View Full Version : Honda CRX / EF Civic (1988 - 1991)
- things to do to avoid breaking my crx si axles
- any one know
- yaaay half the problem solved ? any tech's help my other half? :-)
- quick general yes or no question, please help
- test
- 85 si
- lower control arm help
- Where did you buy your Mugen anti-sway bar?
- exhaust help please
- S-AFC setting for a 91 Civic HB Si.
- Audio?
- Best Set-Up?
- looking for part number
- S2000 seats in a CRX
- O2 question
- Will 20" Rimz fit under my fenderwells with ractive coilovers?
- i know its nto a honda but anyone ehar of isuzu i-mark?
- Swap need help
- Weird noise after swap (b18c1)
- does anyone have pics of
- Stock airboxes that fit 90civic w/ b16?
- ECU codes....not sure
- What engine wil lfit in my 89 crx Si? Help please!!!!!!
- Does the VSS affect vtec???
- Tie rod end replacement
- H&R sport springs anyone got em and how do ya like em ?
- clutch question
- best standalone to get for crx
- Lower ball joint question
- Best way to setup the front end on a CRX (Suspension related)
- cooling fan switch
- Fuel Pump?
- Towing AWD Cars
- is this normal?
- Which wire is "hot"?
- cluster wiring
- What color??
- hesitation
- 86 CRX Si temp sensor...
- Windsheild removal WITHOUT cracking?
- getting Code 8 with PR3 and I completely checked the dizzy wiring
- ID this part (& supply it)
- 94 integra struts on an 89 crx, will it work?
- how much to civic Si seats weigh??
- paint exhaust?
- Overheating, burning anti-freeze, white smoke coming from engine bay
- Camshafts: Jun Vs. Skunk2
- Koyo radiators
- Where does the inline pump go ? help ASAP
- Allright, decided, 89 CRX with b18a, now some ???s
- where to find real jdm mugen kit? crx
- D16Z6 into 89 hatch?
- need help with actuator switch check out my diagram
- EF9 Civic in Super Street....finally they wise up!
- Best place to buy OEM decals?....help me!
- b-series mount kit preference
- Looking for the best price on a Fiber Images JDM style hood. Please help..
- 85 crx turbo help
- 91 crx interior
- my front end is damn crazy!!!!!
- Weird problem, could it be the map sensor?
- need a grey vtec solenoid clip, other cars with same connector?
- manual transmission hangs up
- Bought a CRX!! :)
- grey plug b16a1???
- B16a Block with 01 USA Type R head..Benfits??????
- :: hard starts ::
- 90-93 Tegra mirrors on 89 hatch?
- need a motor b20 or ls?
- code 9...irratic idle/stalling I have tried everything experienced help needed
- Battery re route???
- CRX HF w/B18c5.....shift linkage?
- Any1 put the battery where the 92-95 civic batterys are??
- car running hot; oil loss but no coolant loss
- Are there any aftermarket.....
- v-tec head on a crx si stock block
- rear disc brakes question....... need to know ASAP
- which years of the crx did the rear sway bar come in
- weighted shift knobs
- b16 crx code 9 and 6 ??
- strange problem..code one then crazy high idle!!!
- Totalled my CRX...
- Sunroof Rust
- Any Difference between JDM CTR Cams and USA 2001 Cams...?
- 14 steelie , whats teh widest tire i can pout on?
- 13" crx steelies fit on a crx si?
- If I have a b16 block with a gsr head will?
- ef guys opinions on which swap...thanx
- Anyone Ever Run Just Coilover Springs?
- Does anybody know anything about Hondamotorsonline.com
- A6 vs Z6 timing belt ?
- Lower idle....
- *RIP* My Turbo *pics 56k beware*
- Made another video, some CRX content. Vegas Racing Events...
- Euro SiR cluster install DIY info...
- I need help someone
- does eacv fit same for all crx 1988-1991?
- how do i do it
- Brake fluid leak
- What motor do I have??????
- Problems after replacing the engine in a 91 CRX 1.5l
- cel question...may do better in the integra forum tho??
- Upper Control arm bushing sqeaking like crazy!
- Why cant I post?
- What mounts for a '90 ls motor in an 88-91 crx / ef
- vss
- wheel shake and brakes rubbing
- 89 hatch windows
- would the cps.....
- Has anyone installed a Quaife into a ZC tranny?...
- Temperature gauge acting weird
- Will 5spd tranny from any civic work in place of a 4spd
- Whats Wrong with the HF?
- Grounding a T fitting
- Swapping an HF
- fog lights for ww kit?
- anyone on here get their b16a tranny rebuilt?
- Trade
- anyone post a pic or link to medium grey metallic civic/crx?
- What distributor????
- Racing Seats in an 88 CRX...
- HF exhaust manifold on d16a6??????
- i have searched and searched no help
- HELP with throttle pedal/idle
- 93 Civic Si rotors on 90 Civic STD
- brake conversion
- CRX taillights on Hatch?
- if i get 15" rota slips with a 40mm offset and put them on a 88crx
- aem short ram question
- Are these wires the right size???
