" Exhaust on CRX
- Found Raiser
- Question About DISTRIBUTOR'S????
- what is the best race seat for my crx?
- WHERE to cut holes for rear sway bar on CRX!!
- what would i be my quarter mile time?
- What can i do about the O2 code i keep getting. Please make it stop.
- why is paintscratch.com so expensive
- Firing Order
- startin prob
- NSX brake calipers/corrado rotors/EX spindles?
- Is my exhaust BAD???
- Worth To Buy?
- Struts?
- Can anyone help me find a cheap obd1 gs-r motor
- Fuel Pressure drops in turns(BIG PROBLEM I AUTOX)
- Diary of a Classic. If you love your EF, you're going to love this...tons of pics.
- First code 7, then 9.. now 6.. help. ( 88 hatch with B18A1 block and B16A1 head)
- Mugen Rear Trailing arm bushing install????
- can i run a obd-1 dizzy on my obd-0 dohc zc?
- ZC in an 84 wagon??
- what car did this dizzy come off of?
- distributor wiring
- 88 si axles on a 90 si
- Timing Question for b-motor
- EF2 - What Chassis was this?
- Has anyone used wedge seat brackets for a hatch or crx
- what oem intake arm b16a swap
- DX tps on a b16b
- crx 89 si eletrical question.
- Reverse lights not working, read what i tried and throw in your input
- Need help from engine swap guru...please.
- CRX FOR SALE
- B16 intake manifold question
- Immaculate GSR rims fs
- PE7-661 ECU?????
- test
- Clicking noise?
- Searched with no luck. B16 dies during cold idle.
- si manifold on a dx motor
- B20 Swap in 91 Sedan 4dr *already searched*
- Sway bar endlinks
- Took some pics of the hatch
- all you rota slip lovers...
- Building an A6 block
- Lookin for a new header
- Need help from engine swap guru....please.
- code 8 problem
- mini-me cam question
- head Question
- question
- DOHC ZC... turbo? what would you do?
- I NEED A PIC.
- crx dx to zc distributer wiring
- I need more power!!!!!!!!!!!
- Maintenance parts for 1st Gen B16A
- Hi Flowcat Question
- Speaker Questions (Suggestions needed)
- VAFC and OBD0 ? Will it work ?
- My Motor Finally Died...
- Motor Trob's
- B16 swap problems
- Wild Cam/low vaccuum...what to do about brakes!?
- Flat Black w/ CF hood?
- 94+ Integra (DC2) Suspension Question
- Which prop valve came in 90-91 civic EX sedan?
- lower rear control arm?
- EF EX?
- stalls on first 2-3 starts, but then starts & idles fine?
- just got engine swap.. little help
- Question for those of you with traction bars w/ adjustable radisu rods
- Must I buy TB to fix TPS???
- dizzy gone?
- anyone bought the vis SiR cf hood?
- How much are EF speaker pods going for?
- axles/hub question
- dohc zx swap
- b16 shift linkage ??????
- Replace LEDS on back of gauge cluster.
- what should I be running? d16y6 in 91 hatch? mods listed below
- Help i cant figure out what code this is (code infinity)
- JRSC 88 HF b16 HCP mounts ?'s
- 93 integra axles
- obdo dizzy Q
- hondata intake manifold gasket
- If i put the A/C belt back on will i loose horespower
- Omni Slipovers? Which one is the front or the rear?
- How much does just lowering the center of gravity improve actual real road condition handling?
- B16 hatch question
- Wanting to make my own gauge pod for the center console help please!
- Engine just came in from CALI =)
- 85 Crx ignition column
- dizzy question
- will vtec work on minime swap if i use the 91 si distributor
- vibration while slowing down (not brakes)
- k20a engine
- hondata gasket vs TB bore and intake port match
- mpfi wont start and i did search plz help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- pic request: WW kit & EDM wing on crx
- i have 2 questions...1st is abt lowering and 2nd is abt the engine bay etc,
- Water leakage. Where is the problem
- JDM EG console in EF??
- anybody got a "blox" intake manifold
- A few things for my '88 CRX HF...
- acura oem parts?
- project ef
- Are you running rich???....Read this!!!!
- will stock crx si fuel pump handle b16a + 75 dry shot of nitrous
- Idle Question
- 1991 Crx Si - How Can I Run Low 13's
- Stock or Aftermarket for Minimal Exhaust Noise?
- FYI JDM thin side moldings on Ebay!!!
- ls motor in a 90 si help
- d16z6 cam camshaft question
- d15b vtec
- Trex99....
- knock from engine
- 14 steelies Vs 15 steelies on Azenis?
- Smogg Check..Need a lil help..
- what do I need for my single v-tec swap???????info
- pics of exhaust OFF THE CAR
- No spark...help please
- D series one peice 4:! header?
- I need help ASAP...........
- Is this the chippable pm6?
