View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Right Blinker Blinks Fast - But all lights look like they are okay... help!
- a pillar removal
- what front forks did you use in your h22 swap in your ef?
- Removing the headlights?
- throttle cable question
- frustrated with swap
- gauge cluster
- runing with out a thermostat? how bad is it?
- how to tell the difference between usdm intake mani and jdm intake mani?
- 90 crx si, swaping with a d16z6
- timing belt on b16.?
- crx 91 si Manuel transmission fill bolt stripped help!
- Best suspension/brake on CRX JDM for lapping!!
- 96-00 rad
- widest tire???
- half sized rad
- Help In Va
- collant shooting out the engine
- jdm rear bumper with lip question
- crx rear wheel hub replacement
- Zdyne Super Ecu Pinout Question
- help with temp sensors on b16 in crx
- Transmission
- hf to mpfi dx
- Lights Flickering and Gauges go up and down wildly
- Car Vibrates/Knocks on RIGHT turns, but NOT on LEFT?
- ECU Help
- need info on b16a1
- Options... Rotor to Hub Bolt
- Will a Cast iron turbo manifold setup provide enough room to run the stock radiator (not a thick ful
- roll cage question
- ?? for any one HF and SI weird swap
- Welcome me back into the ef game! i got me a 91 civic si!
- Thinking about buying a CRX, had a few questions.
- ls swap?
- turbo question help
- I AM NEW... NEED HELP........
- quarter pannels?
- B18 Swap in a 91 DX wiring question
- Question about Injectors
- radiator and hoses
- my hatch
- D15b6 block and crank work with d15b7 internals?
- CRX hatch leak....
- fan switch
- vacuum lines pics
- i need new axels
- HELPPPPPPPPPPPP
- WIll i pass emissions??
- rev bogging and intermittance
- 18 short flashs
- nitrous
- d15s
- 89 Cluster into 91
- I need to replace the axel in my EF8. Do I use Integra ones?
- problem with revving
- radiator shroude??
- Civicflow's hatch build
- b16 timing belt help
- water temp gauge
- Sedan LX. never came with a 1.6 sohc from the factory?
- need a new roof skin, for my ef sedan. any ideas? beside junkyard
- S1 transmission fluid
- RSR ExMag vs GT2 vs HKS Sport
- Philk's 88 crx dx with b16 hardly nothing to something project!
- Leaky glass sunroof on my UKDM Civic EF ('90 Hatch) VT
- problems
- need some help on my b16a!!!!
- B16 in EF. starts then will not restart
- they try to steal it
- PICS OF YOUR FAVORITE ROADS!!!!
- I Need Help A.S.A.P PLEASE!!!
- Installing A/C in 88 dx w/ b16, i need some assistance with some things.
- Cable to Hydro?
- LCA Bushings instead of traction bars?
- HELP: obd0 -> obd1 O2 sensor
- Identify Header.
- will 1990-1993 integra axles fit a 1988 crx si with an ls swap?
- D series shift linkage question
- Searched: Difference between S1 and Y1
- the TRUTH about the 5-lug swap re: front knuckles and suspension geometry
- Power Steering "looping" to Manual???
- strange shorting problem
- My swap with some questions
- I need help with ma EF
- reallys tupid question
- ecu question
- Eradic Tach!1!1!!!
- check out this jdm body kit ?
- distributor question!!! obd1 crx
- How to Align Doors on a 90 CRX?
- Anyone Ever Put s2000 exhaust on Crx?
- questionn helpp
- Need help, on wiring harness
- Rota gt3 15x7
- Grant GT wheel on a civic lx w/ cruise? Confused?
- Old Hondas
- Need Some Help..
- WANT TO BUY RADIATOR FAN FOR EF9. SOCAL AREA.
- si/hf question
- obd0-obd1 swap help no spark!
- B16 clutch cable (92-93 GSR)from 90 CRX Si doesn't work on '89 DX w/ same motor?
- CEL code 43 FUEL SUPPLY SYSTEM OBD0-OBD1 D16Z6 O2 sensor placement
- Tachometer
- sidemarker cutout
- good exhaust systems for my 90 si.
- Cleaning Intake Manifold.
- Code 1 unless I run A/C or stay under 3K rpms
- CRX tuck and shave!!
- S2000 Style Seats?
- NOT Sure whats wrong
- sparkplugs white
- d15b2 dpfi to 92-95 civic ex mpfi
- 1991 CRX Si performance parts on 1987 CRX?
- 89 civic std problems
- crx ls vtec help please
- dpfi to mpfi. resistor box need with obd1 injectors.
- Innovative Front Mount + HASport Mounts + B-Series = ??????
- Cooling Fan Toggle Switch
- b16 swap wont run...HELP!!!!
- Exsplicitspeeds traction bar.