- Problem with b16a1 install
- 88-91 EF rear lip
- Sohc vtec cams
- Details on mini me!!
- 89 crx si harness, sir cluster help needed. search fails me.
- If you could start your CRX project over...(best performance route?)
- what back seats for a 88-91 hatchback??
- buying a car from a friend
- I have a b16a1 with stock header. Any tips on removing o2's without header removal?
- Guages Install?
- TDC problem, yes another one!! - please help
- bogging problem on b16
- O2 sensor? Did search no help!
- need a distributor for my b16. what to buy
- Shifting problems
- crx head lights on a ef hatch......?
- supra taillights on 91 hatch
- Using A/C button for fans while lapping a good idea?
- want to upgrade my cooling system......
- is there an external fuel pump on a crx,i want to gat more fuel-but easily.
- Rear Disc Brake Conversion Question Not Asked Before!
- After Market Mirrors for a CRX?
- crx for sale on the east coast
- crank main seal replace qs??
- Kill switch question
- what is the name of this part???
- Should I or Should I not...that is the question??????
- squeaking in cargo area?
- Axles and Alternator
- No 5th or reverse
- I NEED HELP ASAP SEARCH didn't find anything
- Help me ID this engine
- Solid motor mounts....who makes em? who has em?>
- exhaust Steam?
- Anyone installed an Apexi Rev/Speed Meter into an EF?
- Windex On Gauge Cluster Plastic Bad IDEA! help?
- any1 got a 1st gen rex with a zc dohc
- tein full coilover suspension?
- what axles to use on 88 crx hf for b16a1 motor swap
- rims and speed, whats the deal
- Question on placement
- Polishing/resurfacing rims?
- 205/40/16 performance tires for crx, what brands, and where to get them!
- 2005 CRX? *pic*
- CRX SiR Custom Digital Dash (56k beware)
- Service manual now available for MK1 CRX / MK3 Civic Owners & Olive Top ZC/ZC1
- steering rack rebuild worth it??
- could my tranny be fawked up?
- best springs?? TEIN Stech or H&R sports?
- 89 CRX Si Battery Light??? Help!
- CRX Drivers Door Needed
- Another Casualty!!!
- b16 Second Gen....1/4 time..Got better........
- is my cat clogged?
- Polyurethane glue for bushings...and suspension question.
- my shifter is f*cked up!!!
- Steering rack pinion removal????
- factory taillights
- Vtec activation
- '88 CRX swap ...
- [FAQ] replacing the stock lines with SS line and AN fittings
- found a d16y8
- Intermitant Battery light...
- short shifter help!
- where to get fiber glass???
- top speed
- Where can I get this part cheap?
- low mph's + turn steering wheel = loud squeaking??? (crx)
- CRX Exhausts
- MOMO hub adapter owners, please chime in!!!!!!
- auto trans help?
- Cut my neuspeed sports or go coil overs?
- Anyone ever fab there own b series swap mounts>
- Will 90 Integra struts fit 90 Civic that's lowered?
- EBay: High Flow Catz
- DOor panel questions
- Anyone with a **REF** Bar Sticker On a EF 88-91 with OBD1 Motor here...?
- i need a B16 SIR I cable type for a 88 crx
- electrical problems
- Where is the best place to buy a rollcage?
- oyyy.... fuel pump
- What octane gas do you guys use on ur ZC or B16a??
- Question about SiR BUMPER lenses
- Best quality SiR CF hood?
- need a crx
- Help, need insight for springs
- ordered my falken azenis's today
- DX won't start....
- body kit FREE
- anyone running a 92-95 rad. w/A/C?
- ac woes, what exactly is needed to convert from r12 to r134a
- I'm going to Irwindale Speedway...good shops to visit nearby?
- new times...good?
- How do you replace A/C belt? Its Squealing? Hard to repalce?
- zc jdm crx hoods
- zc 1/4 mile times!!
- Nitrous or Turbo
- crx + Z6 + Greddy kit = needed Place Racing cross member?
- Oil feed line fittings ??? ASAP
- Compatibility of 94+ teg springs on an EF Civic?
- CRX Hatch Supports
- what's the best tranny for my zc - crx ???
- Tire wastin' fun
- ZC....Help before I slap him
- 94 01 integra stock gauge pod
- what are acceptable mounts for B16a in ef civic? (did search)
- car wont start, check engine light wont go out... main relay?!? 1st time problem like this HELP!
- ^^^^^different BUMPER SUPPORTS^^^^^
- 12 second B16A... AVI's to prove it.. lol
- Another intake ?
- Please Help - Advice needed
- car will not start, main relay the cause?
- WTB: Passenger side door for 91 CRX?
- widebody drawings/work in progress any comments??????
- Anyone else have noisy spring perches?
- How much for a Brand New 2001 Type R head with Cams complete.
- 90 Civic HB doors..will they fit on crx?
- Which alternator belt do I use for a b16a1?
- pics/ did search got nothing
- PM6 ECU worth anything?
