View Full Version : Honda CRX / EF Civic (1988 - 1991)
- where are the #%^@ rear speaker wires!?!
- Adjust the Clutch Play and Pedal?
- Where are some good places?
- My ZC Crx
- GOOD camber kit for an EF?
- possessed car... (starter? tumbler?)
- People running ZC's...........
- SI wiring harness - HF wiring harness
- Why do we need a rollcage? This is why!!!!!!!!!!!!!!!
- Does the Wings West RS sideskirts cover lift points?
- 88-91 Civic/CRX Meet in Pa April 21st!
- does this look like a body kit to you?
- Installing A/C
- do 90-91 LS axles work in LS swap? or too big? and how do i tell drivers side?
- A/C WITH THE B16A AND PLACE MOUNTS????
- Installing JDM sidemarkers?
- MARIOFEST II MD/VA/DC BBQ DATE SET!!!
- b16 bogging problem fixed
- how do i do a compression test ??
- Front Bumper Removal for CRX?
- Brake caliper upgrade
- CRX Mirrors
- look at this guys.... everything goes...
- YEAAA....I now own a EF and a EG
- front break question
- Well, that's it guys ........ I'm done ........ take care and see you on the road.
- A little help here plz
- JDM SiR Gauge Cluster Q's?
- grinding on 3rd gear, need help on whats causing it?
- anyone have a pic of a vis hood on rex???????????
- AEM Programable Fuel Manegement
- B16A swap info needed
- for those of you that were interested in the rear seats
- drag turbo kit in an 88-91 hatch(post pictures of your setup)
- Squeaks and sqeals from suspension???
- hard cornering, low fuel, major boggage!
- Looking for a D16a6 in Ontario, Canada.
- bought a 88 crx si
- 88 crx wierd idle problem
- My hatch...not much done to it yet
- PICS O MY HOOPDY
- need pics of wide body kit...
- What kind of lights do i need?
- Hesitation
- D16a6 Dyno charts
- Will 91 CRX Si seats fit in a 89 Civic DX hatch?
- Hey can any one post pics of .....
- Shocks Sugestion for 1990 DX
- Integra Type R suspension
- Anybody in New England area
- d16a6 to d18a6 turbo???
- air conditioning help......
- intercooler pipe
- CRX for $430000!!
- my jdm front end came today
- Engine swap help...
- Jdm Engines
- Hello
- How big of a difference will a stock clutch be compared to a performance clutch?
- how can you tell what tranny year you have and the type????
- CRX INTERIOR..
- Height difference B16 and B18 manifold??
- in regards to dustin
- why do i hear a weird squealing sound when i drive with my AC on at almost redline in each gear?
- rear brakes swap?
- MARIOFEST 2 BBQ PLANNED!!!! CHECK PAGE 2 MD/VA/DC MEET.
- ne1 want a new vis cf hood in the CT area?
- Which Crankshaft do I get for my ZC?
- Yippie i got a ZC hood
- HELP?!?!?!?!
- The search is working!!
- will ITR stock intake fit in b16 hatch
- exedy clutch for sale
- need a cam...
- pace setter adjustable short throw shifter
- 3rd gear grinding noises
- Am I running rich?
- Fuel pump issues?????
- where can i get?
- reputable paint shop on Long island New York?
- Speaker Brackets?
- Coilovers or Lowering Springs
- Harness install help
- Rear lower tie bar opinions?
- IDLE PROBLEMS PLZ HELP
- parting out d16a6
- Swap is done, time for pics. Let me know what you think
- 85 crx and b16?
- a pretty cool picture and a political statement =)
- Does LS Tranny fit d15b2????????
- Rod/Stroke question
- Homemade intake
- Mini Me!!!
- Thermostat application for B16A1 ?
- looking for d16a6 in VA,MD,DC area
- Exhause Question?
- Attn: Turbo B-series EFs! Which manifold for our cramped engine bays?
- temp guage probs
- Which cable tranny is the best
- rebuild kit for honda---
- Wheel this fit?
- wtb left side tanny mount-no luck in the classifieds
- shifter
- corner lights
- paint ?
- Thought I'd Post An Auto-X Pic of Me...
- new tires
- One more question! (easy for you guys!)
- what clutch to use with ys1
- nice
- What is the 'mandrel bent'?
- Swapping heads... Can I do this?
- Is this worth it?
- Replacing Axle
- crx stuff
- 1988 White CRX DX 4 Sale: WA Only
- eibach sportlines + kyb agx +b16a =.....2.25 inch drop?!?
- B16 swap in a 1st gen crx-IN PROGRESS help
- CRX Si interior
- Axle seated properly?
- hmm question
- Will an EG rear seat fit in an EF???
