View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Where Can I Find an Electronic Speed Sensor for my CRX Sir Gauge Cluster??
- brake noises?
- Dpfi to Mpfi converson timing problem
- can crank angle set oof my timing
- All these rear disc threads, and not one
- Turbo crx using the EF8 bumper ! help me find it!
- cat converter
- hey guys mini me q's
- DPFI experts , what sensor is this ?
- Z6 OBD1 swap should i bother with the KNOCK SENSOR
- 89 JDM civic ZC headlights fit 1990 usdm crx?
- 1996 civic seats in an 1988 crx??
- is there a replica EDM spoiler?
- PUTTING NATURAL GAS PISTONS IN A D16Z6
- Front turn signal issues
- Front Hub
- Is it worth it?
- injector problems
- Tranny gurus what is this bearing called
- Which is worth more!!!
- Another my swapped car won't start thread
- steps to installing new ignition??
- How difficult is it to replace right front axle? (Seattle HT's)
- ugh, help pls, DX-b16 MPFI issues. Dizzy wires are confusing
- Bilstein + omni coilover sleeve ?
- HF suspension
- Need some help here guys
- Timing belt jumped 3 three, and the belts not ripped?! WTF!
- What year Civic SI seats have red lines?
- LOWERED MY CAR,HIGHER ON ONE SIDe
- camber kit help.....any info would be appreciated
- need a wiring diagram for pm6. having some issues
- rack end bushing / inner tie rod
- radius rod problem???
- Crx aftermarket crossmember
- b16 timing
- Difference Between Exhaust's
- Can't check the CEL....???
- 89 hatch dx vs. 90 si crx axles
- OBD0-obd1 conversion
- dont get hit in A crx or crash cause....
- need some help on this decsion.
- b18a crxr swap help.
- valve guides?
- Finished my MPFI swap tonight WOOT!!!!!!
- Does ANYONE make a master cylinder brace for those of us with a DA teg MC/booster ?
- high idle problems with b16 WHBAT could it be
- i might be an idiot but i need to know how to advance ignition timing
- 1989 eF with 91' front end.
- can anybody help me plz!! i need your guys opinion!
- car is hesitating at highway speeds! please help!
- B18a Swap TERRIBLE mpg
- i am new and i dont know about much turbo!! need help here!
- H&R Race Springs with KYB AGX, Good setup...Opinions???
- h4h wiring *help*
- Towed CRX Project Log
- 87 civic sedan help
- F*%! my 2 day old axle blew...wtf?
- will it fit????
- homemade intake for b16/ef....question about vacuum lines
- traction bar no no
- dash wiring harness
- what is this cluster out of???
- Cam timing theory question
- axel nut no go, help!
- Will these Crane Cams work well with my LS Turbo?
- Need help with confusing suspension problem
- What car is this bumper for?
- help!! engine misses at idle and around 2000 rpm
- Few B Series Things to use, gotta be sure about them interchaging.
- Venom Nitrous Kit
- Searched: Rear Spoiler Brake Light Removal
- suspension question??????
- MPFI almost done,
- Water pump issues
- what do you people think
- finally got her lowered
- And you thought your axle nut wsa a pain
- sir bumper help
- 89 teg ecu is 91 si?
- Clutch SAFTEY switch... what does the wiring look like (trying to bypass/hotwire)
- obd1 distributor with an obd0 ecu?
- Climate control compatability
- oh snaps...my gas tank is leaking.
- Clutch cable question
- Honda dealership denied me any suggestions?
- B16 CRX, which radiator
- Just bought a 91 Hatch
- Engine swap help.
- Window Question
- Tranny Bolt Specs
- are all b series timing belts the same
- EF rear seat swap?
- quick help. engine almost dies at idle i searched
- b16 tranny removal help.
- i Broke My CRX in under a week
- QUICK QUESTION!! Tranny related
- b16a into 91 hf crx help
- Aluminum center cap for '86-'87 CRX Si wheels?
- Is www.redpepperracing.com down or shutdown?
- Rust in gas tank??
- please help
- Just bought a 91 crx si
- Tranny Blues....:( grinds, curse words and some ideas i have in mind )
- Quik help before I destroy my frame!
- life span of a stock b16a and what to look for when buying a crx b16 jdm....
- is a stock zc good for boosting
- EF, 1991 hatch with D15B2 *distributor probs.
- b18a block
- got my JDM fogs installed!!!!!!!!!!!
- Crx Gas Tank Change
- EF? what does that stand for?
- my new EF project...
- civic/crx brake upgrades/swaps
- Mini me spark plugs/timing?
- obd1 swap rear bracket mount help!!!
- D16a6 valve lash?
- Strange Fuse box problem.. Starter Issues
- the whole dash whont light up!!!
- Need help deciding what to put in my street/strip CRX.
- Looking for D16A6 Dual Carb Manifold
- Got my new Dohc ZC Today pics to come....
