View Full Version : Honda CRX / EF Civic (1988 - 1991)
- how much does the crx si weigh and how much does the hf weigh?
- Fresh Rebuild on 90 CRX Si, couple questions
- best ecu for a Zc??
- civic wagon?
- Clutch problem...? Need some help.
- 89 Civic DPFI Throttle Help
- Need Help identifying Gauge cluster harness plugs. PICs
- Resonator question to the exuast mind?
- tranny question
- 91 hatch doors on a 89 crx???
- HOW-TO: simple fuel pump kill switch for CRX/EF security - no soldering!
- B16CRX DX Tach messed up? HELP
- Any Idea???
- How do I remove the trim on the hatch window (CRX)
- eagle rods...srp pistons
- ek side skirts on an ef... how do you do it?
- oil in coolent
- crx b series axel problem.
- what happened to my turbo hatch??
- Ground control coilovers for crx
- omni power coilover kit
- red/black sick ass SI seats
- whats wrong with my ignition?
- Auto tranny, what is this?
- DOHC ZC leaking Radiator Fluid
- B16 Swap No Start..Need Help
- MAJOR probllem/ HELP!
- codes after OBD1 swap. 20, 9 [searched]
- best ignition timing for sohc zc?recommendations please
- which timing belt to use when putting a y8 head on a sohc zc?
- has anyone used a sohc zc block with a y8 head? any power gains?
- Help bolt pattern!
- price on resistor box??
- ls swap
- H22 into a 89 crx si?
- timing belt
- b20b wiring
- Where to get a clutch bracket? and where does the bracket rest on?
- Are these axles ok...seems stiff
- can any one run a vin check/car fax report? on my car for me please?
- Before and after picturs of frame pull on my crx (56k BEWARE!)
- ex knuckles
- Those with a LS/VTEC motor in a EF hatch
- Question about D15B camshaft timing/TDC
- Here's what I think of the CRX
- Me and My buddies coupe...
- HIT & RUN *714* OC I NEED YOUR HELP.
- Rear Crossmember for P/S
- where is my water pump
- tuning is boggling my mind..someone help
- 92' axelback on a 90' hatch
- JDM CR-X Style SII
- Sohc ZC Header?
- WILL 95GSR Front Brake Conversion FIT 89 CRX?????
- can a cf hood fit inside a hatchback?
- Apexi turbo timer, is this right?
- Shifter and shift linkage feel trough!
- si injectors
- tranny leak half shaft
- Weird leak
- My CRX is as HOT as Jessica Simpson in her Daisy Dukes...
- Look at my broke Rex HF pedal assembly!!!!!!! anyone ever broke dis????????
- JDM right side drive
- CRX Bushings
- tps question
- Adj Cam Gear recomendation
- is the wiring harness from a 88/89 the same as a 90/91??
- clutch ? D16z6 D16a6
- spark plug wires into dizzy b18a
- WTF???? EVER HEARD OF THIS????
- 88 crx si rear disk break conversion question(already searched)
- where to buy internals
- check engine light after 60mph
- sunroof wont close
- 95 Coupe suspension into a 89 Hatchback
- Tranny Question
- CRX D16Z6 swap i gots ?'s
- HELP!!! car idle
- b20 knuckles
- Tie Rod Removal
- LCA bolts and Tow hook bolts
- clutch question
- check engine light on 91 civic si
- oil in cylinder help!!!!!!!!!
- rear sway bar?
- which rims on my 91' crx.....list inside
- B16 pr3 obd0 code 8 and 9
- easy clutch question
- timming promblem on vtec engine.
- engine swap in 91 crx si
- 91 CIVIC W/ 1.8 LS ---- WHAT HEADER TO ORDER?????
- my car prob of the week, thanks honda-tech. search engine...it's strong!
- oem rear lip
- rusty fenders- who makes fender lip trim?
- b16 into a 91 hatch axle question
- throwing code 13
- how do i know if my ecu is faulty
- i need your help guys
- My new project!
- 88-91 to obd-1 conversion
- crx tailights....hmm...
- You guys are babies/This site sucks!
- Weird idle?
- y8 head on a sohc zc
- anyone have pics of a stock CRX shiftknob
- d16a6 VTEC question
- so i bought a gsr swap for my 91' crx....
- Over heating in cold MINNESOTA????
- User opinions
- in need of obd0 distributor
- ppl with a sohc vtec/d15b, question on clutch cable
- EF siR cluster No Wiring Included. HOW DO I INSTALL????
- I came up on some stuff.
- Installing 89 si cluster in a dx hatch
- Code 20
- which block?
- wires
- LOOK mid motor rex
- Ecu Problems??
- Si Tranny
- The CRX's reconstruction
- 5 lug into CRX
- recommendation for ignition timing on a sohc zc?
- 93 integra axles in dx crx
- swapping rear disk off 90-91 prelude on to 88 crx si
- Is it possible???
