View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Turbo Vic's 91 std mini me project thread (currently having timing problems)
- is this possible?
- Pulling Hard Under Strong Acceleration
- My d15b swap
- Got my evo VIII seat in and my suspension technique rear sway bar in today
- A/C hook up
- wiring harness questions!!!!!! please help!!!
- check it out y0!
- exhaust fitment dilemma...options?
- steering rack
- ECU CODES 2,22,23 How do i fix/override? B16a obd0
- distributor???
- new hatchy lots of pics inside
- My turn for an ef resto.
- Plastic Headlight Protectors for 91 Civic Hatch????
- PR4 or PM5 ?
- converting 88 hf to 91 si cluster
- how do i know what kind of RS*R exhaust i have?
- need help with swap
- neeed some serious help!!!
- ****I NEED HELP****** CRX CHECK ENGINE LIGHT AND TACH PROBLEM
- rumors: new CRX
- d15b2 swap to d16a6
- obd1 to obd0 conversion??
- Blower motor resistor pack. Where? and what does it look like?
- 11.8 second crx
- b16a1 mufflers
- suspension is shot
- bad head
- selling my exhaust, what should i do ?
- ctr pistons in b16
- CRX exhaust with b16?
- crx si gauge cluster doesnt work...
- WTB EDM CRX siR 1.6i 16v Deck Spoiler! WTB
- i have a quick question about USDM fog light brackets
- lost midrange power after obd1 converstion (b16a)
- Check engine light on OBD0 B16 CRX
- Front Right Wheel Spinning
- Cold start problem
- Should I B16,B18 or H22 my 89 CRX DX?????
- Does a turbo
- Need instructions on how to install EF jdm cluster onto 91 SI!!
- crx temp gauge problem
- brake problem...rotor wobbling VIDEO INSIDE
- obd1 check engine light on 91 crx
- advice needed!!
- crack clamate conrol? not working??
- What sensor is this?
- tranny???
- clutch problems
- after all this work it turns out
- bumper question...
- Where can I buy a Blue Valve cover?
- Homemade traction bars
- sedan using da integra rear disc
- Need help! obd0-obd1 question
- 91 hatch dx
- Replacement antennaes
- Header O2 Sensor question
- 91 crx rack and pinion replacement
- d16y7 head?
- serious overheating problem, where do i start?
- ctr and jr
- 96 prelude
- Rear Disc Conversion Need help
- d16a6 questions
- Suspension for '91 CRX with H2b?
- tuning specialists
- Selling 1992 GSR rims 250/obo
- Where to get a good paint job in OC?
- What type of exhaust sys. for Honda Crx?
- drum to disc conversion
- Anyone bought or seen these seats?
- siR bumper lens?
- gsr in EF what trottle link can i use.
- free b16 or gsr bottom end with b16 head?
- Lip
- my setup?
- clutch problem b16 cable trans
- 89 acura motor for sale twin cam
- DOCH ZC trans for sale LSD
- 90 SI Issues
- Clutch cable????
- External coil
- 91 ed si y7/y8 rev issues
- questions about my motor build...
- obd0-obd1 conv. process?
- help with si cam in stock dx...
- crx headlight question
- Civic SI wheels on a CRX
- Gauge install.
- crx starts real weird
- d15b2 with a d16a6 head, timing issues?
- Neeeeed help!
- engine problem plz help
- Little leak = Wet Ankles, any ideas?
- DPFI>>MPFI, Need Help
- Hydro Tranny /cluster (Speedo)
- ef b swap question
- will crx si harness work in civic with mpfi?????????
- iacv problems
- Hydro tranny in a CRX
- SiR front question?
- lsvtec turbod
- main causes for a code 20 (electrical load detector)?????
- problem need help
- just picked up a new rex (good camera, crappy shots)
- b16a b16 tranny after market sway bar
- Our Lamborghini vs a Honda CRX video
- b16a type R bottom end!
- 3200 rev limiter
- struts help
- what is this called?
- turbo or no?
- Rsr exmag help
- suspention project crx
- urgent will si alt work on dx motor!?!?!?!?
- My low budget, mild EF build.
- Does anybody know...
- weird crx issue (beeping)
- Help me with ecu wiring.............pix
- Moonroof problem 89 crx si
- Cusco Strut
- What seats will bolt into my 89 CRX si with little to no work?
- Problem with Dimmer/Defroster/Alternator Operation
- CEL what are these codes?!?!?
- What clutch will fit a first gen b16a?
- What can be used from an 89 teggy in the ef
- EG hubs on crx ???
- removing fitv on gsr TB
- REX Si Squeeeeek: Is it the hatch or suspension?