- JDM CRX Fog Light Look-a-likes
- Question about tires
- Getting a CRX
- vacuum hose #16 on crx hf, whats it go to??
- crx dual high beam bulb how to
- sun roof question...NEED INFO PLEASE
- Transmission Clutch Lever Modification?
- 2 stupid obd1 distributor questions
- Anyone with an Exedy full face organic clutch please help
- Skunk2 springs too low for GR-2's?
- CRX Si 88 - 91 Passenger Fender . . Will it fit ?
- brake booster follow up problem............
- b18a turbo....b18a tranny or b16a tranny better?
- 90 b18a into 90 crx dx...a few questions
- JDM Sir console < to > USDM EF Civic
- got some more JDM stuff in today!!! :)
- How to remove fuel gauge sending unit on CRX?
- Tranny and axel Q’s???
- ZC Swap. Now i have some problems
- My D15B2 pic
- Transmission overfill? What will happen?
- B18C5 vs B18C1 in CRX
- Best Turbo idea
- i got a ?
- b16 wiring
- Need help with swap problems
- Not getting 12v+ at my fuse box. WTF is the problem?
- crx si sunroof help
- jdm bumper
- question on engine
- Dizzy Questions
- Its a tight fit but...
- quick "tdc" question for an 89 crx dx with d15d7
- just saved a bunch of money on my car insur...i mean build
- clutch safte SWITCH...
- Cable to Hydro conversion without the Kit?? I've seen it done wondering how.
- cv shafts
- EF w/ LS Swap. What o2 sensor?
- crx fog light question
- Fan on all time!
- JDM b16a cable transmission speedo cable problem
- Looking for pics of factory/modified CRX's
- civic dx zc swap help! I dont know what to do with the throttle cable
- Auto Center console into a 5spd. car?
- just got a crx
- crx won't start... fuel pump not coming on, weird cel, etc
- safe to drive?
- How long do stock axles typically last?
- b-series AXLES inter-changiblity..
- Still looking for PCV valve location:
- What's the point of going Cable to Hydro?
- climate control fan only works in positions 3,4
- ZC parts only
- Heater issue
- heater doesnt work!!!!!!
- 88 civic hatch..type-r motor..speed sensor
- Center console
- keepers
- starting issues
- A little help finding this part..
- Throwing Cel Code 15 and 4 (OBD-1 P28)
- b16 Trans
- GSR rear disk brakes On a EF???
- Location of Part:
- crx in the winter
- D16a8 Rover engine... what are the specs on this engine?
- Where's my horn?
- WHat B series internals make for the highest horse and torque in a LS/VTEC
- Passenger side Fender 90 CRX
- Rear motor mount support
- stupid but kind important Question
- Vtec does not work???
- Transmission Compatibility
- Bumpers on a 89 dx
- Car wont start..........again!
- High RPMs bad for A/C?
- crx intercooler size advice
- Need towhook measurements (for crossmember construction)
- fuse diagram
- Help please
- ef designation
- B16A overheating issue PT. 2 HELP!!!!!!!!!!!
- Car broke down tonight
- does anybody know
- Two Wrecks equal a right? 56K milk a herd of cows.
- mini me swap help pleeze pleeze pleeze
- EXACT LOCATION OF JDM CRX SIDEMARKERS PLEASE!!!!!!
- Keep Throwing CEL. What the %#@$~
- Car bogging only after it heats up?
- Will the dash lights not work with the dimmer switch unplugged?
- losing cat and muffler/good or bad ?
- o2 senson ? any gains if i remove it ?
- Pic request (Painted CRX bumper stock paint scheme)
- Got my Rywire stuff yesterday
- obd1 conversion
- Where can I find a Nice Breathable car cover for the CRX?
- help smog my b16a1
- just got my first car (91 Hatchback)
- car wont start ***FRIED SOMETHING*** has to do w/ starter i think HELP!
- quick question asbout injectors
- how to tell 88 from 89-91
- where can i find crystal or black housing headlights for a crx?
- Torque Sequence on D15
- Hmotorsonline motor swaps...pros/cons
- Started motor with wratchet on crank pulley
- y1 cable tranny is b16????
- will jdm ef lights fit on my stock U.S. front end?
- Need a gauge cluster diagram for 88/89 SEDAN. Can anyone help me out?
- i just got OWNED!!
- obd1 to obd0
- injector leak
- Want to hear some theories on why my car overheats.
- D16Y7 Into 89 CRX
- just got my PWJDM EF9 lip installed!
- civic turbo problems
- Bought new distributor for MPFI swap, but wire colors don't match up. Help!
- B20B4 *SEARCHED*
- Roll Bar?
- Rocker Arm Assembly
- major problem HELP!
- head swap trouble list....
- trans question j1 ?
- ZC Timing issues
- dash harness
- Engine swap driving me crazy.. Help me
