View Full Version : Honda CRX / EF Civic (1988 - 1991)
- factory cd player
- Will a cold air intake improve or worsen gas mileage on my D15B2?
- gas tank?
- Suspension
- LS VTEC or GSR
- ZC Cuts off ? Help!
- Need help with ZC!!! I am an idiot some times.
- what would you do??
- My Project With My 2 EF's ***Pics***
- Eg struts into an EF
- Swap questions
- D16A9 - B16A1 convertion problems.
- Sell or part out?
- Does the Sanden compressor hit the crossmember with a JDM B16A bracket.
- ECU Question
- (ECU) need help
- PUTTING ON H AND R'S
- Bay Area Fix For HG
- anyone know where i can get a OEM B16A SiR 1 *STOCK* header????
- brake booster?
- Bad Luck or What?
- Doors
- VIN# run
- Will a ITR Steering wheel fit my EF???
- oil pressure problems
- yellow spray
- d16y8 into a 88 rex si, what do i need to know???
- CIVIC SI 550$$$$ bucks
- anybody ever installed a Apexi Rev/Speed Meter
- Will 96-2k Civic LCA fit my 4dr EF?
- quick y8 oil jet question, pics inside
- mini me swap....oil pressure sensor?
- How do i rewire my 02 sensor??? "1 wire 02 sensor" to "4 wire 02 sensor"
- My first crx... mod help
- racing hooks?
- throwout bearing mismatch PICS INSIDE
- civic wagon 1991-1985 pics
- Need some advice on oil leaks
- supercharger
- need help with a/f guage
- Getting a code 15
- what octace does a 92 civic vx use?
- where do you recommend for me to get the SiR front end conversion?
- Milling dohc zc head ?
- b18a swap --- Mount issue
- brake conversion
- shifter play...help
- ls vtec conversion kit
- dohc zc
- waterpump
- AF w/ B20 VTEC or EF, EG, EK W/ k24?????
- did white 1990 crx dx's come with blue interior
- Will A/C system work with mini swap?
- A couple of Noob questions... I'm starting a new project!
- AF CRX..N/A or BOOST??
- Will Honda ever going to bring back the CRX?
- 84-87 CRX (AF) QUESTION...HELP!!
- Car won't start!
- ECU question
- some problems that crank angle sensor can cause?
- Are CRX HF motors interference motors?
- Main Relay help
- 97 civic coil overs
- 2007 CRX
- 90 HF Tranny into my 89 Civic sedan. Will it fit?
- need 'how to' on resistor box install
- cams
- Weird!
- How to tell difference in 86-87 and 88-89 PG7's??????
- Wheel pattern for Rex
- What head is this?????
- tranny problems
- will 88 crx fenders fit 91 corner lens
- My project is getting slowed down due to theft
- shop that sells traction bars in so-cal
- My project...56k....NO...
- 91 hatch b16a problems Can someone help?
- Anyone hatches in here with an apex ws exhaust and sway bar?
- weird noise?
- Little input would be great plz ....suspension, coilovers and choices
- Replacing catalytic converter w/ a muffler?
- another crx question
- upgrade help d16z6
- Leak in the cooling system
- Has anyone ever heard of the Pro1 coilovers?
- New muffler
- ne body have wiring diagram to swap a crx dx harness to make it mpfi by useing a 93 ls harness?
- replacing inner tie rod
- Whats different about the 88 crx si compared to the 89-91 crx si?
- My new short term project for Road Racing......
- looking for crx dx wiring harness
- should i should i not????
- mini me swap
- H22 questions.
- 88-91 crx fog lights
- AUTO B16 INTO 4DR CIVIC
- Engine life span once tuned plz help me before I blow something
- Shift Linkage Removal. How do you disconnect it? 88 Si D16a6
- raspy muffler
- code 5 (map sensor). everything was fine before the zc, whats my problem
- CRX CARBON FIBER LIP?!?!
- Sanity check needed
- plz help guys
- Car Harness Swap?
- inpo preformance???
- bumper setup question
- COMETIC HEAD GASKET
- 91 CRX weight reduction?
- greddy turbo kit on CRX
- Replacing Oil pressure switch D16A6
- turbo question
- Best Lip for a Crx !! (pic)
- Checklist for my brake swap and a question
- resetting an ecu on a 89 crx si..?
- jdm and edm paint codes
- is it possible to stick a K20 in a EF
- oil in my spark plugs...
- Omnipower Slip Coilovers: Anybody running these?
- Coolant Weep
- dual point wont pass 5200rpm when it was 6400 rpm. Y?
- ITBs questions
- HELP!!...what can be doing this???
- Would da stock shocks work with crx
- RS-R/Thermal/HKS/SKUNK2 exhaust question
- Air Conditioning????
