View Full Version : Honda CRX / EF Civic (1988 - 1991)
- 91 si build
- CRX HF correct B pipe/resonator? Only finding 3 bolt, need 2 bolt
- CRX (First Generation) Clutch Change
- Need some help with rear suspension setup
- Turboedit questions?
- CRX VTEC rear end rebuild help
- D16A9 EF SWAP. HELP!!
- Intermittent loss of power
- bought a Y49 on Honda 50th anniversary
- Building My 1990 Civic DX
- 1991 Civic Si Hatchback 1.6L Removing the head
- Need help with tunning?
- swap problem
- Honda Del Sol Starting problem
- B18C6 SWAP Do it yourselfe
- Turns and hazards not working. 91 si
- 88-89 EF Versions
- JDM parts and information?
- Want to change my D15z4 carburetor to fuel injection
- Wheel cylinder removal
- Removal of carburettor & protection for manifold...
- cams D16A9 D16ZC
- Replacing W.C.
- Parking brake
- Civic Hatchback weatherstripping and moldings
- Strut bar in B swap close to MAP sensor
- 91 civic hatch Dx headliner
- 1991 Honda Civic wagon rear cv axle
- Found some old Magazines for the CRX
- start up problem, any idea?
- Crunch's Nightmare. Project '91 Civic Hatchback build.
- 89 Honda accord
- Need help with electrical issue
- Where to search for Rear seat head rests
- Code 4 after OBD1 MPFI Conversion
- No brake pressure after new M/C,B/B and 1 new wheel cylinder.
- B18 idle/TPS problems
- 90 Hatchback rear bumper cover
- cel code 9
- 89 Civic Hatch
- Old 1988 UK Honda Civic in US on World Tour
- 1991 civic SI window regulator
- 89 crx si
- B18 High RPM High Comp Build
- D15B2 with D16Z6 questions
- How can I get my wind sheild wipers to work
- Help rear strut bushing 1990 civic
- Connecting rod end caps question
- Bearing for Sanden AC Idler Pulley
- Zc
- Crespo Cams
- HKS ZC Cams timing
- D15b2 to d16a6 harness questions, etc.
- EF Hatch vs. EG Hatch (Plus Old School EF Hatch Photos)
- Koni yellow Fork question
- Fuel Pressure Regulator
- 91 Civic Cable Clutch Wont Disengage
- 88-89 vs 90-91 fenders
- 1990 Honda Civic crx si
- 91 ef sedan multi pint swap with auto trans
- Gleam's 1990 CRX HF
- If you guys like projects check this out !!
- Check out My $100 Honda Civic Build!!
- 1990 civic hatch with solid CEL
- brakes locked up on me
- Mini Me Swap b2/y8
- Plexiglass Replacements for side windows
- 91 Honda with b20b swap push starts but won't key start
- R. Side Cover Side - Rear Main Oil Seal
- What’s a good quality dizzy. B18a1 swap
- D16A6 rough idle
- THEY ARE FINISHED...EF SPECIFC FIREWALL MOUNTING PLATES!!!
- suspension overhaul missing anything?
- Beat to death
- Help - Wire/Connecter Identification Under Dash
- Crankshaft pulley question
- Gas tank of car doesn't fill up all the way
- 91 ef sedan no crank no start.....
- 5th Gen Accord Cluster Swap
- Ef9 sir wiring diagram / manual
- 1991 Honda Civic Hatchback CEL Codes 1 & 14
- PLEASE HELP 1990 Honda Civic 1.5 liter crank no start
- Manual swapping an 89 Civic rt4WD model
- 32/36 Weber carb settings on 91 CRX?
- 87 crx signals don’t work?!
- 89 crx dx: new dizzy, ecu throws bad crankshaft position sensor
- Seatbelts 90 Body 88 Doors?
- Thread size/pitch hatch shocks
- 1991 Honda Civic Hatchback Base Headlight Issue
- 90 crx rear disc brake conversion parts clarification?
- 91 CRX Si almost redline at highway speed.
- PCI rear toe arm - can't zero toe
- Auto to manual/88jdm to 91usdm sedan help
- Z6 swapped ef hatch
- Welp! The battery exploded
- 89 civic DX code 4 new distributor and good used pcm
- High idle.
- New around here looking for Parts advice on my Bswapped crx
- Civic 91 sedan won't start after a long drive
- 1990 Civic DPFI engine harness
- New steering rack, car still drives like crap.
- Planning to rebuild motor. Need advice on what parts to buy.
- CRX SI HF Frames
- CRX front bumper on ef hatchback
- 90 Ef Hatch starts stalling when accelerating after shifting
- ASR Hub Horn Trigger Interferience
- Crank no start ... need your help
- Head gasket replacement
- Driver side axle for b series swap too short
- Starting
- Lowering a 1991 Wagon
- Should I buy this CRX? 91 SI 5 speed
- Oh Man! New ALT battery dies 911!
- Newbie lol
- Question about valves?
- D15b bogging
- Can anyone help me find/locate where I can find a ef SiR stock air intake tube?
- Crx Ls swap questions
- Car runs fine up until running temp!
- Engine build and swap advice for boost
- Troubleshooting, Base Hatchback running lean
- GSR swapped 89 Civic Si (Code 20)
- Need Help, 91 Civic Hatch Base Failing Smog
- WagoST build!
