View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Sensor problems -CRX B16
- i dont see my injector resister box
- does anybody have a picture of a b18b on a ef
- Removing cotter pin on LCA
- anyone have a crx si distributor?
- itr hatch wont fire over no more??
- ECU Question....
- b20b, vtec head
- 88 CRX DX Will this engine fit?
- CRX problems
- white smoke
- How'd you attach your throttle cable?
- Clean
- CRX CAD drawing???
- Not sure if this is the right place but i have a really weird sticker question
- map sensor
- Should I buy this junker?
- FS: Hasport EFB2 kit, A/C bracket, JKOBD OBD0-OBD1 harness.....
- Lookin for advice. Ls.vs.gsr
- tranny swap?
- wet nitrous kit on d16a6
- 6 puck sprung on my crx??
- Just ripped off front windshield molding... any advice? (4g4d)
- d16y8 build
- Booster: 91 Civic DX vs 91 Civic EX vs 91 CRX Si
- 91 Civic Dx cuts off at idle
- camber kit ???
- The last hatch I took to less schwab for an alignment
- which distributor can i use?
- mini me ecu help
- do i need to take these out
- brake lights
- brake booster
- runs for a while then stalls and wont start...
- Leaky fuel injectors
- idling problem!!!! please help?
- Dam this is a good ass deal on a new Exedy clutch and flywheel
- da mastercylinder and booster
- Greddy Turbo Timer on a 88 CRX?
- Paint.
- !INTAKE PICKING!?
- Alright. I have a 88 JDM Si Glasstop. Weighing options....
- gsr gaps
- White smoke at idle..
- ECU Qs?
- rolling chassis question
- obd1 crx w/ gsr swap CODE 17 VSS
- i need a 90/91crx passenger door PLEASE
- any one have pic's of some 90 si brake pads..?
- 89 Si differences to other years?
- Sprint Extreme Rx Springs (3.25") + KYB Gr2 Gas Shocks
- engine revving dont know whats wrong
- EF Civic optional console (pic)
- 99 Si springs on 90 CRX shocks?
- 89 and 91 crx headlights need quick response please>
- Which Bolts Do I need To hold on my flywheel? Please help ASAP!!
- k series in crx
- 91 CRX auto to manual question?
- fuse #14 ?????????
- Car wont start
- generations...
- b16a1 vs b16a2???????????
- compression questions need help
- Code 9 CYP - cylinder sensor
- Help! My dash is really loud!
- zc turbo?
- Wiring Trouble
- HELp
- Ls/vtec like Whoa!
- Spoon Tech
- Anyone got pics of 89-91 civic with black rota
- Anyone ever seen this spoiler?
- crx right side driver
- Seats in 88 DX ??
- help engine revs it self b18b in crx
- RCI Racing seat in a crx? Anyone have or saw this?
- Obd1 Conversion ...DO i need to cut distributor leg?
- will ef civic bumper fit?
- quick checking codes question
- i dont know where to post this.....
- 1988 Honda Civic, Transmission Swap question
- need help removing corners
- what bumpers fit crx?
- Wierd VSS problem (code 17)
- Is it just me???????? please answer people
- Need a Photochop please
- LS/VTEC swap trouble !!!
- Energy Suspension
- B Series Hydro Tranny in CRX. Which rear tranny bracket?
- wut rims should i get?
- D- Series
- help* car starts, then when throttle is applied, it stutters very badly and stalls out
- EF Hatch Gets a Paint Job at Home. What do you think?
- Shifter very looose
- B16 O2 probs...
- has anyone used this exhaust?
- 2 wires go that are coming from the lil white box on the back of the guacluster help??
- How much is this going to cost to fix... Can it be fixed?
- coolant problem on b16
- need help (TURBO)
- Traction Bar fore EE9 ???
- alternator Noise
- What do all the inlets and outlets of a fuel tank do?
- something bad?????? :( :( :(
- EF Shirt - Found!
- obd-0 distibutor question???
- b16 obd1 conversion which distributor can i use...
- 87' crx si?
- d series injectors on b16 swap
- jdm
- d-series tranny swaps
- Choking b16 crx under full throttle?
- Fuel pump not priming - MYSTERY!
- will 92+ flywheel and clutch be a straight drop-in on a 91 crx si
- Any Honda_Techers in Va
- how to tell if ef?
- Sudden loss of power
- Gold civic
- jdm cluster wiring
- No brakes?
- For sale 89 Hf Crx w/ Si Motor and Si ECU
- tell me if this is bad rings? Also is this car worth $1000?
- Can you help diagnose my 1987 Civic?
- Recent Purchase...
- Rear Mount Bracket B18 swap
- Skid Plate Protect Under Car What is it Called?
- another lsvtec boost question
- Do you Regret not getting LSD?
- B&M short shifter differences?
- b16 swap in 91 civic but won't start
- Troubleshooting: Car idles low and dies
- What is this worth?
