View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Finally got tooned :)
- d16 stroker kit?
- CRX b16a2 swap pre-obd to obd2
- camber kit options
- i just want it to be quick.
- wiring for mini-me project.
- car bogged at vtec engage WTF
- how to pull codes on an 89 civic Si with D16Z6 swap???
- harnesses, dashes, engines oh my...
- Very faint seat-belt beep. How to fix?
- Fuses on positive battery terminal?
- Takes a while to start up?
- My first "What sensor is this... CEL issue?" post.
- Teaser...
- rear windshield $540.74!!!!!!!!!!!!!
- I need a motor!
- Weird Question.....
- blower housing question
- Coverting B18a1 to Obd1?
- will a obd1 d alternator work on a obd0 b motor?
- How to fix gray side moldings
- Braille shift knob?
- 89 EF ECU wires all chopped and screwed
- having troubles with 88 civic hatch need help
- Need help with Koni Yellow/GC install....
- Radiator leaking: best replacement???
- obd1 b16a to b18c
- EG/EK Swaps fit?
- !!!!!!!!NEED HELP!!!!!!!!! please any1
- EF8 rear lower tie bar question
- cf front lip
- Need help with 88-89 90-91 wiring in my crx
- 94 integra rear brakes ?
- DPFI to MPFI idleing too high
- about shocks that lift trunk ?
- Ecu question for DOHC ZC
- tire / rim question please need quick response before my dad throw them out
- New 500$ Project!!!
- Need to replace carpet with 251k miles on them...
- bought a siR lip but..
- throttle body cable and gas pedal
- How long did it take for your mpfi swap?
- ef c-pilar bar?
- What is this box?
- my car wont wont start. (auto to manual problems)
- Assorted help needed - Wiring, etc.
- Just finished my z6 swap...some problems
- starting problems with 91 civic DX.
- 88 crx hf
- CRX Build but too damn rich.
- What are some good wesites or places to get a nice catback exhaust for my 88-91 civic si hatch?
- First gen acting strange!
- Calling Sir/SE owners (CRX)
- EK9R cluster into EDM EF8 dash Howto?
- s2000 gauge cluster
- TEIN SS. Higher spring rates ?
- 90 crx dx d15b carburated to b18c5 question
- b16 reverse problem
- Ban BROKENREX ??
- b16 harness question.
- the last crx
- planing on jackson racing supercharge my 1991 civic
- Good Locking lugnuts?
- key off engine on ??
- switch back exhaust
- engine harness question
- headlights
- could i use the motor monts froma b18 on my crx if i was to swap?
- Question
- Function 7 rear control arms
- b18 swap quick axle question
- anyone used auto rx before on their car?
- thanks alot but still confused
- 89 Civic Si, Any suggestions for Street Sleeper?
- integra hub ? swap for crx
- e brake cable question
- 1989 Honda Civic DX
- anyone raise a CRX?
- What grade and brand motor oil do you use?
- swaping 88-89 for 90-91 crx
- My car sounds like a wrx...... Need Help!
- Newbee! 87 Hodna Civic SI will not start...i have spark and fuel...but still no start
- CRX HF Seat... (90)
- Aftermarket exhaust with b18 swap help?
- HID Retrofit in CRX housing
- heather being ornery
- B18 question???
- Is the tranny of the JDM SOHC ZC the same as the USDM D16A6?
- Crank Scrapers - Worth it OR Worthless???
- ef cigarette lighters
- Pro's Con's to hf trans
- Power folding mirrors wiring harness, Rare?
- fuel tank sending unit
- Do it yourself: jDM y0! Amber Dash and clock!
- which radiator fits a ef??
- ecu codes
- crx steering rack question
- Max tire width help
- my b16 has a boo boo
- interior????
- EF6 interior*
- b18 EF
- cable on trans
- which company makes 2.5 catback exhaust
- upper control arm
- vss question about the integra cluster swap
- some please help
- HELP...need pic of Temp sensor
- need help badly
- how to lower compression????
- Has any one dont this coversion?? NEED HELP!
- A B16A1 Site with good info!!
- 87 civic si...
- ecu code problems
- Engine is making terrible sounds
- tein pillow ball or ground control mounts
- crx fender (i did search)
- pin diagram needed plz
- just got a 91 si hatch and it has 3 codes HELP.
- motor swap help
- First time efer
- What is the best turbo to get 300hp from a D series?
- resinator direction
- Can a D series block handle forced induction
- hood stuck shut!! help!!
- what trany do i have
- so i decided to make itbs for my single cam...pics
- motors swap
- looking for parts
- JDM Thick Molding.:.RED TAPE?
