- Difficult Cold Start...
- CRX B16a Completly stock w/ turbo ?
- ZC motor swap in 89 CRX EX
- can somone tell me what this is for?
- b18b obd2 swap help...
- Question about changing the oil
- Look what i got...
- z6 vtec head on 90 civic dx
- Addition on CRX hat..
- a6 plug gap
- ys1 starter
- buying new toy this afternoon.
- WHAT CAMBER KIT CAN I USE TO SLAM MY CRX HELP PLEASE!!!!
- teg dash in rex
- Any one try omnipower coilovers?
- how to make my exhaust sound nice and deep
- question about shift linkage for EF b16 swap
- need help with head
- New to EFs, how the hell do I change tranny fluid?
- 90 4door civic/b16a
- WHO WANTS SOME CRX WINDOW VISORS!!!!!!!!!!!!!!!!!!!!!!!
- Unorthodox Crank Pulley, does it replace the dampner?
- shavings on my oil pickup screen...
- Engine price
- water pump torque specs. b16a
- 88 crx si ECM how do you check if its ok
- shift points?
- sohc non vtec vs. sohc vtec
- 1990 CIVIC PARTS WANTED!!!
- shifter....
- Fuel Pump...
- Front bumper difference.
- Sunroof mounting?
- Engine floods fuel pump won't stop running
- EM C Pillar Bars
- redline not consistant?????
- Does your CRX Understeer?
- RE: EP seats in an EF Hatch
- Quality of short shifter?
- someone with a ZC please help...
- not going into gear
- Mugen CRX aerodynamics
- Monza exhausts
- Cleaning parts?
- is there any known issues in having a LS motor into a crx??
- Wiring Need help........... OBD0 to OBD1
- ZC DOHC?
- Something interesting I noticed about my HF Engine
- 88 CRX mods?
- tranny year?
- Randomly threw some codes (quick help)
- CRX/EF hatch interchangeable?
- fixing a CEL
- Head gasket size question
- front mount or a traction bar?
- need wiring help!
- my ef hatch
- zc tranny
- Hasport obd - obd1 for DX crx. need help?
- Looking for the SUN VISORS for ef-9...
- "CRX sticker"?*tail light center section sticker*
- car smoking from turbo and exhuast... plzz help!!
- oil leak question
- how can i make my bumper light stay on on my 91 civic si
- Just bought a 88 CRX HF w/ sunroof?
- How Much??
- 88-91 crx and civic dx?
- RHD crx list
- 94-01 Integra interior into an EF?
- What model CRX do i have
- vtec solinoid
- JDM d15b boggin 2200-3400 RPM Any suggestions or clues??
- swap
- DIY or pay
- I bought a 91 EF 4 door for $1
- got '88 si ecu have question
- Help! B16 swap gone bad
- electronics question
- EF civc parts for sale!!!
- NEED HELP PLEASE!!
- NoT The ALternator What CoUld It BE?
- hotoresizer.com
- Place Racing Shift Linkage
- O2 Sensor Install in D15. How Hard is it to do?
- DOHC ZC ??'s!
- how much would you charge
- Gas Leak 1990 Civic Si
- radiator
- question on cv shafts for swap
- RSR EX MAG VS GREDDY SP
- for those of you that have rattle canned your car.......
- vtec solenoid problem
- how much the same?
- a/c problem, need help?
- no vtec plz help
- pulling motor out, or drop from bottom? whats easier?
- tranny issues
- final drive gears
- CTR shift boot
- jdm crx ?
- lude seats in crx
- how to tell the diff between a ys1 gsr tranny and a ys1 ls tranny...
- Si tranny indentification?
- Any pics of everything needed for DA brake conversion?
- brown top zc
- Spacers anyone?
- engine code.. weird? 02 sensor but disabled.............hmm
- 1st gen B16A FPR on Second Gen B Series.....
- whats a good engine setup..... żb16?
- Car buying help
- kinda of wierd question
- question on 4drs
- Junkyards in the PA/NJ area....
- Fuel Pump for 1990 crx si and b20 vtec
- 91 hatch trade for 95 prelude
- Crx B16a throws CEL but no code
- Dizzy help mini me !!!
- zc tranny or si tranny
- short shifter
- 99 CIVIC COUPE W/B18C TURBO
- auto to standard
- pics of my rex
- help with wiring where the harness clips have been cut off
- ecu pinout
- Help real quick
- What wire harness do I use?
- How the F*k do you mount 90 crx si seats in a 89 Civic??
- picture question?
- Short shifter question?Skunk2
- what kind of rims should I put on this 91 crx???
- clutch replacement. cost? time before its dead?
