View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Performance Spark Plugs and Wires?
- front mount cai?
- Car not STARTING! help!
- Anyone from Livermore? Need help with a d16a6 wiring in 91 dx. Will pay for help
- Trouble with CRX front bumper removal
- 99 SOHC NON-VTEC swap into a 88 CRX dx (manual)???
- Finished ZC Swap today, car won't start, throws code 10 for Intake Temp Sensor?
- any B20 swap people
- exhaust cut-off switch from straight-pipe to stock???
- instead or rewiring can i just go mini-me?
- OBD-1 Injectors on a OBD-0 System
- anyone replace lower ball joints before?
- I found tha HOOK up on GSR SWAP!!!
- Much love for the 1st gen CRX (engine swap is done!)
- couple of goodies i picked up for my hatch
- zEaL B2 vS. tEiN Ha ????????????
- is this a good idea, or no?
- has anyone tryed cold welds??
- my yellow check light is on
- tach, odometer swap
- 88dx is no here
- To all ZC owners!!!
- AT flywheel on a manual trans?
- Car will not start!!!
- alignment after motor swap?
- EF8 front bumper install
- What Amp fuse for Horn on 89 CRX
- Carolina Shops
- Anyone have a B17A1 in an EF?
- No Brake Lights..NEED HELP! ASAP
- Painting exhaust for a sleeper look, anybody?
- What ALL coolant hoses do I need for my ZC swap?
- Coolent issue. Plese help!!!!
- H22a questions
- 1st generation crx will not start
- Help blowing fuses!
- Recommend any good LSVTEC build up sites?
- smc500 im getting atmospheric pressure code and trottle angle,any ideas?
- gsr shifter
- question to people that have worked on trannies.... and another surprise to you all...
- what could be wrong???
- ummm...obd1 - obd0 conversion???
- sesnor question for all you crx ers
- jim fab bar on crx??
- over 100mph for over an hour
- headrest
- WTF!! I blew out a inner wheel well today. Has this happened to anyone else?
- ZC info-
- how much should i sell my crx for?
- GSR Sway bar!
- intake questions
- DFW peeps--I need your help!
- ZC bolts... 48lbs, but one moe ?
- a few questions about zc head
- Is this a good deal?
- useing nitrous
- Junkyard Turbo Kits
- Low Idle and bucking on freeway ( erraticly )
- Sell my H22CRX for a 240SX...gimme your thoughts
- Compression numbers, need d16a1 help
- ZC aftermarket
- NEED a tranny for a ZC!
- ZC problems
- First impressions... ZC
- yesssss someone broke into my crx
- Flat tire rim stuck on car need help asap
- OEM Sway Bar Help. Please! What size bolt is needed for the oem sway bar:?
- Air Intake Question
- emmisions on my '92 dx?
- Rack ratio, PS vs. Non PS
- Kakimoto R EF8 Exhaust!
- help any one in the 703
- Preping the CRX
- Any tips on painting black stuff on the rex?
- tailight center piece diff 88-89/90-91?
- Spoon style mirrors came in yesterday
- Compression....whats it done for you lately?
- b18b into crx dx wiring?
- H22 VTEC - prelude......
- Anyone Have A CRX Interior Hatch Cover??
- ZC and SiR headlights, same bulbs?
- 84-87 CRX si performance pages?
- Help: Trailer Hitch for 96 Civic hatch
- zc brake booster question
- d16z6 head gasket on a 88 d15 block, will it work?
- Which Specific Oil to use??
- something that ive never seen done before
- finding TDC???
- How do i tell ?
- Rally CRX
- newer time map sensor
- fog lights
- msd sci,cap and coil problem need help bad
- Hi Flow cat converter?
- how to lower 85 crx?
- My car won't rev 3.5 OBD1 swap~~~
- camber kit
- Need better brakes for my HF
- I want a Rev-Hard stage 3, what do I need so my engine can handle it?
- crx w/b16 fs?
- HELP! Something really bad happened! AGG!! Need help ASAP!!!
- is there a way to use the automatic d16y8 intake manifold and TB?
- correct throttle body for 3rd gen zc
- Need a tranny ASAP!
- Rear trailing arm bushing...Prothane or Energy Suspension?
- New With Questions
- OBD-1 Wire Harness???
- 86 crx motor swap
- b16a swap HOOD rub?
- power windows on crx
- My 89 EF, trade straight for 17s or 18s?? anyone??
- CRX suspension
- help me.. my shit wont pass smog..
- pins from ecu
- d16z6???
- What are the best brake pads?
- placement on aftermarket gauges?
- For the b16a what car do i get these things from???
- 91 crx si D16Z6 PG7 ECU and MSD RPM yada yada...
- Ground Wires
- Anyone use this HYDRAULIC TRANNY "converter" from TheDropShop?
