View Full Version : Honda CRX / EF Civic (1988 - 1991)
- pic request...skunk 2 exhaust on 88-91 hatch
- 00'SI radiator in a CRX??
- QUICK QUESTION!!!
- i just got my 2004 coupe Si-G
- Daytime Running Lights
- anyone know how to remove tie-rod?
- distributor
- NEED HELP NOW!!!! QUICK RESPONSE PLEASE!!!
- Footrest installation
- 1989 si civic hatchback info please
- Who here has an EGT gauge ?
- hatchbacks rule......crx's too......
- Wheel, tire question.
- SEATS, do 90-91 Hatch seats fit in 90-91 CRX's? same brackets?
- crx and eg strut tower bar differences??
- irractic idle, tried alot of things to fix, please help
- steering rack ratio's
- can i use a 89-91 si hanress on a b18a1 and will it work just as good ???
- Blowing smoke
- Can a crv bottom end fit on a b16?
- jdm vs civic si camshaft, looking for more torque.
- Reasonable drop for a 88 civic?
- NOS
- b16 with nos?
- Turbo is glowing red
- S2000 oil filter vs. stock one
- 13b DSM Turbo
- GAS KEEPS GETTING IN MY OIL HELP!!
- Best way to boost horsepower
- ok here it goes to all you d15b owners!!!
- mini me headgasket
- New HT member...whatz up...EF peeps
- please help
- hydro clutch into ef...
- replace camshaft without replacing head gasket?
- wtb: stainless header for civic or del sol b16
- Help!! Fuses and Relays
- need a hi-flow catalytic converter...where which works best?
- Hasport Cable to Hydro Conversion
- tranny problem......
- ZC crx dieing sporatically. can anybody help me?
- 90-91 prelude Si seats in a 90 CRX?
- Carbon Fiber rear hatch for crx?
- I think I found a new civic site
- ZC Swap... Need help badly.
- question about CIVIC armrests
- d16a6 swap question...
- fuel problem help please
- H22 in a 89 si hatch?
- big ups to honda tuning for the hatch on the cover this month
- wtb: 91 si hatch back seats
- taking off dash to have rolls cage install, any trick or PITA I should know about?
- T70 turbo kit for b16
- How much is a USED Thermal 3" Catback worth?
- Anyone using a gsr or "normal" honda muffler? pics?
- 89 CRX cluster in 89 STD .... got problems....
- what kind exhaust should i use
- b16 90 hatch, prokect racer
- Need advice for engine swap.
- CRX Brake Question
- Help, I cant get my new shifter bushing to work!
- Air Conditioning on '90 CRX. R12-R134 Conversion HELP
- So how screwed am I??
- SoCal-Jdm tv filming at Car Meet @ Volcano Tea!
- my slow CRX (from Quebec, CDN)
- Wheel Bearing Question Help
- what do you think about head milling?
- buying crx
- help me make a suspension decision
- crx roll bar in hatch?
- what web site is the best for buying a compleat motor swap
- cusco
- body styling
- headlights are flashing
- What'd you use to fix door panel due to seatbelt buckle damage?
- Civic tweeter
- 4040 prop valve question on install
- 1986 DX hatch in need of info
- two question, rotors and brake calipers
- Car kinda, idles ok, then looses rpm and stalls out..
- hydro tranny?
- Someone help...
- 94 ls gsr tranny
- Just for looks
- Wiring pictures?
- final drive question
- Wiring diagram for jdm power windows in crx
- HELP WITH B18C1 Headers
- Exhausts....
- Got my roll bar and sparco seats in. review inside.
- leakdowon test
- Pls Help- Will Autopower 4 PT CRX Rollbar Fit Other Hondas????
- HELP: im not getting any spark!
- B-Series motor swap question!?!?!?!?!?!
- towing a trailer behind civic?
- Plan to get CRX, but what info first
- ?s about p08 ecus
- Rear control arm question.
- d15b7 for jdm d15b
- Pics of EFs with upgraded brakes?
- Im thinkin bout leavin the Honda scene , Rwd time?
- mor mini me ques.
- Crankshaft removal. help plz
- 89 Honda Stalling
- radiator fan
- d16z6 to b16 how to
- need obd0 harness pin outs for ecu, installing vafc
- Yes!!! I now have an EF!
- Need 88 crx si gauge cluster diagram!! please!! anyone!!
- OBD1 code 16!!!HELP
- jdm rear bumper lip
- VTM, PR3 and VAFC do they go together?
- Opinion on axles...
- ****QUICK Question! Seatbelt*****
- 100 Shot?
- Post links of where to buy engines plz
- 1.6si with dx intake manifold wont rev past 3500
- Quick ? about jdm front end headlights
- Stock 88-91 Civic/CRX SI, D16A6 exhaust manifold, only 70k miles
- tach question
- '91 Project Civic Needs Some Help.....
- Chassis Shop fixing camber -- Bending front spindles
- what motor should i get?
- PAINTING RIMS....
- ok im stummped on this one PLEASE HELP
- Map sensor wooos???
