View Full Version : Honda CRX / EF Civic (1988 - 1991)
- OBD-1 ZC? What will Dizzy fit?
- aftermarket cross members worth it?
- A new 90 civic si owner here. A few questions...
- siR or acura xsi?
- 1st gen b16 inigitor..can any 88~91 ignitor fit?
- my car is retarded...I NEED HELP...FAST!!!!
- D series rod???
- shock/spring alignment questions.. help me out
- Y1 LSD- what is it?
- looking for a YS1 anyone know where to get one?
- EF Spoon lip
- Help with B16 Swap...
- i finally got my sohc zc in my wagon
- 91 LS swap
- 1st gen b16 alternator crapped on me..need to find alternative
- anyone there
- vavle adjustment quest.
- How much to ask for F**KED up B16 head?
- crap...car's running like crap
- Where are all the screws to g et the front bumper off!
- the elusive 15/16" ....
- CRX With Sprint EXTREME springs?
- electric load help~!!!!
- 98 Civic DX hatch back.. what turbo kit would be best?
- Attention: MPFI swap rollcall
- Bulb Part Number
- whats a d16z6 worth?
- Leaky sunroof! im weT!
- Auto to manual swap any tips before my endeavor?
- ITR suspension on an EF...
- Paintjob coming up: need advice on chassis work
- speed bleeder reccomendations?
- b16a plug gap???
- Is this lip avalible anywhere?
- Block number matches vin#?
- suspension techniques front sway bar
- HELP!!! car wont start!!!
- Good price should I go for it?
- What specific red is it on the 90 civic?
- B16a Car stumbling and missing unless given lots of throttle...
- is it possible--zc??
- what B16 for 91 CRX swap???
- engine removal for b16
- HCI B16 article
- 88-91 Turbo Crx/Civic
- Some pics of my SMIC project
- Cluster install HELP
- Engine Advice For A dummy???
- Questions about chassis and specs...
- ??? *** Why does B16a1 have 2 O2 Sensors? *** ???
- Wiring diagram????
- n20 b16 rex?
- Installing JDM SiR cluster in an 88 Civic Hatch
- pulley problems
- what is the best b's head package for going all motor
- gsr guage cluster install
- Question?????
- hx wheels
- bigger brake booster...
- 98 civic cluster in rex
- b16 sensors?
- junkyard turbo?
- 84-87 crx?
- 84-87 motor mounts?
- quick question on upper arm?
- Lookie what showed up in my garage!!!!
- Red 1994 Honda Civic Coupe *STOLEN* from Tysons Corner Mall
- Help Suspension Techniques rear sway bar install
- ECU question
- need to know wich trany I will get!!!
- engine?
- honda motor guru Q's
- Got my ride back -_-
- 92-95 DC Sprts header on a 89 CRX
- how to wire up jdm power folding mirrors??
- EF wont rev over 3500
- cam angle sensor?
- 91 Civic DX Distributor or SI???????? Dual Point to Multi Point???????
- What will I need to do to a stock SOHC engine internals to prep for boost?
- What work is involved to put si tranny/engine into a dx?
- Need Help With My Tranny
- si and dx transmission
- cleaning my engine
- DX to SI...?
- 12V Switched Power...need to find one..
- Serious question about "Tornado Air" and the like.
- Need a little wiring info for zc or teg dizzy
- 91 Hatch suspension alternatives. What choices do we have?
- Can we talk speedo cable?? b16 CRX
- smoke after high rpms...question
- head shaving
- Replacing radiator. Tips, advice, and a full report.
- Rust coming back..should I fix or start on a clean shell???
- 88-91 and 92-95 sohc tranny question
- b16 piston's
- Bringing out our cams, heres whats available
- 92-95 hb shocks on 88-91 crx?
- zc dohc, D16a8 dohc > is there a difference
- v-afc wiring how-to?
- y1 tranny
- hf to si...
- EG Springs fit 89 hatch???
- D16Z6 with ZC Pistons
- Beeping Sound!
- 1.5 DX Exhaust Manifold
- code 4 help
- is the D16A6's EACV interchangeable with a dohc ZC's?
- alternator problem in b16 crx
- i was offered $4446.00 for my totalled car......
- HELP!! installing ES bushing shifter *pics*
- rearmain seal woes
- B series tranny gurus
- Clutches and flywheels
- what about axis maglite
- need a ZC in michigan...any shops in Toronto?
- revhard downpipe fitment on EF?
- Anyone have a Blitz DTT DC II installed here?
- Tranny Stamp
- does anybody know if this is true?
- Honda-Tech.com, it's a small world.
- Rotor Diameter...ASAP
- can timing set off the crank angle sensor?
- Where to buy 89 Si distributor?