- Major FAIL on the emissions test...
- h22 swap
- 89crxsi(stock) dying out and not starting
- d16a6/d16z6 mini me shooting gas out the exhaust?????
- why is it bogging down at low rpm, help!
- prop valve
- leaking under driver side of bay
- what shocks goes good with h&r race springs
- old piece of shit broken alarm removal.
- Crank - No spark...
- Hasport harness conversion????
- cam timing
- Can y8 head bolt on to zc block??????
- how do i wire up a three stage vtec d15b into a obd1 converted crx using a p28
- Some Pics of bad ass civic
- I just bought a crx!!
- HELP!!! WTF IS THIS NOISE???? **WITH VIDEO**
- 91 si engine bay harness help
- Hi - Can I get a little help with my account?
- Shortening clutch pedal push distance?
- D16 knock sensor probs obd1 and 2...
- b16a question on crank pulley.
- Boosted b16a wont rev past 7800rpm??
- OBD0 ???
- B16a Swap New At This..
- thinest 4-1 headers for b18c
- Buyin GSR swapped CRX
- b16 in my ef
- dohc vtec sticker (searched)
- another camber kit question
- custom interior for sub/amp
- P72 JDM automatic to manual? It can be done?
- Smog Time, NOx Emissions
- tire dimension for jdm b16a crx
- which ecu for sohc vtec?
- D16a6 build
- EF Headligths?
- 90 CRX Si, JDM B18cR, Caged, Fresh paint, GC Coils, Rotas, Kevlar bucket, Etc, Etc...........
- 89 CRX w/ GS-R rear brakes - what rear trailing arm?
- LS/VTEC Wiring diagram?
- Si Brakes ???
- ls vacume lines
- axle trouble
- 91 si alternator..
- Samco coolant hoses
- A/C Help?
- Tie Rods issue wheel moves while driving.
- AEM Cam Gears. B Series + DOHC ZC
- Help with heater fan
- just picked up new rex need some help
- vtec wiring
- intake
- crx swap wiring trouble
- electrical problem..anybody help?
- Will 92-95 shocks fit my 89 si?
- Building up and Civic
- 98 D16Y7 INTO 89 SI HATCH! QUESTION?
- Installing SideMarkers HELP!!!!
- My '90 Hatch Build Thread. Check it out!!!!!!!
- vacuum lines
- 15 or 16 inch rota gt3's on ef?
- gsr acceleration problem
- funny gsr idle
- crank no start B16
- chipping obd0 PR3
- Gray smoke
- CRX 91 Si GSR Swap Mounts(all) checklist
- iacv hoses
- Looking For A Red 1990 EF Hatch
- problem with blower motor
- NEED HELP TO BUY CRX
- CRX PROBLEM, MIL AND TACH
- Saving yet another Poorly Maintained CRX...
- B16 EF Tanny Mount
- How get rear mount bolt?
- question?????
- 1988' CRX HF runnin Hot
- easyest way to get the shift linkage trans pin out
- will 88-89 door panels work on a 90-91 civic? and 4 door rear handles...
- Exedy Flywheel Opinions?
- Crx's & 88-91 Hatch w/ WW RS?
- s2000 rims on crx?
- is there any easy 5 lug conversion out there?
- possible bad rings?
- New front end Ef9 parts?
- axle swap out help
- crx issues
- Axle seals. which ones
- B20 ground clearence
- 90 ef... i need to remove my resistor box
- Innovative 88-91 D Series mounts are now available!!
- car wont start, alarm keeps going off!!!HELP!!
- Can't find my iac wire???
- "SEROUSLY" NO FS/WTB THREADS IN THE MAIN FORUM OR POINTS WILL BE LOST READ THE RULES
- NO FS/WTB THREADS IN THE MAIN FORUM OR POINTS WILL BE LOST READ THE RULES
- 4- crank Position sensor 10 IAT 15 ignition output signal m
- k20a, turbo b18
- --How to: alarm install-- REALLY THEFT PROOF!!!
- Advice please.
- o2 sensor problem fixed...
- 96 dx motor into 89 si hatch?????
- lsd question
- Flywheel weight
- help!!!!!!
- moonroof in hf
- Clunking or Popping noise
- My EF has high NOx....
- Replacement Upper control Arms
- help me out w/ my throwing codes
- B16 CRX problem...
- performance calipers
- Low compression on Cyl 2. Code 1. Bogging. Detailled. Need your opinion.
- looking for light wieght crank , alt, and power stering pulley
- honda harness help n integra help
- MSD spark plug wires ?
- ls tranny--b16 swap?
- b16 lsd axle problem
- Bushing Kit...