- i need help i need the diagram for 89 91 dx to si
- CRX manual
- how many quarts of tranny oil for 88 civic lx d15b2
- motor shut off after disconect bettery cable?
- Y7/Y8 mini me HELP!!!! ive done research just need a little bit more info
- Fuel pressure drops to 0 right after shut off
- brake light Question?? to get brake lights??? need help!
- d15b vtec or d16z6 vtec ?
- Something to ponder about CRX's
- car died, not normal, need help asap!
- distributor?
- quick question....
- JDM front end or bumper cover???
- Exhaust Opinions - Tanabe or Invidia?
- crx and ef
- hf 5th gear in an si tranny
- Question re Fuel Level guage ohms???
- electrical problems (kinda urgent)
- Custom 2 point front upper strut bar for the EF 88-91 Civic/Crx
- will our cars start without the seatbelt wire harness under the seat plugged in?
- stock looking aftermarket exhust
- Need Help Badly!
- EX master cylinder bolt up to Si booster?
- 1989 CRX Si?
- EF Clocks... All the same? (Hatch, sedan, CRX)/
- New solution to cat rattle?
- Tie-rod F'in ends...... plz help
- da integra steering wheel on crx?
- Anyone run a 225/60/15 Drag radial?
- eyebrows? or DIY
- k24/k20a head in ef project?
- electrical crap...
- Slipstream or blades
- d16zr in my crx
- im out of things to think of... please help!!!!
- need b18 a1 info for boring block
- Im New And I Have A EF Hatch Project :)
- Look what I found today!
- what would get better gas mileage
- Fuel Pressure Regulator Control Solenoid vavle..two wires?
- Any body got a pick of a one piece headlight?
- Flat black engine bay
- Clicking noise in doors
- K20A2 vs K20R Whats the diff?
- B16A1 With obd 1 ECU
- found a b16 swapped rex, vtec doesn't work, but runs fine....what could it be?
- Where to find upper control arm balljoint?
- JIM FAB?
- Honda Civic 1.7 CTDI problems
- 88-89 / 90-91 USDM Civic Hatch Differences
- HF CRX Front Bumper support pics request.
- Need advice, what axles should i get?
- cracked manifolds
- no fuel and injectors wont work
- new exhaust is on now there is a PROBLEM!!!!
- best D series traction bar???
- GSR swap in their CRX with Edelbrock Manifold
- b18 swap into 90 crx si
- ---MY CRX IS FINALLY DONE---
- planning to paint my crx, need info
- honda crx Interchangeables?
- what trani dx or si? for d16a6
- will motor swap fit
- Si motor specs
- two plugs ...where do they go?
- wtf is the colour code on this?
- 91 crx si steering rack..HELP
- MAIN RELAY HELLLPPPPPPPPPPPP
- clutch for 90-91 different then 88-89?
- Info D16a6 zc
- where did you mount your sirius/xm post up pics
- anyone know what harness to use on 92-95 d16 into 88-91 civic
- power window wireing diagram
- linkage question
- Engine Temp guage
- Radiator question
- NGK BKR7E-11...what to gap them to?
- New K20-R CRX... lots of pics!
- help with the pedal Assembly
- Bay Area, NorCal: Help my brother find his REX!
- B18 in ef
- Ls/Vtec timing
- Is it my spark plugs that are messed up
- Seat bracket question
- my 90 si ef9
- Factory Service manual on CD? is it any good?
- Any parts from 88 Integra RS usable on an 89 Civic Si???
- Ground control top mounts....
- Crank Pulley Bolt removal
- Panda CRX...need some help/opinions!
- no spark or gas on my b18a1
- jdm d15 or jdm b16?
- brake question
- hatch cover
- What should I do regarding my CRX
- just how much lighter is it?
- sound clip of invidia exhuast on crx
- converting cluster cover switches.4rm 88 crx to 91 crx
- Got my SOHC ZC running.
- GSR VALVETRAIN IN B16 HEAD
- Hey you European and Japanese CRX SiR owners, Suspension question.
- Pics of Espelir exhaust (CRX)
- Race-Tech Exhaust!!!!
- could someone post a pic of the rear bumper support of an ef?
- AN-R: out of business?? (hearing rumors)
- Easiest DOHC swap?
- Yet another foglight question
- how much work will this be?
- FEW NEW PICS OF THE EF!!!!!!!
- Chassis tearing?
- Stripped valve cover stud...how hard to replace?
- extended top hats on a crx
- K24 in crx(Vids)
- im in the bay area and need help!!
- quick timing q
- Need help in pheonix!!!
- which b16 tranny will fit on my b18b engine???
- someone have body manuals for crx ???
- tranny question
- b18
