View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Changing a wheel stud
- gsr hatch vtec problems
- Power Steering
- Put new cams in my hatch and seems like there is less power... B16
- ED9 steering rack removal.
- anyone have any measurements on crx/civic/sedan hoods?
- b16 bogs like a mofo
- jdm b16 with dc 4-1 header. second o2 sensor
- CIVIC Si tranny vs. EX tranny
- Injector resistor box
- civic hatch hood same as crx?
- 91 STD to b16a or b18b power steering??
- can i install wire mesh on my front end of my crx
- Anyone know where to get a complete ef front clip??
- rip EF
- S-AFC install instruction and some questions
- TPS code woes
- CEL light on a a pre obd b16 with pr3 ecu
- HELP! im getting about 110 miles per tank!
- Distributor problem on D15B
- looking for stock spring rates
- Aftermarket cam timing?
- any how to guides for installing an ingalls front camber kit????
- does the 88-91 SI intake mani and TB have a cold idle valve?
- Replacement Oxygen Sensors on B16-- Do you guys recommend a Bosch Universal?
- is a crx si with b16 worth a 92-95 hatch?
- D-series dyno charts
- 1st gen crx info
- 86 civic wagon 4x4?
- 1986 CRX and H22?
- mpfi swap problem with 88 civic lx
- crx rear speaker?
- 90 crx si smokes
- high beams broke
- ouvalve adjustment on a SOHC vtec
- Any hood clearance issues with a mini-me?
- Most economic way to get low 14's/high 13's (all motor) in 91 Civic Si?
- Clutch question
- Camber Kit Opinions
- b16a pressure plate spring rubbing the clutch plate...
- Low voltage?
- Looking for whoever PMed me 5 weeks ago?
- Front clip prices?
- coolant line on throttle body
- how much are DA brakes worth?
- Si vs. Hf
- hydraulic vs cable tranny
- Car running cold.
- Found BEST CRX EVER! (junkyard *rare parts*)
- rate my SOHC plans...another A6 buildup
- HELP!! jg edelbrock victor x intk mnfld//b16a1 J-Spec
- d16z6 in hatch / crx
- Gettin rims
- Need More Advice on a New Exhaust (Ractive)
- HELP any one have CRX FONTS?????
- In a dilema with my d16a6 build....no valvetrain??? what the friek!
- is it ok to use 90 integra ls spark plugs for my 1st gen b16?
- heater is not very warm
- 91 rear disk on an 88 crx
- 90' Crx Si.. Whats the best performance mod to do??
- Header for crx with b16
- cant take my antennas out
- AEM, DC Sports, & Injen Clearance Sale
- Question YS1??
- B16a tranny question?
- How to gain a visual on your ECU
- Coilover question
- Anyone got a home made grill mesh??
- Door difference between 88-89 & 90-91 hatchback
- es motor mount inserts
- will my cat converter, hinder my exhaust setup???
- how do I install
- Im confused.. DPFI to MPFI. HELP!
- Idle problems with B16....
- OBD1 distributors....differences (LS ONLY)
- www.urbanimport.com?
- Is this safe
- got into crash need help with somethings
- MPFI in an auto?
- b18 or d16a6 turbo?? help me choose
- "modability" of an 85 crx
- Polsihing header question
- [FAQ] Real Time 4 Wheel Drive 4wd rt4wd
- Does it matter when you put the mounts on?
- Valve guides
- my car makes a poping noise form the exhaust
- Trani broke. pics :)
- Removing A/C on 90 CRX Si, need missing tube from under dash
- need crx quarter panels
- [FAQ] pulling a motor out of the bottom of the car aka ghetto motor pullin' (56k nightmare)
- Removing engine
- 95 ex into 90 crxhf
- steering wheel question
- weird sounds from front of crx
- already searched...code 17 and vtec troubles on my new swap!!???
- steering wheel adjustment??
- Magnaflow...straight thru or S tubes?
- Finally finished!!!! OBD1 harness
- B20
- Coilovers?
- Si ecu
- real d series power
- something went wrong with swap please help
- Better intake manifold??
- 86-87 integra pisonts in a mini-me?
- idle fluctuates
- d16z6 ... obd0 or obd1 ?
- B16A1 to hit 170whp??
- Space age glue
- Edelbrock?????
- just ordered b16 but how do i get it off the truck?
- replaced clutch, now rpm drops 3-500 when clutch engaged?
- won't start..searched but not having same problem as them
- My 1989 CRX Si 1/8th mile....
- Right size 15" wheel/tire combo on crx?
- 1990 CRX Si tranny - what's the tranny code?
- ok, susp.
- what sway/strut bar should i go with ?
- Alright guys LS-VTEC Idling at 2000 rpm????
- catback piping diameter and muffler for GSR swap??