- My day just went from bad to worse
- Part number for opitima battery
- Tanabe USA looking for new contacts
- Transmission is getting hard to shift, sometimes wont!
- even more ZC help...
- 1/4 mi times.....Si tranny vs. Dx tranny....noticable differences?????
- Alternator wiring problem
- I have a wierd problem with engine sputter?
- Outa gas....Needle on E or redline?????
- dust shield b16a swap
- exhaust popping and clutch question
- how well do BILSTEIN shocks work for lowered cars?
- Greddy oil catch can installed
- F22 swap 91 Si
- Door panels. Search done.
- Flexplate to flywheel conversion
- Just bought some transparent paint....
- blocks
- D15B2 Block sensors... Pics wanted!
- What causes a/c controls to break?
- idle not where is should be. please help
- Tearing Down EF (56k sit this one out)
- Which has shorter gear ratios? A ZC or a d16a6 tranny?
- Starter relay on CRX?
- corner lenses
- Anyone with a 5 lug swap?...Axle question...
- 15.2 sec 1/4 mile.........question
- Future MPFI Swap
- Fuse Block in engine compartment
- swap guide
- Thermal R&D 3"civic exhaust. Ground clearance?
- IS TOO MUCH OIL IN A HONDA BAD???
- Oh no coolent everywhere!
- hey why cant i....
- help cel
- hasport harness for DX crx converted
- For Sale: Skunk2 Muffler and Tanabe Racing Medallion
- OBD0-OBD1 ecu swap
- B16 Transmission
- best place to buy pistons and rods??
- chat
- Quick tranny fluid question.......searched
- BulkHead / Core Support Removal
- Trans grind
- sohc zc vs. d16a6 cam
- typical honda sheet metal thickness
- need more rpm?
- ECU help B16a2
- Best place to buy front clip? Or engine w/ matching cluster?
- 15x7's?
- somebody make a k series conversion into a crx 1990
- will this fit ??? need to know ASAP
- Overheating on newly rebuilt motor
- 16" wheels and Falken azeni. Issues?
- how to drop 100 lbs off a 90standard hatchback?!
- cant find the thread on stock vehicle weights?!
- A couple questions...
- !!!!freekin coffee can!!!!
- Tranny Problems
- Gear oil refill
- DPI to MPFI wiring changes
- Skunk2 Manifold On D16A6
- vtec x over???
- JDM front end/ lip kits
- Omni-Power A-arm camber kit for the EF
- mpfi swap
- Nightime pics of my black painted headlight housings...
- Engine sounds..
- rear disc conversion 90 civic si (did a search)
- ef lip
- suggestions on painting side mouldings
- CONNECTING UR HORN TO THE BRAKES ? A GOOD IDEA ? VIDEO
- CEL code on swap HELP!!!!!!!!
- custom cluster in my rex
- tips and suggestions to get rid of rattles and noises?
- Whats the shortest shifter out there?
- bad fuel economy after swap
- 88 Crx USDM Cluster Pinout * SEARCHED*
- Cheap engine mounts for a first gen crx.(B16)
- obd1 injector question
- hasport mounts
- suspenion question
- What brake options do we have?
- wiring diagram
- what do u think of my ef
- swap d16z6 into 90 civic dx
- afc ll help please!
- da integra front breaks.....
- CRX with a D16Z6 help
- Type-R cams???
- crx with the razor back
- iac valve question
- extra hatch what to do with it ?
- idle problem with my b18a
- To people with seat re-covered in Vinyl.....
- Omni Coilover Kit for CRX?
- Hubs??
- help....how do the plugs go into the dissy?
- b16a1 distibutor
- emmisions failure
- DPFI to MPFI Distributor plug Color wires.
- weight diffrence of EF drums to Rear Discs??
- pa sensor
- Tracking down possible elec prob: need more thoughts on checklist included...
- OVERFLOW PROBLEMS !!!!!!!
- pg7 for mpfi swap
- Code 21 !? obd1 jdm vtec in my EF VTEC spool valve
- A movie I made to celebrate EF Love (tm)
- Exhaust manifolds the same?? Need to know for TURBO!!!
- any guys with a b18a swap in hf?
- EF SIR hood and head light on my USDM CRX !
- Anything to watch out for putting a HF short block and tranny in a DX
- Just instaled my Dry shot ZEX kit on my car, any of yall have the ZEX kit???
- few questions about my swap.HELP
- Integra cams in ZC motor?
- CRX SYSTEM WIRING helppppppp
- TRADE YOUR CRX FOR B18c1 and complete engine internals
- idling problem!
- ITR cluster into 88' crx?