- My first Honda!!
- I got it!
- Intake Manifold
- swaping gears for ls to a b16 tranny
- Help me Buy my springs by Tonite!!
- exhaust for daily drive
- DOHC ZC HELP
- how can i tell if my s1 is an ls or b16?
- climate control faceplate
- oil in plug cylinders
- Gauge Clusters
- 1989 Si/DOHC ZC/Neuspeed
- i think i have wirng problom can any help?
- Distributor Wiring
- New member, need a lil help.
- Lowering Spring Fitment
- need help with suspension
- Boggles!?
- does anyone have a Ef with a Eg front end conversion pics?
- car wont idle feels like it runs on 3 cylinders?
- 91 civic distributor and spark plug layout
- Nice, fairly stock early (1st Gen) CRX/Civic Si needed in Mid-West.
- Master CYlinder PROBLEM!!!
- LX in a 91 CRX HF
- Anyone have a gearing calculator website?
- Found a rex for sale
- Quick Question
- h22 crx???
- should i get an si/ex fuel pressure regulator for crx manifold or aem adjustable one
- 5 lug conversion on my 90
- can rsx brakes and spindles fit on a crx?
- best SOHC motor?
- d16 to d16 swap q:
- *Question regarding positioning of clutch cable*
- 1991 SI CRX for sale with ZC DOHC swap
- Koni/GC combo - Spring rates?
- HELP!! just got done doing headgasket.
- Where can i buy parts for my car in miami? Traveling from Sweden!
- transmission trouble?
- curious about the apexi safc
- Whats the best harness to use in a 1gen crx carb for b16a?
- Happy ending to a stolen CRX story (kinda long)
- need some advice
- UsuaL or UnusuaL?
- how much should I advance the timing on my b18a
- ls/vtec swap.help!
- JDM 90 EF Civic - Something is very wrong..
- what does it take to run 12's in a ef?
- Clutch or Tranny???Need Help...
- will 88 crx parts fit on an 89 si
- fuel pressure check
- Zc Injectors???,
- Transmission fluid
- is my tranny bad or is it my linkage?
- Dead car, checking for spark?
- HELP Identifying Brake Problem>?
- front tire set to close to the fender
- car weights
- reccomendations on timing on a sohc zc? im looking for mid to top end power
- where is my ECU
- my ignition timing on my sohc zx is retarded all the way towards the radiator is this good timing?
- JDM B16 s1/jdm xsi B16 s1... differences?
- charge piping on a crx?
- 87 CRX computer Question
- si head into dx?
- Axle question on 88 CRX with B16A
- car won't start sometimes (not turning over) yet drove it home. searched
- BEST OCTANE FOR A 1990 CRX DX STOCK???? HELP $$$ AT STAKE!
- just seeing if this way works
- Wheel Weight Help Please!
- distributor question
- how hard is to replace the gears in my b16 tranny in my 88 crx si
- Stock Integra Exhaust
- Tranny Woes
- ZC CAM GEARS NEED HELP FINDING THEM ?????????
- Anybody have this muffler on their EF8 or EF9?????
- Civics Idles REALLY High! Any ideas?
- wiring question
- MPFI question
- how many PSI do you run?
- B16A w/ B16 trans...Your RPMs at shift?
- B-16 acceleration problems. Please HELP!
- zc trans question
- igniters keep going bad
- Honda OEm door piece...frustrated
- 91 crx dx b16 swap done, wont start. no fuel no spark*searched already*
- mud flaps
- SiR front bumper, what else to change?
- Ecu's on ebay???????
- just a question of value...
- broken bolt! this is important too! HELP! PIC!
- Front disc brake dust shields, are they necessary?
- question about CRX Quarter Mile Time?????
- rim/tire width question
- Injector help please!
- fiberglass dash?
- right hand drive dash board
- clear something up for me quickly plz?
- Cat Question
- b16 O2 sensor
- Nurburgring Meet - Repost
- JDMDOHCPOWER seen the banner is this guy good?
- please help
- sohc zc cam in d15b1 head
- springs upside down?
- problem with Ignition coil
- wont start please help
- New steering rack on the way - cant wait!
- Alignment data for my 4G4D: Please help to read #'s.
- xtd flywheels
- I did a search but nothing 4 pages for ticking alright i got a problem
- B18 hatch which h/e fit?
- Battery problems with '89 Civic DX
- show pics of 3 inch exhaust on ef hatch or crx
- Ignition problem w/ 1995 VTEC into 90 DX hatch
- Noobie help requested, changing motor mounts on a 91 Civic Si
- boost questions
- 89' CRX Automatic want to Trade for Manual.
- Difference between '91 Dx and Si hatch
- JDM SiR knucles in US EF/CRX
- Why do my brakes suck so incredibly incredibly bad?
- My Project EF
- Crx EE8 B16A OBD0 - VAFC installed - check engine
- b20b swap
