View Full Version : Honda CRX / EF Civic (1988 - 1991)
- dc sports universal muffler into a 90 hatch? Also, some idling problems. help!
- Rims Tilting help!
- converting a d15 to multi-point injection
- SIr hood (carbon fiber) ?'s
- Whats wrong with my car???
- Is there a way to make vtec work and everything that goes with while using obd0
- obd0 to obd1 dizzy ???
- fuel sending unit how to repair? Anyone done this before?
- elect /fuel pump problems
- type r throttle body on a b18a
- SI harness into dx?
- Runing in limp mode I guess. ????
- HELP with 91 civic automatic upgrades
- glass roof crx
- OMG!!! Would you stop with the stupid poles evryone?
- anyone??? TPS d16z6
- need help asap with b18a1 in crx
- Suspension Compatibility
- o2 sensor for b16
- Question
- CRX lip
- ECU wire harness pins
- CHANGING BRAKES HELP!!!
- The CRX shell no one wanted.. just a few pics
- crx hub
- Automatic tranny slipping 1990 DX auto sedan
- Shift linkage problem question 99si
- Rear Drum Brakes Problems
- WTB 91 civic hood cluster. the part that goes over your gauge cluster. blue.
- Is it really worth it to hook up my salvaged ED?
- mpfi question
- Upgrade 1st gen b16 to 2nd gen throttle body
- my new rex, specs, misc
- HELP!!!!!!!!
- which obd1 distributer ??
- PM6 ecu question
- READ THIS
- Right Hand Drive CRX (wanted)
- under fender braces
- Lip
- JDM Parking Pole Value
- 90 si cluster into 89 STD
- EG radiator in EF
- looking for some help from some ls swap guys
- WHERE'S ALL THE COOL STUFF FOR THE FOUR DOORS?!
- FAQ how-to install a Full Race traction bar
- CEL diagnostic help
- Purchase Questions for B18a
- B16 / b20 engine build-up
- purchasing head
- Controller idea.....
- i need a list of everything needed
- newbie honda honda need some help
- 90 std to 91 b18a1 dizzy wiring
- double ignition CRX? theft prevention
- problem with RC injectors in d16a6 intake manifold
- Sold my CRX tonight, pics anyway
- 88-91 civic parts sale
- Planning to do a mini me(HELP!!)
- i have a 90 h/b si, which motor for money and why
- vafc on a non vtec car? can it be done?
- any front lips for 90crx si
- Help
- 16's or 15's...
- K20 into a 88 crx si.... any suggestions?
- Intermediate shaft problem
- b16 in a 4g civic?
- Quick Question!!!!
- 91 usdm crx SI cluster in 90 civic DX ?????
- swaped crx not getting up to temp HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- WTB Streetable CRX Shell SoCal
- ground wires for 91 civic dx
- Hub Spline Count different from model to model?
- B16 running really rich?
- whats a good ef suspension
- Aluminum or conventional radiators?
- Pic Request- White rexes, look inside
- code 2???
- i'm looking for a single vtec motor
- heat jusst stopped bigg problemm helppp
- And people told me it couldn't be done!
- IACV got me stumped.....
- modifying an EG exhaust
- MORE POWER!!!!
- help!@#$
- ??? about MSD RPM activated switch
- sohc swap into 90' hatch
- HF distributor work on D15b converted to MPFI?
- CRX SWAP
- CRX steering shaking w or without braking
- Quick Help please.!
- Tranny Q: What did it sound like when your input shaft tranny bearing went bad???
- NEED HELP!!! I need to know where to find rails/sliders for buddy club seats
- Relocated fusebox and headlight wiring(pics)
- Sorry to bug you guys
- omg. haha. check this out. head gasket change :p
- Part Identifier
- 94-95 GSR seats in a 89 hatch?
- omnipower coilovers, which lca?
- 98+ integra type-r (b18c)
- HELP WITH D15B SWAP
- 90 civic si w/B16a1, not getting any spark
- Ideas For 91 Crx SI
- please help with code 6 coolent temp sensor
- just called about my motor swap and need help
- will skunk 2 camber kit work on 90 crx si
- dutch 87' crx
- another noob question: D15b sohc vtec vs ZC dohc
- anyone want a 90-91 nissan 240 for parts
- New Crx Si looking to create an SiR
- D16z6 into 91 CRX HF... What tranny and axels to use?
- gas mileage on stock std
- city lights
- Password JDM J's Racing Lip, Badge Removal
- Strength/Pillar Bars
- Which ECU do i use????
- About to install front crossmember: tow hook bolt TQ specs?
- just got a CF crx sir lip from password. what do ya think?
- B16 not turning on after cranking a ton no spark
- MAP sensor bad?
- de-pinning ecu
- stolen car in wtby conn..
- how to remove dorr moldings from crx?
- o2 sensor jumblies
- vtec fails after not changing oil after 2500 miles
- Just bought a 91 hatch dx, question about 13" tires
- anyone know torque spec for lsd bolts?
