View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Lighten up the CRX....
- GingerMan Raceway-SpeedTrialUSA April 17
- idling problem
- what size slicks for 14" wheels?
- need info d16y8 coversion
- WTF condensation pooling around spare tire owns me.
- roll cage piping ?
- Sohc Zc Motor Swap - DAD DITCHED ME, axles are main problem, wiring
- r there any header clearance issues for a b16 in a crx?
- ANyone heard of this alarm?
- brakes
- painting my car.... help please
- 91 SI SEAT QUESTIONS PLEASE HELP
- new motor in my std hatch
- my hood wont stay closed...... latch wont pop back out.....
- CV Boot for B16
- instrument cluster
- Im looking for Civic Hatchback From 92-95 (stock)
- Driving with just header, no exhaust or downpipe...
- question??
- OBD0 injectors
- A problem with another damn EF,,, 88 dx mutlipult, fuel/ecu issues
- 92-95 Si Swap in 89 Si rex
- Help! ZC Tranny
- Excessive smoke on my car Help
- 90-93 Integra muffler on a CRX?
- What motor should I put into my EF??
- Just bought a 89 Civic DX?
- Is this just a regular USDM Si lip? Or EF7? Pic of my car.
- DSM eclipse injector question for CRX
- Which axles fit the 91 Civic LX??
- Wiring Harness Question for CD Player install.
- manual/info wanted
- i'm not getting any fuel to the motor...HELP..!!!!
- CRX Interior Q: Heater Control
- Help... Wiring harness.
- 1st gen crx swap wiring....anyone make a plug and play?
- crx wont go into gear
- torque specs on tranny????????????????????
- Minime questions.. not firing.
- DC Cat back exhaust system, anyone running one of these?
- 3" Cold air intake. Anyone make one for EF? Got a 65MM throtle body.
- New member here
- pw0 vs pr3...y1 vs j1 vs s1 searched
- Covering out mods with the insurance company
- who's banged your front crossmember to clear a header? i need help/opinions
- DOHC ZC DYNO #'s...
- please explain me the logic behind adjustable shocks.
- Erradic Electrical Problems With Cluster and ELD
- our new video from this year!
- Whats a good exhaust set up>?
- Major Fuel problem
- 89 CIVIC DX ECU PIN OUTS
- ZC Clutch
- Making a COMBACK on my EF project ....
- Using dx/si hubs and knuckles with STD brakes...
- FUEL PROBLEM!!!!!
- Suspension differences
- engine idle rpm's
- Opinions wanted for wheels.
- Single Cam ZC
- help me get my car running
- What are the 2 fuses attached to the battery leading to?
- rut row.... stud broke.
- rust what should i do
- MAKE UR OWN TURBO .COM????????
- Is there a differnce in a y8 auto head, and a y8 5 speed head?
- JDM headlight conversion for 88-91 crx questions?
- amber corner lense
- JG engine..
- b20 in crx how hard is it
- CRX Roll Cage to Civic?
- b18a into 91 dx 4 door questions...help please!!
- help with my distributer on my 89 civic with a d15b vtec
- What to get for my son's birthday.
- Interchangable parts for 86-87 Crx Si?
- What kind of head is a P2J-2?
- where can someone get jdm front ends?
- starting problem on my CRX Si..help ! !
- yO whos got a roll bar/cage in thier EF9
- normal for an exhaust manifold to glow red?
- clearance issues JE 9:1 pistons in a minime
- wtb obd0 to obd1
- people who own ZDYNE ECU. please read this
- went to the strip today and raced my crx
- time to paint!!!!
- whats brand and where to buy shift linkage
- 90-93 integra lip ?
- b16 problems!
- anyone parting a 88-89 civic?
- clutch help b16
- ecu code 11 help!!
- Return to the world of the living....
- oil pressure question
- where to get 3 bolt exhaust flanges
- b16a vacume diagrams
- h 22 in a rex
- What struts to use w/ H&R Race springs....???
- motor swap ???
- AWD CRX??
- Vtecless Idea's?
- Thinking about building an EF "race car" (LS vs. VTEC)
- wiring trouble!!!!!
- Need some help
- EF Being stolen can anything be done to prevent it
- Rebuild?
- i got accord shocks and they are WRONG!
- True JDM CRX Gauges
- brake light constantly on
- mirrors: Civic 88-91 -> CRX 88-91?
- Need your help guys PLEASE!
- radio displays "COdE"?
- How to stop rust?
- where can i find this item in stock
- DA Integra calipers vs stock Si calipers in regards to actual braking ability?
- ZC Dohc upgrades?
- Getting window back on trac? Need some help! And yes iv searched already
- Speedo gear from CTR in Y2 cable tranny?
- Shes Aliveeeeeeeee Once more ;o)
- No spark, Need help!!!!!!!!!!!!
- JDM RHD Si-R
- 92-95 radiator
- motor mounts for crx-swap-help!!
- Need A SEAT BRACKET HELP ME!!! please
- jdm fog lights
- what number is supposed to be on a 90 SI head? pm3-2? of somethin else?