- HELP! Tranny / Axel Problem?
- Help! Door ajar light/bell when I step on break!!
- Radiator.
- Anyone with Ls????
- y8 intake manifold
- question about the different years of crxs
- help
- Civic 92-95: Mpfi Swap?
- How much HP in a boosted B16A1?
- DeCaRbOnIzInG HoNdA MoToRs
- Interesting Problem with Friend's Car...
- 1989 civic crx fuel pump problem.......???
- 5 Lug CRX?? <--Is this possible?
- CRX REVS HIGH
- WTB: pasenger door mount seatbelt
- compression calculator. need help.
- Help PLEASE
- Anyone know where I can pick up this harness/plug?
- is this possible? tried search, anyone done this?
- How to : hydo gsr trans, B18C1 in EF hatch
- ecu gives a quick flash, then stays unlit in ON position. car doesn't start.
- ZC victory
- What kind of starter needed for 1st gen B16a/ 92 civic camber kit work on 91 CRX?
- Rim problem
- after B18 swap, brake pads get softer?
- which brackets, which year.......B18 into an 88 HB.
- where the hell is my speedo cable? already searched.
- Emissions Question!!
- AWD EF wagon the same as EF EX Sedan Hubs??
- Quick Question (b16a1 swap in a 91 si hatch)
- engine swap question
- tyre size
- Will ITR caliper bolt up to a DA Kuckle/hub??
- 87 and down info
- Injectors?
- what head is this
- 195/60/r15 on EF
- Pedal install problems... (sparco)
- Cost for new syncro's in 00 civic
- my crx does not sit even. please help
- Quick ? about dpfi to mpfi swap
- Where is the pcv valve located
- How do i do a leakdown test
- Help with MINI ME Code e Keeps on coming on????
- PM5 ECU: I need specs on it
- Vision™ c/f mirrors on your CRX??pics??
- Just picked up a CRX need opions on next step
- ITB'S
- guys DRIVE SAFELY..... Sorry for this guy..... CHECK THIS PICS
- Pics of my ED, link to apperance forum
- what size tires u guys rock on your crx si rims?
- 90 Civic tranny problem. Help???
- anyone wana sell there carbon fiber hood for 89 crx si?? let me know....
- B16 i cylinder not giving fuel
- Integra GSR rims on Civic?
- Update on my car: GSi wheels, alarm, gauges, sus tech springs *pics*
- Will a JDM SiR tach fit in an HF cluster?
- Gettin Crazy!!!
- Hondata, Safe To Not Let Go Of The Gas While Shifting?
- how to help removin AC
- Organizing Dash Clutter (installing side compartment)
- ***People with vtec motors with no vtec ECU i got a Q***
- Anyway to get rid of gap on jdm ef bumper besides buying whole front end???
- smog problems?????
- turbo set up
- WHITE SMOKE
- tranny question... please help
- Turbo or supercharger?
- Problems with rotor screw coming out?
- Left vs Right Front Shocks!
- 277/175 torque b16 crx
- MY CAR RUNS, code 10 (IAT sensor) question
- anyone know the valve setting for 88-91 si engine(d16)??
- swap it
- ZC Auto??
- Crx head bolt tq?
- painting my crx.... (NEED AIR COMPRESSOR!!!)
- weird sound when i turn
- 88 1.5 non-vtec what??
- low rpm studder???
- Really need crx color opnions ASAP!
- Need help?
- Primer Help??
- B18c5 Swaping Into Crx Hf
- how many teeth does your timeing belt have
- Anyone interested in Carbon Fiber Sideskirts for CRX's?
- C/F hatch?????
- will the b16 pass emission in ct
- 89 Si hatch front lip
- Suspension issue 91 si
- b16 swap in 89 CRX hf
- Will any Teg Guage cluster's fit my 89 crx, with little Modding?
- mini-me swap
- 2nd gen teg spindals and rear control arms will fit on my 2nd gen crx?
- Turbo question
- 1st Gen CRX harness bar
- Gonna start a CRX project, need advice...
- best place to buy ACT XTSS disc only? (searched)
- OEM/JDM Rear Bumper difference?
- mini me headgasket problem??
- Attention mechanics
- real quick.. is there a way to tell my looking at the block or the ECU
- H22 into 90 civic wagon
- Cad pictures
- what does a failing waterpump act like?
- header replacement question
- interior idea ?
- b18c hatch track times/dyno numbers/pros and cons
- need help with annoying sound
- Problem with Place Racing mounts? Axle issue...
- Big problems ! ! ! ! !
- Got my d16z6 but i need a little help
- Billet Drivers Side Post Mount
- tie rod ball joint replacement... HOW?
- i keep blowing up headlights... wtf
- pics of my turbo D16Z6 4d EF......
- jim fab crossmember
- can i use a crx tranny with my 91 civic si clutch
- -->crx ppl<-- possibly my new CRX!
- what are my option for Rear Lower Control Arm?
- No more nitrous, Time for Turbo...
- just picked up my ls SWAP!!!
- Can you get a OBD0 B18A1 in a CRX Si Bar Certified?