- what swap to do on my 90 SI hatch
- ZC head build up
- Jdm B16a's - Fire right up?
- Help:Valve Cover Gasket Probs
- to those who have stripped their interior......
- b18c swap LOUD AS HELL inside????
- crx center taillights
- My bling bling hose finally came in
- what passenger side axle you use, in you b series swap!
- From what place should i get B16a ?
- Ultra FLO anyone use or hear one?
- mini me swap advise??
- Napa CRX Camber Kit
- Swapped interiors today, not doen though
- A/C Wire Harness after A/C Removal
- V-AFC w/OBD1 jumper
- Question about struts
- b 16 question
- Type R or EF??
- Heater control swap?
- My first Drag experience (racing...)
- Little hesitation from idle when tap the gas pedal, Help...anyone had this prob??
- Crazy Valve spring Idea q's
- how to install side markers?
- Rear wiper removal
- new to the crx
- Engine mount question
- Tach not working. How do you test for signal?
- b16 won't rev past 3krpm... why???
- will an integra ECU with higher rev hurt my civic?
- Will an 88-89 CRX Si cluster work an a 90-91 Civic STD hatch
- Sensor in Cat Coverter?
- Civic hatchback 92-95 parts
- How do you replace a radius rod?
- Need ZC help!
- D16Z6 Swap List
- What LSD should I get?
- Update on the B16A that will never run
- help on doing d series head san diego
- can't log out user name
- 90-91 Teg ECU in my Civic DX
- stock shocks?
- e jdm confusion...jdm dx engine?
- OBD1 question (CEL jumper)
- JIC full coilovers? quality, ride, reviews....
- A few questions about that home-depot lip...
- AWD CRX Turbo -> well actually 4X4 looks cool...
- exhaust question
- Reccomend a glasspack
- need help hooking up jdm folding mirrors
- Mechanical vs. Electronic gauges...water temp.
- Crashed into a snow bank, need help/feedback/ideas as to what may be wrong
- anyone with CRV manual, whats the final drive ratios for the awd 5spd?
- need help w/ obd1 conversion in ef [plz help, search did nothing]
- anyone have a how to write up on fuel pump install?
- Car wont start??!!
- is there any way this is stock
- Anyone running the Tociko Shock with Tokico Spring matched components?
- Front/Rear Apron????
- sunroof woes...
- JDM ITR 96 Cluster in a EF8
- what bulb for 88 dx hatch corner?
- JDM CRX Importer?
- hydro or cable clutch???
- Which engine to go with?
- hf crx injector size and si crx injector size
- injector size for Hf crx And SI crx
- obd0-->obd1 or not?? *confused*
- Compression on a mini-me???
- my new crx
- Putting in the B20 soon some questions
- Starter question
- braking dillema
- How do you take out an ECU?
- heater problem..
- is this a good deal?
- Will the CRX window fit in the 4th gen hatch?
- tranny question
- b18b swap into CRX Si
- 86-89 integra injectors
- Tranny rebuild labor?
- Recommended suspension for GSR Swap???
- DX Vs. Si
- wheelwell separation?
- HELP!! Koni Yellow adjusting questions?
- what size tires please help
- Vibration??
- big problem
- Info on an LS Swap
- camber question?
- What brand type of muffler is good for my setup for cheap
- b16a1 ecu code 12???
- how much will i dyno
- I bought my 3rd crx wooohooooo
- '89 crx si cluster upgrade
- help idel screwed
- Replacing hatch lid on 91 CRX...
- 1991 Engine check light help
- headlights suck
- Help with b16 mods
- Why is the drum so hard to take off for the ef
- ZEx kit ???
- springs or coilovers?
- Stopping hatch rattles?
- tstupid Q
- homemade home depot front lip???????????
- Removing Door step pannel on hatch?
- Got a D16Y8 or a Z6 head today what should I do?
- PM6 ECU on CRX HF motor?
- swaping exhaust from hatch to sedan
- Clutch question........
- d16a6 ?s about block and pistons
- Bushing/ball joint install
- getting correct parts for jdm b16a1
- why is my stock b16 so rich? information inside.
- 4g hatch catback on crx?
- Help!!!!!!!!!!!!!!!!!!
- Jackson Supercharger in B16 CRX....Possible?
- what is need for a dohc zc swap??
- heating
- Failed Smog Test - NO 1134 reading
- BUSTED my ZC Fuel Rail, What USDM vehicle can I use for it?
- 97 civic exhaust on 90 civic hatch?
- 1990 Wagon bumper ?
- 89 civic hatch DX shell swaping....
- Should I keep my Neuspeed Race???
- speedometer cable coming loose
- People that have done complete harness swaps in CRX's
- A question for those with coilovers
- crx armrest pictures