- I got a pair of CiviC ex seats, but it won't fit my 89 CRX DX?
- will a d16y8 intake manifold work on my sohc and will everything plug in ?
- well the time has come
- Running on three Cylinders?
- picked up real JDM CRX. 1988 CR-X Glasstop Si.
- D16Z6 Knock Sensor CUSTOM - Into rear water plug hole?!?!
- Getting new bumpers, Painted or Get the "Standard" black ones?????
- Starting Problem 91 civic hatch
- ef suspension ?
- Anyone here using K&N Intake system?
- Swap Help
- clutch/flywheel
- Block Heater for ZC
- ex door panel Q
- Lower Sitting RECARO Rails
- Off-Topic Toyota Forums?
- Aebs manifold, BBK throttle body & throttle cable ??
- ground control spring rate
- maintenance on 91 civic dx
- Just Got: Rear Disc Brakes...I Have Questions. (pics included)
- what kind of motor should i go with?
- Help!! i need help in how to wire my b16!
- muffler on 91' dx
- Can someone tell me why i have no power between 4500 and 7000 rpm in first gear?
- 01 gsr center console
- 90 Hatch STD (NEW PROJECT)
- Wanted: Rear Disc breaks from 91 CRX Si
- quick gauge cluster question
- how to replace the head gasket on 1991 hatch
- Gsr internals for ls/vtec setup?
- Swap questions???
- wtb cheap ef hatch
- 91 JDM B16A IM Question...
- venom performance modual
- Block off plate for antenna?
- Looked but couldnt find......
- Lookin to paint my rex
- wtb 1st gen civic and crx si rims
- 88-91 sedan taillights same as crx and hatch???
- 91 civic hatch front bumper
- how much hp?
- IS THIS A GOOD DEAL??? let me know PEOPLE!!!!!!!
- I KNOW SOMEONE HAS A BUMPER!
- stock integra suspension on crx
- CRX HF swap question
- replacing CV joints
- CF hood question
- ZC swap ! need help in tunning
- Cleaning my old ass interior!
- 4 door question
- will dc2 front seats bolt on into ef civic
- fiberglass fenders
- dash swap... whos done em?
- OBD1 dizzy and head on D15b2
- y8 manifold and gsr tb is that a good set up
- kyb agx/h&r race. rough.
- Its getting closer.....
- CRX Control Arm bushings
- 88 CRX 4 sale!!!!
- Cluster starts at 40
- obd1 distibuter change/ conversion please help easy
- 1996-2000 civic sohc vtec head on a zc motor?
- will a 93 si harness run a JDM SiR-II (B16A2)?
- nitrous qusetion??
- PR3 Ecu
- front lip on wings west rs bumper
- Costs of an H22 Swap
- Best Book
- best upgrade besides turbo
- mpfi help please! ASAP!
- place to get my motor swap done
- Which ECU for Zc....??
- Best mini me swap for a d15 block?
- lookin for interior panels and parts.. can anyone help (91 crx) tri state
- couple of b16 fuel questions...
- b16 swaped rex problem- PLEASE HELP!
- 1st gen tranny swap into 2nd gen Question
- b16 ecu help
- Still a Noob...What is mpfi and dpfi..
- who makes a header for my dohc zc?
- 97-01 Prelude Cluster in EF **Proof of Concept Phase**
- EF hood able fit inside the hatch?
- Ecu...Which is better pm6 or pg7???
- Top Fuel (fuel magnet) POWER NEO
- How reliable are high mileage CRX's autos
- Where to find MPFI swap harness
- A/T Starter M/T Starter Can u interchange
- camber kit question please help
- aftermarket gauge wiring
- Vtec head in non Vtec car
- what kind of transmission?
- noobie>>>>>want buy D15b sohc vtec from Bluebird a.s.a.p
- 91 CRX LIP.......WILL IT FIT A 91 EX SEDAN?????
- crx and 92-00 civic right tranny mount interchangeable?
- A little help here...
- B16B2 - Will it fit, what do I need, etc.
- Recommendations/opinions on tires with long tread life
- fuel pump
- more power/speed
- No start, smoke under steering wheel, some things work, some don't
- D15b2 to D16a6 Swap
- oem body wtb??????????
- Almost have all my MPFI stuff ( Pics)
- b16 wiring crx OBD0
- dpfi rough idle, bad mpg
- Help!! mpfi swap!! look inside!
- Discontinued window trim
- HELP! Overheating problem *VERY detailed description*
- O-rings on injectors
- what timing belt for DOHC ZC motor???
- weird wont start*?
- B16 Wiring Harness Problem
- can a 1.0 radiator cool a 1.6?
- ahhh what should i do, looking just for opinions or some faith
- Axle Question..
- Mugen Front lip Question
- 88 sunroof on 91
- still probs with the b16
- Need Help identifying injectors
- installing water temp gauge
- Need help
- main relay problems? car wont turn
- crx hood on a hatch