- HELP removing stock rusted headers.!!!
- wat oem suspensions are compatiable w/ my 89 hatch?
- Wanna hear a funny story?
- vafc problems
- rotas
- Wiring for my drag car w/type r engine
- any way to drop a h22a in my 88 rex si?
- help with ef w/b18a [SoCal]
- finished ls swap runs like crap *searched*
- mount? b16a-->b18c
- 89 ls teg motor into 89-91 crx or hatch. please advise
- cheap springs for me beater ef?
- Strut bar on dual point
- wastegate Question?
- 4 Sale JDM SOHC ZC motor
- 92-95 civic conversion
- best tires for blades?
- burning oil, good compression
- How do i check for cel codes?
- Help with removing air filter guard.!!!
- Tachometer not reading correctly
- New Guage Cluster --> Blowing Fuses
- Difference between 88 and 91 Front Bumper
- air fuel gauge help!!!!!
- zc help
- Putting a speedo with tach into a 91 civic hatch, need help
- Lookin for whole ef9 front clip
- 88' 89' pm6 computer
- crx brake upgrade
- PM6 ECU or P28 on a D16Y8
- dpfi to mpfi swap, smog legal????
- s1 tranny
- hatch and crx seats are the same, right?
- NEED SOME EF PARTS!!!!
- Short Shifter or Not?
- Will headers for 92 civic fit 90 civic si?
- CRX HF dropping a ZC in couple questions.
- Bouncy suspension Help Please
- check out my new project!
- alternator?
- lets see those short shifters!!
- LAST MINUTE DECISION: CRX stock bumper or Wingswest?!
- 2nd gen b16 crx
- JDM B16 in CRX questions about Clutch and Mounts
- door molding
- EF Sedan...
- DA rear disc swap
- ok a little help with start up then die help guys!!! wondering what itcould be
- What kind of EDM parts are in demand right now??
- ***hard water spots on windows*** how do i get rid of them????
- zc vs. jdm d15 cam
- Lower radiator hose goes "DriP...DriP....DriP"
- All you rex guys making good HP
- Crx project what am i living out
- mini me ?
- Cheap brake upgrades, comment
- Sanden A/C compressor?
- WTF was honda thinking?!?!
- Auto trans adjustment 88 HB
- EDM EE9
- A Light Question for a 90 civic
- fs 91 jdm style crx
- CRX shell anyone?????
- 99 teg radiator in 91 Si
- does anyone have a link to an online service manual
- i need some help!
- if i put a zc in my crx 89 si what will it run in the 1/4 mile
- CEL codes
- b18c into my ee8 but it does not working...
- Apexi V-AFC for my D16Y8?
- Do I need a new starter for a z1 minime on a b2 block?
- Well, I'm leaving the ED/EF scene for good, I guess...
- crx turbo manifold
- California smog
- Stupid newbie question
- cam gear tuning question
- Brake Parts List
- Trying to buy a full conversion of DPFI to MPFI?
- DUAL POINT TO FUEL INJECTION
- hx engine question
- l-con traction bar ???
- What should I get?
- Vtec wiring Question..
- Alternator issues?
- Vaccum on IM......where's it go?
- where does this vacum line on the map sensor go?
- I need help on wat to do when i get my Honda Crx i am only 15 and i am getting a deal on 1 fo
- FS jdm style 91 crx
- Tell me about 87 CRX's
- suspension setups?
- how to test for ground at the fuel sending unit 90 hatch
- Radiator hose blown...
- strut bar question...
- what will work??
- Question about aftermarket exhaust and sway bar???
- oil pan gasket?
- scary noise i need to address ASAP
- OBD0 z6 swap started and ran yesterday but not today?
- What shop or backyard mechanic for a swap?
- CRX Dashboard into Civic. What do you do about the A/C Controls?
- starter will not engage
- need some tech info
- Fuel filter..
- 88-91 b16 LSD Option
- B18 in CRX..A/C..only Hasport or others?
- Type R style lip for crx...
- Anyone know what this noise may be from?
- Civic Hatchback "Hatch" question.
- JDM civic sir cluster ...direct fit?
- Will 13" rims fit on a CRX si?
- Who makes after market
- Any of you guys using Tein?
- Zc head on a d16a6
- 90-91 teg suspension on a 88 CRX?
- cat on 90 civic
- What drive shaft ?
- Auto to Manual Conversion--Worthwhile?
- How much gas is used each time you start up?
- Crx dash
- Hydro Locked
- Car won't start...any ideas?
- Apexi SAFC and a Fuel rail FPR? please help
- bunger is a scammer
- Question on OMP rear upper strut brace: Please look!!!
- 1991 Honda CRX DX Radiator
