View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Engine swapping Sun Feb 22. Any advice would be appreciated...
- 89 teg intake manifold-----DOHC ZC, hp gains worth it?
- B16a 2 wire O2 sensor
- car won't start - loud ticking sound
- URGENT need a picture for reference
- Car is "lagging": please help!
- GM sychronmesh?
- Used the search, but didn't find exactly what I'm looking for: B18c6 Block
- 90-91 corner lights anyone......
- HELP! Swaping my motor and need help with axles
- es oval
- cleaning products for engine bryte/engine prep
- What other steering columns will replace my 1990 CRX Si One?
- Labor cost for timing belt on b16?
- Anybody with a JDM Sir II?
- Hardcore cam???
- CV Boot Goin? Clicking Sound....
- Anyone hear of break through pads ?
- B20 Wiring (Searched)
- Can anyone PLEASE find me 1 kosei seneka racing rim 17''?
- 90-93 integra cluster in 91 hatch
- whats the prices for windshelds around?
- oem lsd question
- noise when car is cold?
- rpm that vtec kicks in on b16a
- is the swap this easy? b16/91 HF
- 98 gsr seats in crx
- exhaust cutouts
- honda civic 91 hb passenger mirror glass cracked!
- Rim offset question ?
- 10 bucks to whoever can fiqure this out...
- Heads SOHC vs. DOHC
- what is this??pic
- header modification necessary for...
- Cut fender or roll it with a bat? Opinions please!
- DC headers for b18c swap???
- Need assistance.... Rear Brake Swap for my CRX comming off a 00 Civic Si
- H23 EF Installation, what is all needed (AUTO)? Technical read...
- 88 std to 91 si harness?
- fuel pump and rc injectors
- 91 HB radiator in a 90 CRX?
- Will this fit....pls help!!
- Civic and CRX exhaust question
- B16A running very sluggish in my 90 crx si
- heat doesn't get very hot this past week...why?
- Finally did the home depot lip! HDM style
- armrest alternative *pics*...please don't lock
- a/f gauge install help
- 1st gen B-series info needed
- ZC Swap into a CRX HELP!
- Where the heck can I get some Tein's from.....
- anyone have an idea how much a raceing clutch runs for
- whats a pm9 ecu?
- z-10 bars for crx's??
- short shifter/shifter bushing install??
- anyone got brown interior??
- Rear Disc Conversion ????s
- d15b2 mini-me HELP!
- Help reading the codes thrown by the ECU...
- MPFI part III: Update-im a moron punch me
- peice of b16 tranny.. what is it?
- Estimated cost of new alternator?
- I thought I would ask in the "EF" forum since I didnt get much response in the General Discussion an
- B16 Tb on d series???
- -PROB- with timeing belt
- How do I Install my short shifter?
- vtec not working
- Just got an alignment
- DC gauge clusters
- Help!! I dodnt pass my cali smog check... please help
- guys need your help, 99-00 ex wiring harness obd2 version B
- Getting ready to buy a new Rex, Need a little help
- silver EK
- ZC owners , jdm aftermarket header
- pulsing brakes
- Does H22A injectors work with B16A??
- Anyone got a pic of VSS?
- need help with brakes
- camber kits! off ebay? or any others? lets make a useful post
- rip off ... ?
- tie rod... help!
- 90 crx si- rear disc conversion
- Having TPS and Map sensor problems, Y8
- 90 CRX si part out and more..
- d16y8 into a CRX DX - VTEC question
- 1991 Si hatchback heater control "Please Look Inside"
- Turbo, AC or no AC?
- What spring should i get???
- NGK BKR7E or BKR6E plugs?
- to do or not to do (ef9 visions)
- Best Oil for a 160k 91 Civic Si?
- Steering wheel options?
- B17a swap done...some Q's
- what can you use from leftover d15 for b16?
- tranny problem
- Bouncy ride - CRX lowered with Neuspeeds, and camber kit front and rear
- Interesting and Odd request
- Lug nut thread size?
- d15 vs. D16 ?!
- 90 civic hatch bumper corner light....
- Help with S-AFC install in CRX Si w/Stock Computer
- need to replace axle
- Here is How-To I made for removing the AC Compressor and other parts...
- 92 4dr civ seats??
- T25 custum turbo on d16a6...fittings?
- Moroso oil pan for 91 civic hb si
- New Engine Questions
- when replacing clutch in jdmb16 what year/vehicle do you use?
- Differences between CLutch disc size?
- 93 civic dx weight?
- replacement parts for jdm b16???
- Heating Problem with My car
- Need help with clutch...ASAP!!!
- what should be replaced? (my damage from a couple months ago) - pics
- b16 tranny?
- Hello, just bought me an 88 CRX SI...what to do, what to do?? hehe
- i am sorry but i had to post this to share
- Anyone with a Magnaflow Oval Muffler
- turboed b16 questions?
