View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Need help with vtec ecu pinouts??
- attn: Integ, gauge wiring pictures (huge pic)
- I got a 1990 rex now...
- Announcement
- Anyone who knows their Si ECU pin out please read
- How do I fix a code 9 ?
- problem help
- transmissions?
- Pre-EF hatches and CRX's
- removal of injector on PGM-FI
- will all 92-95 civic p28 ecu work with d16z6 so the vtec works?
- pics of my hatch
- too fast cold idle
- anyone have the Energy Suspension bushing kit numbers?
- lambourghini doors for 90 CRXsi
- please help ! shifting problems
- Skunk2 Intake Manifolds
- How to mount the distributor on a Mini-me and gasket remover
- cruisfest colombus
- misc pics
- Vavle adjustment need help....
- My thoughts on the Hot Import Nights Show at the Louisiana, Superdome
- 92-95 civic bumper on 88-91 civic??
- -= 1989 CRX SiR for sale =-
- leaking cam angle sensor on ZC
- AGX/pro-kit install
- 4G civic rack and pinion?
- CRX exhaust?
- Leather GSR seats
- what times does a dohc zc in a 89 hf run?
- Trivia Time: Did new 89-91 Civic Si's come with...
- so how many mods are in this section now...
- i need a p28 5-speed ecu for sohc vtec....
- Painted Trim
- Z10 radius rods anyone have them and what price they paid for them?
- pics of my crx
- Iles too fast too long when cold started
- Stock FPRs question...
- Import Meet. . . .
- b20z in 91 hatch
- Civic STD vs. CRX HF
- Dx to SI wiring question?
- Best GSR into CRX advice..
- How much do you think i could sell my car for?
- Shave rear wiper?
- High rev problem??
- changing drum brakes is it complicated?
- Suspension Techniques rear sway bar pic????
- b16 ef with type r stock intake?
- D16Z6
- Stock Intake Question???
- clutch slippage problem??
- Unsteady cruising speed.
- Poor Throttle Response on a 90 Si - How do I solve?
- CRX/EF'S in the kansas wester area!!!
- Does anyone know how to classify what year the block is off a b16a,b18c etc.??
- Zex or Exospeed cams?
- I Just Got my EF!!!
- civic hatch coil overs
- zc vs. b16 and apex'i N1 corked vs. uncorked dyno graph inside
- rod bearings
- 1988 Honda Civic stalls - Does the repair shop make sense?
- what is the best cam setup for a b16a
- Just picked up an LS
- interchangability between A6 and Z6/Y8 head components...
- HT Site Enhancements, Percantage Points, and Limited Posting - PLEASE READ
- zc headgasket and piston rings!!??
- Who would like the forum to be like this ?
- Fiberglass ZC hood?
- WTB: 90/91 Civic passenger side fender molding...need asap!
- Integra rear sway bar Question?
- Can Anyone Help?????????????
- What Program for B16A ECU?
- vtec controllers???
- Xtreme Car Parts in Florida..trustworthy?
- Honda 2 liter fit on a 4g civic and in engine bay
- Does SOHC ZC bolt up to a d16z6 head?
- B16 sir1 parts interchange guide?????
- Ecu and check engine light?
- how much do wire harnesses go for?
- How can you tell between type r motor and others
- Rexie
- Dose anyone know of any local Fla. Boards/Forums?
- what is the most you can take off a Stock ZC Head?
- I cannot get my crank pulley bolt...
- B18b Ed G-tec times.
- Tips on bleeding brakes on a 91 Si Hatch?
- Is this anyone's car here?
- MPFI Swap: Fuel Pressure Regulator question
- rubbing???
- he s
- exhaust suggestions?
- [FAQ] D Series piston project update!
- Ported and polished SOHC VTEC
- nitrous? newp.. i use compressed air....
- Any one know where to get this
- ls/vtec using ctr intake cam....
- damn i hate crashing my car......
- check outw exhaust......
- mouse in my distributor...squeaky noise from my jdm b16
- fuel pump
- Central Ohio people want to meet up on Sat night?
- What Motor?
- 88 CRX HF to SI tranny swap questions!
- Help me settle and arument
- fuel cut off on b16
- Help Tach Problem
- wheel bearings
- What is a cheap nice sounding turbo style muffler??
- I Need a cat back for 88-91 CRX si
- motor choices
- WTB 88-91 Si wire harness
- JDM corners for a CRX
- interior opinions??
- are all swap moutns for all b series engine???
- 86 integra ls, swapping
- My CRX and it's new heart.....
- Ok new exhaust... What size piping...??
- Is this possible?
- need diagnosis opinions, please?
- battery light on all of a sudden
- People with a 90-91 CRX helms manual?
- nice clean kit for 91 crx
- 89 CRX DX Timing Belt?
- Lets make fun of the idiot who tried to change his fuel filter...me (Help)
- 90 CRX Si, what are my options for brake upgrades?