- D15b2 cylinder head with different d-series engine block
- Check out my engine detail on my 200,00 mile ef
- Ef hatch d15a1 to d16y8
- Need help asap! Wiring issue with 89 si b20 swap
- AC removal question?
- 88 Sedan auto false neutral
- CRX front spoiler broken tabs repair
- Lets make build thread great again!
- 1990 crx si build d16a6
- MAP Sensor Issues
- 88 civic b18a swapped need help figuring out what could be wrong.
- D15b bogging and stalling
- 1990 Honda Civic DX Hatchback
- HELP - Turbo EF overheating issues
- nEW crx STEERING RACK
- PR4 intake manifold, what is the FITV water hose routing
- B20/18 engine, EACV, FITV and TB water lines are in series?
- B20/18 swap EACV water lines throttle body bypassing routing
- Is this new motor mount defective/unusable?
- Looking help, 91 civic dx, has power, no crank no start
- Need help, 1991 Civic Hatchback Base not turning over
- D16z6 no start 88 crx si harness
- Car not starting after taking off distributor cap
- Rough idle, back fires below 1000 rpm after MPFI swap.
- Smoke after install, pcv, etc
- 1989 hatch Si pop out windows
- Is EF B20 swap still worth it in today's standard?
- Honda Civic 1991 AC condenser to be replace
- 91 Civic with dohc zc
- Help of 1990 Civic SI Buy Decision
- Light weight battery recommendation
- Regreasing steering rack and rack end bushing question
- need leads on a replacement D16 for 1990 EF
- Lots of wiring questions....
- Missing Civic
- D15b choking and bogging
- D15B2 1989 Honda Crx O G wire help.?.?.?
- Score
- Had a B18a1.....
- (CRX) Bosal and Walker Exhaust Gasket Question
- Battery Light On All The Time!
- Dpfi to mpfi no power to injectors
- 89 HF engine trouble...
- Barn Find 91 Si Hatch...
- FUEL LEAKING ONTO MY FLOORBOARD!
- 89 HF hesitating and not reving diagnosis help
- Vent visors for 1990 Crx
- Wheel dimensions?!? Help please!
- Barn Find CRX - Where do I start??
- Help me find this part!
- 1988 civic mini me swap
- 1990 CRX DX 1.5 Auto Needs Vaccum Lines & PCV Hose
- 1989 Crx starting issue.
- Tie Rod Interchangeability?
- Help with solenoid diagram
- 1990 CRX Si barn find
- Suspension parts: Any luck with certain suspension brands?
- 1988 EF Hatch Big 3
- LOOK WHAT I GOT CUSTOM MADE FOR MY CRX...
- Carb to fuel injection engine swap HELP
- problems with my d16a9
- B20b EF Hatch Axle Help!
- Honda Ballade CS9 1.6 zc1 motor brown top Timing
- Help with 60amp fuse keeps blowing
- Suspension help
- 1990 Civic Owner; Wants To Upgrade, Need Help!
- Stalling on idle when engine is fully warmed up
- Need help with 1991 Honda Civic si?
- 90 Civic EX sedan help
- 1998 CRX dies after running for 30-40 minutes
- D15b2 performance parts and turbo help?
- D15B2 Exhaust Manifold on D16Y8
- Cable VSS to electric
- Trunk lock not working
- can i change ima for 02 sensor?
- Best resonator for Greddy SP2 muffler
- Loose new wheel bearing
- Side Molding Clips
- 1989 hatch issue starting
- main relay/wiring problems
- RT4WD wagon axle question
- Speedo help!!
- 1991 Crx HF Engine swap help
- D series catch can for race car vent locations
- Can't for the life of me figure this noise out!!
- Emission Test Failure
- Tyre pressure for 205/45r16 in crx b16
- can anybody help me with vss wiring please
- Hi guys...
- Car only starts with main relay jumped
- Hush Performance Clutch Master Cylinder Line
- 91 Ex Sedan Possibly Faulty Cluster
- ef9 innovative traction bar problem
- I would like some advice on my 1991 Honda Civic si hatback.
- 90 Hatchback Wheel Opinons
- how Do you run an oil pressure gauge to a 1990 civic DX
- Civic wagon trunk release
- JDM B16a swap in 80 STD EF Civic wiring questions
- What is a 12v junction box
- fuel pump cutting out
- Camshaft ID 🤔
- Swapping obd0 for obd1 injectors
- Trailing arm spindles?
- Ls/ vtec
- what do i need to put a JDM D15B vtec block with a d16a6 head
- Help please
- 1991 Honda civic hatch
- vss signal on ef9 cluster?
- fixing the up and down idle on b16a
- 1988 civic wa go van intermittent run condition at normal operating temp
- Guide to replace thermostat and gasket
- Are all Intergrated control unit (ICU) the same?
- CV axle issues...
- Passenger side corner/signal light don’t light up
- Turn signals are working idk why
- Can I use a ED/EF cat for b series CA BAR
- are DA’s and ED’s/EF’s cat the same?
- $600 Si Hatchback Restomod Build Thread
- engine mount adjustment
- Rt4wd wheel rebarraled specs ?
- Fusebox relocation, wire tuck. Crimp or solder?
- 1991 1.5 Sohc D15b2 A/T OBD0 Civic hatchback. Solid CEL , ECU show in no codes.
- D15b2 timing problems
- Few questions 1990 civic lx sedan
- injector help