- 88 si trnas. in a 91 si
- water pump question
- Need Help
- Anyone heard of these coilovers???
- another swap ? b16a2/91 HF
- tanni swapping
- sir2?
- b16 tranny?
- dust boots for tokico blues
- [Canada ONLY] FS/WTB ***EF ONLY*** Parts
- update on car.
- blinker fluid?
- Will electronic VSS just drop in and moun up???
- is it a good idea?
- crazy stuff going on with my tranny
- TPS woes part 2
- Brake Fluid
- got an ef, and it doesnt have any trim, where can i get some, its really ugly w/out
- need the best strongest shocks for 3.5 drop ef
- Whats needed for a GSR swap in a 90 crx si???
- Spring Rates
- stock b16 exhaust mani vs. stock b18a mani???
- Anyone with KW coilovers?
- HELP!!!! Heater not working
- CRX dash... who designed this thing?
- Anyone in a country with Right-Hand-Drive cars...
- b18b obd-0?
- What does the -S3- stamp on my tranny stand for?
- b16 pr3 question!!!! LAST problem!! lets finish my car!
- 90 clear bumper lenses doesnt fit???
- Clickin noise when sharp turn??
- Stock Intake Riser Tube Question on Civics
- Cable B16A vs. Hydro B16A
- where are the vss and back up light switch...............
- engine sounds change... cold weather.. happens to you????
- How much for a used alternator?
- civic front brake hose question
- 91 CRX SI seats into 90 Civic DX - what do i need to do?
- what the hell is that noise
- How do I fix this Saggy Bumper?
- 89 CRX With Integra Master Cylinder and Portioning Valve.
- PGMFI relay location?
- 2.5" full catback
- itr sway bar on ef
- looking for fenders and radiator support for a 88-91 crx!!!!!
- 90 integra trailing arm/rear disc brake question i need this one guys i have faith
- 2'' or 2 1/4'' Axel back?
- jdm motors pass inspection
- 96 MGP DX or 2000 black DX?
- trying to reg/smog your jdm b16?
- noing bigger
- how much should i pay??
- teg r pistons and cams in b16?
- Stuffs for sale
- Roll cage for a CRX
- Pr3(ecu) topping out at 115mph
- Tach and Speedometer not working right!
- Theraml 3" Exhaust System Question
- CRX D16Z6 swap
- axis wheels?
- KS, MO, OK, AR, TX...people check this out..
- More problems...Help, anyone?
- how to take transparent plastic off gauge cluster
- ef squad t shirts white-pics inside
- hood wont pop open
- NEED HELP: Car running on 3 cyclinder
- d16a1
- B18a 1/4 times????
- Fuse problem?
- Hey does anyone watch Tech TV???
- b16 manifolds, ls valve covers, and cluster with 10k tack and haulmeter air fuel gauge
- Will ES bushing set for CRX fit the Hatchback?
- 99 conversion
- i need a b16
- little lighting problem
- Automatic Engine Swap?
- Mugen Strut in a EF??
- tokico 5 way and st rear bar
- Anyone have a dyno chart of a mini-me?
- Buzzing evac..no start...help!!!
- bilstein struts????
- b16 vs d16
- got into an accident...=(
- which ones do I repin? I did do a search
- B16A into Crx Instuctions
- Quick question. What's the diameter of the stock front sway bar on a Gen2 SI???
- how do you adjust jdm headlights??
- Yanking the b16 out of the 91 si, going to put in a d16z6
- ZC head lights.
- 90 crx clutch
- Important suspension question
- HELP ! Cylinder Position Sensor
- Big brake upgrade for my '91 CRX Si?
- Rear LCA Bushing Removal
- zc manifold, same pattern as first gen integra?
- 90 crx with d16az6
- Power Windows....
- alternator removal
- Question about CRX
- automatic si question
- Car vibrates - could it be an axle?
- B16 swap difficulty??
- will any other polyurethane bushing kits fit?
- B16a + PR3 + Hondata 2 guys...? for u
- 1.8L D series? Anyone ever....
- Eliminating wheel gap?
- Whoever has installed ES bushings, or not, I have a question.
- B series engine mounts
- Where's the timing connector for a b16a hf?
- Which crx??
- civic and CRX weight differences
- Replacing my rear wiper blade
- are tokico blues a good shock choice for someone who doesn't race?
- 92'-95' radiator support question
- Wanna see some times for......
- just intstalled my sprint springs!!
- the honda is it posible?
- axles help?
- Exhaust- Aluminized Piping vs. Stainless Steel
- quick question about distributors
- Throw out bearing question
- Can you identify these struts?
- alien b16 distributor
- where can i buy a sensei front end for my 90 civic hatch?
- swap brakes
- jdm ef9 sir cluster fit/work in a 88dx hatch w/ b16?
- best place to get b16 mount kit?
- 85 CRX Si Motor Mounts
- USDM SOHC VTEC/ JDM SOHC VTEC part questions guru's (reply)
- about h&r springs....