- CRX EE8 Websites
- Exhaust install set off check engine light????
- Strange creaking problem
- *OPINION* Replacing T-Belt with motor out??
- what cone filter do you use?
- jrsc aftercooler
- knock sensor relocation on a D-series block
- engine swap in san diego
- HELP: need (ps) window for 89si
- LSD how do I tell?
- Spark Plug Boot
- Painting 90-91 crx si wheels...
- b-series action clutch
- Adjustablility left for throttle cable...almost none
- b16 valves...
- does this sound right?
- has anyone ever done 4dr power door locks into a civ or crx?ive searched the archives already
- more pics of this crx?
- MPFI on CRX DX & Future Engine Swap
- rings? seals? help!
- looking for a specific program for my PWO
- b20z into ef sedan
- MPFI swap in MD? Who wants to do it for money.
- My new mod!
- Question! click when pressed on clutch?
- Few questions About my D16Z6 Swap in 1991 crx si
- timing mark on crank 1986 crx-frustrated.
- please help, installed drop zone spring on 1989 hb?
- vtec problems
- b16 tranny from hell
- DA crossmembers fit EF?
- SI cluster in DX
- where to get hondabond?
- Converted my friend's Civic to 5 speed for $100
- Anyone with a B17A1 in a 88-91 CRX/CIVIC, I need some help
- b16 4 crx w/zc
- DPFI vs MPFI plug
- how long does the trial membership last?
- couple new questions about the b18 into crx si swap?
- How do I go about getting someone banned from H-T
- Gauge POD install Q (really quick) help me out!!!!
- Will a DOHC motor bolt up to a 91 civic dx automatic tranny?
- S2k motor?
- obd2 b20vtec into 91crx si?
- 92-00 Rad in a EF
- Steel braided brake line Q
- Engine Code problems??
- Anyone here on J's racing lip group buy last month?
- Speedo prob...help???
- need mini me timing belt help FAST!!!!
- b16 swap is DONE! YAAAAY!
- will a 90LS o2 sensor fit my 90si?
- tie rod troubles anyone?? 91crxsi
- help with wheel choice.
- chipping my PWO- need some pointers!
- Place Racing front crossmember
- help !!! 90 crx si guage into 88 civic DX HB
- Im getting my OLD EF BACK!!!!!!!!
- Proportioning valve question...
- DIY Mini-me and crower cam
- 91 crx si vtec or not?
- what rotor/cap for b16?
- autometer rpm activate module
- WTF is wrong with my front end???
- oil control jet in a mini me???
- Hybrid Tranny Questions....
- code 13 anyoneone knows where is that sensor?
- 9.5" to 10.2" brake conversion, are steering knuckles REALLY needed?
- ITR armest in ef/crx?
- easyer way to bleed the brakes?
- I need help!
- Going Through Alternators Like Water
- test
- Re-wiring Audio....
- Muffler sound. How to get good performance with a deeper sound.
- CRX Maplight
- b18c swap worth?
- Suspension help - KYB AGX adjustable struts - please help.
- MPG in my CRX?
- did any 88-91 4 doors comw with power sunroofs???
- vtec activation switch fucked up shit going on, help cuz the search is down
- doing obd0-obd1
- i tried the search..Who Makes CF Mirrors for the CRX?
- B16A Parts???
- Steering column out of DX fit HF?
- Idle on a gude cam?
- Do you like your hondata?
- cluster problems....HELP
- b16/d16y8 difference
- What exhaust does my car have (won't work on the ZC)?
- dx to si
- droping the tank? got some questions
- How secure are the HASport mounts for the B16?
- Hasport mounts with Hydro tranny?
- can we use 91 teg ecu for crx b18 swap?
- spring rates! NEED TO KNOW ASAP!!
- D16y8 in CRX
- obd0 - obd1 conversion how to's? search down
- ViS Invader CF hood, with b16, would it fit?
- electrical problems with 88 rex si
- quick asap question about wheels... !!!
- Speedo don't work, no VTEC..please help me out!!!
- please help
- How long does it take to let piston rings set
- Need stock exhaust manifold in SEATTLE
- springs?
- obd 1 conversion question
- tranny problems!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- I want to make my civic Si fast!
- 1st gen CRX drums on a 2nd gen???
- obd0 to obd1 dizzy???
- help
- Will 96-00 tokico blues fit on my 91?
- CRX tires and pads?
- Question from newbie
- under dash harness swap question
- speed sensor ?
- need some help with a b18 swap
- backfiring and missing need help asap code 23
- b20 fitment problems???
- 00' ITR for sale link...
- Swap for a 91 hatch
- Would you buy this 88' CRX w/ B16a1?
- CRX thermosensor
- Speedometer Problem
- JDM Cluster Question?
- track times with my newly done b16 swap
- Quick Civic Question
- engine trouble *help*