- Question on compatible parts for my wrecked CRX
- MY Brakes WTF....
- p30 ecu run without knock?
- 92 DA knuckles with EG shocks and eibach prokit springs on 88hf
- Swap SI harness or mod DX harness?
- backfires alot..
- B20B block-B18C/B16A head anyone got this combo in their civ/crx?
- NOOB Question
- my poor hatch : (
- %^&*check my wiring on 4 wire o2 sensor*&^%
- anybody using Innovative h22 ef mounts?
- Door panel repair....
- will 88/89 civic headlights fit 88/89 crx
- friends crx... coolant not going through lower radiator hose... ?
- NEED HELP 1989 HONDA CIVIC SI ????????
- 91 EX sedan front wheel bearing specifications?
- SPARK PLUG BROKEN
- fuel line problem!!!
- Just bought an 89 CRX
- "HELP"how can i get my EF8 with a JDMb16 Bard/street legal
- crx b16 turbo question
- mud guard innerchangeability
- Is my racing chip gonna work?
- sputter problem since swap
- brake caliper interchangeability between civic and crx?
- best street lowering springs
- Rywire
- Post-Manual pedal swap issues
- my car wont stay running
- CRX Dash/Si Door Panels
- oil pump question..
- Please give me a break.
- Head Gasket Question.
- horn button install
- d16y8 swap question..
- cam gears?
- uber tech question
- rhd crx or ef9
- Part it out or sell it whole?
- fuel feed hose/pipe
- 91 starts but has zero power, need help asap
- My 88 4 door was stolen, HElp!!!! ( south central los angeles )
- ef sedan power steering. i want to remove it. which lines do i loop?
- CRX problems
- dohc compatibility
- STOLEN CRX IN BAY AREA, CA!
- traction bar question
- Norcal Crxpo event Aug 11th Gilroy CA
- question about my 91 ef hatch
- Brake dust shield need or not so much Weird noises
- Sweet Burnout Vid!
- foglights...
- Warning Light - I don't understand!
- 2nd gen B16a problem.
- Help with ECU Codes
- Will this fit a 91 CRX Si?
- once again, another problem
- new motor... need opinions
- '87 CRX
- What this part called?
- crank and camshaft misaligned, will it hurt motor bad PLEASE HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- KINDA A LOW AND ROUGH IDLE
- Question about a wire
- japan visitor, what to bring ?
- Folks that uses oddyssey batteries.
- dohc zc swap sputtering
- Knock and o2 sensor?
- Sunroof question for CRX
- Help! what kind of CRX bumper is this?
- duz the greddy strut bar for HB fit the sedan?
- question
- exhaust
- HELP! Card dies then does not start in the RAIN, JDM B16A??? MAP SENSOR?
- Repairing rims with curbrash?
- need engine head specs
- 87 CRX overheating
- ***Neuspeed Race spring user's chime in***
- Lower seat position
- reliable?
- b20
- EG/DC camber fit into an EF
- I just blew my motor.
- 91 hatch bumper covers on an 89 hatch
- sidemarker question
- how the manual tranmission works?
- Changing out hub and spindal and AXLe
- crx edm ef8 bumper and apron (like the one in the link) fit on a civic edm si ???
- Misfire/Hesitation
- Turbo for b16
- Having some electrical problems with my 88 Sedan
- da suspension change?
- civic 1990 sedan awd
- alternator for B16
- New Radiator problem for crx!!!!!!!
- New Radiator problem for crx!!!!!!!!
- help with mounting front bumper, wheres this go ?
- Alternator issues
- Please help me !!! WHICH BUMPER IS THIS ???
- Camshafts for B16 ( BLOX or others ? )
- spark plug gap
- ECU Question
- Im COMPLETELY retarded...
- any1 kno how i can get these tail lights? PLEASE HELP
- rear speakers wires ?
- speedo cluster
- How to remove a b16 tranny? Searched...Please help.
- problems...
- check timing on a d series?
- Brake shudder
- T3 turbo d-series...what manifold to make it fit with stock full length radiator?
- i have a seriouse problem
- what tb for bar?
- Window Cranks
- programs for tuning?
- vafc good or bad?
- how do i fix a code 21
- CRX seats in my Hatch?
- B16 problem.
- new exhaust, now engine smoking/overheating
- Seat belts draining battery, any help?
- 90 Si Quickie paint job pics...
- Turbo from Saab Questions.
- CRX B16 AIR INTAKE PIPING HELP, Which other honda or acura is similar???
- Engine Grounds
- b16a in crx si has a loss of power... help me out
- civic 90 put one piece headlight
- 1990 Civic, does the 1.6 use same stuff as 1.5?
- 90 Hatch Si / ZC Dohc New.
- Car wont start... sometimes