- Sohc ZC to Vtec?
- Ls Questions (post swap)
- 88 hf : mpfi or dpfi
- What are some good coilovers to go with koni adjustables or tokico illumanas? post your fav.
- what distributor can i use in place of JDM b16a1?
- gears in 89 civic
- New to rice. Help-info-suggestions wanted.
- finally got my hood ... YIPPE
- b20-vtec
- do i have to take this out???
- sir
- Search or Post??
- JDM B16A in a CRX
- Some Before and AFter's! Pic extensive!!! 56k beware
- ignited push button starter
- My roomate threw down some cash today...
- A steep (and expensive) learning curve ...
- Got C-REX.................my pic
- 92-95 D16z6 or Ex head
- jdm b16 the 2 o2 sensor....need help
- Louisville EF meet
- injector question
- can these civics hold H22, B18-R, B16-R
- which motor to go with.
- parts for B16 swap
- crx si stock ECU to p28 ECU???
- Id measurements on a thermal 3inch exhaust?
- D16a1 and ZC.....
- Need Help on B16
- DIY CAI: aka Slatertake... website please
- can i use a 90 teg harness?
- Does anyone have resister pack off of your CRX? Pics please
- What wheels weigh under 12lbs?
- integra seat??
- 88 CRX Hf with H22a
- ::Vibration::After Engine Swap '?'
- After 5 weeks at paint shop my car is done!, but...
- SoCal beach meet May 4th
- how many liters??
- Pics of my hatchback with the Honda OEM CRX front lip
- What size?
- WTB. 90-91 CRX Climate control
- Any alternative ways for wiring a sec. 02 on a non obd ecu?
- ATTENTION: Those with canister-style exhausts...
- Oxygen Sensor
- Shocks, what should I get?
- how to check if a motor is stolen
- suspension
- I think my friend is getting the shaft on his new B!6!
- LET'S DRAG ORLANDO
- b16a swap ?
- car won't move, but engine still is revving?
- anyone have pics of a 92-93 gsr dash in a crx?
- will never mess with b16 on free-way again...
- $4100 for ImportBuilders b16a
- 1st gen Engine possibilities...
- what is "I" "S" on back of gauges?
- ZC Hood
- Q- will CRX SI seats w/rails bolt right up to a 90-91 hatch?
- It's Alive!!!!!!!
- Could someone please identify this K&N filter?
- Can i weld b16 mounts into CRX Si stock mounts?
- Racing CRX
- Civic SI w/ Turbo in Newark, DE
- Any other options besides Hasport??
- Pics of the front lip I got ahold of
- b16,b18,b20,b22,LS,CRVTEC?????/
- does anyone know were to get a replacment distributor for b16a
- stupid quick question...
- all red tail lights
- ZC tranny
- parting out 90 teg
- Drag Strip Preperation
- which one do i use?
- my check engine light comes on and when i feed gas its as if its on a delay?? what is this??
- scca racing/crx regulations?
- Timing on an engine....
- VTEC controler....
- Will my car beat this?
- Exhaust and Racing Seat Question...
- time for crx
- Fuel sender probably broken - plz read/respond
- blown shocks?
- AIR/FUEL question
- WHAT ENGINE SWAP WOULD YOU DO FOR 2 GRAND????????
- anyone tried the progress rear 22m sway bar?
- s2000 seats in crx
- New CRX...
- LS tb on a d16z6
- ZC bearings
- What's next???
- installing ECU ? 90crxsi?
- 2001 GSR seats into CRX
- motor for my 89 si?
- wtb: 2 or 3 pillar guage pod
- I need a pwo settings for hondata with 440 injectors
- Boosting d16 w/ 155,000
- itr shocks/ springs.....fit 88 crx dx?
- CRX Rollbar/cage
- first pic i have of my b17 swap
- 91crx-si to b18c5 (shopping list)
- 91 si motor & tranny
- EF to EG ECU
- Cant figure this out....
- IS a CRX SiR w/ mugen body kit, JDM b16, cams, I/H/E, Chip, worth 10,000cdn?
- E S motor mount inserts
- SiR color codes
- Will running a pr4 and open header kill low end??
- Considering Purchasing a 1991 CRX as a Project Car
- Will someone post up some pics of their Rex lowered
- Will 17" Rims hit my Fenders?
- greddy mx
- Code 12 ??
- ******** HELP!!!! Trouble with my B16 CRX ***********
- skunk2
- newbie CRX Questions - long
- EF rear lower control arms
- 90-91 Si seats in 89 DX
- Final Drive swap...Possible? and How Hard?
- i was thinking about----
- ZC ---- > EF DX ... NEED HELP FAST!! axles??..hood??
- fs: 90 crx midwest, few mods, take a look
- Pro's opinion on this and a few more questions....
- Valve Adjusting