- 91 Civic DX Distributor???
- ITR valves in B16A!
- My 1989 Civic DX Up for Sale on Ebay
- need a Helms manual for 90 Civic Hatch
- Muffler fell off - time for a full exhaust upgrade
- 10 west freeway
- I need help on the price of my crx
- Turn signals anyone?
- Which V-tec cams are better??
- 2001 ITR ECU
- 91 integra ls msd ignition
- OT: [New England Area] Anyone want to go to NED tonight?
- cams?
- OBD 0 to OBD 1 wiring diagram?
- code 9 . . . dont know what to do !!! HELP!!!!
- h23a injectors on dohc zc???
- ECU CODE 1 help!!!!
- Si tranny
- Ok I know this is not the classifieds, But I need some EF bumper lights.
- stock crx weight
- What fuel pressure for D16Y8.
- stock SI lip for stock bumper
- vtec selonoid
- Autometer Tach jumps around...
- b16a clutch's?
- 92-95 Vtec head
- b20 vtec crx
- Rear Camber Bolts and Washers
- Z10 Settings
- How hard is it to install the Ingalls Front Camber Kit?
- Need some help with 4th Gen Turbo Piping/IC!
- G/B on indiglo's for a 1G CRX, I need 15-20 ppl.
- what questions to ask body shop?
- suspension queery!?
- code 17? 18?
- FS:1989 CRX SI with B16a moded and full suspension
- 14" Tire choices?
- b16/skunk2mani HELP!!
- Just put some stuff up for sale.
- anyone rebuilt their dizzy before?
- k-series tranny on B-series motor.
- Body damage Question
- Video
- post your d16z6 SWAP TIPS here
- is my engine dying on me?
- zc distributor!?!?!?!?!?!?!?!?
- Noob asking for help
- *failed* emissions test only today
- B16A1 Dyno
- the car has been recovered....
- Crx SI engine bay
- Any EF's for sale?--- Northern Virginia
- What parts other, than the engine, should I be taking? (for a b18b)
- Heres the link to my ebay auction if anyone is interested in it.
- Help with bizarre brake problem...
- i'm scared...help meeeeeee
- CRX battery tie down
- Anyone interested in this??
- POssible dome light short
- TypeTC mirror for your EF?
- battery relocation to where resonator sits - questions
- HELP...im running really rich!!!
- anyone have the vacuum diagrahm for a 91 Si?
- Fenders?
- b16a swap
- head gasket q's
- is nitrous safe on a stock d16z6?
- crxsi/b18c general clearances & 4?s
- more Skunk2 manifold woes...
- What's the advantage OBD1 and CTR N1 pulley??
- quick question
- seat belt lights and beep each time I brake?
- Traction Control Bar?
- b20vtec? anyone run this setup for awhile w/0 probz
- 5Zigen Fireball pics on a EF????
- How to clean fuel injectors
- replaced a cv clamp
- still gettin a code 6 (coolant temp) on a b16...
- which intake for b16a?
- header bolt broke
- help!
- CRX shopbook????
- First Drive with B16 in. Just a few questions?? (kinda long)
- b16a parts?
- What is this noise at high rpm?
- power steering
- CRX door compatability help
- obd1 mini-me
- Stock 88 CRX Si POS+ wire for ECU (stock)?
- $600 for white HF, should I...........
- SpeedTrialUSA track day @ GingerMan Raceway Oct. 20
- Help Quick???
- Arizona Race
- Fuel Injectors
- 1st gen CRX/b16 swap...is a/c possible?
- break upgrade
- z6 block with a crx si tranny
- Tips for changing a water-pump on a '92 16v 1.6?
- Broken bolt stuck in transmission mount
- Anyone lookin for H.I.D. light conversion
- 91 CRX Si + Z6 = 200 miles/1 gas tank??????
- Help With ZC swap ECU???
- gsr bottomend with a b16a2 head burning oil bad!! why? and what should i do?
- Tranny blew up need help!!
- how do i...
- New brake kit for the CRX/Civic...
- things not needed on b16a
- Which of these would be best to drop in a civic...
- How is the mileage per tank/gallon after a b16(or b18) swap into a civic?
- What are the advantages of high compression?
- Oil Pans...
- 88 CRX upgrade...
- Engine Help!
- yo
- honda part prices
- You said rod! heh heh heh.
- Oil pressure gauge suggestions
- What do these "canister" things do on a Honda???
- My CRX is up for sale
- Y8 mini me ----->obd 1; what distributor to use???
- I just lost my car......
- Post your AIM name
- skun2
- OBD0 - OBDI no EGR solenoid control??
- Help my ZC Run, Still Codes Replaced Sensor
- Need some help on a crx