- B16a cam timing?NEED HELP ASAP
- PW0
- Good Hatch Chassy
- Help No t Sure what CRX I have!!
- crx converted to obd1 check engine light ?????????????
- Crx Obd1 adapter harness from rywire.com do i need vtec sub harness
- failed Northern Virginia Emissions today
- will gsr or any integra seats fit?
- mini me coolant lines
- took car to shop, still wont start
- big honda D16z5 ZC motor problem !
- ZC Tranny in 90 Civic Which axles can I use?
- upgrade options for a zc engine
- Help please.....civic wont start...
- Some Autocross video(my very fast EF)
- dc sports 4-1 header one piece?
- Mugen steering boss, where?
- front bumper reinforcement
- EF8 bumper on a EF9
- i need help!! JDM Vs. Look-a-likes
- short shifter same as acura?
- Exhaust Smoke
- Where to get your transmission cleaned up at and how?
- JDM Leather wheel
- FL Pplz Only... Looking For 91 CRX Si Parts...
- anyone with EF turbo, B series and full size radiators?
- Time Slip, just in...
- PM5 Ecu Guide Needed
- 89 Civic steering column in an 89 CRX
- tips for driving manual?
- most common leak
- need tech help.
- clutch question
- 225/50/13 Hoosiers fit for auto-x on 89 CRX?? Too big??
- Misunfortunate Crx Decision.
- Looking for sites to buy built blocks
- Do you need this bracket?
- distributor for b16a
- Loud Clinking noise?
- D16z6 D16y8 Hybrid Questions
- Crx obd1 conversion harness...will i have to touch resistor box for my dsm 450's
- clunk sound
- 15x7's with 35mm offset on a CRX? Will these fit properly?
- Stock 1992 MR2 or 1988 CRX Si - 1/4 mile? 0 - 60? etc.
- ac from hatch to crx
- how much?
- ? about putting ls/vtec in crx
- Wrecked my crx!
- interested in civic si parts? I want to part out a civic si, opinions needed
- NEED HELP (noob question)
- Lowering a 1980 Cicic 1,3 LS
- HELP no click from the ecu relay
- JDM D15B Distributor(searched)
- need to know what this is.....
- Code 7 problems
- cuting short throw smaller?
- b16 in 91 std runs fine but trouble starting in the morning
- Lots of EF stuff to get rid of
- will a 1st gen dsm manifold fit my 1.5l crx?
- obd I conversion to obd 0
- what do i have to do to get my p28 chipped for my b16 swap
- Has anyone put the AWD system from a wagovan onto a CRX?
- B16a Distributor (OBD0) with LS Internals? Anyone know how?
- CRX Road Trip! WA to OH! Help a fellow HT'er out if you're off I-90!
- Aftermarket Clutch kit 88 CRX Si Trans/91 Flywheel
- Ok, the side marker install (pics)
- Yellow EF8 Foglights
- Small Problem
- '91 CRX front wheel removal
- BRAKE PROBLEM!!!!! PLEASE HELP!@!!!!!
- MPFI Swap probs
- which radiator hoses?
- is thermal the way to go?
- Rust/Water build up in the trunk.. What/How do i fix this..
- ZC mini-me question.
- vtec kickin in too early?
- willa stock p28 work with obd0 b16 swap in a 91 civic si and its also converted to obd1
- Carbs for CRX
- Who can help me swap my motor?!!!
- JDM CRX fog light dimensions
- Unfortunately I'm no longer an EFer! Wreck Crx details inside!
- Cracked windshield! need replacement in Los Angeles
- Heater core: Aluminum or Copper/brass
- PM7 Speed limiter
- which ecu program p28???
- air intakes / manifold questions...
- B18b1 in 90 civic HELP
- cel 4 help
- explain or help
- SOHC vs DOHC fuel efficiecy
- my 91 CRX Si in SICK! HELP
- LS vtec monster in crx
- just bought a 91 hatch dx need some diff opinions.
- h23 into 91 civic hb
- Tranny question!?!??!?!? Please help..
- Replaced Headgasket, car smokes only till about 10mph, then stops?
- Vin #
- CR-X 1.5X "G-SPECIAL EDITION"
- What do you guys think are the best after market rear brake lights for a rex?
- GSR cluster swap....need more info
- injectors
- Problems with starting the car
- Can anyone else get to Land Speed's webpage? www.landspeedracing.com
- fuel injector question, need answer ASAP
- Need to spice up my lil B16
- Can't decide on a D-series header? Look here..
- JimFab traction bars are no longer....??
- Fuel gauge not working?
- element help
- b16 swap ecu problem
- airbags
- Project ZC
- is it possible to remove tranny from crx?
- Looking for fog lights.
- Turbo rebuild
- b16 88' hatch,other goodies,CENTRAL JERSEY
- Plexi glass sunroof
- b16 swap materials?