- how can i get the srs indicator light to go off
- Need dyno charts for D16
- what kind of rods can i use?
- 1988 CRX Hf model car....
- Acura MDX radio anttena?
- Clutchmaster stage 1 and lightened flywheel for 630 in my hands?
- Need 89 civic/crx driver's side headlight and corner lamp asap
- setting timing on a B16
- do NOT go to " TWISTED PERFORMANCE" for anything if you live in nc...
- Im a retard
- b16a1 how to get bottom end for little $?
- anyone near wheaton maryland?
- think of selling the rex
- My clutch pedal is starting to squeak
- went to summit sport compact nationals yesterday
- Slightly OT: Import Tuner MPFI Swap article
- fs: greddy exhaust for 88-91 civic hatch
- spark plugs are loosened, what's wrong next?
- Pics of my painted Calipers
- anyone with split head gasket in their b16?
- who would win? b16swapped CRX/01itr?
- Quick ?
- Where to buy ACT clutch and flywheel toghter! (package)
- HELP!
- would this clutch work!
- speedometer doesn't work anymore?
- Replaced the ZC dist. ARRRG!!!
- What Causes Knock ????!!
- I think I need a new Engine+tranny........ PLEASE HELP GUYS
- problem
- NEED 90-91 Civic STOCK Corners ASAP!
- Questions regarding B16A Knuckle and Hub assembly for 91 CRX HF
- Pics of my PT Cruiser.....rrrr I mean civic
- centerforce clutch
- How the hell do I tell what kinda tranny I have!
- Will this oil work for our car?
- How to identify HKS ZC Cams?
- ROLL CAGE help
- Thinking of Selling the Rex-What's she worth?
- header
- centerforce dual friction clutch
- Maybe I can get help from you guys since I am not getting any at TECH?
- just installed antenna..
- thinking of.....
- Code 4, please help!
- obd0 to obd1
- ECU Questions
- Well, its gotten worse!!!
- What engine in an 88 Integra LS?
- ZC CAMS AND GEARS
- diffrencess between 90 civic cx and 90civic si
- Which companies make polished radiator hoses for our car?
- power steering in a 88-91 hatch?
- CODE 23!!!
- get off flywheel on auto d16z6???????HELP
- Anyone knows the number for American Honda Finance Company?
- gauge cluster swap - need help!
- All B-series engine builders need help!!!
- I HATE WEATHER!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Ripped Axle Boot...
- Test pipe?
- dimensions of the d16a
- In need of some help
- EXTRA!!! EXTRA!!! GOOD NEWS FOR EF OWNERS 2DR AND 4DRS
- aftermarket engine temp gauge?
- race(weight) prep dx
- Conversion Complete!
- need lowering advice
- Who has a y-49 ???
- questions for those with knowledge
- Newbie here, Pics of my car
- Is it worth it?
- What Kinda times would a H22A make in a Rex?
- 88 CRX Si interior for sale...cheap!
- in regards to hf distributers
- LS/VTEC or B16
- I'm Pissed.....
- eg to ef distributer wire conversion
- HF to Si Head swap?
- rear sway bar mounting points?
- ls into ef times
- EF rear camber and tire rubbing fix
- hey guys my pics and crap
- question about Sunny Styling CF hood from JDM hondaparts
- Gab wheels, new shoes for the Rex
- Which KYB shock do I need?
- Rolling back odometer
- Comments on putting a H22a in a 89 rex?
- can i use the DX trans case for Si gears??
- am i old school?
- 2 b16a1 q's
- Cheap Clutch Upgrade?
- ZC problem ..need help
- what do you guys think? compression ?..
- Pics of the B18b!
- What weight spring to replace my coilovers spring with.
- Lets get to know our fellow 4th geners, you may also include early 80's models as well.
- Code 9 HELP!
- co,pression with NO2
- is there a difference?
- AEM CAI from a SI on a DX?
- Need pinout diagram for nonobd
- 88-91 Civic/CRX Meet in Pa for April 14th is Cancelled
- seatbelt doesnt latch?
- front bumper ground clearance?
- f/s 89 CRX ls/vtec
- 88-91 Civic Hatchback Clear Taillights
- questions about trailing arm bushings and replacement
- anyone have a hood for sale??
- CRX SI distributor on CRX LS
- Parts Interchangability???
- who can answer my question?
- timing belt walking away
- CRX fuel line diameter?
- What should i do??? $$$
- altezza lights?
- what is that bracket looking piece for in the throttle body?
- Broke my axels ... Q?
- CRX B16a w/ supercharger
- how to get rear control arms off?
- EF AWD???
- Headlight lenses
- mount kit adaptability...
- Clutch Question
- anyone running a ys1 lsd?
- automatic b16a
- what type of o2 sensors should i get?
- APEX'i N1!