- Breaking the case on an si tranny...?
- Getting from Point A to Point B..... need suggestions
- hp number: CTR pistons in JDM b16A
- new wing for 88-91 civic hb??? check this out
- Gsr in a crx: a few questions
- Need advice on b16 turbo HELP!!!
- now i wann know were to get jdm front ends
- need crx si vacuum diagram...or help!
- can any one show me some pics of efs with eg mugen lips on them
- Ahhh, no brakes!
- did any go to the tech meeting at blodel?
- what years are what????
- high reving
- just finished most of D16A6 swap into 89 crx hf...vaccum hose on t\b questions!
- can someone car fax this crx? JHMED835XKS017409
- low budget brake upgrade...sedan/integra...again...searched
- I need help with a ZC problem!!!!
- H series to B series Adapter plate .....Has began.....
- will a audi k03 turbos work for an 88 crx si??
- Fixing sun burnt black std bumpers...
- Old head bolts longer than head bolts in new cylinder head. Which ones should I use?
- CAR STOLEN
- crx owners help me out with removing some interior questions
- Parts wanted
- which of these will work on my b16
- Integra Brake Booster in CRX?
- crx help
- Tire loose??!!
- Distributor for MPFI swap(tried searching)
- 88 dx d16z6 swap
- Mix and match shocks ok?
- ZC VS SI wiring ?'s....
- WW Bumper ???
- My CRX :D
- how to open hood when cable breaks?
- ls/vtech or super
- What should I do?
- Armrest going 4 nowadays........
- need a motor need one soon
- HF to DX questions
- crx rear hatch Q's
- new alternator, but battery still dieing.
- My Timing belt is running out. Cutting up the Plastic covers
- Possible to ID EX knuckles?
- How to hook up Apexi VAFC to PM6 ECU?
- CRX with GSR and cable tranny STARTER question?
- rota c10 on EF PICS requested
- What is a good ZC header?
- H22 IN EF
- SOHC ZC into 88 hf
- rear quarter panels?
- How much should I ask for?
- i think i just about totalled my car tonite...here's the story
- relocating battery quick ? unlike others
- what linkage for bseries gsr hyrdo tranny? into 88 crx si
- 94-01 gsr seats in my 88 crx hatch
- 95 gsr drivetrain into my 88 crx si
- crx pices
- ZC timing belt troubles
- will this rim size work?
- WW RS CRX kit Question
- E-BRAKE
- B20 IN 89 CRX SI???
- 4th gen 4door civic DX project inside....(56k do you feel lucky?)
- what valve seals for JDM DOHC ZC? (my part numbers attached)
- Street Racing
- want more power
- Hondata announces Reflash for Greddy Civic Si and RSX-S
- is taking the head off the z6 the same process as taking the a6 off?
- Increase horsepower for a '90 Civic DX Hatch
- viper alarm
- cell 22~
- Test Only In Los Angeles
- LCA swap. TECH info
- putting in ecu pins how?
- does anyone know what kind of radiator would fit in the SIR?
- Springs for EE2
- doing a b16a1 swap. need to know everything
- 1990 Integra RS Block....LSVTEC correct???
- MINI ME
- damnit! broke a sensor on the t\b when lowering down car to bolt up motor...help!!!
- spring is right around the corner... Bought some parts...
- 91 civic 4 door radiator support assembly removal.. Spotweld removal???
- I need to know how to fabricate eg spoon mirrors for my crx ASAP
- can stock HF header fit onto an si block?
- Avid B series shift linkage...and Hasport Billet mounts?...work together?
- ZC is running 1 problem tho
- tokico illuminas or kyb agx???
- more power on stock
- b18a into my hatch??
- i need a 91 crx si core support
- High Flow Catalitic Convertors
- Old hasport mounts
- which Front lower tie bar work with B series?
- why use b16 head on ls/vtec? why not use gsr head?
- Putting a B20Z in my 88' h/b DX, need help and info please. My first swap!
- OND-0 2 OBD-1 (DID SEARCH)
- 2nd gen teg dash in 89 hatch?
- need new clutch! what do u recommend?
- tranny swap info??????????
- tired of searching
- Tips to lighten my 90 civic hatch
- ZC axle question - not the usual Q
- Del Sol Side Skirts on EF?
- How to lighten a 91 CRX
- Need coilover help, which go on front? 350, or 450?
- Alignment off from coilovers...
- Wats the best and easiest junk yard turbo for a 88 crx si????
- b16a1 ECU Clip missing????
- YOU KNOW WHEN YOU FIND MONEY IN YOUR POCKET?? kinda like that!
- how to fix a code 6
- energy suspension bushing help
- How wide of tires can I go before I rub too bad? P225/50R-15
- quik question
- 1985 crx si 140 mph speedo
- which camber kit for rex???
- suspension
- spark plugs, wires,
- ZC in CRX motor swaps
- tranny help, pls!
- proform shift light install
- which exhaust?
- can't get the tensioner loose for the timing belt???
- has anyone used these on there crx
